View Full Version : Forced Induction
- 65psi...is it possible on a built b16 block? and how much hp is it worth?
- Tech Question: Head Milling info required
- help on nitrous
- Power steering pump for water cooler water pump?
- What turbokit is smog legal for a 90-93 integra?
- Omori Gauges?
- ls motor swap and turbo
- Is this 3 bar MAP sensor?
- Vortech FMU ????
- need help reading these plugs (nitrous)
- Sleeved motors
- AEM V2 as a charge pipe?
- instructions for a rev hard kit??
- ATTN: CRX's with Greddy kits on
- What 2 gauges to run for turbo???
- I need a b18b asap!!! whos got one to sell??? please
- Good idea to switch to ITR oil pump for turbo
- 99-00 Blue Box on EG
- how long have you had your turbo in? set up?
- $5000 - Build your own turbo setup
- civic charge piping
- What is "boost spike"?
- AEM V.2 on JSRC Hybrid ?
- OT: The new Lancer EVO comes standard with...
- Good transmission for highway pulls and ocassional drag on an LS?
- greddy kit
- Need some help choosing exh size..
- Need help from knowledgable Nitrious guys
- GEM Engine Rebuilding (TONS OF PICS)
- Question about o2 sensors.
- Whats your idea of an ideal suspension setup
- What JetHot Coating do I need? 1300? Or 2000?
- Check out these T25/14B adapters to HF manifolds
- nos license question?
- Precision Turbo Big Dog T67!!! Pics
- SFP Manifold design (hurting performance)?
- How much hp would i lost going from 3" to Apex WS 2 1/4" exhaust
- Anyone use this MBC?? DIY setup.
- oil return leak help
- Finally got the loot for Hondata, now which one do I need!?!?!?!
- Main relay question.. Please help. stuck here.
- Building a boosted accord ...
- BOV swap question?
- Inlinepro Turbokits??
- What b series turbo manifold bolts up to the greddy sohc turbo?
- Need Experience Tuner Advice For LS/Vtec Turbo
- How do you know when the o2 sensor has gone bad???
- Gimmie some ideas for my catch can??
- advanatges of 2", 2.25", and 2 1/2" IC inlets/outlet
- Where to find silicone intercooler hose?
- turbo setup
- Detonation Question...
- Part II in A20A3 rebuild
- i need a downpipe?
- Decided to go with the SMC
- spark intercoolers...any thoughts?
- part number for colder plugs on a f22b1?? (94accord)
- sohc setup sound good?
- boost controller?
- DSM fuel pump rating???
- NITROUS guru's please help
- can i tap off the oil cooler line for the oil line for my turbo
- Where to buy dump tube?
- losing boost between gears.
- downpipe diameter and cat diameter to match b-pipe diameter?
- Type R camshaft Identification
- internal wastegate question-can i take it off?
- semi built d16a6-nx dp 80 or 100
- Jackson racing SuperCharger on a B17a
- greddy turbo/ ls
- Greddy e-manage
- Greddy turbo kit install.
- new track time
- Need help finding a product (Bronze Valve Guides)
- Vtec solenoid/oil leak theory
- homeade turbo kit b16rex FAQ's
- Quaife + ACT XTSS or HDSS?
- Anyone with Z10 radius bars and a FMIC?
- using "stop leak" in your oil....
- finished polishing
- Picked up a new engine yesterday for my friends Hatch.
- Solved my oil pan dilemna! Pics inside...
- Turbo intake + Loose Bolt = ....
- who else hates downpipe bolts?
- OEM honda metal HG + Copper spray
- funny story..could have blown a motor...possibly
- Ever installed your own turbo?
- RC 310cc and afc hack?
- Thanks VIREN ( b18bturbo ) !!!!!!!!!!!!
- Boosting an LS...worth it?
- Is this price for 4 injectors or 1 injector?
- Anybody running an oil cooler?
- greddy 18g kit vs jrsc
- Any sites or links for b18b turbo?
- Anyone used GT25 BB turbos?
- What type of oil? Synthetic or Non-synthetic!
- NEWB Question for guys running hondata in cali
- Who all uses the starion InterCooler on their custom setups????????
- Problem with car after VAFC install HELP! ASAP!
- 94 integra gsr w/ greddy kit... can he use 97 gst ingectors.....
- stock cams VS Skunk2 turbo cams
- fmu and inline fuel pump install pics
- Alright the setup is complete Thoughts?
- Any 99-00 Si's with MaxRev kit?
- N00b at turbos
- 02 accord to OBDI?
- where to get a 90 degree silicone coupler
- need opinions on turbo head build up
- Turbo manifold flanges
- Exhaust System Size?
- anyone know just how much altitude affects 1/4 mi times?
- home made water cooling system
- JRSC w/ aftermarket flywheel question
- Honda nudity (Engine build-up page updated)
- Best build up for a boost bound B18B? (LS)
- dying at the top end???
- Bench Racing at it's Finest.
- JRSC sounds
- 310's and Hondata
- Turbo plus no...
- Got my pwr intercooler! whoohoo!
- anybody boosting with civic type r cams?
- Turbo install experience (4 bolt t04e w/ inline pro manifold)
- can any of you chime in on vw vortex for a minute......
