- Are you sure fuel cut off is bad for FI?
- whats the best turbo?
- How do you get the o2 sensor off the cat?
- eClutchmaster Clutch. Are they good?
- j&s safeguard keeps on reading knock
- The liquid intercooler from JR for their supercharger. Does it work? Is it worth it??
- ANyone see new AEM ecu? Does anyone have any inside info?
- Anyone need?
- Block Sleeving?
- Big Problem!
- Hondata 4b for sale
- Double Reinforced Silicon Coupler
- Oil cooler?
- NEW Greddy Full 3" exhaust!!!!
- Engine Block # ?
- Difference between Turbonetics 60-1 HiFi and 60-1 Regular?
- Do Octane boosters in those bottles at kragen work?
- What will I need to repair my oil return line?
- BOOSTING!!!
- VTEC problems... please help...
- Jackson Supercharger or Turbo kit for my b18c1 92 hatchback...
- Installing Greddy turbo kit on 88crx si?
- do I need a aftermarket fuel pump for this setup?
- I BOOSTED!.....for a second anyhow
- can you name these parts?
- where can i order a FMU recalibration kit??
- does anyone know the oficial DRAG site
- anyone ever heard of running toluene in your tank of gas? octane rating of 114??
- JRSC Times
- Is Import Parts Ben still alive?
- largest turbo to bolt to DRAG manifold
- HONDATA USERS
- Greddy I/C pic's
- What flywheel with ClutchNet?
- CM 7.5lbs Flywheel.
- Clutch chatter???
- How to adjust HKS Super Sequential blow off?
- Dustin !
- Thank god it's not....
- boost guage hookup
- Tubular Manifold
- attn: ArTurbo
- o2 sensor question
- What is a good price for RX-7 Twin Turbo set-up
- Good to use Lightened Flywheel with Nitrous?
- how to read compressor maps?
- Greddy FCU
- What Spark plugs should I use?
- motor mounts?!
- Thinkin or running JRSC & Nitrous instead of Turbo??
- problems problems
- Cheap and safe way to make the Tial wastegate quieter?
- exhaust gas blowby through wastegate...?
- Just put in turbo....Greddy gauge not reading boost.
- Turbo install starts in 9 hrs...see ya there Art.
- New Turbo manifold....
- Stupid questions!!
- For everyone trying to IM me....
- Blow Off valve used to control boost
- help me code 13
- New boosted gsr...some questions.
- Building bottom end. Is this really needed?
- Is the drag kit supposed to come w/ a flange to weld onto the dp to the cat?
- Compressor fitting!?
- zdyne ecu controls
- what kind of boost can i run with my set up???
- Boost Creep
- drag 3 is installed!!!!
- help me get rid of this...
- is this a good pice on a turbo?
- water pumps...
- Where can I find a C clip for the HKS BOV?
- What crank work?
- Aftermarket Honda blocks finally!!!!
- What happens when turbo "kicks in"?
- what is a hondata?
- Downpipe.. How hot?
- Sleeve pinning...
- problems problems problems....
- where can I find the actual gear ratios for honda trannies?
- OT: Canada's first 9 second racer
- nitrous oxyde = laughing gas?
- any charged ITR with Haltech here?
- rev hard manifold
- need instructions for installing a basic turbo kit
- Help me with my Hybrid!
- FS: TURBO LS/VTEC MOTOR
- All i want to do is run 10psi daily on my 94 accord. is this list of upgrades good?
- JE Pistons...
- Intercooler piping prices.....
- PCV and Valve cover - can they be connected together to catch can?
- Compression VS. Boost
- anyone have the nira results for today
- Connecting rods...crower or Endyn Eagle Rods?
- Question about vacuum lines for BOV and turbo
- Friggin' A...compression test done.. bad news :(
- Some More Fmax Pics
- eighth mile time saturday
- Fmax - BOV won't clear the hood
- To oversize bore or not?
- Oil return line kit
- NEED BOV HELP!
- anybody want some 720 cc injectors ?
- Whats a good heat shield for the oil return line?
- I promise I really did do a SEARCH!
- How much boost is safe on a stock JDM b16a?
- I need a good downpipe...
- having trouble visualizing............(DRAG owners)
- well, motor finally gave out....
- boost controller? manual
- why does my turbo only boost at 6 psi in 3rd and 4th but 8 in first and second, with manual boost co
- Speedpro
- MFU or MF2 which one
- JE B16 pistons?
- toda cams on turbo cra?!?
- helphelp code 17??
- What should my car do in the 1/4 as of now ?
- final checklist for the Drag install.....tia for helping..
- Dyno of my car, very dissapointing :(
- would i lose hp if i got a 2 1/2 " piping for my civic ex coupe......no turbo, stock otherwise
- Map sensor
- Shogun Power tuner?
- Fmax--Need to cut the radiator fan shroud
- Just got a Profec B for about $225 brand new in box!...good deal??
- Question about homebrewed turbo
- WhooHoo!! Turbo came in! Compression test is done!!
