View Full Version : Forced Induction
- I am kind of stuck on how to go about my setup
- what is the loudest BOV?
- gsr or si trans?
- Mild or Stainless for Turbo manifold flanges??
- whats longest your stock block turbo gsr lasted?
- tial wastegate hose hookups???
- is it bad to "slip" a puck clutch
- BOF springs?
- SOHC Turbo Kit on DOHC Motor?? What needs to be changed for it to work??
- Cant boost over 5 psi WTF!
- REV HARD vs. DRAG
- Horrible Spool times on SC50 SOHC
- 60 trim t3 with a 48 a/r...anyone used one?
- b18c1 turbo, are injectors needed?
- sohc turbo size with 250whp goal
- alittle advice please..
- Intercooler in's and out's
- MAP Sensor /Missing Link
- DSM install... Do i need to modify rubber ring at bottom?
- wastegate order question
- vafc hack--worth it?
- Turbo Debate
- New chassis (56k Warning)
- help with rc440 install
- fuel pump, 190lph or 255lph??
- New personal best
- How do I make a Quicktime video from my camcorder
- Need help hooking up TurboXS dual stage boost controller and Tial wastegate...
- trade grinding GSR tranny for LS tranny?
- ITR rear Swaybar and 3" exhaust clearance issues?
- 450+ hp people: Transmissions: stock?
- wastegate spring question ( i searched for it "wastgate spring)
- Help with tuning smc500...
- Sgt tunning comes to New england. Tunning available.
- Intercooler Spray Bar.
- Big 16g into a 89 turbo probe GT. have some q's............
- ls turbo or jdm itr swap
- Spec Stage 3 Clutch Kit
- manifold on turbo bike
- turbo choices for homemade setup
- Is it worth having a duall ball bearing turbo
- Turbo Cam??
- New upgrades...
- can i use the ge ls/vtec supply sender that goes on the oil filter for my turbo line
- Lost post: great in-depth comparison of turbo and supercharging
- Anyone have a pic of the pcv on a 95 ls integra. I search but none
- Turbo Help!
- DRAG gen 3 limits?
- Gsr Motor w/b16tranny discussion
- Pics of my car!
- Post your LS turbo setups and a few questions..
- Skunk2 intake manifold good for turbo?
- best 125$ bucks I've spent on my turbo setup, good tires and poly filler
- guess my HP boosted sohc
- JRSC Slipping Belt
- importparts.com - Mushroom Foam Filter Blow-Out - PERFECT FOR CRAMPED TURBO SETUPS!!!
- i have a weird exhaust question
- How much power needed for 25" slicks
- Where to start a d16 turbo project
- What to look for when buying a used turbo system?
- Tegs with DSM sidemounts what piping do I need?!!!!!!
- Smaller radiator for turbo space?
- d16y7 or y8 tranny
- dyno tuning vs. street tuning
- New numbers Stock D16a6 (zcsohc)
- air comming out of oil cap during leakdown? what does that mean?
- Need brass feed tee in MD/DC/VA ASAP
- Oil temp sender install
- need car tuned. indiana. willing to drive.
- turbo size
- question about oming out wires for resistor box intsall.
- All you THERMAL RESEARCH owners! Whats this fit?
- F*&^ING A
- Why does having a BOV automatically fail emmissions??
- Custom Turbo Set up Opinions
- ball bearing turbo?????????
- nitrous woes: loss of power, need help diagnosing.
- what do you use to cut siilicone couplers clean?
- Cast SideWinder is SOOOO close :)
- anybody runnin over a 250 shot
- Switching to manual transmission w/ turbo in mind. B18B1 or B18C5? (did search)
- Built 01 GSR will not start?????
- ITR vs. GSR cams for turbo? which is best??
- Precision Contect - Preliminary Results
- preset wastegate at 7psi
- Twin Turbo or Sequential Turbos
- Getting new studs for a log style manifold?
- Turbo rebuild kit?
- greddy kit won tspool until 4k
- can I hit 300hp with an LS with this setup?
- Can I hit 350 whp with a built b16 and a drag kit? How much boost and what setup?
- Pics of St00pid tuned, Mochanic built 465 whp b16 powered Civic
- I give up!!!
- stock honda rings with wiesco pistons?
- guesstimate whp?
- AEM UEGO WB Simply Question!
- would too much fuel cause the car to bog a little when shifting?
- what should the fuel pressure be at when at idle?
- Another stupid gauge question...........
- Emisions Inspection
- Tilton twin disk PICS! 56k maybe..
- Greddy Boost Gauge
- Hondata and Smog???
- tech edge datalogging
- can i get the nitrous guys opinion on this
- help!!! something weird sound ONLY when decelerating!!!!! wtf!>??!?!?!?!!>>>>>>
- Drag vs Greddy Turbo kit
- Jackson Racing Supercharger - boost gauge install help
- SC61 on D16... Don't laugh.
- What does a open dump tube sound like?
- Need help resistor box install??? aLREADY SEARCHED
- Transmission Mess
- how many miles are too many to turbocharge?
- geoffs civic
- Anyone use the S13 sr20det turbo? .80 and .64
- Any info on peicing together a cheap turbo kit for a Crx D series? Anyinfo appreciated
- Happy Halloween from the importparts.com team!!!