- ? about oil feed line size
- high lift cams for boost?!?!??????
- hondata tuning..
- yea check out my new Y pipe for my exhuast...
- Bolt Fell off Turbo, Specialists Please look
- Oil return leaking... what can I use to seal it without dropping the pan?
- Anyone have the specs off skunk2 turbo camshafts?
- Problem with 02 Si turbo build.. (turbo size)
- map limiter Q's
- Mounting intercooler in a 92-93 Teg - Hows it done?
- do I need bigger injectors
- Testing Posting A Pic of My New 4"turbo Filter-checkitout-
- What all to upgrade w/ 5 psi on D16Y8?
- 5psi on a .48 a/r T3, are stock injectors w/out FMU or FPR okay?
- Zex Nitrous Question
- intercooler flow question......
- Quick SMC question
- What sounds to listen for?
- HELP PLEASE w/ turbo timer!!!!!!
- Stand Alone Users And Tuners, ....Question????
- n20 maps
- How many U-Bends do I really need?? I still have my CAI.
- i ordered a hondata but it didnt come with...question
- Procharger?
- For those who have T25 turbo's on their cars........
- Mandrel Tubing?
- Exhaust smell inside cabin after boost?
- compressor bolts
- Homemade catch can
- Did you turbo your first Honda?
- How to lower boost on a t25
- Should I get GE sleeves?
- NGK- BKR7E's for nitrous?
- GE pricing...
- is it ok to do this with a turbo...
- Just for kicks, does anyone have the pics of the turbos the shuttle uses?
- ... bearings... acl or stock?
- CRX+AWD+B18C+turbo....Vids.....
- 14b actuator locked up any solutions?
- blue smoke at idle... what could it be....
- max rev turbo kits, 2kteg's group buy
- RevHard kit and intake?
- Edlebrock?
- revhard price
- Boost hits at 6000?!
- GE sleeved blocks, what does the bottom of the sleeves look like?
- Intake cam?!?
- Garret 4-Bolt VS. a Ford SVO Style 5-Bolt with pics.
- NEED HELP! GSR loss of power in acceleration
- Quick Question about LS block
- Research time!
- Autometer Gauge....Opinions....
- Installing Drag gen 3 Turbo on an LS tomorrow - Any learning experiences I could avoid?
- What are normal compression test #'s on B18C1's ?
- Poll Ls Turbo
- Seperate vacuum source for Boost gauge and BOV?
- Thermal Research and development
- Bilding a turboed h22a
- universal fmic help
- can someone explain turbo specs to me
- Greddy Manual Boost Controller
- Saab Turbo?
- Need to pass emissions in PA!
- Will a different intercooler affect my dyno "tuning"? dsm side mt to a front mount?
- Who uses AFC or SMC with stock fuel pump?
- What can be used for intercooler/charge piping that doesnt require welding?
- Running a safe turbo
- just got some new stuff to go with my turbo sohc
- Leaving the Bottle valve open
- sensor settings on s-afc
- problems with my drag 3 turbo
- Turbine housings
- Transmission selection on 550+whp
- Just installed SMC+ and can't get my car to idle?
- Anyone know the manifold to turbo size on a SFP manifold????
- Greddy Type-S BOV: do I have it installed right?
- what FMU disk should I run?
- JG EngineDynamics isnt dead....
- no intercooler on d16y8?
- New Section in Tech Forum Section: Tuning Systems
- gb on inlinepro manifolds?
- Oil filter cutout pics (new, not the Prelude site) - link
- Trying to contact Spoondc4
- Expertise on metals Geoff,Rtype11 many others
- What turbo for my setup?
- Nitrous
- I need The Pin out For the o2!!!(p28)
- Getting compressor maps?
- Best pricing for Roll Cage Install in the Tri-State Area?!?
- With no a/c...any reason not to run comp. on driver side?
- b18b vs b18a
- pressure question???
- Safc question need the wiring diagram pls help guys!
- Car pics from Japan
- Manual boost controller help
- Apex-i Power FC: Who uses one?
- RC Injector Wire Clips
- how much would u buy this for?
- Turbo Oil Feed Line Question.
- fuel pump...
- nitrous oxide
- Dont warm turbocharged engine up? (VW related)
- I need a lesson in AEM school, EMS professors SCHOOL ME!!!
- Pro drive Oil Pump gear needed?
- rs machine?
- 88-91 Resistor Box
- How to build the ls motor: All tips are welcome.
- So, Who's got the most HP from there AEM EMS setup
- please read! will this turbo fit my application?
- Here's your chance to get a T3 turbo for cheeeap!
- AEM vs Speedpro
- Really Worth Boosting a d16y8?
- I got a fat ass injectors.....
- Dirve Axel
- Tax Return Turbo Parts?
- Precision SC61
- what boost pressure and fuel control unit
- SMOG and CARB CA FI Owners.
- question about Meng style headers
- boost pressure adjustment.
- What size intercooler should i use with 15lbs of boost
- hondata
- Portflow Headwork?
- Rocket and ef-1.com
- What gap on spark plugs for a LSVTEC turbo?
- i ask you this
