View Full Version : Forced Induction
- skunk2 pro series intake manifold vs. 1st design
- cams??
- crx d16z6 turbo help
- Piston Help!!!!!
- gt3076r billet wheel
- changing internal wastegate on 14b turbo
- head gasket time!
- Best manifold up to about $500??? Inline Pro, SLS, GO-AUTOWORKS??
- catchcan + moroso exhaust slash cut + e-cut question
- d/b series boost
- Who Makes Custom Aluminum Mufflers?
- boosting D series help with turbo
- turbo lag?? and surge
- Turbo D-series spark plugs
- Fuel presssure regulator
- catch can setup/venting the valve cover
- h22/h23 throttle body wheel
- B18B with a DSM turbo setup?
- B20B Turbo Safety
- T1 Racing Turbo Blanket Observations
- what turbo for fast spool and 350whp max
- Boosting lsv
- fuel injector size
- Gsr Nitrous setup Hondata s300 help
- f22b1 build
- Passing Emissions with Greddy turbo kit and Blue Box?
- Need help!! Boosting Ls need help with vaccum lines
- pistons keep cracking
- Size of Injectors?
- Question before i pull my engine
- flat valves
- an fittings size
- stock b18c turbo smoke high rpm
- FREE G.E. FUEL RAIL OFFER
- Checking fuel pressure
- acceptable compression on b18c1--turbo setup
- turbo b20
- Which turbo to go with?
- F22B turbo ?'s
- y only 9psi on a 1 bar w/g spring?
- Charge pipe help... EK-DC
- B20V Sleeved vs B20v Dart Block
- Turbo Manifold
- complete loss of power in full boost, am i losing spark?
- RAMHORNS: A/C compatible v.s non compatible
- Wastegate spring 1,2 bar 17psi help
- any one have a review on this d series manifold?
- t3 or t4 turbo? 450whp lsvtec-t dd
- car cutting boost at high rpm
- 300whp on GSR Help
- Would a ACT Xtreme plate & 50/50 disc +300whp ?
- Which clutch for a b18c1 turbo 300hp
- OIl pump problem
- Quick sparkplug gap question
- What to build to hit 20 psi.
- Garrett turbo ideas for my b18c...help!
- oil pump ?
- Anybody using SCAT H-Beam rods?
- Anyone boosted a stock h23a bluetop? Dyno sheets please
- Twincharging setups
- 1997 Prelude Turbo H22A4 Build
- Best turbo for my B16a?
- how do i tune boosted region
- twin plate clutch help
- oil breather tank
- Eagle rods for B18c1
- Budget/junkyard turbo build for my Integra LS?????
- B16a turbo overheating problem
- I'm On The Fence B18C1 build for FI 330whp daily driver
- New to Boost questions
- B20v turbo build, shooting for 600whp on stock sleeves
- Whats this called? Is it helpfull?
- Owned a mustang today
- Anyone running a Borg Warner S372R with racecover??
- what trans should i use on my gsr turbo
- How reliable is a boosted z6?
- Need Arias part# from a specific Honda-tuning article.
- can you boost a dual point d15b1?
- best valve for turbo
- help me determine if skunk2 pro1's will be ok for my setup
- car burns oil at stop
- turbo comparisons
- restrictor for a banjo bolt ?
- Help Identifying Precision Turbo
- I think I'm coming back.
- opinions on my return line
- Maxing out id2000 @ 25psi? What's wrong?
- Wiseco Pistons Eagle Rods
- post your bilt boosted sohc's
- Engine has no power! Help!
- TRANNY SELECTION FOR 35r
- Top mount turbo manifold H22
- turboing, need some pointers
- 99 gsr boost!!
- gsr swap 96 dx
- Need some help/input on my new setup
- B18B1
- b18 continues to die when idling
- zex turbo spark plugs
- what injectors works best with E85 or what works best for you.
- Peakboost manifold on h2b?
- sc6176 turbine housing work on a sc6169?
- Wastegate touching A/C Lines? Why?
- Wastegate spring
- Setup adjustment Cam Gears, CAM ITR B16A boosted
- 88-89 civic/crx fmic pics plz!!! fmic's of all sizes
- turbo j35
- itr cam question
- Need picture/ideas intercooler placement
- h22 sleeving
- GSR Intake manifold swap & Why?
- BBK performance IM or Victor X
- Which compression pistons should I go with for my setup?
- whered you get your test pipe?
- Need throttle body advice for my boosted SI
- An idea for a “Sticky”
- Garrett GTX3582R???
- New Guy, Here is what im starting off with. Pics
- low altitude tune in a high altitude place
- Finally figured out my idle surge, now need advise
- turbo civic smoking
- Sleeper D15b7 Turbo Build!
- Going to build an LS-t could use some advice/input
- Cold Engine Boost??
