View Full Version : Forced Induction
- d16 turbo setup
- Anyone does turbo street tuning in IL ???
- Boost and Piston Rings question
- Anti-Lag base settings
- Defi Link Display /w boost guage vs. Autometer guages
- Hondata S300nDatalogging Question
- Car sits a lot lower now with Boost
- Lovefab? Still around?
- turbo rebuild, which seal??
- Tial 38mm WG spring question!
- PSI going way to high(HELP!!!!!)
- Turbo Charging my 95 Integra GSR.
- random bogging at low rpm under light throttle
- ebay turbo kit
- t3/t04r spool time?
- wastegate problems?
- need help fast
- 3/8 ARP 2000 -12 rod bolt stretch spec?
- Cost Effective catchcan idea! 14 bucks! (hope it works!)
- drag turbo kit
- hallman pro rx users ... question
- Coolant temps on a 99 f23a1?
- Help identifying precision injectors
- exposed timing belt, good idea or not ?
- Turbo Brand Help
- Thermal Efficiency
- found a turbo, which way should i go?
- Designing a new Intake Manifold
- intercooling idea?
- A question on what your using to keep your A/C
- turbo oil line kit
- trans fluid in motor oil???????
- Fresh built motor, my break-in and start up procedure, need pro input :)
- NOOB! Buying a used kit
- block guard/head gasket question
- Can it handle it
- Vitaras?
- take a look at my bearings and tell me what you think
- Z6 Crank = Y8 Crank?
- electrical problem?
- Trying to find a Vband housing for my GT3582R
- Hit it in 4th and BING BING BING!
- Moroso Oil Pan tapping
- skunk2 stage2 EX and b16a2 IN
- what turbo for ls/vtec
- Tranny question
- jdm f22b DOHC turbo build
- Boosted DC5
- Anyone using a Tial knock off BOV ?
- Power cut-out
- i have been watching speed channel all day....... question
- Turbo Blanket with a "shorty" manifold?
- Greddy Type RS or Type S for 6 PSI low boost Setup ?
- dsm piping
- Skunk2 Pro 1 Cam Owners! Identification Question
- wavy intercooler mod
- Piston - Wall Clerance on Boosted setup?
- Starting To Hate All Cars Not Honda
- Can I use the pcv valve vacuum line for my boost controller?
- coolant in catch can for crankcase water in valve cover catch can
- 546whp low boost dyno
- turbo
- wastegate dumptube help
- AC compat. Manifold
- jdm h22a with nitrous. What sparkplugs to run?
- new to turbo, integra question
- sohc ~ dsm blue vs black top 450cc injectors
- OmniPower/Hondata 4 Bar Map Sensor with s300
- MSD ignition troubles..
- 500WHP SOHC TURBO STOCK SLEEVES
- vtec won't engage on ls/vtec
- Need a pair of nice turbos?
- Need advise for a Head Gasket in a Turbo d16a6.
- Turbo spooling rpm question
- best turbo option
- Cams and Throttle response?
- what do you think about MSD Pro Distributor?
- boost creep with profec b. suggestions?
- What cams for a nitrous motor??
- Made a new home for my ngk wideband in the dash
- Precison FMIC ????
- Boost Guage and Blow off valve... help
- HMT style HF/14b downpipe and IC piping setup questions
- Vacuum diagram (K-series + boost)
- car on jack stands ... quick question
- z6 boost
- precision injectors
- compression test
- revhard turbo kit
- Who makes these 550 injectors? (pics inside)
- T3 oil feed adaptor?!
- RoYaL PuRpLe
- down pipe and manifold???(searched)
- 5 psi more equalling 15 whp?
- Happy 4th of July H-T Forced Induction Crew!
- turbo identification question!!!
- 500 whp clutch question...
- TiAL 38mm Gaskets..... NAPA/CarQuest equivalent?
- 18 hours of driving with JRSC?
- Wrap It Up!!!!!!!
- timming b20
- Help on 1000cc Delphi
- Exedy stage 1 clutch for 220-240whp?
- Accurate Location for Water Temp Gauge
- Back from the Dyno Pics/Vids Need help on spool time
- problem with my newlly boosted z6.
- CM Twin Disc
- B20 Turbo Newb
- Injector Dilemma - RC
- I need turbo help asap!!!
- b16 turbo question
- Keep braking trannys on low boost on street tires....what do i need to correct this pattern besides
- kinda overheating, turbo gsr
- EG hatch, gsr boosted, LS tranny?
- Long ass time warm up
- 60 trim on a sohc?
- which iat sensor to use
- ITR Cam swapped, lower vacuum reading?
- Werid overheadting problem.
- Do my vacuum lines sound right?
- catchcan question...
- Power Steering Cooler?
- ANYONE KNOW A NAME BRAND DOWNPIPE I COULD BUY? for a 92 hatchback t3/t4
- High IATs...cause of surging idle???
- What size LSVTEC oil line do i use?
- HELP! Spark Plug Problem!!!!
- amount of wrist pin oiling holes ?
- what vacuum do you guys get at idle?
- Should I buy this?
