View Full Version : Forced Induction
- good machine shops for helicoiling
- Is there a difference?
- Why do some people lower the compression on a boosted car?
- Golden Eagle Mfg. #2 question
- Compressor surge vs. Blow off : How to tell?
- greddy down pipe on crx?
- BEWARE: Web Cam broke in half in buddies B20 Hatch
- Standalone with upgraded ignition?
- Need some convincing...
- Anyone need an FMU or Inline pump.
- hondata amtel chips.... going bad?
- kkk turbo?
- can someone please help me with my revhard kit problem
- quick question about sx fpr
- Switching from Synthetic to Regular?
- Golden Eagle Mfg.
- AEM EMS question, Is it really that hard to tune yourself
- Max HP on B20b with blockguard?
- WTB: Starion FMIC
- 500hp Civic for sale
- If you have a 100 shot of nitrous or more on a GSR
- Pics from my 1g dsm turbo setup on 89 CRX Si
- how much for a new rotor and dist. cap?
- cam question--learning experience--message to newbies
- Some pics of AR Fabrication's Project (AR Fab)
- any body need a cometic head gasket for LS?
- blockguard w/ boost
- Exhaust opinions...
- synthetic mobil1 bad for turbo cars?
- NSX + Nitrous = POP! (vid)
- Where to buy 3" flange
- Question about Earl's "auto-fit" fittings/BSPT and NPT
- What turbo should I use?
- exaust question.....need opinions guys help me out
- anyone hear the turbo xs RFL BOV??
- Guess what block this is....
- Manual Fan Switch.......Who has one????
- Anyone use the PWR Air-water intercooler?
- any experience with the msd digial sci? or 2 step rev limiters
- How many hp do stock injectors hold?
- PWR Water to Air street kit
- h23 turbo and hondata..what ecu?
- DSM BOV sound clips?
- B16a crower rods is there a difference between generations
- dyno'd my car....tell me what u think
- completely stock b18b turbo setups
- BOV Question.
- Help identify this turbo
- 360cc with smc
- Some pics of my turbo set up
- Best clutch???
- Hondata or AEM Ems?
- Center Diff Spool's
- skipping problems....turbo experts inside.....
- spun 2 main bearings...line bore with boost good idea?
- o2 sensor reading more than 1 volt...
- NX nitrous groupbuy
- Anyone ever used these guys for axles?
- What piston size do I need for B18C1??
- who keeps shelf stock of crower cams?
- what everybodys thought about JGenginedynamics???
- oil feed line for turbo.. what to use??? HELP ASAP!!!!!!
- cheapturbo.com t3 vband adapter pics
- Zex nitrous with turbo???
- 310cc injectors for a 96 GSR- GReddy
- Where to Buy o2 Simulator
- Drag Radials
- Hyper clutch/Action clutch special .!!!
- fuel pressure question for guys with fp gauges
- What is the MAP SENSOR Volt reading for Integras??
- greddy 52mm electronic gauges
- Car is running lean under full throttle boost..
- broken bolts
- SMC and Jackson racing supercharger
- A few items you may want for Christmas
- System requirements
- Super Charge Vx. Turbo Charge whats better for what?
- OT: Recaro trade
- Can anyone please answer this question? Thanks
- Help! 450 DSM injectors not firing?
- How fast in the 1/4?
- severe hesitation at 5-6k rpm
- Colder plugs for a DIS system.. same as a normal ignition??
- BIG Brakes....whos got em...who wants em?
- Clutchmaster Stage 5
- Good downpipe size for t3/t04e turbo?
- Any one with tips on how to install a msd btm on a honda civic?
- Will it help me to increase the size of my downpipe? Greddy Kit at 8-12 psi
- my battery drains need help please
- Which BOV is louder????
- Filter (?) on T3/T4 60-1 w/Inline-Pro manifold?
- wiring "blue box" for greddy sohc
- what is a good setting on the pressure regulator???
- want to turbo by spring?
- holley throttle bodies
- overboost
- what would you do?!
- greddy type 31 intercooler question
- Anyone going to PRI Show in Indianapolis?
- What does your boost guage read at idle?
- Need advice going to dyno
- .63 a/r or .82a/r...
- FMU help
- best slicks setup 89 CRX
- *PICS* DIY: OEM DSM side mount intercooler *PICS*
- what should my fuel pressure be at idle?
- Removed a turbo kit: what to do with oil feed source?
- cleaning up cast iron manifold?
- Tapping the exhaust manifold.
- Turbo installation
- Homemade/Junkyard turbo in the making to share. . .
- Finally some setup and room pics from me...
- Dowel Pins...
- n2o soft lines?
- afc hack
- new vids up
- ever crack a plug?
- 3 bar map and pigtail
- slow car + F-MAX + NX = ME
- Is there any reason why you can't run a .45 bar wg spring with high boost?
- Yay! I likey Hastings now....
- which turbo?
- White smoke!! help diagnose
- What makes a 60-1 a 60-1?
- Wich turbo to buy? Please help.
- installed the turbo and tons of smoke when i boost, help please
- My dyno experience this weekend, do these numbers seem right?
