View Full Version : Forced Induction
- what injectors should i get?
- Need help (Turbo Guru's) on my dyno session tom. (3-10-02)
- Some pic of my intercooler
- will i hit 12s on street tires? R turbo
- hard to boost in 1st gear.....
- car doesn't idle anymore... :(
- Which ecu
- EGT link
- gsr turbo
- HIGH COMPRESSION WITH TURBO
- o my god how is this done???
- I'm confused
- Boost on stock sleeves
- efi pms engine management
- LS Turbo guys/questions 4 non vtec turbo setups
- Any V-AFC Gurus Here???Need some help!!!
- turbo and emissions..........
- Questions on Goinb Turbo 2001 Prelude Sh
- N/A or Boosted ?
- Hondata turbo maps
- Prelude Injectors
- EG + B18C + DRAG 3 + TIAL = No hood clearance?
- Even with head and valvetrain work on a H22a head, what is the safe maximum rpm for the H22a?
- Argh: Valve cover bolt broke....
- POrt matching
- Blitz SS or TurboXS Type S BOV?
- Daily driving with a turbo
- Gasket Suggestion?
- JG is bad for turbo engine work? I was just about to box up my engine and ship it out to them.....
- The Pain
- Newest member to 11 sec club!
- pics/vid day 2 of WIC
- OT: WIC round 1
- sfp manifold pics
- For Sale: Custom Integra LS turbo kit
- Aftermarket axles- can someone tell me if THESE axles are worth getting for my car...
- DIY Wideband O2
- What size turbo should I get?
- clutch for 350whp daily driver??
- tuned the R last night....
- Who still hasn't recieve thier MaxRev turbo kit?
- will i need to upgrade my fuel system to run 5-7 psi?
- Pretty cool dyno vid
- Will this fuel setup be OK for 20 psi?
- Need Zdyne Groupbuy partner in Bay Area
- VAFC hack and 2nd 3 bar map sensor
- Can you guys tell me what I need/ LS turbokit
- My Fuel system
- Need Help w/my turbo setup!
- Finally drove on the hondata ...
- who here has a car that doesnt work?
- ARGH: Found source of the Check Code 90 (followup)
- She runns!
- TIMING RETARD ON 8 TO 9 PSI???
- how-to read a compressor map
- how can i richen my mixture??
- Pipes blowing off... Why???
- **TURBO LS NOT BOOSTING??**
- The Great thanks to Honda-tech FI.
- gasket between turbo and manifold??
- Dyno result
- camshafts for FI
- fs: nos
- EFI or HOndata. i need your advice!
- cylinder compression ?
- SFP manifold came in today! The hondata is in and running!....But
- OT: pics of JL Audio/importparts (viren) car at WIC
- Dustin: Making your downpipe...
- Spool up time...
- Endyn Head Work....
- slightly OT: Texas peeps
- Nitrous Questions
- Max-Rev Turbo Kits
- J&S Safeguard Settings Q
- NGK SPARK PLUGS?
- anybody interested in a glimpse of my new turbo?
- HONDATA worth it?
- QUESTIONS.. Hondata..
- Need Help Fast.....What will I need to make a civic si turbo kit bolt up to a gsr
- Pro drive oil pump gear worth it?
- Tuning w/out Hondata or dyno??
- trying to find a 3'' exaust/pics/comments on a 89 rex??
- Chassis builders websites?
- Try to reduce oil pressure at turbo or not?!?!?!
- Need opinion on choice? TD05 vs. Saab T3
- Fuel Pressure
- Anyone have info on VDOs EGT gauge?
- Intercooler Size
- replacing seals on a turbo??
- Blitz guages, do they make a/f and EGT? Are they all mechanical?
- water spraying on the intercooler?!?!
- Turbo, Oil Feed line?
- NTK (Wideband) o2 sensor and Leaded Gas?
- Crashed my car last night :(
- upgrading my turbo need some help
- sohc turbo build up.
- blow down good for NA cars, good for turbo cars?
- Extended invite for DFW meet
- Does anyone have a ZC turbo?
- FI a 94+ LS motor for turbo?
- Anyone have pics of their gauges on their pillar?
- Fuel pump?!?!
- Anyone know about Clutchnet DUAL diaphram Pressure plates?
- Why do i keep blowing headgaskets?
- Using a turbo timer w/a Viper alarm system. Interference? Problems?
- Boost guage location
- stupid question.... can a B20 crank pulley be used on a B18c1 crank?
- Da real Low Budget LS Turbo w/ Hondata Stage 1B
- Very impressed with Golden Eagle's workmanship, facilities, and friendliness.
- Peak and hold & Saturated
- Videos! Everyone loves videos!
- Group Buy Inquiry
- Anyone going to E-town saturday?
- Argh. Threw a code I can't decode.. HELP!!
- does anyone in the philadelphia area have a stage 4 hondata system?
- B Series Turbos... Need Help Quick...
- Turboed B18c1 people what do you get on average for MPG??
- rods brands..does it matter?
- Resistor box
- Rod and mani bearings
- Jackson Racing Liquid Intercooler System??
