View Full Version : Forced Induction
- 350hp turbo
- UEGO install and wastegate question!!
- AEM 320lph
- P0108 - MAP High Voltage - Boost=<5lb
- cb7 turbo f22b1 lots of crankcase pressure
- D16 Turbo and Nitrous
- Go-Autoworks one of the best companies
- Hondata, Neptune, or???
- d16y8 stock, building for boost-input?
- Block guard or no guard?
- PTE 6262 Compressor Cover Removal?
- Oil cooler pipes/location
- Nothing but water in my catch can, sign of anything?
- High HP guys, some build questions
- K & N Cold Air, Throttle Body Spacer
- has anyone ever monitored transmission temperatures
- Piston to cylinder wall clearance (darton sleeved block)
- b18a1 600hp build
- B16A Pistons & bore question
- 2000 civic boosted b16 problems
- B20 V.S. LS
- Precision 5031e vs the new Precision 5531
- DSM 440cc for turbo setup question?
- Which throttle cable? [jrsc ef b20v]
- Precision Billet CEA 5831
- Cold Air Intake Box for a turbo
- b16a2 help
- New Dyno numbers on my Darton Sleeved GSR Eg
- little help plz..civic ef turbo ac friendly
- B16 Turbo... 9.0 Compressiong or go higher?
- CSS Block/BWs366/Q16-LsVtec Build
- b20v, or lsv or non vtec
- Standard bore B16A ?
- D16 EDELBROCK FUEL RAILS.....CHEAP
- EDELBROCK INTAKE MANI....CHEAP
- darton sleeve help
- JRSC questions..
- Help to connect MSD Box?
- My D16T ( Nothing So Special )
- 94 sohc turbo questions. will this work?
- Turbo Coolant Line Routing
- Help! What turbo should I use?!
- Need Help!! I have an LS Turbo EG HATCH...
- best set up for LS-T?
- sc34 shaft bearing?
- BlaastPerformance Ebay Turbo Upgrade/Rebuild
- Turbo selection
- B16b
- 2.25" Intercooler piping restrictive for 300whp?
- PTE 5831 vs 5858
- LS/Vtec Turbo Build
- Piecing together a b18c turbo
- some advice should i finish the turbo set up or go N/a
- my turbo build problem
- looking for a shelf kit for a b18c1 setup
- ****98 Civic Coupe (JDM B18C Boosted Sputtering / Idle Issues Help!*****
- Does anyone actually have a f20b turbo set up?
- trying to turn my na commuter to a boosted weekend warrior.
- Aluminized VS Mild Steel for DIY exhaust
- question about ,maximum injector fuel pressure
- Reliable Turbo B18
- 310cc ingectors on stock boost
- Help making a decision..
- aftermarket cam, please explain? (vtec newb)
- My 60-1turbo LS Integra street radials(new personal record)
- Not Holding Psi...Wastegate Spring?
- Greddy TD05H-18G upgradable parts?
- headgasket oil leak? Oil leak near edge of block, Pictures inside.
- d16y8 bottom built safe boost
- GSR jrsc build need help
- What kind of sleeves are these?
- SOHC turbo cam suggestions?
- vitara pistons
- Mandrel exhaust kit, anyone use this site?
- Must have guages for a turbo?
- oil problem
- D16z6 vs B18b1
- Sohc/Dohc turbo
- my b20 (b16) turbo build (in process)
- dual walbro 255 intank
- Is this real...JM F22b SOHC Turbo engine awd
- Bullseye Power Turbine Housing Identification
- -Video- 11.72 @ 124 @ Stock b18c 15psi open diff
- Turbo advice
- D16 turboed Carnage
- Looking to boost my 99 CRV
- Sc61 vs holset h1c
- Doing a single cam build. Like to hear your thoughts.
- 1/8" PT - will it thread into 1/8" NPT and seal?
- Exhaust for turbo d16?
- Best place to put ECT probe for gauge? [B-series]
- blown head gasket?
- Dynamic ignition timing discussion
- boost by gear in high/low boost setting
- Can i still use these?
- Fuel injector problem?
- Having manual boost controller issues..
- Full Turbo Kit Build?
- 93 civic turbo
- boost set up
- b18b1 build for more power.
- Legitamate Boosting Questions ( I hope)
- Which wastegate....tial, precision, or turbosmart???
- Turbo center section not sealing against exhaust housing
- B18a stock, looking to boost.
- Turbo Selection Help!! K serious inside...
- Relationship between EGT's & Ignition timing
- Car surges when hooked to mpx4250ap sensor?!
- Bov "exhausting" air while idling, increased with rpm
- cleansleeper's Turbo G23 Build
- 400whp b18
- Intake manifolds
- Pure Turbos
- hks ssqv stay open at idle?
- Civic Si / Turbo involvment ?
- full race turbo kit?
- Can someone help me ID this Intake Manifold?
- ls-t build opinions
- lsv turbo questions
- what size fuel line
- Forgot to install thrust washers?
- Is this oil feed set-up okay?
- 200-300hp D16z6 bulid
- help me choose..
