View Full Version : Forced Induction
- Decisions decisions...
- TurboCalculator.com reliability... some problems with buying a turbo from them.
- How do you rotate a central cartridge?
- boost on low compression vs. high compression
- afc hack + emissions
- South Georgia Motorsports park &Pictures of my car at the track
- dsm turbo, b18a, CRX
- Cant boost over 6psi
- Do you need block sleeves to run 450whp?
- turbo b crx with ac
- ignition timing ...need help (to retard)
- intercooler
- Are there any D15 Turbo setups out there???
- How to identify a used ZEX 59300 cam ???
- What sleeves are these ???
- turbo VS Supercharger
- anyone with 500+ and 17's (DD 10-15 miles a day)
- fuck snow, fuck using a turbo car as a DD
- how much power you all making with stock GSR rods (maybe add in arp rod bolts)
- GT35 or GT30????
- hondata ecu options
- boosted 2nd gen
- how did you like you're 60shot???
- Oil Line Kit. Whats Missing Here? *PICS*
- Garrett GT35R (GT3540R)
- if your making over 500fwhp
- Low impedance injector drivers in the Honduh ECU
- toyota ct 26 turb ona B-series?
- Choosing valve train
- muffler shop downpipe.
- New Wide Band O2 Sensor?
- horsepower b16
- Lotus Elise turbo kit...
- Can any identify this intercooler?
- smaller turbo higher cylinder pressures?
- AEM EMS Tuning Available (JDogg + Crew) January 13-15th! (New England / Massachusetts)
- OBX turbo mani's- good/bad?
- Clutch for my turbo gsr.
- SI D16Z6 or LS B18B??? going custom Turbo...
- injectors--resistorbox??/ do i need it
- New motor build strange problem.
- Oil return line picture needed?
- The autistic guide to aftermarket piston and rod instal? (aka i need help)
- Precision SC61 Turbo specs?
- cx manifold to t25 adapter
- tuning vafc2 for turbo?
- 2 q's - tial wastegate, and losing boost...
- who has ran a blue box?
- I have searched but no luck need info on a good turbo for my needs???
- Hondata Tuner in AZ (already searched)
- My EVO8 boosting *Video*
- >>>> Replacement rings for Wiseco pistons ??? <<<
- Q: built vs stock motor under same setup?
- How much diffence swithing a 14b to 16g HP wise and other ?????
- Downpipe gasket
- GREDDY E-MANAGE ECU ENGINE FUEL CONTROL UNIT
- i searched.. nothing... EBAY intercooler
- Got my car dynoed 231hp/191 tq and want to make more power should i get a new turbo?
- half radiator questions
- Greddy blue box work if using Missing link or check valves for MAP??
- Which BOV Would You Use?
- JRSC or Vortech?
- I need help ASAP guys, Boost H23.
- Please a little help for a newbie with FI here B16A1
- ECU Socketing difference between Uberdata and Hondata?
- d-series manifold
- Just got back from the DYNO @ DRT Racing in Queens, NY
- 94 to 92 Octane
- Hondalogger + mac
- 10.5:1 pistons and thicker HG
- Finally! EFI 101 and ADVANCED in TEXAS!
- now THIS is a supercharger
- Gauges What do you prefere and what work best in your findings/opinion
- y my built engine smokes?
- Is anyone using the Cybernation Gaurdian?????????
- EG chassis intercooler setups
- what problems did you run into when going turbo?
- our newest project vid (not a honda!)
- BBK SSI Manifold on turbo B18C1......slower???
- What #'s to shoot for? Built b16 for Semi-Daily Driving
- How high are you revving? *boosted B18C1's*
- Which valvesprings/retainers?
- Idle adjust on C20AT (V6 2.0 turbo) engine
- Blox intake manifold...?
- help me identify JRSC parts
- what length/bends for a 14b on b18 hatch?????
- DFI Gen 6th tune disc --- NEEDED
- 190lph Walbro fuel pump enough?
- greddy manifold modifying
- Yes or No question
- difference between ZEX and NOS kits....
- a question on rocker arms
- to4b, drag manifold, spearco front mount, 750's with hondata. projected whp?
- Secondary Fuel Injectors
- map sensor relocation
- What are your street/strip (SFWD) cars using for brakes?
- Tuned Greddy 18G, whats wrong? help
- Weird Oil Pressure Reading.
- 45* or 90* oil return fittings???
- D16Y8 Turbo Kits
- Dart Block and Girdle???
- safe to start?
- Pistons rings???? PLease help!
- what injectors 300 hp?
- lil weekend project dyno! 9 psi
- hondata work with DSM injectors?
- What is needed to datalog with palm? (hondata question)
- Turbo question?
- Difference between a 2.5 inch downpipe N 3"?
- how to tell a gsr crank
- Oil Consumption & Shaft Play?
- Building RSX S on boost what should I do??
- You guys think this is a good SETUP?
- to guard or not? blockguard thread
- act clutch recomendation..and advice needed urgently...b16
- 8" JRC installed.
- Whats The New Bandwagon for 2005 ?
- New JRSC setup
- RC 750's too big for LS/TURBO@10 psi?
- .::My New Nuekin Manifold::.
- where to set my safc baseline % single cam
- skunk 2 turbo cams?? good or bad??