- d16z: greddy turbo + higher compression pistons
- need info or pics of charge pipes for drag turbo kit
- Im happy
- problems w/ greddy type-s bov
- FS: Modified Starion IC
- RC 440cc injectors...ECU BLINKING???
- how much to sleeve my bottom end
- Supercharging question
- anyone know of a place to tune on a dyno in nj, pa, ny?
- DP question
- pic of intercooler piping............
- Spark Plug Gap?
- Sacramento SOHC's
- What is that website....
- Where are all the Max-Rev kits making 600hp?
- Liam...quick question for you.
- need help putting hondalogger/romeditor on my laptop!!!!
- does anyone sell turbine housings??
- HELP! Rebuilt motor, head leaking oil
- Turbo LS Civic drag times *vids*
- getting a vortech! what else will i need.....
- t3/t04e clearance in 5th gen prelude
- Any CA people using DRAG and How'd you pass emmisions
- OT:just got motor back from machine shop, MAIN CAP BOLTS?
- 1.8ls turbomotor what is needed
- anyone know how to reset the hondata 4b blue box ?
- most power seen with a t3
- just blew my motor !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
- K&N valve cover breather pruduct number...??
- Please Help! a question about Ebay!
- Tuning Order
- How do you choose your Exhaust / Turbine size?
- Are my EGT's high?
- Fuel Injector Duty Cycle - 100% = open all the time
- code 71 and 72, oil residue came out of the valve cover breather, more oil comes out at higher revs.
- anyone need a fmu or fuel pump?
- Fuel Line Sizing
- T3super60 vs T3/T4
- Difference? P30/P72 Oil Pans
- Help bleeding coolant after Fluidyne install
- Limits of 450cc injectors?
- Need some opinions
- someone familiar with fuel pressure , systems etc.. HELP!!!!
- SOHC Turbo stats
- thread sizes
- Bell Helmets. Need feedback.
- T25 Measurements?
- boost problem!!!
- Homemade intercooled supercharger?
- Ballistic turbo
- Cartech FPR or Vortech SFMU
- Overheating question....
- Lucas disc type Vs. Denso
- My love affair with the mail carrier continues!!
- APEXSER: do you have a chart for turbo selecting?
- Somebody give me links to websites or books that explain turbo/superchargers
- Zdyne - Recalibrating For 340's
- OT: Where are my engines?!?!
- **Hondata... injectors... WTF!**
- Wet system on b16
- Intercooler sizes.....whats everyone use, whats good?
- So I did a search.......FMU
- Brand New 440cc for sale
- B16a with 350 - 400 whp?
- -------***afc hack write up***------(for turbo fuel management)
- Why does the fmax kit only include 2 injectors?
- Where to get a roll cage??
- DIY egt: is this a bad idea?
- Did i get the wrong turbo?
- Anyone have 720cc or 900cc injectors for sale?
- ClutchNet stage 3
- Turbo Install (Couple Questions)
- Litle worred bout comp numbers...
- Turning the turbo
- Beginning Turbo Install
- Pics of my SS Inline Pro Turbo Manifold
- Boosting a ZC
- Choosing a motor for my race car
- ever heard of it
- DSM injector clips same as Honda/Acuras?
- The Right Turbocharger
- Actual boost is different from controller settings?
- What size turbo for b20? please help!
- water temp sender vs. sensor
- hey guys has anyone did custom HEAD STUDS before
- GReddy SP CAT-BACK too small for t3/t4 setup? 60m piping
- Zdyne Ecu Groupbuy
- boosting a stock 1.8LS BLOCK.
- Need to remove ball joints in order to remove drive shafts?
- Nos tech told me i need another regulator ???
- Options
- Does anyone use the turboxs duel stage boost controller? Is it any good
- what oil do you turbo guys run?
- Hondata in TX
- FI kit options for a 95 GSR
- Turbo LS project on the .... track.
- cheapest place to get a 25 wet NOS kit???
- question regarding pistons
- Anyone know the thread size for the fuel inlet/outlet of b-series aem fuel rails?
- Darton sleeves
- Yahoo!! Oil filter clears the cooler kit now!
- Quick Question for Hondata users
- Someone help me inform this lame person turbo and vtec is GOOD
- Greddy TVVC? any good?
- any body have a t3/t4 with an .82 a/r on the turbine?
- Back in action...
- FOR SALE: GReddy air/fuel ratio gauge NIB
- need answer fast
- Rebuilt engine- boost or no?
- Bonding head gasket
- Which turbo to use?
- ~~~~Where to find CTR crank pulleys?~~~~
- ignition help
- best place to buy revhard?
- Why does everyone use 440's with hondata?
- Highest boost a B18B1 can handle?
- revhard stage 2c???
- Building an engine for Vortech...ques???
- Is a CEL Code 63 (secondary o2) bad?
- Closer to turbo install!
- putting together a turbo first aid kit to keep in trunk
- **Help me put my turbo kit together**
- Cybernation Integra ran 11.1
- Rev limiter Q
- What has broken on your car since you started boosting?
- FS: FMU and Bosch inline...
- "Arturbo click here..."
- Supercharger questions
