View Full Version : Forced Induction
- head gasket questions
- wideband replace o2 sensor?
- toubro my DA
- Coil on Plug and Fuel Efficiency
- Pressure switch from JRSC kit...is it adjustable?
- Turbo kits for a dx motor in a 97" cx hatchback
- Replacing the valve seat for Tial 38mm???
- Bosch Fuel Pump Question
- Precision Injectors, opinions please.
- map sensor?? what do i use for more than 11 psi
- How much power can this intercooler support? PWR Aero 2 intercooler
- injector differences???
- 450 dsm injector question
- XS Power Kit
- Evo 8 Intercooler Cost?
- «:::CAN I PAINT MY INTERCOOLER:::»
- Not a Honda but still cool...Turbo e30 BMW!!!
- Turbo kit....need some advice
- Some more cam + boost debate...cylinder pressures...
- intercooler piping *picture request*
- recent change in spooling noise. bearing???
- running SS line to turbosmart MBC?
- the best turbo for an ls crx
- TurboXS DTEC use wideband O2 Tuner for "auto correct"?
- b16 tranny 2 short for turbo??? please help
- Looking for chrome chipped ecu
- advice
- how to tell if a turbo is in good shape?
- has anyone ever used a 91-92 ish MR2 turbo?
- turbo shaft play ?
- problems after new turbo install...
- what gt30 turbo to get? help me decide!
- SC6152E (4bolt DP)
- Anyone use the
- need help deciding on what color couplers i should get
- wastegate problem
- Greddy e01 & aftermarket ems
- Future plans for my EF: To Turbo or Nitrous?
- G2 Turbo, HMT style.
- Important finding about adding oil during compression tests...
- LIGHT WIEGHT FLYWHEEL AND TURBO ?
- relocating wastegate on drag manifold??
- Lots Of white Smoke from the Exhaust...Help!!
- Ebay Turbo Kits
- Proffec B spec II, which wire?
- Pictures of custom internal wastegate after clocked
- What kinds of numbers should I be able to see?
- d16a6 & gt25r
- sc50 + h23vtec = insane spool?
- AEM EMS Questions
- Help with compression test results.
- VTEC problem with JRSC
- Integrate a dual stage TurboXS boost conrtoller into Neptune...Help please.
- help me convince my teacher that it is possible to boost high cr
- turbo advice
- tdo5h not running coolant lines....
- IAT's and knocking????
- Flywheel-Choice?
- S2000
- Eagle Rods 3/8 bolt
- tps sensor + detonation
- SSAC air to water intercooler
- strange a/f numbers even after tune.
- is it ok to break in with turbo?
- New build question! Running in built h22
- Anyone running the ZEX Direct port nitrous kit?
- 25 dollar electronic boost control solenoids!!!!!!!!!
- Gm 3 bar/S-afc settings?
- pre-boost check
- New Hit and Run manifold Design, lots of Pics
- need to clock used turbo, turbine housing is stuck!
- T4 Turbo Integra - built, but wondering what else I should do...
- 700hp eg alignment, clutch and tranny issues
- painting block
- gsr pistons in LS vtec turbo?
- How do i put DSM injectors on my teg?
- anyone who has installed the endyn breather with the motor in the car
- d16z6 build cost?
- Trailer: Fast & Furious: Tokyo Drift!
- Springs&Retainers: Suggestions
- Video: Tobay Fest 2006
- 5.5 psi and RFL bov
- Do I need valves and valve guides?
- AEBS Head studs
- can i run a gsr without an fmu
- 5bar map sensor with k-pro????
- EM for auto accord
- compression test...
- Question about cooling fan
- location for wb o2
- Plug reading assistance, looks like detonation?
- oil return line
- ? about ss auto chrome
- Charge piping and BOV quick question
- 67/37
- Advantages of GSR block over LS?
- Has anyone ran A/C fan all the times when car is on for turbo cooling?
- Does racegate flange accept any other wastegate ?
- Polishing Stainless?
- Boost Controller....
- swapped a head gasket, retuned stiffmeister's car, dyno chart inside! yay!
- leakdown/compression check. help me make sense of these findings please
- walbro 190 pump
- Turbo Setup help
- How much can a piston/rod LS block take...
- What size is the banjo fitting on the 92-95 D16Z6 fuel rail???
- Lawnmower vs Nitrous video
- built b20, what ar on 35r?
- b series turbo mani needed
- what size turbo should i go with?
- Heat And Carbon fiber
- At what point does te stock fuel lines max out?
- Oil feed line question
- Fluidampr pulley will not fit
- b18b compression readings and fmu's
- AiResearch T3 (.24/.42?) w/ internal WG - anybody have experience with these?
- ATTN: Turbo GSR owners. 300hp advice
- CP piston rings and locks
- Ring End Gap - I must be STUPID
- tranny choice for turbo gsr
- Just got kit done and tuned today......but sputtering and cutting out after driving a while?
- What caused this? Ignition problem?
- Turbo D16A6 with turboedit misfires at WOT but not part?
- cant get oil pressure
- Help afc hack pros, 3 bar map question
- detonation, why am i still getting it?
