- turbo upgrade question
- D16 Jackson Supercharge
- Greddy Blue Box functioning properly???
- What would be a good price?
- biggest turbo on lsvtec
- Rod weight differences
- IMW-Built/Fabbed/Tuned: 390whp/340wtq Honda CR-V of Death
- turbo timer,overated or useful?
- max HP for 650cc injectors on e85
- Built NA or JRSC B18c1 ?? 215-225whp
- Precision 5557B 0.82 A/R Feedback
- Boost Cut @ 4lbs
- How big is too Big for a 38mm
- Tire choices???
- LS/Vtech Question
- What's the difference between Skunk2's new and old b18c1 intake manifolds?
- H23 turbo Project back in action
- Help! Looking for belts for JRSC
- results of my custom turbo kit for my s2000
- Twin Turbo Setup?
- b20 vtec turbo dyno graph & boost chart
- 50a/r 63turbine vs 60a/r 63turbine
- b20 turbo
- Do I need a resistor box for my APexi Power FC
- how many ft of braided hose i need?
- How much would you expect to pay for -10 female line?
- Question about my GT30r...
- what arp head studs do i use for my ls vtec
- WTB: HF Manifold or similar
- 92 civic 1.8T
- Boosting jdm b18b quick noob question?
- New Aeromotive 340 Fuel Pump 30% more flow then a walbro 255 lph
- D16A good for a build or use undersized brearings?
- what hose size for -10an fittings?
- Help with Stock LS turbo
- d16 y8 greedy turbo kit blowing smoke at stoplights
- can i run 5psi safe
- Peakhold vs. saturated injectors for my setup?
- b20 vtec turbo numbers
- crower stg 3 cams and BOOST
- turbo gsr dying
- what turbo next
- need sum help with sleeve questions
- Precision 6031 vs Garrett 60 trim
- Time for a new turbo, suggestions?
- Will this volvo turbo work on my D16?
- Jun 3 camshafts + Turbo= ?
- Best b-series boost camshafts??
- Quick dual intank walbro question
- Potential “real world gains”
- Tuning Hondata S300, IATs and Honda vs GM for the IAT sensor
- need some info on b20 build
- 96 1.6lv turbo question help pleassee
- 87mm rs sleeves (magnum)
- Competition clutch stage 4 vs Action MS2 ? d16
- turbo without tune
- What Front Mount Intercooler To Get For EG?
- Divided turbine housing for GT30R /GTX30R
- the official ebay turbo thread.
- Blue Smoke When In Boost
- garrett turbo question
- oil catch can
- finally decided on a build!!
- High horspower nitrous setups
- smoking on start-up
- Catch Tank Filling issue - back of block
- ? About turbo
- Boosting 96 1.6lvtec Hx coupe need help!
- Timing Question..
- B16 Cam journal damage? Advice???
- bad headgasket being the source of my loss of boost?
- OE Style Engine Rebuild Kits
- OEM IAT sensor. How accurate?
- How is this catch can set up?
- Supercharged d15b Please help
- competition twin disc...
- anyone used this turbo?
- werid power/air fuel readings....(help)
- Stupid question from a newb...
- The Endless Quest
- D16 EDELBROCK EG KIT ON EK! QUESTION about piggyback
- B17 turbo build
- Whos on meth lol
- Swapping turbo manifold styles, should I get a re-tune?
- Gauge Nedle Flutter
- Precision sc34 ----> BW/Bullseye s256
- need help picking head gasket for built motor.
- B18B1 Turbo
- So sad!!!our oem b16 bottom test motor is hurt i guess 470 is too much i guess lol..
- B20B/Z vs B18B
- Garrett Turbo Dead in less than 100 miles????
- more boost in higher gear?!!
- HELP-supercharged Civic needs a more HP please....
- Problem with axle and OBX LSD!! help!!
- Using Silicone Sealant to hold PSI from boost???
- h22a stock internals turbo questions... please help!
- Boosted GSR
- spooling a t72 turbo?
- Is it normal?
- Piggyback????
- Which Neukin manifold suits my setup?
- Prefabricated turbo downpipe?
- GSR Turbo questions??
- serious blow by
- Turbo z6 question?
- walbro 255 and 255hp fuel pump?
- running a wideband on open downpipe?
- What turbo should I run.
- Turbocharging h22
- k20a2 compression
- Motor setup for boost..question
- Built B16 Bisimoto Cams?
- oil return on a top mount...where to run it
- DW300 Fuel Pump - 300LPH In-Tank!
- T28
- rims for 27x10x15 hoosier???
- Turbo for my B16A. What to get?
- When is it time to upgrade valves?
- whos running a ford t3 .60/.63?
- Anti lag/ignition cut question
- trying to order a clutch from clutchmasters with no luck.
- |Help indentifying this turbo
- bout to turbo my b16
- Yes or No? Exhaust Wrap...
- need advice on turbo kits/turbo's
- alright to tune during the winter?
