View Full Version : Forced Induction
- anyone knows how to do uberdata in mn or wi?
- Little brother went LS turbo
- Good D15B turbo setup?
- B18B turbo... block guard or deck sealing.. advantages
- HELP: CAR RUNING LEAN WITH TURBO
- Ebay turbo kit
- need help ladies plz...!!!!!!
- SC50
- Confused on MSd 2 step hook up
- Turbo d15b VS. 220K d16z6 turbo?
- A good place to order turbo's/ turbo parts?
- Max Boost With Emanage
- upgrading my turbo
- Anyone? Drag 3 kit on stock B16 engine???
- 60-1 vs sc44
- Prelude turbo Question!!!
- AFC hack, cant seem to make it run rich
- gsr turbo beast!//////
- You guys wanna see crappy dyno plot lol.
- Where to buy OBX LSD?
- How do my JRSC fins look?
- Turbo D16 Dyno
- High Horsepower Honda's with catchcan. Question?
- Sohc turbo kit on a gsr.........
- Non Honda: Project EVO
- my setup 95 gsr, non forced-induction stuff included as well, but not too much
- Is my BOV Broken?
- HELP: sohc Greddy turbo kit(LONG POST, SORRY)
- JRSC on stock b16 1/4 mile ET in crx
- CTR intake with boost????
- Too many problems.. smoking, weird noises
- Idling Problem With P06 in LS???
- best compression for LS
- will my pt-sc61 get me to 500whp?
- question about tuning..
- What else am i going to need?
- o2 Sensor Help
- Getting New Motor need advicce
- ounew guy question again...
- cracked block, anti freeze drops under hood and only on pass side, help
- spraying the same as hitting boost?
- b16 ecu
- NEED HELP...Sohc Turbo beginner
- Injector Question?
- EF Hatch W/Boosted LS Roll Call/Discussion
- Breaking in the new beast
- Recommended Muffler shops/welders in Socal??
- BOV or CBV?
- Turbo GSR video -- 11.5:1 CR, ITB, 9200RPM redline, 12 psi...
- Breather (PCV) system for H22 - help..
- turbonetics 60 trim
- Radiator install during turbo install
- 1600cc injectors
- need some advice with b16a2 power up
- SC61 or t66
- zeitronix wiring
- Is your downpipe a larger diameter than your exhaust?
- act unsprung 6puck clutch questions
- jrsc: do i need and LSD
- Running super rich under daily driving
- new to honda need help!!
- Your Oil Catch Can setup!
- Cheap 46mm, 50mm wastegate EXPERIENCES
- Where would I find 4" 90 degree bend rubber hose/ stainless steel pipe?
- Just ran compression test. 180-170-180-180 good?
- Would my exhaust setup be okay? Or would need to run a straight...to get more P O WER?
- st#uds
- cheap good cast mani
- Intercooler CFM efficiency
- dimension of c&r crx radiator
- help with greddy kit
- Should I sell my Spoon Cams???
- Factory Fuel Pump info
- simulating 02 heater circuit with resistor?
- tuning with open downpipe
- Lets see pics of your intercooler....
- getting started
- What is the usual cause of failure on high hp stock internal engines....
- Question about using Hondata IM gasket on boost applications...
- V-Mounting Intercooler on EK
- **Nitrous with chipped P28?**
- apexi turbo timer
- anyone experience this turbo?
- H22 Turbo Opinions
- no room for air filter...now what?
- My hat's off to Eagle's oustanding rods *destruction pics*
- boost controller and BOV
- blow off valve
- Radiator question for boosted cars
- Need help hosting a 41MB video -- turbo GSR video
- supersharger or turbo
- Anybody upgrade their turbo on a greddy kit?
- D or B Series for Turbo Buildup?
- is the AEBS manifold decent for boosted apps??
- new to the turbo world....
- b16 JRSC exhaust question
- To all the SOHC soldiers
- Exospeed sleeves
- QUICK!!! How much boost will I make on my JRSC!!
- HELP: Quick question about downpipe.
- O2 sensors? (no cat)
- anyone have any problems with a slim fan?
- Cheapest place to buy a TURBO
- broken fitting in block
- Boost with VERY large TB/IM
- max hp on stock sleeves
- need to know what comp housing is interchangable with this
- Are these #s ok?
- Just got a JRSC what should I buy?
- Condition of this turbo?
- Best head gasket for d series
- Need more info on the Apexi Turbo Kit for SOHC.
- Please take a look at this Injector...
- b16 built for turbo? loss of power?
- Street Imports Intercoolers
- What should i do?
- Help with installation of Nitrous?
- lookin for 400-500 hp ls turbo crx
- motor ?
- For 25psi Turbo XS H-RFL or Tail 50mm
- Tial Wastegate Hitting Hood
- JRSC FUEL HELP...
- questions about turbos
- Just installed nitrous pressure gauge, but stays at 200 psi?
- Supercharger??
- New intake air sensor for JRSC on 00' SI
- Ebay Manual Boost Controllers any good?
