View Full Version : Forced Induction
- Does Rev Hard Warrenty their manifolds
- B&M Pressure gauge help.
- Tricks to installing Spiral Locks into pistons?
- Greddy Full Auto Timer Question
- Please post your idle and what fuel management/ injectors
- ecm code 13
- how many custom exhaust peeps we got here?
- All Turbomafia members respond....
- looking to buy a equal lenght turbo manifold
- Victor X
- Somebody asked about powdercoating...
- compressor side
- Updating turbo, should i retune??
- look at my turbo setup.. See anything wrong?
- Are LS and b16 tranny shims both 80MM
- Your thoughts on a t3 super 60
- Intercooler Question?
- Hondata 2b: is this all I need?
- spoon 2 ply/copper spray
- turbo sizing???
- Thoughts on the ZEX wet kit ??
- hondata basemap anyone?
- which hondata?
- Heagasket/idle problems......HELP!!!!
- TUNING hondata 2b and s100, Shopping List
- Well, any more news on The Drop shop?
- RX7 injector's
- place to buy a good clutch
- quick dsm injector help
- Need a pic of that dude standing next to that turbo that was like 5 feet tall
- tuning in jersey.???
- twin BOVs.How many people have them?
- Look what I got! ( SMC 500 )
- Hondata 2b --> S200 Need help cause I dont get this stuff
- Quick Poll: Which turbo for LS motor..
- Smoke out of exhaust when downshifting?????
- injector question rc 440's
- Compression....
- smc or smc +
- Prophets dyno # with our manifold and downpipe.
- which turbo garret or turbonettics
- If running an AEM EMS do you need an Apexi AVCR?
- High fow cat or straight pipe
- how much can stock rods handle??????
- What should I gap my rings at ?
- side mount intercooler
- how much HP do the DRAG intercoolers support???
- Question about msd btm.
- how to install DSM injectors
- Cam gear settings for a GSR turbo
- Are these going to work for F.I. application?
- turbo wont build full boost with filter????
- Need DSM injector wiring help!!
- T3/T4 Drag turbo ?'S
- d16a6 turbo buildup ?'s
- Anyone know of muffler shops around *DALLAS* that can make a D/P ?
- post your BOOST TIMING setups
- What is the best exhaust for turbo and is still some what quiet?
- lowering your compression?
- want the same spool time like now, but with more top end.
- Nitrous, timing and etc.
- Have yall ever heard of modifying a DC header for turbo?
- Hit railroad tracks now boost gauge reads max boost all the time
- What are these parts called?
- Boost pressure?
- t3/60-1 or t4/60-1
- rebuilt ZC w/t3 package $$ > ?
- Stand alone fuel management Simple Digital System (SDS) what you guys think?
- boost controller-greddy profec a vs. b
- Any Interest in a Bracket for Spark Racing Turbo Manifolds??? Click
- I've seen quite a few posts about thermal wrap lately
- Can this setup be accurate?
- ***your turbo setup preferance!***
- Super T collector design for Garrett
- internal and external
- r cams vs gsr cams once again
- JDM front with intercooler
- Supercharger vs. Turbo vs. All-motor..H22CRX help
- turbo manifold support brackets
- 400HP Top Fuel Mie Turbo ITR for $7000 on YahooJ
- stupid external coil question!!
- newbie post
- powertrain vibration, not sure what it could be, maybe in the clutch
- GSR Revhard piping with maxrev IC. anyone?
- GSR and turbo
- FMU 0r SAFC for boost tuning
- getting a used turbo kit what to look for
- The Turbo b18c Hatchy is done!!! 56k beware of the bling!!!
- b18b1 with JRSC....any good?
- Turbo problem...plz look in turbo guys.....
- JRSC civic video
- turbo + Y8 + afc hack = DYNO RESULTS! *pics up shortly*
- fuel line qustion ?
- How much race gas do you guy's usually take to a dyno session?????
- Profec B took a shit!!!! HELP PLEASE!!!!!
- question about EAGLE RODS
- Lightly Modded 4G63, NO Nitrous, 779 HP to the Wheels
- what Oil????
- difficulty starting car w/ dsm 450's
- big block d15b swap
- Pics
- b&M fpr?
- How to connect Hondata to techedge o2 sensor controller?
- MotorMatrix=Rip Off
- jrsc straight pipe
- HELP...what is this?
- safc teg wiring diagram
- Why so many haters on HT?
- Sad update again on the auto turbo Experts read please
- Shouldnt these have capasiters or something? (chipping for hondata)
- T28...T3...or T3/T4
- Dyno Tuning
- thermal catback
- DIY Controllers, Fuel and Nitrous
- Anyone use Total Seal Rings?
- Ignition Upgrades?
- Where is Motormatrix ?
- msd wiring instrucions???
- Going to E-town tomorrow
- DIsapointed2
- My AVCR/VAFC carbon fiber mount
- Part # for d16a6 one step colder plugs..ngk
- Gathering info on turbo
- Pulled out Sid at lunch time
- Drippin Wet.
- Golden Eagle headgasket and block problem...