- Turbo Setup Help Needed for a B18C1
- t4 turbo questions
- anyone tried the Ball Bearing BW's yet?
- HELP!! me troubleshoot, No start
- timing for boost quest
- coolant reservoir filling up..rad cap or headgasket?
- How to adjust JRSC psi on a delsol
- Im running Rich.... Help
- Do you have a strong opinion..lets hear it..b16 w/boost
- GSR Turbo 18g - j-ktuning.com tuned
- turbo kit brands ?
- Turbo question
- stock b20b turbo
- Burning oil
- any ls /b20 non vtec nitrous setups
- How much psi can you run on a B&M fpr can you get 500whp with it?
- Very First Turbo Build
- b16 turbo help
- Homemade Breather Set up
- debating
- ? first turbo d16z6 ?
- What's the correct fuel pressure for my JRSC?
- 2000 Supercharged Ls Swap F/s
- h23a1 turbo build
- Another one of those possible "Bad Turbo Seal" problems
- difference between d16z6 oil pumps? 15100-P06-A01 or 15100-P06-A02
- Turbine changed its sound to a higher pitch!! Why?
- b18c1 building bottom end for boost piston ration 9.7.1 or lower?
- 1st lsv-T build is this block salvagable?
- Build my PCV set up
- turbo on a stock engine
- d16a vtec/ turbo issues
- need some help with basemap problems
- Jackson Racing Supercharger On GSR
- walbro fuel pump going bad?
- Bad Tune or what?
- Turbo LS Question?
- E85 Gas Mileage Thread
- Drive Axles?
- Best BOV placement
- simple question
- Coolant leaking from exhaust manifold studs?
- Another dang catch can?
- ls turbo question
- Has anyone ever orderd from this company
- Feeler: Precision SC6162 PTB 300-6162B BB
- F-Series Block? - Need build input
- Big Boosting B16 guys
- 7 Headbolts stripped!!!!!!!!!
- what is the best turbo ramhorn style manifold for a 88-91 civic hatchback?
- another what turbo would be good for my goal.
- ::: Tuner Shop Search :::
- Integra gsr Thermostat question. need help big time.
- Aem wideband install
- is it worth buying NOS for my car
- 2.5" vs 3" turbo downpipe
- Map Block off?
- b16 block finished or can benson sleeve it ?
- Please help me identify my new turbo
- Dart Block Head Gasket Sealing?
- Go Autoworks and keeping A/C?
- where can i buy alot of t3 gaskets ?
- dsm injector seal problem, please help
- mini me turbo build y7bolck/y8 head
- Evo 3 16G turbo advice....
- turbo recommendation for B18C1
- Symptoms of bad/failing/sticking injectors? (RC Engineering)
- anyone know a shop that sells BISIMOTO AND TOGA parts?
- Need help on D16Y7(turbo) set up!?!?
- are thses turbo's genuine? Precision
- Nitrous help
- NEED HELP competition clutch stage 5
- Need help with 26 inch tall for s300
- new turbo manifold = new tune?
- Wheel chirping; boost spike?
- fluidampr race pulley info
- injectors
- dipstick problem
- Vtec Solinoid oil pressure switch
- POWER POTENTIAL HOLSET HX52 Fully built lsv
- Bad turbo???HELP!!
- Just An FYI On Fuel Pumps
- max whp for street tires?
- supercharge type r?
- random lean condition when coming to a stop
- When To Go Forged Internals?? B18
- Tilton Hydraulic release bearing.
- D15b turbo engine how?
- Turbo Manifold: Steel grade and sizes?
- Borg Warner S362 vs PTE 6262 DBB Billet
- Is a Garrett GT2560R too small?
- Need some help on my gsr build... any pointers?
- Choosing the proper Map sensor for you Boost setup
- HELP! need sidemount seatrails and sliders
- Vortech BOV problem
- New to H/T my project
- best clutch fro set up
- single turbo questions
- Muckman's 500hp Integra Hytech GT30R
- Comparing s2000 Turbo Kits
- So, i want to know...
- LS/VTEC Monster
- Afr question
- GSR piston valve relief height
- oil pressure gauge reads zero, do i need thicker oil?
- First turbo build...gonna have lots of questions
- Rod Bearing Problem Question
- Stoopid question...
- DeatschWerks Fuel Injectors
- could my eg pull on a carrera ????
- blew my apexi turbo need a replacement??
- fitting size?
- lookin for bare block
- pcv problems plz help
- Boost: retard timing by..? per PSI
- B16a with high horsepower in question?
- Breaking in a B18C build
- Turbo Exhaust header
- SOHC turbo vaccum line help plz
- Question about turbo kit
- Heating problems
- 3.5 turbo
- good bye cylinder 3
- HTA GT3794r any experience on fully build B series
- Where to have motor built in Arizona
- stock fpr with turbo
