View Full Version : Forced Induction
- What are you guys mounting your Precision IC's to? Pics requested.
- Looking for rod bolts
- issues since popped headgasket - timing? fuel pressure reg? ls/vtec turbo
- Wiseco piston
- Just came for from dyno. b16 built low numbers. AEM boost controller .?
- Manifold for evo turbo?
- Can not make up my mind.......
- Need locations of shops in SD
- Help, JRSC on b18b in dc4....will this intake fit, you think?
- tail bov ?????
- zex dry kit *help with WOT switch*
- interchangable rods
- 10 minuet drive..
- manifold to turbo fasteners keep getting loose
- crower stage3 bad idea for turbo?
- tuning sat dyno sheets and pics here
- any in take pump good for 600-700 hp?
- How much to use?
- dump tube length
- BOV's don't function on low boost? true or false?
- All Motor Cylinder Head With FI??
- AR's???
- H22 replacement sleeve strenth 90MM bore???
- 1/4 estimate... went 11.9
- Tire fitment question
- axles
- Help with force induction forum rules
- AEBS T-Sleeves can they handle a .5 overbore??????????
- QUICK CLUTCH QUESTION.....
- Free turbo give away round 2 drawing finalists
- New - Few questions
- FI NOOB and NEED ANSWERS
- Vortech SI Tuning
- 18g turbo oil leak
- Civic half size radiator, oem used dual core or ebay $40 aluminum single core?
- Good tuner in van, bc?
- GSR project.. opinions
- to vtech or not to vtech
- HELP nx nitrous direct port
- Nitrous and Agressive Cams
- what is wrong?
- Need some help on a turbo setup. Lancer evo turbo.
- Upgrading to Vband exhaust housing....
- Vitara Wrist Pin Install Help!
- turbo kit on 91 integra
- b20 questions
- turbo question??
- 4" DP Tooo Much?
- safe boost
- ECU Question Turbo -> JRSC
- exhaust setup
- Clocking Carrier On Turbo?
- dump tube emissions question
- hp restriction???????
- arp head studs?????
- which NGK spark plug for turbo b18c1?
- turbo questions
- What do u guys think of this manifold?
- I NEED HELP PLEASE {D16.B16,B18,H22
- omni vs supertech
- Jackson Racing Supercharger belts available! 3PK1220 Bando
- need some help
- Help...need transmission advice for turbo build!!!
- Turbo Manifold- cant not enough space to put on all the nuts...
- rev speed turbo kit
- cleaning the inside of an intercooler
- metal strap that holds chra to exhaust housing...
- Boost goes up then backs off
- 114 octane to make 500+whp??
- Garrett 57trim turbo question
- PIPING...
- 500+whp Possible?
- need info on srt4 fmic
- so i got thhis topmoung because im trendy
- What upgrades will i need to have when i upgrade to a turbo kit?
- need help with emanage data was erased
- Fuel return hard line ???
- b18b w/ direct port setup
- Where have you all mounted your Intake temperature sensor???
- :::: EQUAL LENGTH MANIFOLD :::::
- Balanced Performance in GA, opinions?
- Cut blow off valve spring?
- boosted b18c or b18c5
- jrsc question
- What tranny should i go with on this setup
- ECU Wiring HELP!!!
- how many hp can 440 injectors hold???
- Blown Motor pictures
- H22 catch can install drilling valve cover baffle blow by search friendly i know i know
- Couple of LS turbo questions...
- BLOX TURBO CAMS QUESTION...OPEN THOUGHTS
- multiple gt35r questions
- How much should I pay for a motor build?
- wastegates
- finally got my stock d16z6@10psi dyno'd...
- lovefab mini-me or mini-me eq in a prelude...does anybody have pics
- Need Gasket, SC61 to downpipe URGENT
- PROBLEMS PROBLEMS!! Please Help
- d15 turbo setup and price range
- K&N air filter for turbo, what model do you use that flows enough?
- Wastegate Spring colors, Im posting them here as I do reasearch
- fuel pressure for 8 psi JRSC
- Can I use this vacuum port?
- Turbocharging a D16Y8....help?
- A couple questions
- Jay Thornton
- 3" exhaust piping?
- Aeromotive FPR on rail???
- Question regarding turbo exhaust??
- Stock Internal b18c (GSR) Reliable WHP
- gsr
- yah another oil pressure ?
- D15 thrown rod
- Blow off Valve
- Dynoed my ls vtec Graph inside
- Nitrous Queston.
- VIS carbon fiber hood clearances
- Spray on my B18C
- New Setup Ordered. Forgetting Anything? Comments? Couple Questions.
- Quick response, question about my sohc
- should i thermal wrap my apexi turbo mani?
- thread pitch on oil pressure sensor?
- Rev Hard B Series Custom Tubular Manifold REVIEWS Good or Bad?
- timing for turbo
- Motorola 3 Bar MAP Sensor Install
- 50 or 57 trim
- HKS EVC Boost controller: learn function almost blew my engine!
