View Full Version : Forced Induction
- timing on a new head gasket
- OT: looks like I'll be bowing out of the import scene...Look Inside
- AEM EMS Question
- HKS SS BOV c-clip help?!
- a pic of my motor
- Ot: Todays entertainment..hehe
- Hoping for 500+hp daily driver, need turbo help
- My b20/vtec turbo engine
- Stan aka FlamencoT
- best plug wires for $
- Where to get custom radiator?
- F.I. expertice needed
- I think my head gasket may be leaking..
- T25 turbo help
- Sucess! Hondata and MSD 72lb/hr injectors
- car is backfiring at like 6000 rpms... but not always
- F/S - Hondata 2B, P28 ecu (chipped) & Harness $750
- Difference betwen MSD and RC
- DRAG 3 Install pointers needed!
- A/R Ratio for T3/T4 turbo?
- RSX TURBO Manifold
- GB on oil cooler kit...ANYONE??
- VAFC fuel settings for 2000 Si w/jrsc, dynoed and tuned...now?
- Post your B20 non vtec turbo setups please...
- Post pics of your check valves or custom missing links...
- Boosted hard...got a CEL. Think it was a 10...anyone get this?
- turbo idle problem
- Anyone seen a J&S Classic For Sale?
- Delta II waste gate problems!!!
- Which fuel management for me?
- trouble boosting
- Oil in turbo
- Just curious; has anyone had any success with a profec A?
- F.S.....HKS EVC........Electronic Boost Controller
- To those with AEM EMS
- Where can I buy a stripped down B20 block?
- Toda B Cams in C1. Bad or Good with low compression turbo set up?
- Got my car tuned today
- exhaust for turbo
- How does boost affect top speed?
- which kit comes with polish charge piping????
- Need help with figuring out which nos kit to buy!!!!!!!
- crap, how do i install the bolt on the downpipe in the sharp bend?? MAV-REV setup btw!
- ....................Supra Fuel pump .................
- calling turbo h22 civics (if there are any)
- Do silencers hurt turbos?
- *New Products* Carbon Fiber Dash Benzel. What do you think guys!
- idle loping
- Can I use any housing?
- OBD1 to OBD2 harness?
- Switching from JRSC to Turbo
- Fprced induction videos?!?!?!?!
- Anyone have a part number for a resistor box?
- where can I get a good deal on t3/t4 turbo???
- How is your MPG/MPT?
- Chris C's FMIC group buy
- review of Pivot auto shift lamp
- Halmeter AF30> anyone run this?
- RC 310 Ijectors
- Opinion on Crower Econo Rods
- stock timing belt question...
- what BOV is loud but has good performance
- SFP JetHot mani and Crower rods for sale
- ? about sputtering type noise
- Need a Garrett 4 bolt DP flange ASAP - Where?
- can you turbo techies clear something up for me?
- What do you think of this muffler?
- b16 vs b18b which one better to boost after built bottom end?
- Anyone use the purple fin insert in an HKS SSQV bov?
- 95 gsr for $4500, is this a good deal?
- sticky street tires (for launching)
- hondata & ecu question
- CAMS: ITR vs Gude turbo
- Which BOV Flange do I need?
- Zdyne users/ question
- why do they turbos sound like this... ?
- Injector swaps & interchangability
- Painting Intercooler
- Aftermarket fuel pump needed?
- desktop dyno with B16A
- t3 turbo lag question
- race gas on turbo gsr?? (blue gas)
- 88-91 Civic STD exhaust manifold
- civic greddy blue box help ASAP
- should i get injectors?
- who was selling the custom 3" pipe?
- attn: SOHC VTEC Turbo Owners...
- Exhaust Question. Want to keep it quiet.
- I need a t3/t4 turbo!!
- Oil lines help
- B18B w/ JRSC??
- Please have a look at my new engine's compression test
- What's a descent intercooler size for.....?
- how often do you guys change your plugs....?
- ::i need turbo help::
- I got the flange already for the waste gate.. how much should i pay to weld a dump pipe?
- Where to get NUIMAGE turbo manifold?
- Drag III kit for a SI?
- timing question...anything bad possible here?
- compression after rebuild?
- Clutch Install $
- pic of my new ic and pipes
- Need install info on Apexi turbo timer in a 94Si... did search already
- 89 Integra ECU used in an 88 Turbo CRX?? Will this work ok?
- pistons and rods for b20.. what kind?..
- SFP Downpipe? Ya or NA
- What spark plug wires are you using for high h.p. applications???
- intercooler websites..
- dynos on turbo kits
- does anyone make a deltagate to a 40mm tial wastegate adapter?
- Need help understanding Intercooler dimensions
- Attention Engine Builders..How is an engine balanced?
- Help: Problem Starting Car with Hondata
- sidemount intercooler pics anyone?
- Best turbo for my application?
- which size a/r to get?
- how to tell if injectors are saturated or not....
- integra FMIC question
- Turboxs RFL BOV
- clutch question
- -8an feed or -6an???
- Apexi Gauges
- question about aem fpr
- Any interest in Greddy boost and fuel guages?
- what cc are 24lb, 36lb injcetors?
- AEM EMS is here!
