View Full Version : Forced Induction
- Venom vcn-1000 nitrous kit
- problems with first turbo, please help mee!
- -10AN/-8AN Fuel Lines
- motor wont hold boost
- Where can I get RC injector gaskets?
- Quick Noob question
- Greddy emanage.!! Is it good or not
- Rod bearings
- Crank question
- Best built LS-T on a budget
- NOS on a mInI me
- I finally have a reason to post here! Can you Turbo junkies take a loook?
- Do I hace a chance?
- installed an apexi fmic and piping from an eclipse gst onto my eg
- What does "B13 TDC P" do?
- WTF piston/rod help
- Turbo cams with nitrous?
- help diagnosing, turbine wheel does not rotate!!
- B-Series EGT people, how is your wire routed?
- which wastegate is better tial 38mm or 44mm need opinion
- the craziest cams for turbo ls\vtec
- block gaurds
- PLUGS?
- What do do with wastegate exhaust.
- dowpipe with inline pro manifold
- Is my turbo Bad
- 4 Turbo questions - from a NOOB to forced induction.
- results on my compression test
- FI cams
- people with t3 5 bolt flange/downpipe setups, running a gasket?
- whats better 82 a\r or 63 a\r which do u prefer
- Apexi vtec controller settings
- Hey SC61 B16 Guys......
- backfire like a mofo
- How many miles did you boost your Honda with?
- GT30R T04E or T04S???
- Best build for boost
- ls turbo help
- Anyone have overheating problems on a daily driven built motor with a blockguard?
- flange?
- Question about compression and leakdown???
- sohc turbo question
- Did you ever seen this D-series headgasket ? D-series guy take a look please ...
- is it nessacery to plug the coolant plugs on a turbo?
- which vac nipple on this bov?
- got msd 6a laying around...should i put it on?
- Head lift during dyno pulls, read more...
- i need help with turbo
- anyone running or hear turboxs RFL bov?
- Thinking about getting dart b series block???
- yes for vafc or no?
- what do you think
- Hondata chip??
- iLeaning out.... at only 6psi
- Adding BLOX intake manifold will it?
- wont go past 5k
- turbo clocking question
- WHAT TURBO COMPANY DO YOU FEEL IS THE BEST?
- D16y7
- throwing solid cel....cose 0 ecu need help
- any way around the e-manage cable? usb to serial?
- h22 boosting low, whats up.
- hiding nitrous
- civic put down 305whp, but now alot of smoke
- HELP! Leaking oil
- How much OIL?
- How many people are running the greddy blue box?????????????
- 604whp Accord..........
- Just got tuned...
- question
- J&S Install Questions
- pros/cons of running R5671A-9 plugs??
- Do I have to rebuild my turbo?
- ARIZONA (PHOENIX) PLEASE READ
- to filter or not to filter that is the question....
- Safe A/F Ration on 10:1 CR
- Turbo on D16z5 or D15b7
- "Ring Seal" and other oil additives...do they help stop oil loss???
- anyone running double stacked headgaskets??
- compression ratio for turbo set up
- gasket
- Stock Greddy Kit and 3" exhaust question
- built b16
- Can you hear the turbo spool more with a open downpipe????
- overheating, only after long (45+ minute) drives
- Full-Race Stage 1 on a stock GSR block...bad idea???
- msd 2 bar map sensor
- sc-61 question
- 91' CRX need some advice
- Turbo Size question
- Silicon Transitioners??? i need 2-2.5 Can someone HeLp~!!
- wastgate hookup??
- 3" elbow
- Is this okay?
- greddy blue box work on obd0????
- vitara pistons?
- bearings? please help
- Do i need a MBC to raise boost on greddy kit?
- how much power will a stock d16z6 make with a t3 super 60 at 12psi?
- Peakboost manifold w/38mm Tial
- t25 air filter
- How will "turbo" engine perform w/o turbo?
- 3" exhaust with a greddy kit???
- Turbonetics Caste Manifold for D-SERIES yay or nay
- Tial 38mm spring
- Over-torqing head bolts ok?
- Head gasket For boost???
- is there such thing as supercharger for civic?
- whats up with my turbo?
- BlackTrax K24 Turbo...
- start up/timing issues help please.
- boost surges from 12 down to 9ish and back....Need ideas
- Street tune best reliability 4 daily driver in Bay Area? Local shops only dyno?Wait for MASE?
- Best BOV Video Ever!!
- New to the whole turbo thing...have a few questions
- Which Hasport Mounts?
- Rut Roh. turbonetics and garrett
- gaskets
- hondata question
- turboing b16
- Clutch Masters Stage 4 on gsr
- Car boggs and backfire at high boost!!!
- Boost activated exhaust cut outs?
- Integra ZC, How muich can it handle?
- nos question (not sure where to put this)
- D15b ninjas!!!
- 70k too many miles for stock block turbo?
- where to get Fire ring for tial wastegate??
- how do you pressure test charge pipes?
