View Full Version : Forced Induction
- precision turbos....
- stealthmode injectors? Anyone familiar?
- best set up for ignition upgrade?
- what rings do i run
- Retuned hondata on my z6 + another problem
- ceramic coating, good or not ? interesting link inside...
- b16a2 ready for boost?
- Fuel Filter choice
- Supercharged Exhaust Recomendation
- Turbo ID help
- Is it worth attempting to increase low end power on Honda engines?
- CP Pistons
- Problems on start up. (since recent turbo install)
- CRX charge pipe tips
- new rear mounted turbo kit coming out!!!
- Head Games
- Help on turbo!
- My SOHC turbo pics
- Rev Hard BOV question
- Stock 95 ECLIPSE GST BOOST
- where do i hook these up to?
- jrc intercooler users chime in
- Car wont start immediately after shut down...did search
- Gonna wire up WB to ECU harness, can I wire in my gauges to the ECU also?
- wastegate
- One of the Coolest Street Drift Battle Video!!!
- Turbo lag? b16 w/ greddy kit
- My Future Setup.. need your Advice Turbo experts!
- can any one tell me the specs on this "kkk"t3
- clocking/rotating t3 turbo HELP!
- Is my alternator on its last leg?
- UberNoober...
- bearing clearances
- Need help With JRSC Exhaust setup/size. Integra GSR
- Is a -3 feed line with a restrictor starve a full race t3-t67 turbo?
- relocating brake lines for a cleaner look?
- fuking that was quick :( .. help please!
- State Inspection (South East Pennsylvania)
- T6 Garret Turbo in a DA???
- one more q about stockb16 and boost
- turbo ecu
- turbo kit instal
- What Turbo is most popular and common to use on a B18B ls engine?
- turbo s2k missfire
- anyone tune Neptune in the Southeast (Fla, Ga, Ala, Miss...)?
- Neptune???
- Do these jet specs sound accurate?
- stock Gsr head... built bottom - upgrade valvetrain?
- tunning question...
- Liquid-to-Air Intercooler Question?
- Getting ready for jrsc. My compression test results, concerned about cylinder 3
- New Moroso Road Racing Oil Pan!!!! Pictures Attached
- GSR: GReddy kit vs. Rev Hard 2
- turbo rebuild
- greddy turbo timer went crazy...help?
- lovefab sidewinder v2
- Verify this install please. Profec B Type S.
- Remanufactured Turbo's Shaftplay (video inside)
- CRV Crank Pulley to Alternator Pully on GSR motor... What belt??
- ecu code ?
- all the uberdata sites are down where can i download from
- how vital is a catch can
- whose turbo is thier daily driver?
- LS crank in a GSR block w/turbo
- any advantage to painting IC piping?
- cel 10 on h23...... anything to worry about?
- Turbo setup question
- Ex turbo dp on a Dx
- 3 Bolt Downpipe
- any ct tuners
- Hondata tuners in GA
- B18B LS Street turbo setup question?
- cam gear necessary?
- rims/slicks
- ssac manifold - bracing it
- What would you guys do....
- BOOST ON A 85.5MM bored sleeved block?
- rc440 swap for rc550s will it run?
- Bottom end options for d15b jdm vtec >
- Radiator question for turbo kit.
- BLOX Mani + SC34 = Grinding
- t3 turbos
- - Ignition and plugs for LS-T -
- need k26 oil feed info!
- how long did it take you to piece together your kit?
- question about hondata with chipped ecu
- what gaskets do you need for a turbo kit?
- what engine management/fuel management do you choose?
- weird start up
- .::need info on 86mm gsr::.
- RC Injectors, Ball, Pintle or Disc?
- who's ran an fmu?
- Garrett GT28R?
- Overdue Props To First State Motorsports
- Cool SHOT Nitrious KIT
- PeakBoost VS. Full Race
- is my compression too high to boost???
- Question about newly built motor. About piston rings sealing.. Experienced input please
- Thinking of boosting: 138k old internals?
- saturated or peak and hold for b16 turbo?
- My new turbo manifold
- junk yard turbo question
- .:Need info on turbo selection::Searched::.
- Cam rockers....
- gt3040R VS. gt3540R
- Another Build.... **The Sequel**
- d16, 14g and a manifold that keeps my AC.
- MSD Programmable Timing Computer P/N 8981
- vacf good?
- b16 head ????? valves ???
- b20 rear main oil seal
- b16 vs b20 water pump
- Where to mount Zeitronix LCD in 92-95hb?
- Turbo del sol Qs
- which turbo??????
- Continuity .....installing DSM 450's....?
- Will my Gears be to short or just Right???
- LOW OIL PRESSURE... tried almost everything
- 4g supercharger?
- b20vtec turbo
- std and dx the same exhuast manifold?
- custom 97=01 prelude FMIC piping
- fuel management h22 turbo?
- missing oil....
- Amp style vs Twinky looking resistor box's, any difference between them?
- help with turbo selection for my set-up
- BBKA goes to the track and runs 12's... SOHC Power!
