View Full Version : Forced Induction
- DALLAS TEXAS TUNNER
- turbo EJ
- Misfire with new OEM distributor and low boost
- ideas on mounting brackets for intercooler
- Is it my 3 bar map sensor?
- TIAL BOV
- what would make fuel pressure surge?
- Compression of 84.5mm Wiseco pistons in B16 ???
- Turbo GSR build...waddya think about this
- mounting manual boost controller
- Innovative GT61S on an LS?
- What oil are you turbo guys using?5,10,15w
- custom air filter rig
- Hks evc 1 or 2, how reliable are these ??
- are these pistons fixable or are they finished
- Semi Built B20 Turbo
- Which BOV?
- inspection..just want to make sure I have everything right
- Blow off valve
- SOHC turbo
- What turbo do I have?? I was told GT30R
- Extremely strange Battery issue (lean popping, misfiring) vs running perfect in 4 week difference.
- list of stuff for sohc turbo
- Vacuum line routing?...pic
- Tune with a apexi V-AFC????????
- 11 heat range NGK plugs
- Greddy BOV / Blow Off Valve Vacuum Fitting Replacement
- Benson/Earl/Full-Race B18C1 - New setup, white smoke while decelerating in gear only
- Does anyone out there have the Greddy Pressure Relief Valve installed?
- blitz dual sbc spec-s
- Turbo setups with A/C and P/S (ac ps air power steering compatible)
- cheapest place to get Tial WG springs?
- t3/60-1 .63/.70 Peak Power?
- Good tuner in Md
- turbo overspin?
- Turbo Muffler??
- what would be a good set up for h22
- need a tuner around southern wi
- another crankcase ventalation question
- GReddy Oil Block Adapter Socket Size
- how much timing to pull for a 10:1 compression
- My Customized Turbo Kit
- Peakboost turbo kit
- Fogging Oil using in a boosted car??
- Tech specs and ?'s bout Garrett T3/T4 turbo I just bought
- Twin Disc Drivability?
- Best way to 350 whp in EG
- LS-T gas milage, what are you guys getting roughly?
- question on pistons
- More power for h22,
- how much difference between these turbos
- i have searched all over
- Problem turbo gsr backfire
- boost pressure on K24?
- noobie question about oversized pistons
- Just installed turbo into GSR and I need a new clutch!! suggestions?
- Anyone driving on open cutout or DP?
- Whats the easiest way to relive crankcase pressure?
- b16a ACT clutch help
- P06 and P28 Question pics!!!!
- Running RICH any suggestions?
- Valve seat fell out... pics to come
- ignition problem.....maybe??
- I removed my muffler and I lost 4-5 psi in 2nd gear?
- Car OVERHEATS! Brand new everything! wtf....Help!
- STOCK BLOCK K20(A) OR K24/K20(A) MOTOR COMBINATIONS
- car bogs after i let it sit for a week? confused.
- strange ignition issues (possibly)???
- Down pipe flange ?
- Weird idle problem...help
- turbo motor??????
- GT31R and GT37R Questions
- where can a buy a new or a hybrid volvo turbo?
- manifold help
- gsr boost misfire
- Weird CEL and fuel cut
- Hone / Sleeve?
- Thinking about goin D16 turbo
- Pic request dsm turbo on civic..
- OT: Anyone else missing the whole season waiting for parts?
- max power on greddy 18G
- Need some feedback on ebay hks style bov (fake)
- Post pics of nitrous set-up...plz
- some pics of my new build 85mm build
- Some new D16 numbers
- Zex dry kit problems
- 04 RSX 415WHP!!! ET??
- TD04H & TE04H Is there a difference?
- squirters question
- anyone using a thermal exhaust? need opinion
- where to get oil from? (EK)
- lol! ssauto ad on ebay!!
- My GSR turbo project
- Built Motor w/200 miles light smoke from Breather????
- Sleeved GSR or LS block?
- Cast Manifold Question
- **Post your whp/wtq for GT35R**
- ecu test
- boost gauge problem i hope???
- Post all your FI videos here!!! Lets get this started...
- Turbonetics Super 60 Question???
- Anyone have a hondata S300 Map for 7.5 Psi on a stock B16
- 619 Whp stock block s2k
- wich BOV should i get out of these 2??
- crank rod turbo piston combination.. need help
- what is my greddy intercooler capable up to??
- need help picking out parts to turbo my d15b7 in my 92 sedan
- need some info on sleeving a motor
- Need Tuning For My AEM EMS Before Tuesday or be done on monday , NOR CAL TUNERS , AND DYNO SHOP PLEA
- big boost in a CRX
- t3 t4 conversions???
- turbo kit for h22a in 92 hatch?
- best oil for boost
- Oil cooler questions!
- Another catch can question
- looking for any D series perfomance parts!!
- Tuning w/ different manifolds
- Liquid gasket ok?
- blox intake manifold and boost
- Got a expert b series transmission question?
- check out the LS-T, how zit look? (56k no way!!)
- Who carries this cable operated cutout?
- Safe to run without o2 sensor, untuned?
- Boost Controller
- Best Internals to use for boosting...
- slight idle stumble, fuel pressure surge, WB reading really rich after couple hard pulls at the trac
- Discussion: Do we forget about velocity when we design intake manifolds?
- LHT Performance Turbo charged Honda Insight.
- Are all E-cutouts like this?
- urgent.. hondata tuner needed in OC area
- aiResearch to4b for a b16?
