View Full Version : Forced Induction
- decided to go the FI route...need opinions (b18b1)
- fmu
- Just got my Log Style a/c compatible turbo manifold
- Where to find 1bar Tial 38mm wastegate spring?
- superchargers
- heater hose for drain tube?
- Boost spike on turbo GSR....
- safe boost on GSR?
- car sounding better but still not starting! code 22 every time!
- runs lean when i let off the gas
- spoon chip with nitrous
- Vacum lines?
- Fresh rebuild car smokes on startup
- Uberdata Need base map in Miami area
- turbo vacuum line, mbc and wastegate question
- my turbo broken?
- Uberdata Tuning questions
- Question
- edelbrock kit
- Holset hx30 or hx25 for a D16Z6?
- Big Problems, HELP, skipping
- precision 440's not plugging in?
- Deburring combustion chambers????
- really bad idle and smoking turbo
- RC 440cc's in a VW?
- Please help! Installing Turbo timer, and air fuel controler.
- Words from HondaHans' family!!!
- greddy timer & boost controller display
- HKS 40mm WG wonders
- 3" custom downpipe bends?
- Anyone use or have used NTK o2 sensors?
- Apexi Turbo Muffler...
- video u guys been waiting for ..
- Turbo Setup on H22 Civic
- 3" and 4" plastic elbows..good for intake tube piping..
- Im building a manifold Questions guys question???
- help.....nitrous bottle broke
- can i just use hondata without changing my fuel pump or injectors?
- anyone with the full race turbo kit on h22
- Help! Please identify Nissan turbo for me
- how to make your turbo spool louder?
- Innovate Motorsports WB question
- can i use 290 cc injectors on a vafc hack
- Code 41 giving me hell!!!
- Your recommended turbo kit for a b16a
- going turbo need help.
- Transmission question.
- Has anyone used the 4inch e turbo?
- How many miles/Km's have you been running on stock sleeve?
- intank fuel pump? how long does it take to change it? D16
- ZIF socket with rounded insertion pins????
- ecu and fuel for a turbo LS
- Problem to shift since I installed a new Action clutch 2MS ? Take a look please.
- te04h rebuild kit
- good place to start with timing on a boosted sohc mini me?
- HF/CX manifold question!
- Oil in turbo
- water temp of FI d16?
- Junkyard H23 Turbo Set Up Opinions
- Sohc Vtec Turbo 97 civic ex , quick question
- Nos nitrous jett size??
- PLX wideband install help
- Garret GT35R vs. Innovative GTS61
- Greddy FCU????
- Turbo in revhard stage 2 kit able to make 300 whp?
- whats the quietest BOV ?
- are there any good engine builders around the jacksonville, florida area??????
- anyone have any probs with cheapturbolines.com turbo lines??
- mmm 10 psi is fun
- Any hondata dealers in northeastern PA??
- Will hondata/uberdata/VAFC hack pass emissions *emissions questions*
- Boost controller issue??
- JRSC or Drag 3 kit?
- Carburated B16 Turbo ...
- DP touches Fan...how bad is this?
- BOOSTED D16Y8 CHECK IN
- o2 sensors?
- Which Turbo Is Better??? Need ASAP
- TURBO FOR 2000 SI!!!!!!!
- Frustrated. Bolts from turbo to manifold.....
- Transmission for high hp (600+)
- I need some help with checking rod bearing clearance how too's
- what should my base fuel pressure be? seems boggy down low
- Tuner reccomendations for western PA & OHIO?
- msd digital 6 install question about the boost retard
- Differences between b18b turbo and b18c1 turbo setups?
- Lowering engine bay temps...
- can i put different cam in same engine?
- SSAC Manifolds
- Where do I find Precision 1000cc Injectors...
- blown headgasket
- Just recieved Dp, could this cause a loss of power???
- does this sound right?
- Greddy Profec A Install
- turbo spooling?
- Does my oil return look fine?
- what could be wrong in this bov ? (urgent)
- moosknuckle is a SCAMMER!
- stock injectors on a turbo kit ???
- Tips on building a turbo manifodl for a 240sx ka24e sohc 12valve
- Big big fuel troubles... HELP ME!!!
- where can i get a new nitrous bottle valve?
- 14.7 psi on stock b16 block?
- Boost related question about super low compression in a Ferrari
- turbo car chokes
- What does the box that comes with hondata do?
- Resonator or Muffler?
- Anyone know where to get 3.5inch mandrel bends?
- saturated injectors d16z6
- what exactly is uberdata/hondata
- JRSC with alternator stepper pulley and jrsc crank pulley only 8psi!
- bolts from turbo to manifold always coming loose
- ZEITRONIX wideband O2 used with AEM
- Q on 3bar map connection. Which wires? Already searched
- Missing Link and Injector/VAFC controller?
- ITR oil pump... from search I know it flows better, but is that what I want for FI civic?
- sohc turbo setup
- Need Help With FUEL PUMP!!!!
- HKS Wastegate Flange
- It did happen to me :(
- What do these gauges do?
- fuel management
- H22 bottom end
- Vortech FMU
- Hondata 4b and s100 compatibily on socketed ECU's
- Weird plugs colour/deposits - help?
- the only high octane gas in my city is methanol(sp?) mixed....whatsup?
- turbo+Internals?