- want go past 3100rpm then boggs..
- Nos spray for the intakemainfold
- WRX turbo
- Who painted their intercoolers?
- Slim line Fans
- Stock LS injectors
- what all do i need besides hondata?
- where to buy SFP downnpipe
- Which WG spring is this ?? (Green) *PIC*
- ls or gsr? turbocharge
- ATT Hondata freaks!!Hondata S200B throwing code 1 (O2 sensor)
- b16 build up
- ACCEL DFI
- turbo civic on ebay
- turbo'n b16a2
- Jdm fuel pressure regulator
- help me finish my setup..
- turbo'd b18c1 block has carbon (?) buildup?
- Replaced my MSD blaster SS coil for a MSD Blaster 2 coil... is it ok or not ??
- integra turbo question
- Air filter
- Wastegate open even when not boosting????
- D15B honda civic
- in a D15b turbo ..... T28 turbo
- can I use NOs in a D15b
- remote mounted turbo on a honda????
- WTF is wrong with my car?
- Finally Tuned, numbers inside
- turbo rebuild kits
- turbonetics t3t04e downpipe?
- any bone stock gsr turbo guys?
- anyone have any pic or a diagram on how to hook up a resister box
- Smoke after new motor build. *more inside*
- What do I need? Difference between "Saturated" and " Peak and Hold"?
- turbo cams on gsr
- rc fuel injectors???
- Something is wrong, but what???
- bad mustang dyno calibration?
- specifications of the stock GSR camshafts
- what size is 1/2 pressure nipple fitting converted to AN?
- Unhooked Evap purge control solenoid
- when you rev from idle, does fuel pressure rise or fall?
- Built H22 Compression numbers?
- k pro tuners
- turbo GSR 10 psi will 440 be big enough
- What kind of intake fuel pump ???????
- Ebay turbos
- what size injectors? turbo crx
- Choosing intercooler for 400whp - JRC vs. boostcoolers
- Turbo GSR with Stock Bore and Stock Sleeves? Quyestions???
- arizona emissions
- running a turbo on stock block?
- help please 12a mitsubishi turbo?
- dsm obd2 450cc injectors oem h22 resistor box
- debating between 4 turbos for b16a?!
- Base map for turbo edit
- Water cooling turbos
- What blockguard for the B17A1??? And what does "o-ringed and sealed" mean?
- Air/fuel questions...
- EFI tuning books and websites
- difference between precision turbos?
- water and oil cooled turbo
- Where to tap for nitrous fuel supply?
- 34.3 Aluminum Freeze plug
- BLOW BY
- Drag mani redrill??
- nitrous setup do i need cam gears
- can you cahnge internal to external wastegate??
- EGT probe compatibility
- Installed turbo kit today got a couple ????????????????????
- oil feed installation questions D's only
- Need Advice on Precision turbo to get.
- Need opinions FAST PLEASE!!!
- is this good for a gsr motor???
- T3/T4E 57 trim with .63A/R too big for b16?
- What companies rebuild Garret GT series turbos?
- wastegate - Internal-VS-External
- Turbo laws and insurance?
- 01+ Civic Manifolds?
- B16 Peakboost kit, Tial WG, holds till vtec then massive boost creep
- couple questions plus 500 hp monster pics
- Fuel pressure on a nitrous setup
- oil feed line size?e
- rods through block, quick question?
- CAMP1320... IM VERY DISAPINTED...
- softer engagement after tune
- Pls help me with my hatch.....
- oil leaking from somewhere,cant figure out help...
- do i need a MAP with hondata
- ECU Mounting for OBD1/OBD2 swap - how to make invisible?
- Turbo with Crower Turbo Cams
- Finally built and Tuned by Mase, 478whp 344ft lbs tq
- EVAP purge solenoid
- Piston to deck height
- Ideal air/fuel ratio...?
- dyno tuner in/around Indiana
- anyone have a side exit downpipe?
- turbo Q's for 99 si
- 300whp not cracking it...shooting for 400whp (minimal expenses)
- t3/t3 .63 exhaust 57trim vs 60trim
- Whats everybodies Fuel Pressure at?????
- Where to buy Garrett turbo components?
- SRT FMIC on my HB???
- Aem tuning
- Turbo and Timing
- Max Oil Pressure A Turbo Should See ?
- new setup COMPLETE!!
- -3AN or -4AN oil line to turbo.....which one is smaller?
- Blowoff valve spring rates?
- tunning?
- Bosch / Endyn intake pump HP limits
- Knock Sensor needed for turbo setup or not?
- eEdelbrock VictorX trouble brok where the stud goes
- Looking for experienced welder to come help me in RI
- How do my times look?
- engine bogging out b18b1 HELP!!
- ????? new to boost i need your help with my greddy turbo?
- cf hood and turbo manifold - how close can they be?
- b20z turbo help?
- Compression Ratio calculator where is it at?
- fmu till i could afford to tune my hondata ems