- What turbo to go with for a d16z6...max goal of 200-225whp
- tunning
- f22 turbo
- NEGATIVE BOOST????
- Oil SPRAYING out the top when doing compression test???
- JGS 44mm Billet Wastegate
- CEL (Dash) Rapidly Flicking - Fuel Pump SOMETIMES Primes - Car Wont Start - Motor Swap
- T25 at 6-8 psi in a Civic
- blown head gasket 10 min after start up?
- anyone have any dyno's of ball bearing t3t4's
- Questions About Piecing together my turbo kit
- Has anyone ever had their cam gear cover melt? (thx Full Race)
- Whats the best Ecu for a turbo B16?
- 98 itr turbo question
- Got the D16 cooling blues - Solution inside >>
- h22 + 500whp= possible???
- nitrous led to high idle
- is it possible to tap here for an oil temp sending unit???
- is my timing off enough to keep valves open?? pics to help out inside
- name that injector
- Oil Pan leak...Please Help.
- my first sony, uhhhhhhh turbo set up
- RC injectors - was i sold the wrong ones?
- H22 build questions,lots of questions, compression ratio, 18g turbo(yeah i know its long
- Not Tech-Related, but a possible solution for all of us without AC!!!!
- top mount with ac?
- gsr jrsc, ls/vtec, crank need options on fix
- how important is a battery?
- What's the real story? Venom intake VS ported ITR for turbocharged application.
- Injector???
- B18 turbo build?
- Innovated backdoor design intercooler
- Chaging Oil Return To Steel Braided Hose
- Greddy Turbo Timer... HELP
- GT40R VS GT42R
- Apexi world sport good for a turbo d aiming for 200-225whp?
- Anyone replaced a Gator axle under warranty?
- a human living in my BOV?!?!
- what bends are needed to build a 3" exhaust on a eg hatch?
- loss of boost, no more compressor surge
- dsm injector question
- t3/gt40 too big for built h22???? need feedback?
- injector sizing and which brand
- NGK plugs
- anybody kno any good tuner in south FLORIDA ??
- Which one? Dart or Type R block...
- Oil squirter not needed with forged pistons?
- What do I need?
- Tuners Please Check In!
- turbo dropping oil!
- which fuel pressure regulator?
- GT4780 Anyone? HPF's new upgrade for Supra's
- Question about storing a boosted honda
- JG cams any good?
- New Product Alert!!!
- What are yoru egt's like on the highway?
- OBX intake manifold design
- Integra alternator question on obd conversion
- HorsepowerFreaks EVO w/GT35R (535whp, 421wtq on stock 2.0L) w/videos and dyno
- one bolt stuck, one bolt doesnt go in
- Please help... or the motor gets it. Follow up to vavle springs binding post.
- Building b16 for boost...
- Sputtering prob in 4th gear
- Looking to use a manifold other than Greddy Mani with 19t
- Efficiency drop from a puller to a pusher fan >>
- Need a good 3" cat for boost
- polls in FIwhats the best motor to spray direct port
- B16a+turbo+VAFC=WTF???
- 60mm for exhaust piping on turbo d good?
- dsm injectors
- Manifold
- DSM or knockoff Greddy Type S
- B16's with the GT30R...dyno graphs?...
- Thinking about turbo'N my D15b somebody help me with this set up??
- BOOST questions?
- what else do i need to complete my kit
- Lessoned Learned! Be sure your DAM fuel rail is on tight!!!
- Turbo Seals Blown? Oil Residue in BOV
- Does anyone make turbo LS cams besides Crower?
- Who wants to shoot me a F.A.S.T. standalone 1000cc basemap?
- 92 civic e-manage
- AC compatiable H22 TURBO manifold for the prelude, anyone??????????
- J-K tuning
- summit or earl's?
- Eagle H beam rods
- Free revving=bent rods=spun rod bearings?
- is my headgasket stuffed ?? 2 vids inside
- bkr7e's whats the highest hp before going to 8's
- Oil Leak on Return Line
- Stealthmode oil line restrictor to big?
- pistons in stock block
- Broken d16 dohc, what caused this?
- Which Turbos come in 5 bolt?
- civic radiator too small for boosted prelude?
- Cracked Block @ PCV Blackbox hole (DO I NEED A NEW BLOCK or will this repair hold up)
- POST YOUR K24/K20 DYNO NUMBERS...QUARTER MILE TIMES...
- can you use oem pan gasket with moroso pan?
- which of these turbo's would be best
- What gap are your plugs at?
- strong smelling exhaust...
- Anyone using an AEM 3.5 Bar map sensor?
- can someone explain to me why my dyno graph looks like this?
- PLX iMFD (simply amazing)
- Had colder plugs for nitrous, now N/A
- Ebay Special Turbo Kit Idea
- What do you high HP civic guys Run for Axels?
- K&N Filter anyone used the X-Stream Clamp-on filter
- Garrett ball bearing upgrade for T series turbo's?
- Boost gauge crapped out?
- Manual boost controller install. need help !!
- evo 7 turbo on my sohc vtec zc engine????
- ls rods for my sohc jdm VTEC ZC ENGINE?????
- GM 3 bar map sesnor neccesary?
- 494hp and 301tq with a stock gsr and PUMP GAS!!!!
- Funny FI video
- Opinions on sleeves
- Anybody Have a Stock SRT-4 Compressor Map???
