View Full Version : Forced Induction
- Recent Turbo Group Buy
- Phasing distributor with speed pro?
- which plugs are you guys using
- OT:forget it guyz..im going n2o
- How much do you pay for dyno time???
- checked my plugs today.....
- As far as axle strength rating is concerned- does a Quaife LSD put twice as much, or half as much st
- Length of oil feed and return lines?
- traction(wheelie)bars. serious drag racers click here
- custom turbo
- 93 turbo talon injectors
- custom turbo questions???????
- Cleaning exhaust for smog...
- VAFC Hack Results/Issues
- Can you have a blown headgasket and perfect compression?
- nitrous problem
- Blitz BOV fluttering ... Why?
- To everyone with boost
- Where exactly should I put the drainback plug on my new oilpan?
- attn: max-rev
- blow off valves
- safe boost level?
- ITR or GSR for turbo?
- attn: Slow_ass_4dr
- NEED HELP (PLEASE) Hondata Heatshield Gasket Instructions <--------
- How much did you guys spend on tunning?
- opinions on road racing size turbo for B18C1
- Anyone know where i can find a compressor map for a TB03?
- what compression ratio to go with?
- How much louder are forged pistons than stock pistons?
- ok i just got a code 9 on my 2000si ???? any ideas please help
- does anybody know what this wastegate is set at?
- Need help with Hondata Please!
- b16a BOOST'ed Hondata rom's.... hehe hand em ova !
- engine build up?
- JG84mm B18C1 35psi?
- HOW FAST?
- Hondata + Wide Band = Big F*ing Grin
- Questions about MSD inline pump
- F-MAX kit...thoughts, pros, cons, ideas?
- secret to put in RC injectors?
- DSM Injectors-Not quite plug and play?
- pictures (large) of jrsc '00 prelude sh IN PIECES
- Redline Engineering announces New Stainless CAST manifolds for H22A and B series
- SOHC vtec running 7-8 psi
- In the bling bling mood......
- where can i find a carbon fiber air damn for the front end.
- who here use the holley tb
- Vaccum/Boost
- Does an inline work exactly like an intank fuel pump?
- Changed oil, filter, and added "small child" filter on the turbo
- can i use a p05 ecu for a hondata setup?
- Intercooler inlets and outlets?
- My car overheated!
- car just died please help!!!!
- SC Belt Replacement
- Manifold Temps?
- Bling bling-----maxrev manny
- O2 simulator ???
- Dyno question
- there is the oil cooler mounted
- Pics of my engine bay!
- got money - filed tax return need fmu missing link bov and ic w/ piping
- Where to get BIG CHEAP injectors that fit hondas?
- Custom turbos-problems?
- $1500. Starting on Turbo?
- selling my stuff for turbo parts
- WTB: Apex N1 Universal Muff for CHEAP!
- PICS OF RELOCATED OIL FILTER.
- Will this intercooler work?
- TO4E 40 Trim Vs. 60 Trim Question
- HKS Blow off/Compressor Surge
- new LS track times! did DIRep go faster? time slip inside :)
- Inline Pro Turbo Manifold GROUPBUY!!
- Supercharger Belt
- i was racing tonight and i overrevved my turbo ls...i need some help
- get ready to laugh guys, i got home from the track!!!
- JDM BOV's????
- Direp's highway vids
- My A/F Gauge messed up or what???
- why won't this work for a MBC?
- Detonation?
- Questions on AEM FPR...
- sparkplug gap...
- GSR NOS plate Question..HELP????
- Bought a Garrett turbo at the junkyard. What are the specs?
- 92-96 prelude injectors
- need help with egt guage readings
- Changing Plugs?
- Speed Pro tunning?
- anyone have pictures of...
- 9to1 gsr pistons in an LS equall??????? thanks
- D16A6 Turbo
- wat standalone do u guyz reccomend for this?
- Itr Cams Worth It For FI??
- turbo timer install...last step...need help...
- NOSzle" Direct Port E.F.I.
- B16a in a 91 civic......turbo? is it possible
- Which kit is it that is made for the 2000 Civic Si but will work with an Integra LS?
- does vafc show boost reading?
- which pistons for ls/vtec turbo?
- WTF is up with this?!?!?!?!??!?!?!?!?!?!?!?!?
- Solid stage 2 axles or tubular axles from the Driveshaftshop.com? Need your advise on which to get.
- funny video
- Help this guy out with some info...
- Stock knock sensor, what kind of signal does it give?
- New members on the board...
- Toda oil pump gear VS. Prodrive oil pump gear
- Installing APEXi AVC-R
- anybody got b18b1 turbo? what is your setup and what are you running?
- Who sells fully built Ls turbo motors??
- Put in my custom exhaust and magnaflow last night-
- Shimmed oil pump?
- fuel sump for 5g civic
- New cam = new pics......breaking in car
- Some pics of my junkyard turbo setup! Just completed
- Opinions on my fuel setup?
- dyno day in VA sat 4/6
- good shop in denver area???
- looking for a T3 manifold for a zc/d16a6...
- The inevitable...