- sneeky peetie bottle??
- JG intake manifold worth ithe cost on a B16A?
- 270degree thrust bearing vs a 360 degree thrust beering
- opinions on my winter project build for b18b turbo
- omni rods???
- who has a vortec supercharged b16?
- regular v.s. synthetic
- blown turbo seals after headgasket
- Which MAP wire?
- GREDDY EMANAGE?
- Audi A4 Turbo Setup good for parts
- Toyota CT20 turbo
- help! - need to go through emissions w/ my turbo teg in 1 month
- I beam rods for turbo?
- some pics of my lude
- who is having problems or have had with hondata?
- Tapping in to my oil for a feed line
- Precision SC61 vs. (ITS) t03/t04e w/GT35 Wheel
- Apex'i Power FC
- Where to mount pump/filter?
- Resurfacing flywheel for a turbo clutch
- why would oil be coming out of an intercooler?
- Whats the potential of my t3/t40e?
- High whp D's - valve cover venting?
- Boost and altitude (searched+read faq)
- Put web race regrinds in my buddys LS B18B and now lost power????
- internal/external wategate
- turbo cams which to use
- My new d-series turbo set up is all done! Check it out!
- AEM EMS gurus, need help with Idle tunning
- Single Head TURBO
- JRSC boost upgrade question.
- Some pics of my turbo setup
- finished the d15b7 setup, lovin it
- Best Axles for Boost
- thinking about getting a Greddy kit
- Emanage Communication Problems
- Ssautocrhome Fake Tial Wastegate + Fake tial BOV Vs Real?
- which engine is the hf manifold from?
- supercharger or no
- Whats the best turbo to use on a b16 wanting 300whp on stock engine
- Where to buy engine building tools (micrometers, dial bore, straight edge)
- TurboCalculator SS Turbo Manifold + AC = ?????
- Is anyone using the street imports intercooler?
- Surging Idle After Rebuild *urgent help needed*
- Question About SC61 Turbo.....
- stock ls+80shot+methodmotor works=171.6whp 175 ft tq
- How can i tell if the turbo i have is bad?
- how do i get an uberdata
- Help please,,,b18b weired engine sound
- Catch Can options
- 1g dsm bov??
- DIY: Tial Valve Seat Removeal
- which turbo should i run??
- my boosted d16 setup
- wastegate touches manifold
- JRC 6" Intercooler on EG fitment issues. Need advice.
- jg intake question
- HELP!!!Hitting wall at boost/load/wide-throttle!
- Arias pistons good or not for 15-18
- Best Supercharger for D16X8
- Vidoe of our TurboKompressor Mini Cooper-S
- Turbo ls teg progress pics/video
- JR idler pulleys wearing out
- Hi every just dyno my car 252hp
- ARP Headstuds
- ZC JRSC...fuel and ignition
- block sleeves
- Nos got a few qustions
- 16" stret tires
- just got a t4 for my 98 EK?
- weird overheating problem...thought it may be my headgakset like usual, but this seems different
- WANT 2 TURBO MY D16Z6..HELP PLEASE!
- any one running the large t3 from a 300zx?
- gsr cams in b16 what timing map to use
- t3 .48 .67 (esi)
- best setup
- T3/T70 too Big?
- turbo timer?
- basic turbo setup....will my exhaust be enough for it?
- Turbo skunk 2 cams?
- turbo a d16z6 or a b18b want 200hp max
- custom h22 manifolds
- Which head to use USDM B18C or JDM B18C?
- Finally got the Teg back on the road
- Why are B18B LS motors good for boost?
- D15b Edelbrock Turbo *PROBLEM*
- oil sandwich adapter
- fot those with electronic boost controllers...
- endyn vs. greddy catch can
- what to expect from my new setup?
- About to buy a GE sandwich plate, whhich adapters/fittings do I need?
- My Dyno Tune #'s......
- GE vaccum manifold problems
- Is a FMIC necessary if im only making like 250 hp?
- Where do the oil lines connect on the turbo?
- People with rollcages, what does your gage setup look like?
- Is a Test pipe really needed?
- EF Turbo issues.
- installing a spec stgIII?
- weird idle uberdata help
- boosted h22a w/safc settings?
- Failed inspection :(
- D16Z6 setup question
- hf manifold gaskes/mounts
- Ever been on a "bad" dyno? Car seems to be too fast for such low numbers.
- d16z6 turbo problem
- Uberdata tuner in Honolulu
- Honda Block Rebuild. Detailed Guide? Parts List? Cheap Ebay Distributor? SOHC!
- Best AFPR???
- CYP sensor, car is bucking in low rpms. How do I solve this problem
- Yet another turbo seals question....
- psssssh
- EL mani for my setup?
- Garrett GT25/40R on a built D16 - Please Help !
- Mission: Impossible (56k I dunno)
- Skunk2 stage 1s and boost??
- any one got experiance with these
- thread size (oil pressure switch)
- Turbo whine/whistle
- boost vs boost/vac gauge
- WARNING CRP Manifolds (do not buy)
- Painting intercooler
- Will an equal length mani fit here?
- Blitz Turbo Timer
- Heres a JRSC'd Honda Id drive- Video
- which clutch
- D16Z6 181.2/172.0 T25 8-9psi