- What turbo is this
- neep help on catch can set up
- FAL fan wont fit PWR aluminum raditor??
- Cam's For Supercharged Set-up, Vortech+b18c5
- Turbo B16 Smoking!
- Thermo-tech turbo insulating kit???
- ct26 turbo help
- what can i do to make it last?
- ACCORD TYPE R TURBO (HELP)
- Can a throttle body be too big?
- trying to do performance and its just not working for me
- 2005 RSX ECU and Fuel System Questions
- Do I need bigger injectors for my Turbo H22A ?
- Stock turbod B16 OR B20
- New Turbo...First startup questions!!!
- Arp head stud installation
- need help, any experience welcome!!!!
- cel under boost
- BEE*R rev limiter install ?
- when do you check your oil?
- What B20 Sleeves?
- intercooler too big cause loss of power?
- charge pipe came off & after re-insta. boost is lower.
- edelbrock or skunk2
- Oil Change Question.
- smoke
- car die's out,rough idle
- Block/Head problems
- B20 TYPE R HEAD WITH JRSC
- do i need a electronic boost controller?
- drilling fuel rail to fit 1000cc injectors
- Terrible Misfire
- cel when boostin for a couple of seconds?
- Redrill/ Reweld d-series ramhorn to fit b-series.
- chipped ecu need aftermarket map sensor?
- Looking for information on RS Machines headwork and Isky valvetrain.
- t3/gt40 blowzilla
- My fully built LS/Vtec Turbo build
- movin on in my turbo build.
- Godspeed Wastgate - anyone using one?
- ITR supercharged vs GSR supercharged
- Car smokes when i let off the gas why??
- What downpipe?
- 450cc DSM Injectors - Good enough for 300whp
- TD04 and lsvtec?
- overheatin gt35r topmount
- precision injectors wont fit
- DD setup with a/c, best way to combat engine/engine bay heat?
- WTF?? What causes this?? Broken throwout bearing which came with my CC stag4 4 clutch
- high idle without vacuum leaks
- Best turbo blanket
- ITS ALIVE BABY!!!!
- Anyone B20 turbo???
- 1999 Honda Prelude Turbo - Love Fab Eq, GT35R Vband, Myk Fab dp
- Down pipe fabrication obstacle
- new d16 turbo user on board
- I smell fuel with the new setup using Aeromotive fuel pump. Please help
- Where can i get good IC piping
- a/f
- Bad O2 sensor??
- Few questions on boosting a b16a.
- wtb turbo intake manifold (H22) empty stocks everywhere.
- Greddy Type S BOV
- boost'd gsr
- Lab results: Castrol GTX vs. Amsoil synthetic
- turbo b16 problem...???
- Overheating issues (TopMount GT35R LS)
- Head noise, lma's, broken valve springs, blown out valve guides? Discuss
- civic project
- Small Turbo I have yet late boost?
- ebc instead of pwm
- H22A Turbo Manifold Suggestions ?
- lowering boost lower then wastegate spring??
- itr cams vs s2 stage 1 vs brian crower stage 2
- Buddy Club Spec 4 Cam and Boost
- Main Bearing Failure; almost carnage, engine guru's please look at pix.
- new WG spring still gives me the same psi as old WG spring? wtf?
- DSM Injector help...
- thoughts on defi knock off gauges? are they accurate? experiences?
- Variable Vein Turbos
- Anyone had issues with superterch K-series springs?
- Sneak preview of whats to come from Bullseye Power!!!
- 5 bolt FLANGE HELP!!!!!
- gm boost solenoid and rom editors q.
- KPA to PSI conversion table / chart Accuracy ??
- AEM FPR Bad?
- Boost difference for GT30 to GT35 upgrade?
- Lightweight flywheel or OEM??
- How Much Power can I make on my stock GS-R????
- Bogging Down
- Supercharge D15B VTEC
- Does the AEM FIC MAP Clamp Work on our cars?
- new MBC...
- Nitrous ZEX Kit
- The best fuel pump
- B18c1 engine rebuild with jrsc questions
- If you had 4k and a stock b18c1 what would you do?
- DD ej1 coupe, 250whp in mind, built bottom end.
- What map sensor's are compatible with Power FC?
- distributer help
- I have a 95 EG type R turbo boosting 20 lbs possible boost leak, or fuel cut??
- 93 Si Turbo Street Build were doing.
- Another Oil Restrictor Question???
- Over Heating HELP
- valve seal or oil rings
- Good turbo exhaust?
- Largest size TB for Victor X manifold?
- 70mm throttle body hook-up
- turbo civic SI smokes during boost . what is it ?
- omni 4 bar vs stock map vacuum voltage scaled the same....?
- Question regaurding rebuilding of motor
- Ctr intake cam and GSR exhaust cam ????????????????
- What am I missing from my turbo setup...?
- T3/T04e Question
- SLS Civic Shop Project
- Looking for visual differances between gsr and b16 cams.
- Motor Build
- No power
- msd blaster hvc coil
- Rough Idle/Bog
- BOV NOT OPENING QUICK ENOUGH PLEASE HELP ME!!