- Thank You RLZ/Speed Innovations!!!!!!
- Intercooler Piping
- b16t head assembly help???
- Please help with new build questions...
- oil pressure problem
- manuel boost controllers vs electronic boost controllers
- dynoed my ls vtec turbo
- Any of you guys run without ARP headstuds,and have no problems?
- Same WASTEGATE , different MANIFOLD = different BOOST ?
- what clutch??
- b20/vtec turbo build, couple questions
- My garret T3/T4 .60.63 turbo, is it busted?
- What to get to hook up pres. sensor,oil feed,and oil pres. gauge? Block fitting,or something else?
- Where to find a 2.5'' Intercooler Piping kit for Civic?
- F22 boost level
- how do i know what my car is tuned with
- My first real turbo build....
- ><>>>< TURBONATOR!
- how to instal a missinglink
- flash and burn "addressing in hex"?
- Turbo prices
- middle of 2/3 sleeves has .003 clearance... mill it?
- Any JRSC'd GSR's out there??? Help me out!
- JB welding a BOV
- What setup do ya'll suggest?
- Car stolen in waterbury, CT integra turbo
- p14 hondata s300
- what resistors to use with Precision Low Imp 1000cc Injectors?
- Question about GSR turbo piping and edlebrock IM?
- OS Giken Twin Disc Order?
- which boost controller for my setup??
- turbo and heavier wheels/random ramblings
- Turbo mainfold pipe diameter and length
- Critique My Setup
- new setup need input
- Portland, OR - Torque Freaks Dyno Day - Saturday 3/31
- need help with spark!!
- AF Performance and SC Tuned
- Looking for a valve lash write up
- Powerloss for a split second right before vtak
- Mahle gold series pistons in sleeved H22?
- necessary to run ARP HB, Cam gears etc, help on fuel system??
- Need d16z6 build help
- b16 what i need and how much
- New to boosting need opinions
- are there and boosted DA's and/or ef's with AC
- nitrous problems
- Planning out my fuel system, input appreciated
- getting ready for turbo install :)
- crome tuner in sc
- about to change my head gasket
- T3/60-1 VS T4/60-1
- Why oh why won't my D16 die!!!
- Coolant lines for turbo
- best place to buy an obx diff?
- need help finding right turbo rod
- arp headstud/head gasket
- Another Injector Question :(
- full-racetopmount or didvided mergecollector topmount
- H22: Questions about Boring out Intake Manifold to fit larger TB.
- What pressure plate for 400hp integra
- Umm, im confused
- It wont start!! Help!!!
- water temp gauge
- i got a Question about aem wideband
- Aem 5bar map sensor on hondata s300?
- Quick initial startup questions regarding injectors.
- catch can install help search and got confused
- wat do you think about this turbo?
- turbo + fuel injectors
- Need some help with crankpulley
- Nitrous + Sort of High Compression ?? (safe)
- Where do you guys suggest looking for....
- S-max Speed max intercooler
- such a ghetto turbo install. . . help badly!
- oil leaking to the outside
- What turbo to run?
- vtec stays on?
- What turbo should i use!!!! everyone chime in!
- o2 on my gsr downpipe
- Smoking at weird times but very consistant. engine or turbo?
- :: Quick LS-T Question (What size turbo for 220whp/quickest spool?)
- Turbo Pistons
- Any tuners in Norcal that tunes Turboedit??
- 480whp video
- Manifold to turbo bolt keeps falling out - Will threadlocker red take care of it?
- LS/V TURO HELP!!!!!
- best ecu b16 n/a eg hatch?
- For those of you using TunerToys oil pressure sender fitting...
- b20 crank pulley--JRSC
- manifold rattling
- good compression ratio for about 20psi?
- dump tube....
- Another single cam - Almost 400hp
- I was just wondering.
- vitara pistons
- MAP sensor pinout question
- People with Venum Intakes post up your throttle cable setup
- 2JZ 240sx Ver3.0
- 97' civic Greddy Turbo timer No harness? can i still install
- what happened to my turbo?!!!
- what options for h22 mani/dp?
- overheating on hot weather only because my intercooler too big
- put the bottom end together last night...
- GSR Girdle on LS Block? How to......
- Need help ASAP!!!
- What kind of Nitrous shot to put on a stock Ls/V-tec????
- D16Z6 - JRSC w/ Stage 2 Boost Upgrade?
- Budget manifolds? Others besides Inline Pro..
- Anyone know why these two 3071s are so much cheaper than the rest
- Which head/block for K20/K24 hybrid?
- 2step, launch control, anti-lag...
- Will the new e92 block have issues with FI??
- Electric supercharger
- turbo installed = horrible smell?
- Accusump???
- Single Waste Gate or Dual Gates? Top Mounts
- surging idle with stage2 cams
- Did my turbo blow its seals??
- aem wideband