- thermal or magnaflow 3in system
- Help on racing w/slicks please
- VTEC Light, VTM VS: VTEC Solenoid wire
- trust kit for thew b18c5???????????????
- Test pipes and high flow cats
- turbo with vafc?
- Question about what causes blown rings
- DSM Injectors
- compressor surge/fluttering
- TB Size?
- RC 550 injectors don't fit Australian b16a2 cars you need the correct plugs...
- blonde question.. but when will the archive search work... grr so much turbo research
- Prepping a B18B for Turbo
- *HELP* Does anyone still have instructions for the Greddy turbo black box?
- Quick question on gauges, pods, and sizes...
- TURBO/CHECH ENGINE LIGHT
- GReddy Type R or SSQV?
- Any of you guys still running stock...
- stock greddy wastegate adjustment
- Exhaust for my new turbo car
- Re-Torquing Arp Head Studs
- t3 for my custom turbo?
- Checked plugs after a spirited drive
- Motec M4 orM48 to run 8 injectors ?
- Downpipe flange?
- turbo sizing question
- turbo help! little bit of white smoke out exaust!
- Today's SOHC Dyno...
- supercharged d16y7
- air/fuel gauge installation-need answered now...stuck
- My stolen car recovered pics inside =(
- apexi vafc with drag 3 tuning
- DRAG III Integra Kit ???'s
- GReddy e-manage
- Oil pan gasket, dealer only?
- what size slicks?
- adjusting fuel pressure....
- ????? if i were to build a new bottom end, could i bolt on a turbo right away????
- Saab 9000 Turbo
- hooking up inline fuel pump to power
- here we go guys Pro Drive Oil Gears
- Anyone with a turbo'ed auto and a BOV
- installing nitrous
- question about my external wastegate... help please!!!!
- Fuel Pressure.....
- fuel for turbo(been answered at least 1000 times but....)
- Which Tranny
- BEST place for TODA cams??
- how do i adjust boost on my td04h-15g?
- Fuel Pressure Regulator question..
- poll: which engine would you boost?
- revhard kit
- OT: Anyone going to ATCO tonight?
- drag3 kit. 7psi... inline drag3 pump or walbro???
- What spark plugs for turbo?
- SOHC turbo cam
- Arias Piston
- How to set rev-limits without push button on Hondata?
- Oil feed line suggestions for you guys that need them!
- I need an honest opinion from you folks.
- Pics of filed block
- trap speeds for turbo LS hybrids
- Oil Temp Gauge
- Sleving a broken block.. for my turbo project.. HELP
- My car was stolen =(
- any one get there maxrev kit yet?
- Drag Gen 4??
- greddy type-s BOV question... what do i plug it into...?
- Can a turbo still make power to 9k?
- magnaflow=thermal............
- Car won't start up =(
- Which intercooler to get. anyone have experience with Griffin?
- Water Sprayer Tank "thingy"
- Adjustable Fpr???
- Where to get welding tips online?
- What other cars come with injector resistor boxs ?
- UEGO (wideband O2) Group-buy!!!
- Thermal 3" dyno numbers
- Hondata users!!!!!!
- Anybody have any experience with this SC?
- Greddy Turbo Kit
- fuel pump?!?!
- Drag 3 for B Series Engine for sale
- Anyone using water/air intercooler?
- vaccum line size
- Turbo kit to use on a B18b swap in a 2000 civic hatch?
- Motec M48 vs SpeedPro??
- Help, oil pan tap leak
- galley plug?
- April 27th Import day
- Got turbo and will be boosted soon!!!!!
- wiring diagram for blue box and black box the same?
- Which company would you send your head to for big turbo hp #'s?
- Blitz BOV??
- JRSC in an LS/VTEC?
- gaskets for manifold to turbo, wastegate, and turbo to downpipe?
- For you turbo people in california........................
- check out new turbo setup!!
- Changing from NA to FI...where to go...
- Slightly OT - Tell me you don't want one of these for your car...
- egt probe question
- How would I lower boost pressure ?
- boost gauge help
- b18b1 build up
- flanges
- :::HONDA-TECH BBQ IN VA:::
- Gauge quality
- CRV Pulley in a JRSC GS-R
- Intermittant power lost to my hondata 3b
- prototype air box.....
- turbo numbers
- Coolant flow?
- Taping the oil pan.
- Fuel system Recommendations
- does anyone know where to get a gas mask for tuning damn cars
- What amp fuse for fuel pump cut off switch?
- I'm getting a victor x for $200
- Hood clearance problems with Tial 35mm w.g on Drag manifo
- Leaks on the top end.
- The Rest of my Turbo kit... thanks to Ben from importparts.com !!
- Anybody want my dual pillar pod to mount their gauges?
- Lisa Kubo's intake manifold??
- JE Pistons ! jsut got them.... but maybe there wrong.. oh NO
- BOV flanges?? (Vortech BOV)
- Downpipe length???
- Im installing the turbo this weekend.
- Did any of you guys go from 17's to 16's? And did you get more traction?
- my nightmare =(
- Hondata 3b ok for daily driving? or go with 2b instead?