- T28 Turbo for a Honda SOCH ....d16z6 all stock
- problem with tunning 1000cc injectors to get it idle
- Video of my twincharged Ion Redline
- Doesnt matter any more, it blew up
- First engine part to fail stock blown boosted chime in please
- Need Help Hooking Up Oil Lines
- THERMOSTAT D15B help! WAAH!!!
- How Close Is Your Radiator To Turbo
- whos all running with a fmu?
- LS ARP Headstuds with GSR head ?
- Hot tanking a block.
- ceramic coating in the bay area,ca?
- msd timign master
- MBC install...
- Black Soot?
- please help me identify this turbo NeEd hElP t3t4 Q????? what brand????
- what turbo to get?
- how much hp can peak boost intercooler handle
- boost gauge
- Clocking a turbo
- s300 HELP
- Cat question - need help as soon as possible
- b16 head
- Any detriment to running 100 octane leaded gas (Avgas)??
- How much can a stock K20 engine hold?
- Full-Race Build: CSI Turbo Street Cobalt Update
- Catch Can: Breather or no breather?
- damaged chipped fins in turbo
- Has Anyone Used A T3/T4OE 46 Trim?
- next plan of action, what should i do? built motor, leaking... eek!
- Wanna build my 99-00 b16a2 for turbo need help...?
- msd distribturo cap/external coil work?
- What oil pans are compatible with z6?
- 3 inch DP fitment on an EG with Ram horn manifold...need pics
- noob question about inline fuel pump...
- WILL THIS WORK?
- Endyn Breather Tank Install
- new motor
- B16 rebuild questions need help....those who have done a rebuild
- FMU Question
- How do you hook up turbo vacuum for GSR?
- Can i run like this?
- anyone selling hondata? or chipped ecu?
- Will any obd1 ecu work?
- SC Numbers
- what exactly is pinging?¿?
- how can i check for detonation?
- LoveFab Excaliber 4 SALE
- adapter plates
- any higher HP manifolds that are AC compatible?!
- DSM piping to civic?
- Can you rotate the bottom half of the head on a tial wastegate?
- What the strengths and weaknesses of internally gated manifold?
- Anyone heard of CC-Fab? And any info on how could their manifolds are?
- Dry Nitrous
- 88 rx-7 460cc injectors work with little or no modification?
- GT35R .63 AR hotside. Why does hardly anyone use them?
- is a GT30 good for a sleeved 2.0l?
- Question: Highest Turbo HP on stock igniton?
- fuel pump questiion need help quick
- Mazda 3rotor, 3 turbos, really Weird, link with vid....
- Turbo Kit 95 Accord
- Looking for intercooler that will work with GReddy piping....
- RevHard Stage 3 - can you confirm this turbo, guys?
- Question about an Rsx TURBO
- GSR pinging
- Project LS TURBO finally done! =D
- WTF my HKS ssqv just fell off
- Suzuki Vitara pistons where to get them
- Resistor Box Question?..
- injector question....
- TurboElements.com **Great Customer Service**
- putting together a cheap sohc, vitara piston questions
- TRANNY WAS STUCK INPUT PLEASE
- A/F while idling... how stable is your idle.
- Which hub bearings to use with prodrive hubs?
- downspool...??
- Dyno Tuning Day in Mobile Alabama.....need some input/interest?
- Question for Ball Bearing turbo users
- Anyone using coolant lines on GT turbos?
- Running fuel pumps parrallel
- b16 ERL superdeck 2
- GT2871R on B16A2
- Just finished install....couple of questions, please help.
- wg dump tube size?
- anyone been to turbostore.com
- Light Clutch? Competition Stage 4 6 puck Sprung.... hm...
- best turbo for h22a?
- B17a1 Rebuild 2006: 400whp here i come!!!
- PINGING on JRSC D16
- Benefits of a knife-edged crank?
- OT: Anybody know alot about T/A ws6's
- POST PICS OF YOUR TURBO SETUP W/ AC
- It started... but i need help... please....
- host your car vids for free
- Type R turbo : GT28RS Vs 3071R
- Another DSM injector Question Please respond
- Goodies back from Full Race - HPC ceramic coating - Part 1
- High volume intake mannie for turbo d16
- sorry have to vent
- Whats Better for boost!
- SSAUTOCHROME...........NOW OFFERS CAMS!!!!!!!!!! LOL
- Turbocivic94 Build for 2006
- Precision 600hp FMIC vs. Spoolin FMIC
- confused about wastegate springs and boost levels
- JRSC + NOS 25 shot, Complete, need tune......
- What color/location for the Stock 02 signal at the ECU?
- T3/T4 STAGE III .50 .63 57 TRIM
- Anyone knows where I can get custom intercooler piping?
- Turbo making a strange fluttering sound when spooling up
- Anyone ever use an SC32 for a low boost (under 10psi) B18C1 setup? opinions?
- need spec for JE pro seal ring
- b16a2 turbo setup DIY
- anyone heard of this manifold?
- Questions on Turbo
- problems with wiring for autometer tach...
- blow off valve
- JDM B16 and Crome......VTEC Solenoid & VTEC Pressure
- Turbo cam vs. ITR/CTR/GSR cams..........
- turbo question
- ACT solid 6 in obd0 b16???
- GT40R w/H22
- Troque plate for boring?
- My top mount mani and a picture of the turbo.