- turbo my d16z6
- what turbo to choose ??
- Fluidyne Radiator with Turbo Kit A/C Compatible?
- Disabled o2 heater + 4-wire narrowband
- WHAT IS THE GAS SMELL 24/7 NEED HELP?
- Opinion: Love Fab Tubular Sidewinder manifold
- Oil from breather?
- Had an idea about fixing the fundamental flaw of AFCs....
- turbine
- Whats needed to calculate volumetric efficiency?
- what are the sizes of the silicone hoses in the drag turbo kit
- BLOCK SLEEVING???
- GSR Wiseco 8.8 pistons into Ls block, what will be the compression??
- Will i need vavle/springs and retainers?
- dont know much about turbos need help finding out wat the heck i jus bought
- Price check
- ???Sleeving???
- turbo kit question(s)
- Comp Cams Turbo, good or not?
- will it make alot of differance
- whats the best bang for the buck (management)
- lovefab Minime
- turbo kit "peace one together or get the kit"
- Boost leak?
- new here
- Looking for info on this turbo,,, custom
- Need help with setup: Vortech FMU + DSM 450cc + Walbro 255lph
- need help with G-Techpro On-board Dyno
- Vortech FMU disc size ?
- d16 turbo
- What turbo for 450-550 WHP on b16 with good spool up...
- 450whp with B18B head and pump gas?
- UBERDATA W/ P07 VX ECU? E-VTEC... :/
- clutch up grade?
- Question for those of you with A/C and Turbo
- Going to the dark side...need info ASAP!
- Exhaust Cutout E-cutout McCord DMH Quicktime
- AEM UEGO and logging question
- Turbo Spools to 5k and feels like its not pulling after 5k
- Dyno results at 13 psi with T60-1 with .96AR
- NEED LOCAL HELP (MINNESOTA)
- Wastegate Problem, understand problem before replying
- T3/T67 spool..what RPM
- My Ride
- runnin in 5th gear with turbo
- What head gaskets you guys use??? (D16)
- Rear mounted turbosystem?
- ihi-rhb5 vs. t3
- ACT XTSS-Will it hold 350whp for street use? (I know clutches are rated by torque)
- How much boost can a stock JDM b16 handle???
- looking for high HP d series turbo setups on pump gas, please post here
- Garrett T4/61 .70 A/R too big for my b16?
- non-vtec ecu in vtec engine?
- supercharger question
- smoke out of oil breather and oil filler white
- wHat the hell kinda pistons is this?
- post-turbo exhaust leak effect o2 sensor readings/engine performance?
- What hack is the better hack?
- how can i tell if my head is lifting under boost?
- where to get this gasket?
- how can i tell if i have a bar/plate or tube/fin fmic?
- want to turbo a d16 head on z6 block what pistons?
- New to boost, need help with an overheating issue
- BLEW MY TRANNY !!!!!
- wideband o2
- Help - installing JRSC on D16y8
- ***Forced Induction Forum FAQ***
- Y Downpipe
- which turbo, t25/t3
- Post Your Supercharger Setup
- anyone AT ALL make a 4" exhaust for an integra?
- sensor type setting for an Apexi Vafc and 3 bar map
- A few of my time slips from the NHRA event the other week.
- fist time at the track Turbo Sohc!!!
- semi engine build
- pcv question (yes I searched)
- T3 turbo
- Tuning issue
- Exhaust dump
- heat tank manifold?
- Injectors for turbo civic
- Need help on a turbo :plz help:
- Just installed Rev Hard Kit: Not feeling quicker.
- Is this a bad turbo?
- *LOOK* Where can I find this oil fitting screw?
- WHat turbo for my civic?
- needs help!!greddy turbo kit
- When will it spool
- Blitz Dual SBC
- Its done what do yall think?
- any uberdata tuners in orange county so cal??
- Edlebrock or greddy 19T for the sohc
- Yes, AFC sux! But, is there hope???
- Billows of smoke when starting car
- Life span: Daily driver, Boost, Stock B16A
- block sleeving?
- Hondata 2B vs Hondata S200
- TurboEdit
- just got back from the dyno.
- 2.25 vs 2.5 exhaust
- lookin for a at29c256 chip
- FMU & V-AFC?
- why is A/R so important?
- Help me identify this intercooler
- Does this sound good, or do I need to buy an engine hoist?
- turbo d16
- CAR PROBLEM.. LOOK
- Guys! I need your help!
- Help On Where To get a Garett T28,T25,15G.
- Turbo Prelude Finished
- need help boost creep
- Turbo oil question
- evaluate this setup please..
- Please help me identify this turbo
- turbo setup???
- Best manifold for my EP
- Just searched for 45 minutes, HT and Google!
- Wanting to GReddy Kit My Automatic Teg - Few ???
- Who use a kevlar clutch disc in their 300whp+ car ??? take a look...
- How is inspection and emmsions with a turbo car in NJ?
- wastegate not clearing hood, help
- Head lifting under boost??.....SRT-4
- Am i ready to start boosting?
