View Full Version : Forced Induction
- z31 300zx
- I need help! RS Machines had has my block for over 4 months! (VERY LONG)
- Engine Temps and Spark Plugs..
- anyone know anything about a te04h?
- **** BOV flange interchangablity list ????
- Needing some help!!!! With a boosted h22, Vaccum lines needed badly.
- Sleeved B20 or Dart block?
- Water Temp Sensor, shot out of my block!!!
- Ingalls Torque Damper
- Stock Ignition system?
- Those that are running the power fc...
- Full Race Turbo
- Major backfire from Digital 6 and 2000 si turbo
- how to clean a turbo?
- Question about DSM injectors
- DIY Dyno, only $235!!!
- If i have hondata, i dont need a FMU correct?
- anyone use Exedy Clutches?
- q for anyone with a turbo kit
- Inspection (New Jersey)
- 600cc Injectors, How much WHP are they good for??
- h22 buildup Eastcoast..
- I got ripped!!!
- PSI on stock B20
- Do factory oil pans have an oil return?
- MN people... anyone have a Wideband 02 for rent/to use?
- In what situations would ITR cams provide a better powerband over GSR
- Compression Ratio Help!!
- I heard something today about my hf
- rally cars bov's
- Those using Zip's SMC Product ?'s
- rev hard ls kit
- South Florida Performance mani w/Greddy TD05...Will it last?
- another block guard, but who has seen the power
- just tuned with uberdata.. a couple minor problems
- Whats the difference between High Imp inectors and Low Imp injectors??
- Boost Controller and Regulation
- Whats up fella's, I am wanting to see some SI's with a/c and BOOST
- Anyone use multi electrode spark plugs??
- who's runnin stock block 300whp setups?
- How much whp can this block handle?
- hey new to boosted hondas can i get some help???
- anyone using garrett gt35-40R how good are they
- Can Anyone Burn me a Hondata Basemap???
- question about GSR tps for Nawwzzzzz (need help quick)
- wiring diagram for emanage 2000 civic ex d16y8
- Hows this setup for an LS?
- turbo help...
- Where can I find the cheapest 3" flex pipe for downpipe??
- Turbo Timer Question: Searched already
- PICS OF MY PROGRESS!......
- 7psi with big turbo diff as with small right?
- ooooohhhh Pics of my new toy
- i'm out for a while....... built H23 cooked
- dsm smic mounted in front... anyone done it?
- Fired up my car for the first time...
- A few pics of a car a friend and I have been trying to turbo
- any setups simular? need help thanks.
- Need some help with some boost issues...
- Anyone using Turbonetics 62-1?
- Question with HONDATA 3B ! (P72 -> P74)
- stock gsr valves?
- urgent plz help,, simple stupid question.
- A little intercooler flow help
- radiator problem....
- Crower Billet Rods and OEM BEARINGS
- Rev Hard vs. Drag Kit
- GREDDY TURBO TIMER HELP!!
- which spark plugs with zex kit
- Ls turbo question
- Help with Speed sensor wire coming out of 95 Civic ECU!!!!
- Ubertuned h23 question?
- D16 Turbo or B16a n/a
- Greddy Profec B Spec 2?
- HELP! DOES ANYONE KNOW WHERE I CAN BUY A HKS STANDARD WASTEGATE SPRING??
- HELP
- msd 6btm and ignitor problems
- Boost gauge maxs out when spraying...weird??
- Spark Plug Change
- Turbo Build-Up PUMP gas check-in...what you making? all series engines appriciated!
- Too much torque.....
- Fully built turbo motor less turbo to pass smog?
- guys running a JG IM .. Question..
- volvo turbo??
- When to turbo after rebuild?
- am i in deep shit?
- neukin manifold????
- Crome, TPS enrichment and long term fuel
- advice needed from experienced ZC turbo head...
- Nitrous Built D Series. $2200 Limit, Help me out
- My LS Turbo is slow.... help!!
- Help please, CEL + running funny as hell.
- Turbo d16z6 questions
- Rough idle b20/vtec turbo????
- Need the set screw size for AEM FPR.
- this motor better blow - part 3
- Turbo Timer wiring question...
- does the t3/t4R "big kahuna" need to be placed opposite if you have A/C
- how do you tell the difference between small and big tial wg springs?????
- ls turbo piping?
- can i use rev hard sohc downpipe with ssauto mani?? plz help
- cheap ebay wastegates???
- AFR, fuel pressure and timing on boosted ITR
- Another ls/vtec or ls boost ?
- Black smoke when in boost
- pipe of Greddy turbo kit
- boosting a stock b16
- profec b settings
- She's coming together - B18C, Lovefab and T04R...pics***
- Searched to no avail, SAFC HACK WONT START
- some turbos have a CONE inside the turbo on top of the blades ?
- turbo DA how to... need help..
- Doing a bunch of maintenance at once. What order to do it in?
- Slow spool time...help?!
- Tial Wastegate & Boost Controller Question
- Oil catch can???
- is this turbo too big?
- Turbo problems, please help
- 189k + Rev Hard kit???
- EAGLE RODS WONT FIT FOR TURBO SETUP...NEED HELP!!!
- ls/vtec turbo sizing?
- will some one please help me make an uberdata P28 .Bin Map for my Z6 T!
- Overheating: Big intercooler blocking my radiator?
- Help! My setup is overboosting..
