wont idle in closed loop
Old Sep 28, 2015 | 02:33 PM
E-mac's Avatar
Default wont idle in closed loop
Ive got a 2000 civic si that Ive installed a turbo on runing 8psi, after I rebuilt the engine and reinstalled into the car Ive been having an idle problem. my car will start up and run and rev just fine in an open loop setting. But after the engine gets to operating temp ill rev it up, let of the throttle and itll die out. If i ease off the throttle itll catch itself before it dies. Ive replace the iac valve, the map checked out fine, redid my grounds and swapped out ecm for my standalone. Im at a loss with it now, can anyone get me a push in the right direction thanks its much appreciated!
Old Sep 28, 2015 | 02:38 PM
turbohatch96y7's Avatar
What are the afr ratio
Do a datalog at idle and post it
Old Sep 28, 2015 | 02:40 PM
What ems?
How much vac is it pulling?
Did u compression teat yet?
Old Sep 28, 2015 | 06:57 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: wont idle in closed loop
Did you properly set base idle after the rebuild?
Old Sep 28, 2015 | 10:23 PM
wantboost's Avatar
Who is Mr Robot?
Did you use all new gaskets for the intake manifold, throttle body, etc?
Old Oct 5, 2015 | 05:17 PM
E-mac's Avatar
Here's the link to the datalog. Couldn't upload it on here so it's on media fire.
https://www.mediafire.com/?e0a9jmv64a74467
I used S300 to record this. Pretty sure I covered all the basics when I built it so it should be solid. It was idling correctly before the bearings in my turbo initially went out. Had it rebuilt by Precision Turbo (pretty close to where I live) and here we are.
Old Oct 11, 2015 | 10:00 AM
E-mac's Avatar
bump
Old Oct 12, 2015 | 04:32 PM
wantboost's Avatar
Who is Mr Robot?
Any sort of tuning done or this on a basemap?
Old Oct 19, 2015 | 05:25 PM
E-mac's Avatar
Its just a basemap that I uploaded to see if i had a bad stock ecm or not, which the car acts the same on both ecms. the car was running fine then the turbo bearings went out and threw oil though out my intake system and it started acting up after that. Also Im still pretty new to boosting and tuneable ecms, so Im not sure if Ill be able to pass emissions using the s300 ecm.
Old Oct 20, 2015 | 04:39 AM
wantboost's Avatar
Who is Mr Robot?
You can't pass OBD2 with it. If it's OBD1 then as long as you have a good cat an a tune that isn't **** you'll be fine.
Old Oct 20, 2015 | 06:58 PM
E-mac's Avatar
thats what i thought, but i still dont understand why it wont idle after the engine warms up
Old Oct 20, 2015 | 07:49 PM
wantboost's Avatar
Who is Mr Robot?
Do you have a wideband that is sending feedback to the ecu? The S300 definitely can't do proper closed loop with a narrowband sensor.
Old Oct 22, 2015 | 12:43 PM
E-mac's Avatar
i dont have the wide band hooked up yet, but why is it acting the same way on the stock ecm?
Old Oct 22, 2015 | 10:44 PM
wunfstgsr's Avatar
Loved
Community Favorite
Sounds like either the ECT sensor got unpluged, (its the small sensor under the distributor with a single wire plug to it) OR its not working anymore.
Also its possible the oil that got sucked in fouled one of your sensors like the IAT sensor or MAP.
got_no_sol
Oct 2, 2016 10:19 AM
Iloveyourhonda92
Apr 11, 2015 07:46 PM
erichackett
10
Jul 27, 2010 06:43 PM
crxfreak1117
10
Oct 29, 2007 07:35 PM
vtec94civic
Aug 9, 2005 03:35 PM