- Need Help And Info About Turboing
- Greddy w/g question
- turbo sohc dyno pics and timeslips
- finished up turbo install, question about oil return
- SC34 vs GT35E for a mild build b16a... Overkill?
- nOOb question on hondata
- just did compression test but bit worry about #
- Reliable External Wastegates?
- TurboXS MBC... left IS loose or am I smoking?
- JRSC w/ Kamikaze header (fitment issues)
- T25 turbo question
- ZC GARRETT TB0363 WATERCOOLED TURBO HELP!!!
- car stalls after letting off throttle.
- Where to tap EGT probe on b-series Drag mani?
- k-series turbo manifold
- Done with custom turbo kit but HELP!
- START YOUR WIDEBAND 02 SENSOR REVIEW HERE!!!!
- Throttle body spacers???
- Forget Uberdata and run the hack?
- Johnnyracecar / Tyrus Intercooler - New dimension - would it work for Integra?
- 20g turbo in b18a
- ECU Code 13 Barometric or Atmospheric Pressure fix with E-Manage Emanage OBDII Integra search f00!
- Turbo XS TXS DTEC?
- Greddy kit blue box ???
- Anybody running stock m2b4 h22 lsd on forced ind. and/or drag?
- build turbo sohc
- ic piping, dump tube, and downpipe
- Skunk 2 or rev hard IM on LS/Vtec??
- twin turbo b18 ls/vtec?!?!?
- Increasing mid range on a b16..
- head gasket starting to go, need help
- spun rod bearing look and tell me what happen (pics)
- FI question about cams.
- steam after spark plug check?!
- My Turbo problems are here.
- what ngk plug for sohc turbo
- L2H2 wideband sensors on Ebay, $85!
- question about HP rating turbos...
- autometer egt gauge stuck at 2
- fastest, daily driven boosted sohc?
- Turbo exhaust 93 civic EG?
- oil drain help please!!!
- typical/ideal boosted air intake temps
- Edelbrock VictorX or Skunk 2?
- How do you disable the internal wastegate?
- Need help fast! Johnny racecar 6" intercooler fitment on my 96-98 coupe.
- What are the differences in taps, and which ones to use to chase holes?
- Another t3/t67 dyno
- Please help vafc can only fun rich. shuts off when trying to lean.
- Pics of Intercooler Mounted, and Piping Routes on EKs
- I need help with the wiring of the PIVOT A/F Monitor
- IAT sensor pigtail
- running hot
- where to get wrap for ac lines
- boost creep
- b series manifold difference?
- msd ignition worth installing?
- FAST & easy question..... size of DRAGIII charge piping? 2.25 or 2.5?
- Denso injectors:23250-35040
- where i can get the termal wrap for header, and tubo pipes?? in dallas tx or who sell it
- Will I need to Rip Apart my block for this??
- Bosch fuel pump Part #
- Part Throttle Hesitation/Lean Condition Help Needed!!
- Quick Question !!!!!!
- egt mounting question
- Are all T3 turbo Flanges the same.
- Engine Smokes!! Need Help!
- bolting turbo to block?
- places on east coast 4 motor building???
- Why Are My #'s So Low?! HELP?!
- where do you guys tap into oil pressure and what size fitting?
- cel code 81? running really rich
- Don't think people will follow your instructions...
- Precision AS1026 Intercooler Mounting Brackets
- Looking to buy an adapter harness for APEXI POWER FC for 92-95 civic
- too much ignition timing bad?
- How can I tell if the Vortech FMU works correctly
- My 1999 Civic SI turbo project using the ONE Fabrication Manifold. Dial UP RUN!!!
- callin "How-To/DIY" thread creators
- Please check out this .bin file
- Turbo Install in PA
- Return Line T04d
- FMU install.....already searched
- weird boost problem... help me out!
- D16y8 turbo questions...
- best header for use with sc?
- RC440 install: OBD2 Integra *searched*
- what external waste gate to buy
- car stuttering d16 turbo
- Built Turbo Motor Question
- PICS of Full-race kits
- part number for turbo b-series plugs
- 4th and 5th gen turbo prelude exhaust
- CODE 5 GIVING ME HELL..(MAP SENSOR) ON THE HACK
- 2k1 civic turbo
- Can you name this Mitsubishi Turbo and wheres its from?
- blitz bov fit dsm flange
- too rich
- Does anyone know the a/r on the 18G
- 10,000 RPM 550+whp questions......
- 400hp on stock sleeves?
- need help enhanced willem programmer
- need a quick question answered?
- only gettin 10 lbs of vacuum at idle?
- Plugs after ~700 miles on 7psi
- Nebody with a non vtec 350+ hp car???
- JRSC + Issues = Confused
- PROBLEM WITH TIAL BOV!!!
- What Else Is Missing From This Turbo Kit????
- LOOK! Please give +/- coments on this 1/2 way kit
- Which Plugs
- Skunk2 H22A Manifold...Just received the first batch...
- To those with PLX M Series Widebands
- Is there dyno tuner near Seattle
- Fuel Pressure drop?
- motor built for turbo.
- Driving w/ turbo installed NO IC Piping
- Best tranny for a boosted D?
- defi gauges
- Denso injectors
- Repair Delta Wastegate?
- AEM UEGO widebind question.
