View Full Version : Forced Induction
- help with BOV on d17a2 turbod civic
- Diff between b16 and type r tranny???
- Honestly - What turbo? Vitara build
- Any one ever turbocharge a 99 accord F23 with crome?
- map sensor for 0.7 bar spring?
- Anyone willing to let me "borrow" a manifold for mockup?
- Help Id'ing my turbo? Pics inside!
- what to do next?
- powdercoat ok on compressor cover?
- New Competition Clutch Stage 5
- civic turbo spec and oil line question
- firewall mounting an oil pressure guage
- BDL "K series" TB not fit K24???
- Help on oil restrictor
- H22 motor, considering a FI build...
- gsr head - ls b18b1 bottomend on boost ! ???
- High Vacuum on Decel
- Aeromotive FPR - Victor X manifold - vacuum line
- Built z6 + Low compression > safe to run N/A?
- pro1 or m22x cams for FI
- autometer egt sensor\bung question,
- Opinions please JE or Mahle?
- Supercharge High mileage EP3?
- odyssey batteries
- 6 years of POWER from PeakBoost!
- ? about gearing & turbo set ups for B series.
- dropped my block off for machining ?????????? H22A1 w/ Mahle pistons
- Dart Block Questions.... searched
- Fuel pump problem
- How do some turbo cars blow off with no load ??!! LOL.
- fuel pump question
- help, tryn to find out size of a turbonetics wastegate
- 400whp turbo
- meutek b18 cast manifold. ?????
- strange problem with Greddy boost gauge, needle stuck on high side
- sleeve chiped h22 please help
- gt2871R good for gsr?
- What plug gap has worked well?
- No BOV sound under no load and revving up to 6k ?
- b20 turbo how many psi?
- greddy type s bov install
- PRECISION Intercooler owners please chime in asap!!!
- SOHC Performer x Intake manifold
- The new EM1 build - TONS of pics!
- New T67/T4 setup... Time to join the rest of the crowd
- Boosted B16 - Smoking Issues
- Loud sound at high RPM's under boost. Searched.
- 92 Civic fuel guage ohm rating needed for fuel cell sender
- Turbo s2k overheating problem
- Do I need to upgrade my valvetrain...?
- HMT setup, but no boost pressure? vaccum problem? WG?
- home made ebay turbo kit ?'s
- Rings and bearings
- What's the difference between T3/t67 vs T04R
- Sohc Turbo
- lifted head
- lindsey racing intercooler pipes any1 tries them?
- no boost ?
- S372r/Full-Race/EK
- please help take a look
- Fairly new to turbochargers...
- JDM D15B obd2 w/ vitaras -- rods/headgasket/head studs
- head oiling issue?!
- Is this a real garrett?
- wideband O2 + autometer air fuel gauge =?
- spec stage 5 clutch
- HELP... How do I Remove DSM resistor box.
- running rich on only one plug??
- what turbo for sohc build?
- no oil pressure
- low power output on boosted h22?
- 92 gs-r turbo help
- 91 Boosted DA won't rev past 3k
- CopperSeal for turbo flanges?
- B16 Build
- cars bogs
- trying to get started
- Valves or messed up turbo?
- Rod options for LSVtec running boost
- finally done, boosted sol
- Hey whats are some number you guys are outting down with gt35r with piston and rods in a gsr?
- Turbo piping
- Stock Block C16 Tuned S2000
- Rate this turbo oil return. And Turbo setup, oil everywhere.
- need exhaust opinions.
- How much horses or boost can stock pistons handle?
- high compression nitrous wet kit on e85 or race fuel
- were are you guys mounting you oil catch cans
- T25 making funny noise
- boost problems
- weird noise Help (video clip)
- rich or lean?
- FI Please Help ME!!
- what do i need to buy for a stock b18b1 goin on boost !!
- B18C1 Hatch turbo selection
- i have a ls b18b1 is this a gud motor 4 boost
- Motorolla 2.5 bar map any good?
- Stupid JRSC Question..............hondata s100?
- What turbo is this?
- Car smoking!...Bad turbo...or piston rings
- -FINALLY DYNOED! PRETTY HAPPY!-
- Torque late and falls off instantly
- Cast iron manifold questions
- need a tune in dfw?
- My B16 Setup
- injector size on Boosted SOHC (yes i searched)
- Turbo Gurus please read..
- Burning Oil
- what cams make the most power for a sleeved 2.0 with a gt35r
- 84mm b16 turbo motor
- LONGSHOT!. ATP T31 EXHAUST housing Vband??
- turbodano or anyone else in the know on BW
- what clutch disc??
- Idle/Fuel problem on turbo EM1
- jrsc on obd-1 b16
- Having some FR traction bar issues.
- My Catchcan setup - is this ok?
- Turbo Timer help
- What is the largest t2 flanged turbo? (Supra motor)
- Injectors
- I need Turbo Guru Opinions on Built LS/Vtec-T
- Need Help
- [specs needed] vitara 75.50 piston to wall clearance and ring gaps.
- SUPER NOOB QUESTION...H22A
- A couple quick JRSC Questions
- Turbonetics Turbos?
