View Full Version : Forced Induction
- Need Some Help With b16a Build for Turbo..
- Turbo GSR CRX (vw beetle exhaust)
- where does everyone buy the programmer(burner for uberdata)
- Let me see your Slip style MANIFOLDS Please !!!!!!!!!!!!
- Zex 95300/105300 cam valve lash question
- what is the best management for a forged Dseries???
- JRSC ENRICHMENT RELAY HELP!!
- drivability with 8.1 lbs flywheel?
- Do any of you think a full 3 inch exhaust is necessary for a 5th gen Prelude boosting 7lbs on a Gred
- Cracked tip dsm injector still usable?
- To those that live in areas where emissions is a must, what do you do?
- Would 550cc injectors be good for 15-20psi??
- please read, i need some help
- Excel Spreadsheet - Plotting Compressor Maps for D-Series
- Dyno Stock LS 300whp
- install apexi sohc kit on my b18b :)
- functionality of oil sensor...
- b16 Question
- Turbo car wont go past 5-6k with Hondata 4b. Help
- Turbo Q? FMU 12:1 Full-Race Apexi
- gsr civic greddy turbo question
- Emanage tunable? the one that comes with the turbo kit.....I SEARCHED ALREADY
- Where to buy 90 silicone transition couplers for a decent price?
- Turbo help!!
- new hotness
- h23 turbo manifold
- What turbo should i get?
- What kind of power is being put out on the greddy kit on a sohc...stock?
- Boost troubles/motor is done for
- b20b or b18b turbo'ed t3/t4
- when do you reach 7psi boost on your SC34
- Very quiet for turbo car
- AEM EMS tuner in DFW?
- Tuning GSR turbo w/hondata
- thinking for a d-series setup
- Where can i get the downpipe gasket for my drag kit??
- 2.5" exhaust ok for big boost?
- Headgasket
- do i have to get my o2 sensors fixed?
- STOP bringing up old topics!!
- Anyone using BLOX Turbo Cams?
- will this intercooler be big enough
- anyone make a blower for the crv vehicle?
- Anyone used the Profec Remote control unit?
- Help Me Diagnose the Problem w/ My Wideband!
- help me setup custom direct port n2o kit.
- OverRev's 592WHP Del Sol in progress
- why forged internals make more power at same psi?
- HELP!! Will a b18 charge pipe fit a sohc vtec! LMK asap. Thanks
- New motor, new turbo, new tune
- ss autocrome ?
- ecu fuse is blowing! could it be the main relay?
- Max Rev turbo manifold ?'s
- ------- What turbo is on the Mitsu Evo8 ?
- what fitting to get for oil return and feed lines t3/t4
- Turbo or Supercharger?? Need help
- VORTECH
- Question regarding Weight of Tubular Manifold.
- B18C1 @ 15psi boost and 12 psi boost
- **Bypassing my turbo question**
- jr supercharger...switching headers worth it?
- what is the most popular turbo...
- E-Manage wiring
- okay, so how do i know if it's dual (just got it in mail)
- Timing belt slipped under boost
- Burns Stainless Forced Induction Turbo/SC R & D project
- what other OEM honda o2's are 5 wire besides the 92-95 civic vx ?
- Should I take it easy?
- Crankcase Ventilation
- for all that are running uberdata look!
- Another turbo D!!!
- Blown Turbo seals?
- Hack Problem
- 93 integra running a t25 hits 5lbs of boost and falls flat on its face
- quick question, please look!
- In what sort of steps should a turbo kit be installed?
- water cooled and oil cooled?
- Denso Iridium Heat Ranges
- Major stumble...can't figure it out.
- Turbo and nitrous
- B16A2 + Value?
- my turbo checklist, advice if im doing this right (Bay Area locals help me out please / Uberdata)
- turbo not spooling
- Cheap ass manifold...
- D16Z6 + 14B + Dyno = .......
- Spend some time on the dyno b18c1, t3/t4 60 trim, lovefab, 3"
- Wierd manifold?
- built b16a1 turbo questions
- clearance. searched already
- Altenator question
- Intercooler Painting?
- turbo goign on
- apexi fmic sylvia core, precision 440's, autometer a/f gauge, stock rods and pistons gsr for sale
- 2-Step Rev limiter AEM EMS
- Too much turbo?
- JRSC BTC and MAP controllers
- Help: What type of rods are these?!
- Uberdata - Willem Chip Burner Probs, chip Burns fine, but won't work, please help.
- manifold adapter (help)
- Just got my k24 block...sleeve it or no?
- DIY $4 Water intercooler sprayer PIC & VID
- Alcon Brakes: anyone used them?
- Best turbo for a EP
- 100 shot nitrous possible on b16a??
- Brake booster for vacuum source
- Best turbo manifold for b series????
- turbo b16 plugs
- cam gears on a turboed car?? worth it?
- air/fuel ratio o2 bung
- GSR or B16 tranny.........
- clutch question
- NGK plugs on SOHC?
- Missing link and VAFC?
- Carbon Fiber Intercooler pipes
- TiAL Wastgate Question?
- Where to gap NGK plugs on Vortech Type R
- My tranny set up??????
- Clutch need help
- Will a B18 Charge Pipe Work on my D16 SOHC Vtec?? Please help!
- all you turbo owners..
- 9:1 comp loses low end
- Jackson Racing Supercharger help!!!!
