View Full Version : Forced Induction
- Ok FI guys, this probably doesn't belong here, but take a look anyways.
- DUSTIN - Question on your install for DRAG 3 kit
- geuss what? This is totally WOW!!
- OT: Well, kinda--still has to do with turbo..
- a couple questions regarding a JRSC and my LSVTEC
- Where to go next?
- really weird problem running lean: UPDATE PART 2
- HELP: Rod bearings?
- Pictures of my Max Rev manifold
- Detonation...sad nite
- rev stage 1 vs 2
- stainless oil return line--slipping on barbed fittings?
- Help on a DSM boost problem
- new free mod for anal teg owners
- OT. .ATTN GUYS WITH NITROUS
- Building a turbo block
- Intercoolers and Water?
- b17a to b20 vtec turbo
- tial wastegate only boostin 3-4 lbs
- whats the compressor housing size of a T04b and a T04e
- ECU and VTEC
- Okay...Selling LOTS of stuff.... mostly Turbo related
- OK I know this isnt a turbo question, but I need some help on picking out a nitrous kit for my GSR..
- OEM head gasket?
- Integra Track Weight
- Anyone know about ECUs??
- Pump it (oil system topic)
- Hondata with measured 2.2-2.3v on a 2 or 3 bar map (dont know which) w/ignition on.
- My broken motor pics
- GAS.. which grade to use w/ turbo..
- F-Max direct bolt on to a GSR?
- ZC Question????????????????/
- Anyone ever have their AC hose (on top) cut between the wastegate and radiator?
- Endyn S/C Stepper Pulley dynos?
- D16z6 > B16?B18?
- ATNTION! POST Ideal custom peiced together turbo Setup, Its for a GSR! List the best stuff!
- Post Pics of this
- greddy turbo on d16?
- Hondata problem
- can anyone ID this turbo
- Which turbo is best for a d16z6? T3 or a 16g.
- Turbo lifespan???????
- anyone selling an intercooler?
- My turbo has a .84 A/R turbine section .. is that need for concern??
- what should you get ona leak down test for a b series?
- I have a T3 from the Junkyard (off a Volvo)
- What was your arrangement to turbo your Honda?
- Turbo Prep?
- Where do I get a 5 psi spring for a deltagate wastegate?
- Supercharger with NOS
- WG and BOV lines same size ?
- Need some opinions on axle choice for high hp application.
- turbo B18B
- Do I use B18A1 series ARP headstuds for my B18B?
- WTB: vortech FMU
- Where to buy SS oil lines 4 my turbo??
- HELP: DragIII oil feed line & Autometer oil pressure sensor.
- Which injectors should I use...440cc or 550cc?
- How to detect boost leak
- Some FI stuff for sale...
- IC piping dilemma
- MAP or MAF?
- How do I figure this out?
- Which nos kit on my b16a?
- Which aftermarket pistions are you running?
- Strange EGT's
- dyno video
- Anyone order a cometic gasket from here?
- Tell me if i am mising something
- Greddy Type S BOV?
- Will jrsc from b16 fit on a gsr ??
- ATTN: Dustin
- My New Toys!!!!!
- sites that sell turbo parts?
- custom turbo kits
- Timing light.. what brand and where to purchase from?
- need some good guidance
- Saab Turbo upgrade question.........
- Need some advice on getting my head built.
- Disappointment with my f-max H22A
- Getting pistons coated...worth it?
- ATTN people using turbo XS boost controllers and tial wastegates.. ??
- good source for 3" stainless resonators?
- OT: displacement increase without larger bore?
- Hondata Tech Question #2
- SOHC ?
- how to hook up oil feed line for turbo? i would like to know what everyone thinks on this. not loact
- built bottom end, stock head, how much boost?
- EGR hose question
- I seized my motor I need help !!!!!!!
- My motor siezed I need sugestions ??
- max-rev what or who is it
- Just killed my wallet again! Damn Importparts....heheh.
- where can i find a 3in flex pipe for good price
- Haltech E6K....
- what spark plugs you runnin
- Need some answers on Exedy clutches...for turbo Si.
- found this item on ebay
- TURBO GEEKS???? NEED OPINIONS
- Where do you guys tune in the Bay Area?
- Big Brakes Groupbuy!!
- GSRWBOOST
- has anybody with a JRSC replaced bypass valve?
- few questions about turbo an safety
- OT: TAS pics
- Engine builders, need serious tech help..
- What torque specs to use for Crower rod bolts?
- Question for turbo pro's!!!!!!
- Is the Y20 DX tranny the best for D16Z Greddy Turbo Kit?
- need Missing Link valve
- Hondata 4b ECU code error 20 Flashing led
- turbo type r with 350whp 1/4 times on drag ridals?
- DRAG 3 + VAFC ?
- Dustin or Art !!
- Mechanical water temp. gauge
- Serbaz
- retard timing on a 75 shot of wet?
- Is it ok to drive around with a ice cold frozen intercooler?
- Fuel Pump....
- Newbie Turbo GSR
- Why Turbo cars Shooting so many fireballs?
- turbo fitment
- Guess what i am!
- Closed loop?
- How often to change plugs?
- Auotcross/Road Race + Turbo= ??
- car almost stalls, tach to 0, what could it be?