- Look what happen to my oil return line...
- Can any of you guys help...shift gate prob
- Help me!
- anyone have a b18c1 hondata basemap for me?
- CEL problems with IAT and IAC
- apexi intercoolers
- st00pid turbo "kit"...
- OBD 1 P72 users...
- Where to buy new downpipe?
- any one make a manifold that is a/c ......
- question apex n1
- Can anyone help with finding some ARP head stud NUTS/washers?
- For you guys that weld
- Size pipe to plumb for turbo????
- Replaced Headgasket ~ problems.... (help!)
- boost cams for d16
- boost on MILD build.....L@@K
- How does the AFC Blue wire hack work?
- **extrude honing a turbo manifold?
- Progress on my D-Series.
- Iridium plugs
- anyone know where a good place to rebuild a turbo??
- Turbo setup underway, any help or comments.....
- Max-rev turbo kit, Max-Frustrations.
- question on blowoff valves
- Turbo and JRSC on FULLY built motor!
- Reflections on our Autronic
- Colder plugs or not so colder plugs, that is the question.
- B18b turbo at 18psi what clutch?
- Sohc vtec turbo??
- how do the injectors work...clips,cc???
- Project Silver Bullet underway...
- pre made oil return?
- Aeromotive FPR ? anyone know anything about one?
- Is the Tial WG supposed to come with an extra flange?
- Where to buy L.A Sleeves
- what size fitting?
- tips for relocating your alternator HELP
- 3" Polished SS exhaust intrest? Manifolds / DPs too
- turbo si 4 sale
- fuel pump???
- final purchases-help me choose
- What do you think of my Dyno sheet?
- I am SO upset.... is this block ok? (big pictures)
- size of oil return port on turbonetics t3/t4
- fuckin POS s200...HELP ME!!
- HELP..i'm runnin lean and cant' figure out safc
- Power Estimate on my Setup
- 647 whp DAILY DRIVER DYNO SHEET is up on original post
- Just finished mounting my Spearco Boost Gauge!!!
- Type-S BOV flange same as type-r?
- Best place for Air/Fuel?
- Stuff I got ...HKS injectors.. Apexi boost & egt and some questions
- Update on the good ol Automatic Turbo Teg
- LHT Performance IC for JR supercharger is here!!
- ATP Turbo Stage 1 and 2 for SRT-4 ****Dyno Graphs****
- ls/vtec turbo, deciding on what pistons/rods???? opinions !
- LS-GSR Tranny Questions?
- Does anyone have custom intake manifold
- Walbro noise???
- what size weld elbows forDIY manifold
- Has anyone tried the new NX NXL system?
- venom intake manifold and iacv questions
- 5 bolt vs 4 bolt turbo
- KS Motorsports Sales, News, and Announcements -- Lots of good info inside!
- FPR vacume line question??????
- does the stock oil pressure sending unit have to be hooked up???
- How to weld internal wastegate shut? (turbo newbie questions)
- throttle body question???
- Engine Rebuilt...Wont Start....
- Revised Compression Numbers
- help finding turbo kit
- Possible bad tranny??
- how much boost?
- Should i put my flywheel cover back on?
- rc injector, b and d series same?
- dyno charts?
- V-Afc hack on a JRSC Si
- Hondata Review (updated)
- Thermal Exhaust
- Exhaust opinions...
- this sux, why do I get 1 Bar with 0.45 Bar wg spring?
- B16 Lost Motion Assemblys
- fitting size?
- Please post dyno charts of Greddy 18G on LS... searched already
- Need Quick Answer on Leakdown Test Results
- 370's+aem fpr+vafc+255 intank+missing link=
- 3" Down pipe Problem.
- P28 or P72???
- Hondata intake gasket
- My new dyno numbers
- anyone with boosted hondas from kansas?
- who needs to go to dynospotracing???
- h23a boost kits...92 prelude si
- 54 A/R versus 70 A/R
- Need Expert Electrical Help... Hooking up alarm to turbo timer
- i hurt my motor tonight
- Philly 3/15 auto-x w/ B20 VTEC Turbo
- cracks in wastegate chamber, turbo usable?
- Honta-Tech represented in Las Vegas
- does this sound possible?
- Greddy EVO...Tanabe Medallion...Apexi...which for turbo?
- of now i have my WG and BOV vacuum source
- Please need Answer ASAP Going to use blended synthetic penzoil?
- Cam gears.... oil cooler?
- hondata tuning in Houston?
- A few trubo questions
- Dammed overheating again...help me follow this theory, tell me if its true.......
- Revised Compression numbers.
- Blow-off Valve sound bites
- timing?
- 500hp and little lag B18C
- New pics of my turbo EK4
- what kind of turbo exahust
- Reviving the dead...
- SoCal folks: where to weld aluminium for ic piping??
- cant decide which turbo to go with..and a few other quesitons =) please help
- Spun Rod Bearing
- Question about moroso oil pan?
- Manifold question?
- Friend Pissing me off, LS vs GSR turbo
- look what i found
- AWSOME Turbo Deal? But is it legit?
- installed my new turbo set up...a few questions