- Question about Spoolin Performance
- Score of the week
- If you were to Supercharge? Brand & Why?
- Turbo b20b p8r Reliability
- Need opinions...big external coil needed for 500+ whp??
- Single Scroll manifold, twin scroll turbo with Quick Spool Valve (SPQSV)
- AFI Bottom Mount Question??
- need help new to the FI
- B16 Jrsc gaskets?
- Where to install EGT sensor probe in header?
- Oil on a clutch make a dyno graph like this?
- how to check a leak in the charge pipe?
- My weekend toy/drag car. Slowly getting done
- Need Help Building a 350-400hp engine!!!! Clearances, ring gap Turbo high comp. LSV
- Turbo kit help
- I've been spoiled by torque
- In a situation
- Five-O Motorsports Fuel Injectors?
- Fluttering..
- can you tell me what turbo this is PLZZZ??
- b16a/50trim/peakboost..hitting the dyno again
- my spool results of log vs tubular manifolds logs spool was faster but make was less
- PTE 6768, 14 psi on F20c
- turbo 91 crx
- Heat Management Testing and analysis (DEI Heat Wrap, Turbo Blanket, Reflective Tape)
- What is the best turbo for b18
- go-autoworks prices
- Authentic Garrett turbo?
- VTi Turbo
- CRX + GSR + JRSC - does it fit?
- V-Bands are great.....BUT
- hey guys...
- Heat Wrap cracks manifolds?
- Oil Weight - My oil pressure is insane on cold start and driving
- What do you tell the parts store, for a half sized dual core rad cap...
- turbo b16a2 bogging before boost 0psi
- New engine break in concerns
- bc stg2 turbo cams
- Teggieetuners LSV-T build /600whp?
- Thrust washer/bearing question
- Unknown issues with map?
- CRX turbo install
- What Turbo Would You Put On My B16 Turbo Set-UP???
- boost vs NA... whp vs whp
- Cast top mount questions
- B18b fully built bitten end
- Ls/Vtec which pistons for boost?
- Meth/h20 injection wear on JRSC blower turbines/internals?
- TiAL MV-R Spring Help!!
- Turbo GSR 500ish whp fueling question
- Need Advice on parts for turbo prep
- Roto Master turbo
- Garrett TP38 (T4) Turbo too big for LS/Vtec?
- Need opinions on a block setup!
- Limits of stock ignition system
- Darton Sleeved Engine Question
- boosted high compression
- Turbo Engine Question
- basemap question
- ls vtec turbo lose power in 4rth gear
- which ATI crank pulley for my Turbo civic@600HP?
- Turbo F20B CF4 Accord SiR-T
- Injector wiring....WTF... Help
- the turbo drama continues aka wtf caused this
- Precision 3 5/8 v band on t4 6262
- Help with gasket?
- gsr pcv size?
- Swirl Pot or no swirl pot
- RC440s in y8 manifold fitting right?
- Building a quick spooling high compression bseries @ 300whp?
- turbo and tuning
- Hx55 comp. map?
- Too lean for my tastes
- 84mm supertech 9:1 b16 stroked Crower h beam rods
- Gm 3 bar map sensor plz help quick!!
- I need your help please.
- Headgasket issues
- ID1000 Seat Cushions
- turbo D help
- drew17ths 84mm b16 dyno results/experiences. KStuned
- need some pro opinions on P2W with cast 336 aluminum pistons
- InLine pro V/S GSP manifold
- my b18c1 build
- Want more power from b16
- tuned the car and then it died on my drive home!
- JRSC optimal pulley config?
- Top Mount Vibration
- sites to order from for rebuild components
- Trying E85
- Do all vacuum lines need clamps after turbo install
- Wastegate has 3 ports. Can I run off the spring at first, then to MBC
- B-Series nitrous cams any suggestions?
- checking used block internals? pic
- Newbie Turbo Questions here
- Catch Can Questions...
- tricky no boost problem,pros needed..
- what turbo to use on b16?
- adjusting cam gear timing for .074 head gasket
- Moroso Oil pan capacity question?
- My turbo b18c streetcar build
- Hondata K-PRO is now $300 cheaper!
- B18c block with b16 crank.Rod/stroke setup question.
- What to do with 6265 with a bent shaft..
- Floating pistons???
- Open DP Fab, straight down to ground, or bend it under the pan? NOISE!
- Jackson Racing in good condition?
- Intake/Compressor boost sources. Which to W/G, which to BOV
- Catchcan placement - does it need to be placed very high?
- Need help with Apexi Neo install. 97 civic running P28
- D15b7/a6 turbo help!
- CEA Turbo?
- Will I reach my goal??gsr turbo build
- Damn!turbo locked up...
- Re-using head bolts
- turbo b16 afr problem
- R18 Turbo - Intro
- skunk2 pro2s who has used them?
- Msd 7 map and software
- Turbo charging a monster 493 CI big block
- Turbo b18 Integra Question.
- Turbo Questions
- water/meth users - how do you activate?
- After thé pump GAS?
- Anybody know which manifold this is?
- 350whp 250trq Ls/V Turbo High Comp!
- Precision 6266 HELPP