- knock sensor
- Anyone attending EFI 101 in Connecticut?
- Drag Turbo Kit On Accord
- TD04 Oil Feed Fitting ? ?
- proper way to install block gaurd
- Question about ATP turbo heatshield and DRAG manifold
- TURBOCALCULATOR??
- Can my 93 dx obd1 ecu be chippet to run a b18b swap and uberdata ?
- Greddy E-manage Pressure Sensor/Harness
- turbo kit swap
- Oil Feed/Oil restrictor Question
- Engine troubles...
- wtb some parts for a fi set up but....
- Wastegate actuator
- 238 compression
- Going from Revhard 2.5" DP to 3" change dia. before or after oilpan?
- RELIABLE
- questionable used T3?????
- pics of your bumper cut for intercooler
- homemade itbs and nitrous?
- need some advice
- Pics of a few manifolds we made for our customers.......
- Adjustment Bolt Broke off on my HKS SSQV
- How much do 2 gen (95) b16 heads go for
- gt30r + B18B question
- good places for a turbo rebuild in so cal?
- Need some help from HT.....
- Any experience with these 3" Mufflers?
- hondata launch control question
- impressions of a newer Clutchnet clutch...
- header wrap on turbo manifold
- Advice needed on mods for JRSC GSR Thanks!
- Need advice on 3 turbo kits. Which is better?
- 4" V-band Downpipe discussion
- 150 shot on D16
- Does a cam gear effect detination?
- Golden Eagle Manifold...what rail and regulator?
- SSAC selling bar and plate intercoolers now.... Your take?
- LS TURBO have bin told i dont need a fuel management system is this ture ?
- Ferrea Valves for type r head
- sleeves or pistons and rods
- just a lil nitrous question
- Idle problem after turbo install. *more inside*
- pistons for my turbo?
- Bumper Turn Signals After cutting bumper for intercooler?
- vafc tuning?
- D15B Supercharged Project
- hayame exhausts any good for fi
- JRSC on an LS ? Good deal, what do you guys think.
- need you to confirm this manifold
- are there any 14b turbo manifold for b-series?
- Vortech fuel rail d-series compatibility?
- Surging idle, Car wont rev, brand new built SOHC Turbo! PLZ help!
- Arias Ring gap
- which tb for type r intake? and what size the best for FI
- for turbo gsr cam or type r cam
- turbo d16 big power guys.
- 84mm mid gsr sc61 ac kit pics, sse teknologies
- Searched, no luck. Clutch related
- Havin a few problems with my NX wet kit on my civic
- smoke coming from breather
- Best Clutch
- how to install oil feed line etc etc
- Greddy Full Auto TT (searched)
- Turbo CRX burning oil
- power@half throttle, none @ full?
- boost on stock motor
- transmission
- Whats this Turbo Kit like? Will it work on a DA?
- need help making an 88 civic b16 make 500 whp
- uberdata??
- DID MY TRANNY OR MY CLUTCH GO OUT
- B16 ass-end needs more junk in the trunk
- something that can hold pressure?
- .42/.48 T3 on d16
- Convert P06 into a P28
- Can Someone explain this......
- Emission Problems
- Lower compression+higher boost / Higher compression + lower boost ...why??
- bad turbo seals???
- Major problem. water neck on back of motor leaving >>
- tell me about my turbo? need advice on my setup
- Help done installing my turbo runs fine but
- Quick question, wideband tuning
- 60-1 on a stock b16!!?
- Boost is backing off
- type r turbo?
- what clutch for 350-400hp
- trying to make my own turbo mani... need to find a merge collector. anyone?
- new headgasket install not working?
- what u can expect from t3t44 0.50 0.63
- breather tank & oil catch tank ???
- B18C.......I think i might be goin turbo...help me
- where can I find turbo manifolds for a h22?
- plx wideband? which one suits my need?
- Is it safe???
- zex with kenji chipped ecu............
- if piston rings are going out soon, will it do anything to the head?
- blockguard issue
- iabout to pick up a turbo. what can you tell me about this turbo
- Cleaning Block/Head Deck of Headgasket.... HOW
- 1 slim fan Good with a/c ???
- Oil in Compressor INLET?!? WTS?!?
- WHY it sux when my car breaks in the wintet with no garage...
- b20 turbo? has it been done?
- tuner for honda data in sac or san fran area
- Which motor mounts?
- turbo question ...?
- Block Guard Installation
- gt2871r or gt3071r
- Another sc61 dyno...
- MSD 6 BTM. Needed For Higher Boost? And Chipped Ecu....
- Stock SOHC Vtec tuning??????
- tips on drilling oil pan for oil return fitting?
- Fluidamper, What? No SOHC love???
- Where to find CP piston dome height...
- Flame away: I want to become a tuner.
- Just questions...
- NEW Greddy EVOTT (turbo tuned)
- all h22 turbo need some help
- turbo help!!!
- Best Lsd Differential out there
- turbo wont build pressure?
