View Full Version : Forced Induction
- Oil leak from the Feed line and the Oil Temp harness of a 93 prelude, Help!
- what turbo for 15-20psi?
- intercooler effectiveness while on dyno
- Direct Port Tubing question
- Wats required with Hondata S200b?
- new to FI. wanna go SOHC trbo; just some Q's
- Zex Kit Help
- size of inlet/outlet holes on MBC's??
- Mustang Dyno/Dynojet. Comparison
- Project update: Lovefab SST pics inside! (56K go away)
- Finally turbo!!! Now I got a problem
- How much HP could a B18b hold?
- any place cheaper than maxrev 2 find a 4 bolt turbo dp.
- Engine rebuilders help !!!! piston clearance
- looking for a good engine builder in georgia. Pref atlanta, alpharetta, marietta, woodstock, kennesa
- Golden Eagle Mfg Oil adapter install?
- look what i just picked up
- I love it when i get a package!
- Forged D15B rods?
- vafcII vafc2 question (searched)
- vortech FMU/dsm injectors..black box??
- aem regulator. which oriface for 255lph and 440cc?
- HKS Intake Carb Sticker!!!
- Question about AFC hack and a Chip (turboedit)
- Garret GT37
- Precision GT32E
- Crower valve question
- Turbo exhaust & wastegate optimization according to Garrett engineer...
- Question for people with Full-Race Manifolds
- filling ur mad tight nawz bottle y0!
- cheapest homemade turbo
- Should I go Super Charger???
- Thermal research and development 3inch turbo exhaust
- why is the oil pressure gauge so important?
- o\t for trade
- SOHC vs LS dilemma
- Hatchback turbo exhaust options...
- EGT probe choices
- zex wet kit
- heres yet another wideband controller on the markety
- fuel pressure
- Is there a limit as to how much boost above rated WG spring rate you can run?
- Multec 2 injectors
- qeustion about supercharger
- more blue box Bs... h22 eg w/ 450's???
- clutch
- I just got word from RC that feb 1st they should be having some new injectors(SATURATED)
- What is a good price for a VAFC? ALso some turbo Q's
- blockguard...yay or nay
- What do you think are the Top 3 MUST HAVE Gauges?
- not holding boost and other stuff HELP
- egt or temp
- Turbo D15 need help and opinions
- Which turbo would benefit me the most? Please help!!! sc34, sc60, 61
- ceramic coating question
- My Try at reading Turbo compressor map - is this right?
- is this item worth it!?!?
- Which one to use? missin link or MAP sensor
- turbo XS BOV?
- Gauges just came in *pics*
- question about ls turbo and hondata!!
- Narrowband to Wideband Gauge Converter....any try this yet?
- Would you?
- Intake Manifold
- Internal upgrades finish should i........
- have a dp that was used in a hatch will it fit my teg?
- Sleath mode: Stock exhaust on FI car with cutout.... Pros & cons?
- what for turbo 8:1, 8.5:1, 9:1, 9.5:1
- Eight Fuel Injectors w/EMS
- red heat sheild sleeves, or any heat sheild sleeves to protect oil and water lines????
- ********URGENT*********
- inline pro mani w/ internal wastegate?
- Safe Boost for SOHC
- is this normal for a block....
- OBD0 injector clips same as OBD1 clips?
- Bigger Charge pipe dia affect spool time?
- junkyard turbo question
- how are these injectors
- need some ideas/help
- will a pr3 b16 ecu work ok with my turbo on my b16
- SFP Manifold/Dipstick prob
- Best valve train without major head work.
- DRAG turbo efficiency range
- rerouting bov to intake
- here is my plan.....will it work?
- Race Enginering Block guard- PICS!
- blue box/emange?
- gasket reusabilty?
- silcone coupling question???
- help diagnosing my friend's b16 turbo problems... stock computer, vafc
- Plumb Back BOV question
- my custom turbo kit
- D16Z6, Turbo, Eagle rods, whats the real scoop
- Opinions about the Johnny Race Car's 6in IC
- LS, TD05-18G and Hondata
- SC61 efficiency range?
- what the bigger one
- South Florida (Fort Lauderdale) machine shop?
- Any good downpipe fabricators in (SOCAL)
- Anyone had a problem with shipping damages before? what did you do?
- Best valves springs for my setup? (1st gen b16a)
- what is gm 3bar map sensor
- 60 mm exhaust good for LS turbo?
- any point in 20psi?
- Which basic fuel management setup for LS turbo?
- need help changing over to fi from na
- isn't it better and cheaper to put together your own "kit?"
- Short ram VS CAI for JRSC?
- HELP! broke a ring during assembly
- b16 ecu on ls motor
- How do you guys align your cars ?
- Need valvetrain help?
- turbo or nitrous??
- Slim A/C Fan, Room for Bigger turbo in del Sol???
- SOHC supercharger
- way OT: I need help undoing the yellow airbag clips!
- anyone who has tuned a nitrous car
- LS turbo 10psi safe for daily driving?
- Question about piping sizes...
- b18b/b20 turbo on integra body.....
- durability
- Exhaust needed for 55-shot nitrous?????