- JR cahrger set up ??+vafc??
- Block fitting (Oil)
- air to water intercooler vs air intercooler
- compression numbers after rebuild
- b18a1 fully built and about to boost need info on fmu
- Strange noise from around the intake manifold
- Revhard install in progress...how's it look so far
- BEST NOS IDEAS FOR B18B1 IN A HATCH SETUP....
- oil feed problem with 60-1
- Square Water to Air Intercoolers? Anyone know who makes them?
- GSR-T project
- areomotive fuel pump install question
- Built motor startup problems
- engine builders (eagle rods on b18b crank)
- Finally my H22 turbo dyno in my 93 civic 4dr!!!!!!!!
- 3 Bar Map
- greedy turbo question?
- what stuff are u using on your ls crx turbo?
- H22 transmission mounting issues. Please help!
- code 23 obd1 knock sensor have a question
- intercooler
- need help identifying turbo
- Just a pic for the turbo guys to cherish
- AEM EMS hi/low boost switch?
- How to prevent Boost Creep??
- Multi Coil Ignition using the AEM EMS?
- how to do a 91 accord h22 turbo swap?
- EGT????
- ****HI pitch scrapeing noise left front susp.******
- wiil the autometer pressure sensor fit the greddy sandwitch plate
- injector size for b18b jrsc
- full race/manley turbo tuff rods
- Tech Question About 2.5"-3" flared dp
- hey is this a decent turbo kit?
- cant adjust fuel pressure below 42psi?
- To Turbo Doctors Help
- about to turbo my car, have a thermal n/a exhaust, can i run this with no problem?
- turbocharing and supercharging at the same time
- a/c wrap neccesary with greddy turbo kit?
- installed walbro 255lph fuel pump....what psi for fuel?
- FI on jdm motors
- Need help rich running turbo but horrible low end torque
- is there anyone that has a nos on a stock engine?
- car dies when you let off gas
- turbo guru's : All the sudden not getting any boost ? WHY ME ???
- Hondata + Deceleration = KABOOM "I blew my motor up" Long
- DYI cowl air at its best :)
- PWR Radiator Cap?
- Injector install question.....
- bad oil pan tap = white smoke
- question about making power after 8000K??
- Is it OK to drive around without the intercooler on??
- What WHP are DSM 450's good for?
- Could a 3" open downpipe cause a 5psi boost creep?
- Timing question... Low compression/Big Bore B18C1...
- Filter Question
- Are All PWR Radiators Dual Core?
- Falken-Aze. or BFG-Gforce???
- My turbo install + pics (56k sorry)
- dual core or single core radiator
- B series forged? D series forged? forced induction?
- colder spark plugs for turbo honda? d16? denso iridium?
- how likely will a too big of feed line make my car smoke?
- Where are turbo seals?
- need help with hack
- civic turbo
- vacuum lines of avcr
- ls turbo?
- witch is safer?? 75shot? or 12psi boost?
- Just bought an EG w/ LS motor, need some opinions
- running Zero lbs of boost cause engine problems?
- what would be a good sized turbo for a M3?
- bent fins on intercooler
- Just got back from Track ...
- Headgasket or need of ARP headbolts
- ARP headstuds ??? z6 block - y8 head
- what spec will i need to make on my valve adjustment....????
- No start after OBDI changeover- code 41 ?
- Need wastegate recommendation!
- Zex Dry Kit Spraying More Than 75 Shot?
- MSD6a QUICK wiring question,HELP please ASAP
- installation of AEM UEGO WB w/EMS...need quick reply.
- check engine only at full boost ::need help!::
- NOVA: Big Race Last Weekend in the area?
- need help tuboing 2000 civic si
- Greddy put a restrictor plate on their B18C kits? WTF? Do I take it out?
- Tempest Racing
- Back to n/a she goes
- when to upgrade ignition?
- Full turbo rebuild including bent fins?
- D16z6 Total timing
- Anyone have that pic of the Intercooler Duct-Taped to the hood?
- Boggin' like a Mutha!!
- Whats the best bang for the buck fuel management?
- compression test 210 across but still smoking???
- Civic EX 04 Tyranny cost?
- NOS tips on a automatic 04 Civic EX.
- Who has re-torqued their ARP studs and they weren't the same?
- suspension setups.. need your advice and setup
- stumped! boost guage reading off?? please look
- pump gas ?
- Driving my car cause i just got my turbo tuned and everything by AutoWave and my radiator cracked H
- t3/60-1 and t3 super 60 the same turbo?
- 3" Muffler - which one is quiet w/o robbing too much power?
- wtb B18C RODS
- making my prelude fast
- post your vid here!
- Missing Link
- T3 .60intake/.48 exhaust Questions
- Boosting and Vacuum advance engine.
- B16 with individual throttle bodies....
- dropping compression, what size head gasket? h22.
- B16A how many HP with stock sleeves? when better darton/benson?
- wastegate vacuum QUICK question
- Not Boosting As Well
- safe settings until tuned
- retarding timing when VTEC kicks in?
- Greddy 18g turbo Flange???
- install is done!!
- supporting turbos and wastegates
- Question about using AFC as management
- which head gasket?
- Street turbo for integra gs-r XS-Engineering?
- Boost control buttons and or 2step on the steering wheel? Questions
- How to compression test motor that is not in car?
- sheet metal intake actual gains