- B18C1 Turbo of choice: POLL
- couple questions after installing my walbro fuel pump (viren)
- Broke my starter housing...How the hell did this happen!?
- Eagle Rod Pricing
- Anyone blown a motor with 8 psi?
- Understanding Compressor Flow Maps
- need civic
- Uh-oh
- ran my d15b7 on 10psi ... still running fine
- Ideal o2 volt?
- building a bottom end
- B18A and B18B questions.
- does anyone currently make honda cylinder heads?
- Turbo Calculators
- Junkyard Turbo...how to check for condition
- need help difference between b18a and b18b
- Not auto related. Well kind of...How to pay for turbo parts.
- Look at this Civic...BS!
- Coolant leak since boosting??
- where can i get my sleeves put in another block?
- standalone owners beware
- best turbo for LS
- should I do a clutch install at the same time I do my turbo install?
- RSX-S turbo = wtf?
- Turbo Type-R
- CRV Turbo
- What Size Injectors
- FS: Apexi AVC-R, box and intrsution manual included
- Exhaust manifold and wastegate flange location.
- How bad is it that I run my daily driver without a Filter on the turbo?
- Help with Boost problems
- PICS OF MY MY TURBO is up.......
- wiring turbo timer
- let me here some auto ls turbo times thanks
- tranny swap or Forced induction?
- FS: Brand New Fully Built H22A1 Block and AEM EMS Computer
- Garrett GT series
- Question for those using Greddy Gauges with Autometer 2 1/16 dual Pillar Mount?
- ATTENTION all engine builders..welders..do it yourselfers....I NEED HELP ASAP
- why does HKS, Blitz, Greddy gauges cost so much compare to autometer
- techedge and ems?
- I almost killed myself tonight!!!!!!!!!!!!!
- Phantom Grip LSD questions...
- FFGeoff's turbo kit spotted at Palmdale
- Venom Intake manfold... how the F do you make the IACV work with it?
- FPR question...
- Radiator Fan Relocation (pics)
- GSR vs LS Crank
- Forced Induction -- Bringing back the dead
- Pics of my new downpipe
- FS: Brand new: Garret t3/t4 and Tial HP 35mm wastegate
- noticeable diff with vtec on turbo d16z6?
- Back from the Dyno. Results inside
- piston sizing?
- Turbonetics 60-series turbos
- iat grommet
- Group buy needed on pistons for F22
- will this be good for my turbo R
- what kinda clutch will i need to for a turbo R
- ? for nitrous guru's
- Tial wastegate question?
- Where to get RC 440 injectors and clips?
- Please help, what could be wrong with my profec b?
- purdy tial hybrid wastegate
- Torque Specs?
- POLL: For those who have spent over $15k or have over 300hp!
- Need help with fuel pump
- Pic request: t3/60-1 Vs. t3/t04e
- How do you aviod boost spikes?
- tapp auto manifold?
- Lemme see your Turbo R's !
- oil send line for my turbo
- Help me design a air/liquid intercooler set-up for my car.
- oil pan issues
- fmic dimensions on a 5th egn accord
- drag kit fitment questions
- where can i get a 3 inch test pipe for my 2000 si so i can run the thermal 3 inch??? help me out her
- rolling chassis and all the parts you need for a 500 whp turbo motor
- Pictures of GM 3 Bar Map Senor Installed...???
- Im getting ready to go turbo
- avc-r.......help
- Dart blocks
- anyone try any turbo spec CRANE CAMS...
- finally tuned :^)
- ... engine builders... look inside...
- tranny? for gsr turbo?
- Im sooo close I can taste it. and it tastes like chicken! yummm
- VIDEO - Prelude Turbo vs. Civic Si Turbo
- So who's using motor mount inserts?
- BCPR7ES11 gap?
- How should I run my VAC lines?
- True or False....
- So it starts... The quest to boost...
- DSM Eclipse GSX Injector Size?
- SMC and JRSC with Map controller
- Integra 1.8L
- oh my god, check this out...*vid*
- anybody interested in trading me my turbo setup for a JRSC?
- FS: Probe ultralite rods and Wiseco Endyn pistons(84.5mm) for B20
- oil leaking from turbo
- Modifying Intercooler Intake.. feasible?
- Turbo the B18C1, do it do it!
- idle problem
- Importparts.com Year End DRAG Special!!!
- Intercooler by this month!! + and few other things.
- how much hp could this handle?
- Greddy Blue Box - White Wire Connection???
- Greddy downpipe, cat solution
- hondata question
- help! car wont start!
- FS: NuFormz block guard, airtex fuel pump
- which piston to get?
- Give opinions on potential set-up?
- Audi 87's intercooler-->Frount mount??
- b-series oil squirters- good or bad?
- Dyno sheet, kind of disapointed.....
- What CEL codes put the ECU in limp mode?
- replace my 15g greddy?
- Check Engine light just went on... Just installed A/F from Apexi TT
- home made engine hoist
- Blown ring? ARGH!
- T28 02 housing/DP options?
- Kaboom! There goes a sleeve..