- question about garrett turbo
- b16 with 6765 turbo
- 670whp DD fuel pump questions
- HELP.!! BOOST CREEP W/ FULL RACE TOP MOUNT
- OBD2 Closed Loop Tuning - Dialing in STFT?...
- GSR Turbo Overheating issue
- ebay intercoolers any good?
- turbo identification question
- Took car to the dyno... Need help troubleshooting
- question about this set up
- Turbo question
- Some Late night thoughts..(turbo,power,flow etc etc)
- Bullseye S366 vs. T3 60-1 back to back dyno comparison
- please help me find this turbo's hp rating
- build or bust
- Wiseco wrist pin lock rings
- How to put turbo on zc dohc engine?
- b16a arp kit on d16??
- pte 6262
- what setup did u run on a d16y5?? :)
- Main and Rod bearing question B18C1
- d16z6 street cam
- H-series Precision SP6765 T3.63 A/R
- best turbo for 420+hp on ls vtec?
- wtf is this
- Mass emission mission. What am I missin'?
- vacuum block question
- need info from experience
- LS Boosted? Gas mileage?
- Boost leak power loss Scenario
- import racing
- Ls turbo bad oil leak
- ::newb:: Best way to install Intercooler on EG coupe SLEEPER style??
- NEWB to boost
- True freakin super charger power!
- Walbro 385lph
- Boost loss after rebuild
- Hondata s300 in a P72?
- hp limit on 950cc injectors at 60psi
- Y7/Y8 mini-mi with spray/sc?
- 400hp clearances
- Anti-Surge Compressor Housing Question
- s2000 3mm headgasket question
- high compression turbo ?
- bad o2 sensor??air/fuel surges??
- my boosted stock b16
- Missing 2 bolts on my exhaust manifold. Why is this happening?
- What do you think would be a good spark plug gap?
- nitrous help?
- upgrade wheel and housing on sc61
- Turbo in winter with no airfilter?
- O-ringed block??
- 600 whp need advice.....
- what intake manifold for my turbo setup?skunk2? edlebrock victor? performer?
- GT35R ls/vtec progress thread
- Rebuild due to rod knock question?
- Valve springs for 10k rpm and 40psi
- Turbo DA B16/Hi-compression/E85 8-9psi Dyno Graph!!
- Ls turbo problem ?? help
- can bad tune cause turbo surge--help
- Engine step deck concern
- My d16z6 turbo build!!! 56k warning if anyone still uses that
- best intake manifold for 800-900 plus hp
- Can't keep an idle when the car is warmed up. Help!
- do jrsc b16 and a d16 pulleys interchange
- Turbo S2000 Fuel ?'s. Walbro & Bosch 044 & ID1000s...
- ecu help....
- head wrap header
- vacuum diagram
- Upgrade questions
- EK - What engine should I get for turbo?
- H22a turbo blowing out huge clouds of white/blue smoke!!
- some guy had to put regular in...
- h22 boosted in eg
- LS/Vtec T04e setup help???
- B18b 10:8-1 how much boost can i run?
- Need Help - PeakBoost Fiasco
- Wastegate with only one outlet - Wiring a boost solenoid as a bleed valve?
- z6 boosted vitara
- People with B16's and GT35r this is for you
- Sharing information - 505HP 356TQ Stock Bottom LS
- Nitrous on a h22 prelude help
- new eg owner with engine questions
- Doing a Research paper on Turbo Honda's need some help plz
- B18C build info needed
- b18 gaskets and beaings
- HKS 50mm or knockoff help please?
- oil cooler on lsv setup
- Rattling noises; cannot identify, find, or diagnose.
- Stock LS/Vtec - which turbo?
- turbo bseries ideal temp
- Any stock body crx or ef civics running front mount turbo's?
- need help choosing the right turbo for gsr
- my ebay kitted 2000 4dr with ls swap.
- Sohc d16z6 turbo build
- b16a + greddy td04h?
- Oversized LS pistons
- Is anyone running a turbo elements manifold?
- ls vtec question
- is this a 50 trim (ad on craigslist)
- oil passing by seals
- Bosch 40 intank fuel pump?
- slick and launching question
- Two questions about the Borg Warner EFR turbos
- E85 straight pump users: quick question.
- boost solenoid and boost by gear question.
- New Open Dp. idea out Bumper..and QUIET. Let me know what you think!
- inovative or hasport mounts for 500hp integra
- 650hp+ what tranny??
- what pistons and rods should i go with?
- godspeed turbo manifold
- precison 6765 spool?
- MBC hooked up correctly?
- TD04L (wrx) turbo to T3 adapter
- Specs on greddy e-manage pressure sensor?
- question...
- HHO on GSR-T; Has anybody done this before?
- t25 manifold & turbo flange issue
- Turbo Honda Vibration Battle
- please help!!! only 8 psi suddenly
- AEM Cam Gears BROKEN!!! D16Y7 Turbo
- Divided Housing?
- GT35R turbine housing removal question
- Chasing boost loss gremlin. Ideas?