- For those running 70+ NOS????
- Supercharger or Turbo
- What Kinda Turbo Should I Get for My Hybrid...plz look and lemme know!!!!
- code 90: Evaporative Emission Control System leak detected in the fuel tank area
- Interesting stuff: Type One Earthing System what'd you think?
- Specific ACT clutch Questions
- Purple FPR identification?
- Question concerning the 14b /14g/
- Where to find exhaust components online (resonator, cat)
- Running too Rich... help
- if anyone wants to see pics of the max-rev set up
- turbo with nos
- Stronger head bolts/studs with 15-20psi needed?
- good welding equipment for custom plumbing?
- Hows the Greddy Turbo Kit for GSR's???
- Mounting radiator fans on front side of radiator?
- Phantom Grip LSD Group buy!!!!!!!!!!!!!!!!!!!!!1
- Need Greddy turbo help BADLY!
- Any tuners in Oregon?
- FS: T3/T4E, Drag Manifold/DP, Airtex Fuel Pump
- 16G TURBO ON 2000 CIVIC SOHC????
- Honda's new factory turbo'd 4 cyl...
- OT:new nitto slicks!
- Valve train upgrades
- Took apart motor for 1st time Part 2 (Big pics)
- Cutting ss braided line...need help!!!
- anyone see a 4bar mapsensor yet
- Aeromotive fuel pump?
- Question for turbo Build Up? I have a gsr but thinking of doing ls/vtec to save driving downtime.
- spraying intercooler
- change head gasket??
- how much power for my setup ?
- Headaches of Turbo install...
- Type R Turbo??
- Comments on the new N.O.S product?
- Question for internal work for b18c5.
- Its gonna take me forever to buy a turbo Im thinking about buying the NOS Big Shot kit for my GSR ..
- Buy a kit or piece it out (turbo)
- changing out ic endtanks.
- Turbo selections :(
- FS: Turbo stuff for all types of Honda's- ECU's, boost controllers, WG's, RC injectors, etc
- Any good tuners in Philly area?
- Twin chamber BOV v.s Single chamber..
- Turbo on a high milage car
- What pistons\rods for JRSC 6psi?
- Some probs, narrowed it down
- hello everyone im new and would like to say to all and let you know a little about my self!!
- How many of you still run a catalytic converter
- sfp turbo kits..
- What CC Injectors to use???
- just got back from dyno, my numbers kinda suck :(
- Profec B
- safe base fuel pressure
- header primary length, and FI applications
- what am i going to notice on dragII with an intercooler?
- Greddy Type S BOV problems
- anyone have a pic of a 1999-2000 civic with the front lower grill cut out for drag intercooler?
- anyone ahve a pic of there EGT sender position?
- AEM EMS software
- where to buy max rev manifold?
- 12s in a LS?
- JR Ported?
- f/s Nitrous Express N-tercooler kit
- Supercharger How-to?
- LOL! My girlfriends comment about F/I
- My car is alive again
- what size injectors
- Another HONDATA GROUP BUY!
- what can i do about boost creep
- Turbo and Hybrid Potential For New Honda Engines
- Okay, here goes. Hondata Group Buy
- Hondata (quick)
- Can't put a filter on my turbo, Help!
- Missing link map bypass... how do you clean that bad boy??
- HKS BOV
- pic of my setup
- 2 more weeks... then i give up and pull the turbo off
- Need some help finding a vac leak, well some advice
- i finished my 5-speed conversion...trying to get a 1/4 e.t. estimate for my set up
- Art, Dustin, Mark C..
- middle ground between stock and forged internals?
- One last time.....
- what ecu to run?
- What is code 76?
- Hey Arturbo
- Woo hoo !! Just ordered my turbo!
- Can someone please help me pic a hondata system for my setup.
- best boost controller?
- Just took apart my motor for the first time
- J&S Ultra Safeguard.... what exactly does it do?
- URGENT! I need a downpipe flange for a garrett t3 turbo!
- How to solve overheating after 2 hrs of running hard?
- Spoon Cams with Turbo?
- Help me decide!!!!
- Anyone interested in hondata 2b with boost for cheap?
- Hondata Group Buy anyone?
- Does everyone have a gasket between turbo and manifold or no? Necessary?
- JRSC@8psi + Hondata = Yummy!!
- 400+hp = what clutch?
- does anyone have a msd intank fuel pump?
- People with stripped interiors....
- Why I chose Multipoint injection
- nos in a b18c5?
- I'm boosting!!!!
- is getting a b16a2 complete including install the same price as..........
- FYI: Greddy ProfecB for sale
- How are JB Welded modified Starion intercoolers holding up?
- Kinda OT: Turbo Screensaver
- Wat do you guys think of water injection on front mount intercoolers?
- any one broken a piston or blown a head gasket
- FS: JG/Edelbrock Victor X Manifold
- OT: LSD Identification
- so cali. people...
- flywheel question...
- Will a JRSC fit in a B18C1/5G Hatchback hybrid?
- Block guard w/ benson sleeves? Search didn't answer questions.
- 10,000lbs/torque @ 10RPM
- T4 turbo
- D16
- Injector upgrade w/Drag 3, stock ECU, and stock Motor?
- J & S Safegaurd?
- I discover a new feature of J&S Ultra Safeguard