- The Energy Suspension motor mount-Zip Tie conversation.. Well mine weren't and they broke. Now what?
- HELP! turbo timer & boost controller instruction manuals in Japanese - but I'm a white boy!
- 2.5'' to 3'' downpipe gains?
- Dyno chart of my stock ls with boooost
- Question for cars with ZEX N2O kits???
- tubo ls auto
- KHS TURBO TIMER INSTALL HELP?!
- hondata?
- Finally....
- inline pump install on 2000+ teg
- turbo guys..help!!!
- Downpipe Questions AND custom setup review
- hondata owners, what all comes in the box?
- Equal length manifold?
- Where can I get a thicker headgasket?
- Endyn haters don't look... nice price on breather/separator kit...
- Another essential tool for Fmax turbo install
- Drag 3 install help
- Down Pipe Question
- Thermal Exhaust Question
- Missing Link Question
- Drag Combo Result.
- Losing Boost...GReddy ProfecB Boost Controller or BOV or ??????
- what needs to be changed if i want a 92-95 civic greddy turbo kit for a 98 civic copue ex?
- Kumho Tires/ Nitto/ Any suggestions?
- wtf?(coolant over flowing)
- 3inch or 2.5 inch
- INSTALLATION of my GREDDY FMU!?!?!?!?
- Ok to install turbo w/o fuel pressure regulator?
- Analyze my track time please
- check engine light problems...boost related?
- What tranny do I use with....
- good or bad to switch from b16 in a hatch to turboed sohc vtec?
- Turbo trim help
- ? about greddy gsr kit
- Greddy D series Kit in a '99-00 Si?
- rod bolts
- ? What ýs resleeving?
- Recommended turbo upgrade...?
- anyone here get a Turbonetics BB turbo rebuilt?
- Quick question on tial WG...
- Adjusting the HKS SS BOV
- Upping boost
- Were to get garret t3/t04e turbo fo cheap?
- Need Help with adjusting GReddy Type S BOV Soft? Hard?
- i need help on buying a turbo kit...
- Anyone have pics of the oil pressure sending unit connected to the oil feed?
- Backplate questions???
- Woohoo!...block's back.
- why is my car running so LEAN!?!?
- what wires do you hook the resistor box up to for low impedence inj?
- You think you're fast? Check this out
- Help with creating my own oil inlet line
- Where do you get your plugs?
- OT: New Dyno in NoVA!
- Hissing noise, can anybody PLEASE help?
- Revhard FMIC.. this thing is HUGE!
- this is bad ass product to use on front mounts
- hondata tuner in OH????????
- Turbo gurus...need advice on a foundation to boost.
- Max boost on non-sleeved block?
- Exhaust Resonators
- custom turbo kit w/ hondata
- intercoolers-prices?
- hondata question: does it replace the factory ecu?
- what to do with the second 02 sener (OBD2) in a custom exhaust setup?
- how do you plug up oil return line to oilpan?
- Head work - do I need it?
- Completely OT: I am sooooo happy.............
- Turbo horses???
- 440s or 370s
- fmax or drag 3 for ITR??
- where to get a scattercheild
- homade boost controller 10psi?
- Turbo sizing . . . Greddy vs. Garrett
- testpipe=more boost
- ? about greddy intercooler
- turbo bolts always loose..?
- BOV question: Easy
- hey is that group buy still going on from importparts.com???
- Aerochargers?
- Got my turbo done today...But somethin is slowing it down, i think it is my crower cams??
- HONDATA???
- Ben from import parts...
- 255 intank or the inline that..
- Englishtown 10/17
- How to tel cranks part?
- Recap of some 11's sec honda's today at e-town.....
- Time slip with Greddy Kit in my GSR
- 3" intercooler outlet vs 2.5"?
- ARP bolts?
- turbo prelude motor in an integ
- Any techs in San Diego wanna help me out?
- Lightened stock flywheel on turbo
- whp for drag kit
- 150 to the wheels
- garret t-03 turbo
- fmu 10:1 with stock injectors
- drag 3 kit for type r??
- DRAG 3 turbo upgrades?
- intake air bypass valve
- How much boost can stock B17 parts handle?
- Civic+B16A+Turbo=?(1/4 times)
- ball bearing turbo info?????
- Flange for HKS SSQ BOV?
- RC 720cc Injector Group Buy!!!
- Just Curious...
- anyone using prothane engine mount inserts?
- NEW TURBO
- Is anyone using the hp racing manifold.
- Is "break-in" just for street motors?
- Using Prelude Injectors
- FMIC in CRX...
- Do you have to drill to install drag's intercooler?
- RC 550 injectors and stock fuel pump?
- anybody have the phone for HONDATA ?
- Motor questions.
- Just installed Drag kit....
- Cars beating bikes??
- greddy gsr turbo installation instructions online?
- 150 hp to the wheels
- head work on a turbo RS, what can I expect?
- Nos 55-75 Shot - For my Civic
- Ok, finished turbo install.. Spark Plugs?