- What Turbo for B18C5 7-10 PSi
- Taping over fuel inj. resistors
- Lost vtec
- Inlinepro Turbo Manifold
- How can you tell if a turbo is "clockable"
- Need Help With b16 Build....
- h22 turbo dont want compression to be too low!
- need help...which b series?
- boosting only 6-8 on stock engine w/ stock inj...probs?
- question about saab turbo
- Clutch straight to the floor. HELP
- Siemens 83lb injectors...good idea for my setup?
- Drag oil return[searched]
- LS turbo or keep my B16
- Good turner for FAST/Speed-pro in North Cali?
- only made 185 whp w/ gsr turbo
- Superchargers JACKSON or VORTEC
- NTK sensor vs. Bosch LSU4 sensor
- honda crv turbo kit
- Running an exhaust cut out
- Best Clutch and flywheel???
- Help me brainstorm my boost lag!
- where can i find a scoop that goes in the bumper vents of an eg?
- best turbine a/r for b16
- newly turboed D16 misfires
- converting hondata ecu back to "chipped ecu"?
- Getting ready to install turbo
- Crower 402T VS 403 For LS Turbo
- who has the highest mileage on AFTERMARKET sleeves ? Post here
- Is it possible??
- RevHard intake piping and charge piping.
- boostin z6 wont start PLEASE HELP!!!!!!!!!!!!!!!!!!
- JRSC boost question
- Has anyone ever blew up a tuned stock block UNDER 400whp
- does nayone know anything about this turbo, or have you used it........
- Turbo Sizes
- t3 60-1 and sc61
- anyone makes sleeves for the J-series, V6???
- Final Decision: Boost till I Die
- Block Resurfacing
- about JRSC and crank pulley
- has anyone ever treid and "evacuator" fan????
- what kind of compression ratio is safe enough to run 150 shot direct port set up for street and stri
- new guy here, bov not working...
- Golden Eagle Mfg. needs your pics!!!!!!!!!
- Check out my oil return...
- help me choose a turbo.
- for guys with 600 whp....
- Is it worth it?
- why is my b&m fuel pressure gauge stuck at 10 even when its off?
- wich turbokits fits in the ef8?
- Benefit of higher WHP @ lower PSI
- Tial 38mm Firering
- Oil Pressure gauge quick question?
- B16B PISTONS
- is it good to squeeze with this set up
- Compressor trim help
- tial wg and turbo xs mbc hook up...????
- anyone know what the screw inside the b&m fuel pressure gauge does?
- Greddy E-Manage help
- did i break my tranny?
- What are your SC61/B18C1 setups making @ low boost?
- turbo fitment help
- Your first engine build, how did it go ?
- Question regarding Home Depot MBC
- Messed with vortech supercharger blow off valve now car is mis firing at hi rpms
- Any D16 uberdata 3 bar maps floating around?
- Who makes this Downpipe?
- How many of you drive your turbo car in the winter or going to?
- My dyno #s and timeslip - it's been a long hard road
- turbo Stock Engine?
- Uberdata 1.666...can someone send me a link to download it?
- Inline Pro Head Gasket On B Series
- how well does the BLOX manifold flow......
- Turbo CRX d16a9 not revving over 4k RPM, vacuum leak?
- How quickly does your z-10 catch can fill up?
- Post up your airbox/filter setups (searched)
- turbo setup laggin above 5k rpms... please help..
- 511 whp Andy Tuned
- HELP with Clutch suggestions. Whats better for me..?
- Dyno'd the Girlfriends car today
- Should I deal, when is a 6-puck needed. Help before makin mistake....
- Question about Stock Boost Level on DRAG Kits
- Need some turbo advice..
- Noob question
- Boost finally got me.....
- Help at the track?
- Help with leaks!!!
- brand new gauge showing boost
- I have a question about boosted B16.
- Connecting rod Design
- missing link?????
- JRSC 10.5psi, should I add nitrous?
- 5 bolt t25 turbine outlet flange with opening for wastegate...
- relief valve pressure on a walbro 255hp pump?
- Carbon on pistons.
- what is a good midrange cams on my supercharger set up?
- help with T25......wastegate question.............
- Am I just being paranoid? Blowby issue?
- white smoke
- b16 with procharger c-1??????'s BIG TEXT!
- Garrett Part Number references...
- budget b16 turbo
- Fuel pump upgrade with SMC or SAFC (and ignition recurve Qs)
- Fuel pump won't run with chipped P28 and Uberdata.
- turbo integra sputtering and CEL 43 fuel supply, help please!
- D16Z6 1/8mile what a joke...
- How long will stock sleeves last? (full race turbo/sc61s)
- B16 cams for turbo
- prices for dartonsleeves and install
- breather
- Turbo seals
- h22a setup
- How to ruin a perfect Saturday.....
- greddy kit on a 01 gsr?
- my custom turbo kit...am i missing anything??
- anyone had any problems with the missing link?
- Blox manifold w/ Drag dp
- Need help with this turbo! *pics*
- What is a Variable Nozzle Turbo?
- Integra Turbo Heat Problem!!! Is This Normal?
- exospeed sleeved blocks vs. dart sleeved blocks
- Type R Boost Build Up Questions
- Let me see some turbo setup with pictures!
- skunk2 IM on turbo LS
- Turbo XS RFL Problem
- Turbo Pricing
- How to pick a wastegate?