- Big thanks to Kyle at Wiredspeedlab
- Tired of the gay ass greddy filter!!!!
- center sections
- injector flow testing in the bay area?
- Help w/Clutch & Flywheel Combo
- Heat protection for hood....
- hack v-afc
- turbo question
- YAY!...got some parts in...Thanks Ron, and Kyle!...
- I'm back
- greddy bov horn?
- Dubai Autoshow December 2003
- My delimma, HELP, Dart block VS LS block
- need input on building an engine
- 3 bar map sensor what part #?
- piston help please
- I need intercooler pipes...where can I get them?
- Parts List...Recommended places to buy from?
- Ball Bearing Turbos
- Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside
- Buy a new clutchmasters disc and use old cm pressure plate?
- possible to use this port for oil pressure???
- Broken plastic connector on Injectors. still salvagable?
- searched stock sleeves and didn't find out what kind of compression people run
- rods and pistons
- intercooler sprayer
- ??? for tilton clutch users
- type r valve springs?
- fly wheel
- Rocker arm resurfacing?
- Boosting B16 need help not trying to blow up motor.
- will my mugen chipped ecu blow my drag turbo'd b16 up?
- Hondata datalogging issues. . .
- ** Need settings for my VAFC **
- i called up ms cleo and she said my plugs didnt look too good
- Experience with Greddy E-01 Boost controller / e-manage ???
- ?'s for my b18b turbo set-up
- Why people say that?
- Cat hurting or helping
- downpipe questions.....
- Turbo S2000
- oil pump/water pump for boost?
- aeromotive 13116
- Nitrile or Silicone Hose Connectors
- What are people in PA doing for this new Emissions testing in PA?
- series gt turbo
- gt22
- oversized valves? Good/Bad
- Inline pro manifold fitment
- need to borrow an intake pipe
- Boost on a semi stock block
- junk yard turbo kit
- I.T.R. cams with J.R.S.C
- Hondata Hesitation...?
- wiring the blue box
- I think I may have blown HG or WORSE .... PIC
- autometer guage reads boost but no vacuum
- Free Turbo Engine!!....not a Honda :-(
- whats best intake manifold 2 use?
- best shop in LA or inland empire that do costum turbo installs?
- WTB: Complete Turbo Kit for B18b LS motor
- turbo manifold problem(need help)
- Not a Honda but FI Related - Turbo LS1
- AIR intake manifold carbon fiber $1500 WOW
- greddy turbo kit ?
- wiring piggy back - blue box...
- Boost controller which one???????????????????
- Anyone test this before? Pre spooling Nitrous
- might be turbo related, but feel free to move.
- can someone hook me up with the link of austriantyper roadracing?
- gsr trans on a b16 turbo?
- possible cons to turbo an automatic?
- I
- Boost Controller Poll!!
- Direct port install question
- HUGE amounts of white smoke....... then nothing.
- Sneak peek......
- Compression Test Numbers???
- Super T Motorsports...
- how many people here with turbo setups have done it properly?
- Need Help Car is smoking!!!
- shaft removal
- best place for crower rods?
- Integra owners with FMIC
- Anyone have any good experiance with Zdyne Gold Ecu ??
- need HELP taking hks ss bov off welded pipe????
- tuning ls
- What size T3 on a D16Z6?
- d16 greddy turbo help needed
- TURBO instal problem!!!!!!
- what cam???
- ah shit.... threw my balance shaft belt for no reason whatsoever... I have a Q though!!!!
- dyno or wideband?
- vortec ls or turbo ls
- How much is are these worth?
- Need t3/t4 rebuilt
- displacement calculator-- how much to bore H22
- Boosted B16A2 w/ 9:1 JE Pistons... what cams to use???
- Anyone have experience with Crower stoker kit?
- Safe and correct cr for a built b18c
- Anyone know where I can get an 1/8 NPT fitting for my egt gauge
- what turbo should i get for fully build b20 Vtec engine???
- Should I listen to JOTECH??
- Intercooler piping
- is a T3/t04b good enough for 350-400 hp?
- just curious, how bad is it to lean out the car on highway??
- b18 or 20 for turbo...have both
- anyone stroke their b18b? take a look at this ebay ad...
- GSR questions...
- I Wanna Go NITROUS
- what grade bolts for turbo manifold?
- How many of you with turbo'd rides get on a road course?
- Stock Fuel Pressure Regualtor + Boost ?
- weird track numbers...need help
- SARD BOV
- Which grade metal for turbo piping
- turbo set up help?
- b16 tranny with typer diff.......................help
- Advice Needed/Wanted: My Sohc Turbo Setup coming. (Lil Help. )
- TurboXS Dual Stage Boost Controller Install Help Again...
- Kit almost complete, whats wrong with the starter now?!
- What size bolts/studs are you guys using to attach the turbo to the manifold?
- Not Honda, FI Related, *Warning* Watch out for this Isuzu!!
- --injectors--??
- do i need an oil restrictor?
- How many of u turbo guys???
- Oil Cooling System leaks - do I really need this for turbo on a CIVIC ???
- Dyno results from the boosted LS