- LSD help!!!
- Screwed pistons, any input????
- AEM FPR
- Twin Disk
- Little vacuum port on side of T04E.. what use?
- My Turbo D16z6 Civic
- ECU CHIP + JACKSON CHARGER/ ZEX CAM???
- my MF2 kicked the bucket
- Schedule 10 or 40 for turbo manifold?
- Problems with Arturbo
- ITR throttle body or JG 65mm throttle body
- Turbo needs
- look what ups brought
- Its gone
- Who makes 3" exhuast(besides thermal)
- Stahl's at stop
- My turbo SOHC ... with pics !
- NITROUS + D16
- 4 or 6 Puck Clutch for Turbo D16
- Question about dump tube...
- used geddy kit
- Too much oil pressure or flow for the turbo feed?
- need help with intercooler choice
- What are people running with d16z6 turbo
- most power made on a "B" series motor supercharged?
- HomeMade TURBO!
- custom turbo kit companies in ohio or surrounding states?
- torque steer?
- trying something different...saab?
- AEM EMS and WB I have a couple questions!
- gsr crank in b18a/b, what rods/pistons - gsr?
- estimated track times
- i need and to know this tonight????????????????????
- WTB: T3 Turbo W/ internal wastegate ASAP
- Piston rings gone?
- turbo ALOT louder with wastegate vac line off
- Dyno: B16A Precision SC61 Hondata S100b
- 91 LS with 8psi.. questions.
- !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1
- Hondata and CEL
- Best valves for turbo Mini-me
- Anyone with like 30x10 or 30x8 IC on a teg?
- FS: 1g Eclipse blow off valve pipe
- Dyno: H22 463 WHP @ 14 PSI Pump Gas :)
- Boost Spike. Help Please.
- hooking up all vacum lines for smog???
- ? about clutchnet clutches
- Will this be safe?
- low vs. high compression
- Size of Turbonatics T3/T04e
- 84.5mm HG on 83mm bore
- ez? help out plz
- Serious problem with S2K oil filter
- Hondata ROMS: What is the minimum latency for the EEPROMs?
- which bearings? (did search)
- powdercoated valve covers or any parts. any intrest???
- 15g on a b series ....is it really ok .
- Zip or SMC owners
- VAFC hack....pros and cons???
- pics of EK setup
- stone headgasket
- SC61 compressor wheel???
- oil feed... how to reduce flow....
- i can't hear my turbo spool
- blitz headgasket?
- Using ABS plastic pipes for compressor inlet to filter?
- Favorite Method of Boost contol?
- adjusting cams gears on turbo prelude
- adj. cam gears??
- gsr cams?
- Opinions... on my first manifold......
- Stock B18B w/ Turbo @ 10psi hp?
- Problem with my maxrev mani...
- whats the max hp on 450cc's???
- Precision SC-50 compressor flow maps
- Can i get the same power out of an ls?
- Need opinion on this CLUTCH KIT please...
- check engine light on your Greddy turbo ??????
- Cheapturbo.com's newest 400whp club member! ::cough:: s2000 ::cough (56k a-ok)
- OBD 1 ECU for hondata question
- Aftermarket cats and emissions
- Flamenco-T??
- Where to get Raychem
- Finally, the completed 350Z twin turbo kit...
- somebody help me out
- Question on thread pattern for Cheapturbo 4-bolt wastegate Oil Drain Flange????
- IC Piping....
- removing Inline pump, will it mess up tunning?
- Which Cam Gears for H22A ?
- Weird question
- Intercooler question
- Turbo manifold collectors
- Greddy Turbo Kit
- which is better....????
- Dyno Shops in the Denver, Colorado area
- What is zip tech? I did do a search
- what A/F for conservative SAFE tune?????? on street diff than dyno load right?
- d16 JRSC
- TurBO kiT
- turbo si
- Turbo Integra acting weird..please help
- do they make a kit for this?
- Big Box outside the door
- intake manifold
- quick newbie nitrous question
- will really small chare piping work (if its the size of the turbos exit)?
- Could this be a Hondata issue?
- can anyone recomend a good kit for an ls in a crx? I want FAST spool!
- Are All T3 and/or T04E Turbos the same whether they are made bu Garrett or Turbonetics?
- Worth it to upgrade my piping and IC?
- hack$$$
- Over fueling problems..
- (OT) Not honda related, but intresting vid!
- When do you need and Ignition upgrade??
- How much of a role does compression play in a turbo spooling.
- turbp q's (search-n/a)
- Anyone know how to tell...
- Help, CEL when A/C ON
- Where to buy turbo parts? I mean actual turbo parts
- Oil Pressure Saftey
- New Pics but little progress. Turbo/IC pics
- Explaining Specs of a Turbo
- Anyone have or know the exact wiring for the resistor box on a 2000 Integra
- Turbo size
- D16 Jackson racing supercharger???Searched foun nothing
- Looking for a Aftermarket LS intake manifold for FI
- how much this cost around??
- i THINK i may have found the culprit!
- Help me & shut the brother up!!!!
- For those looking to save a little $$ (OEM injectors)
- Boostin ITR Owners....Which BOV do you use and why? (Need Advice)
- whats longest your stock block turbo gsr lasted? / help with setup
- is 525cc injectors too big?