- turbo sohc build.
- New to turbo set up
- Remove internal wastegate?
- Which clutch for street driven 372 tq car??
- H22 upgrade issues with fuel pump, fuel cell and injector driver.
- Some new numbers
- possible wastegate issue
- gt32??? anyone try yet on 1.6-1.8
- I need to get ahold of SuprDave. Left messages, emailed, text him.
- crower cams
- garrett turbo
- SPUN ROD BEARING!!! OIL PSI LIGHT!! HELP!!!
- belt
- boosting the teg
- Burning Seals?
- Question on mounting Drag Radials
- wire up 3.5 bar map or leave stock map
- tial spring?
- H22 Turbo build
- Thermostat - Keeping cool
- Turbo Timer and Car Alarm
- ebay muffler
- where did you guys get your exhaust from?
- Where to get the best deals on pistons and rod combo??
- Blitz dual boost solenoid with S300?
- Hit the Dyno last week.
- Adapter plate help?
- turbo question...
- BoostedB20eh2's 452whp B20vtec Build Dave Blundell Tuned
- White smoke
- turbo question
- Okay turbo guru’s need some insight on this issue I’m having.
- intercooler causing overheating on 97 lude
- turbo honda's and 100 or 200 cell race cats? any experience?
- B18 LS First time boosting - Need Advice!
- MAP Sensor question! Is it possible?!
- What do i need to make this work....
- First time turbocharging, require experienced advice
- Castrol Syntec 5W30 for H22A Turbo - Okay??
- notching girdle/block and clearance
- Problem with RC Injectors!
- gt35r .60 a/r cold side?
- help with my integra
- Anyone use the Clutch Masters Stage 4 or 5 sprung clutch?
- best location to mount boost solenoid
- meutek
- Hondata S100 - S300 or Crome?
- Hondata 4 bar map sensor ?
- Where is uberdata?
- Who owns that 5th gen auto lude that is turbo'd
- Synapse BOV and Boost control
- How do I check for fuel leaks after new injector install WITHOUT having motor running ??
- Need a Neptune tuner in S.D. to tun e ,my FI del sol
- Tuners in Mboro?
- 350 hp goal
- GM 3 bar installation
- Opinions for a clutch on a B16 "cable box"
- Turbo Ls/Vtec Build up
- mac valve with neptune.
- no boost ?
- BOV and boost control
- 400whp clutch???
- Built motor scary sound!
- Post pictures of you bosch 044 in tank fuel pump
- going boost
- Rc 310 injectors.
- Fire Ring
- LS Turbo not making power
- Advise on auto tranny boost build
- QUESTION?? ABOUT D-SERIES AND B-SERIES COMPLETE TURBO KITS!!!!!!!!!!!!
- rebuilding turbo .. which part am I missing ?
- where can i get arp 12 point nuts for headstuds?
- GT3582 options as my first turbo?
- RC 440 injectors
- Hotwire or Karman Mass Air does anyone know how to test for them
- GREDDY E-01, QUESTIONS, info...ect
- Too much?
- DSM injectors
- stock b20z2 block and stock gsr head on boost.
- Can't find what i'm looking for
- gt28rs on a 1.8 dyno
- civic turbo problem please help me
- Vecco 36" intercoolers?
- Turbo install trouble
- Best A/C and P/S compatible Turbo Kits?
- Boosted GSR w/p30 pistons????
- Good setup for boost?
- 94 civic ex greddy turbo kit 5psi do i have to change the injectors???????
- poor mans dual stage boost controller?
- kill thread.....
- can a bad im gasket cause a map sensor code?
- Drag Manifold, EG chassis, Tial 38mm... Hitting hood Anyone use a Turbo Smart Ultragate??
- Engine build input
- Edelbrock
- Integra type R 488,7whp @ 18-19psi
- Pics of the new turbo setup...Holset HE351CW!!!
- I get a quick "pop" backfire when i shift gears sometimes...
- boost leak test question...
- Made my choice on turbo. Finally!!!
- fan fuse keeps blowing
- MAP sensor & injectors errors on a new build
- can someone take a look at my timing maps?
- Help with turbo drain!!! Help Please
- Quick question; when do you get your turbo-back exhaust installed? (tune)
- non vtec P8R head on a built b18a bottom end???????
- Which turbo?
- Anybody with a SOHC street car on an SC61? comments? Suggestions? Flame me?
- obd-0 injectors help
- 85mm or 84mm pistons??? 85mm builds chime in!!!
- o2 disconnected
- Will Fuel Filter Be Enough
- injector and resistor box help
- Boosting SOHC
- Need help on deciding which cam. 400+whp sohc
- PLX wideband incorrect readings
- block guard??
- Fuel Pressure is about 2-10 psi after Boost, After about 1k miles with turbo I think boost killed my
- turbo setup?
- foolish downpipe snag
- Any recs on special head gasket?
- 1991 Daily B16A CRX Turbo Build Help
- b18 LS w/ vtec head build..
- Darton 84mm Sleeves b18c4. Where to buy from??