- Problem with Oil Pressure
- STR Pro Drag Intake Manifold, will it fit a B16 Head?
- Thinner Cooling fan???
- Dakota Digital gauges...how accurate?
- car broken into 2x in 2 nights! dammit!
- just installed turbo kit, runs crappy. HELP!!!!
- anywhere to tune in ny ????
- Serious question for nitrous techs..........
- Drag kit for LS or GSR??
- fmic will i need to ............
- Would i be able to change the turbo?
- another detonation question and i need help to resolve it.
- Extracting existing ECU maps into Standalone?
- GB on inline pro headgasket...when??
- Guage ? Greddy or Apexi
- When can we get another FJO Wideband GB?
- For all you b20 vtec turbo plz help
- new engine question--forged internals
- joined the darksidee..... few problemmsss
- Pics for Engine bay
- Skunk2 Exhausts w/ turbo, good/bad?
- Propane injection?
- Got a rod question?
- Anyone have 5th gen turbo ludes
- HondaSaver took my money!!! (pics)
- Fuel Pressure help!!
- What is a good fuel pump to get for boosted imports?
- Garrett GT30 vs Garrett T3/04E .57 trim pics
- fmu question (black fmu) ??????
- You gotta see this!
- Question about my miles
- Formulas for ideal turbine wheel and housing...
- Spearco water pump VS. ?????
- Who wants a air to water intercooler fo a JRSC??????
- t3/to4e compared to HKS gt2540
- wastegates???anyone got for sale
- Ok is this a resonator or muffler?
- Anyone have SMSP's webpage and/or phone#?
- Which type of clutch to get: Metal or Kelvar?
- New intercooler
- Engine rebuild Success!!
- how much boost
- Jackson Racing Detonation
- 18's with 15psi ?
- the pros and cons about Maxrev and inline pro.. MANI'S..
- Which would you rather do
- problem on AEM EMS board
- Max Injector cc for Stock ECU
- damn exhaust leaks...
- FMU and boost
- anyone's AC acting up after a turbo install?
- Group Buy on Greddy 660cc and 720cc Injectors
- Can't get bumper to fit on properly
- Where did you mount inline pump?
- turbo, 2 bar map sensor, and a v-afc...have a question.
- Procedure for tapping EGT ?
- Ignition faults or whats going on? help asap!
- OEM Fog light clearence with Drag intercooler on 99-00 Si???
- Does anyone have a spare T3, T3/4 turbine they want to sell? Anyone?
- Mugen Twin Loop W/Turbo
- peak and hold vs. saturated injectors
- this question is asked every week, i'm sure.
- Is this head repairable? Please take a look.
- intake fans
- Greddy Turbo *Blue Box* Need wiring
- Check this out, will this affect anything?
- need pix- spearco liquid>air IC
- Anyone know a car dealer? Need help getting my turbo.
- $5 boost controller question
- Acura Integra GSR and VTM signal
- Here's how to run 450cc injectors without a VAFC
- Can you guys help me out with my setup?
- b16a2 turbo kits???????
- Recieved my Garrett GT30 BB turbo
- cams and turbo?
- Jrsc
- Boost gauge line
- Where can I find Info On Homemade turbos
- ARP head studs for the h23a
- Where do you buy your BFG DR's???
- turbo kit for preludes
- Anyone in the Central Florida area have either aem or hondata tuned by a shop?
- How big is the a/r housing on the f-max turbo kits on their turbine and compressor side?
- Is high compression possible for a daily driver?
- your G-tech test results --> post here!
- AEM Tuners in IL?
- Anybody use 720cc injectors on their daily driver?
- wanted to trade: 99-00 OBDII-I harness for 96-98 OBDII-I harness
- Custom intercooler piping
- Anyone interested in another DSS axle GB
- Engine Piston - Rings / Rod Clearances for FI Rebuilds HELP
- Dalton Sleeve install gone totally wrong maybe.. HELP
- Defi BF boost meter installed!
- Where can i find some RC 550 injectors cheap?
- BB turbo's....any others then the GT's?....
- thinking.....Tial WG....Iron mani....no flange....?
- b20b into an ek.. shopping list?
- Spark plug help
- 60-1/t3 or t04e/t3??
- High Flow Cat.......
- blitz egt gauge. anyone ever install one of these?
- How much room in front of the radiator?
- If I get the skunk2 manifold, should I upgrade my TB too?
- turbo question...finally redline my car
- Does hondata make an intake manifold gasket for the b18b?
- wastegates and boost controllers helping spool up times.....someone please explain.
- Clocking a turbo
- intercooler pics please !
- BBK 62mm TB
- Custom turbo
- Adam Hudson
- how hot does your water temp run when under a lot of boost
- how many of those who have FI cars has not blown motor
- Turbo/SC
- Problems with profec a help please 'CH' alarm wont go off
- Boost of 3000GT, TD04 turbo
- Anyone ever snap their belts when boosting?
- h22a integra, turbo? NA?
- Which Spark plugs ?
- Again another interesting OT post...
- correction: torque specs of Eagle rods for b18c1
- Where do I attach my guage's ground wire to?
- octane boost.... really works or really sucks?
- Has anyone every tried one of these?
