View Full Version : Forced Induction
- PeakBoost a LS
- turbo civic shutting off!
- Dyno sheet: 394whp/387ft lbs. 27psi Turbo Neon
- which intake manifold for quicker boost
- Vx to Si throttle body
- big turbo crx problem ... NEED HELP FAST.......
- W.T.B. h22 in an integra turbo manifold
- mysterious oil leak / explosion / spray ( i have about two days to fix so please help)
- to those with stock internalled motors at their limits....
- wear in stage for greddy turbo...???
- Anyone bought from these guys?
- - Sprung hub carbon clutch opinions on this product comming out.
- Quick question about spool time and backpressure?
- Who makes air temp guages?
- code 20 , no vtec
- JRSC on a GSR w/ a Pr4-4 Head
- Who has bought a 3 inch kteller cat back for a 92-95civic and how did it fit?
- Full Race connecting rods...who's using them???
- Anyone ever turbo a motor that has big cams?
- painting IC
- smallest nonbb turbo with out loosing top end???
- goin FI
- forged rods/stock pistons?
- Red 2000 Si Turbo Stolen Charlotte, NC
- 3 vs 4 An oil feed lines???????/
- Do my timing numbers look good for a turbo GSR?
- Crower Rod Failure
- boost drop with profec b on greddy 15g...any help?
- Launch control on TullosTech EBC
- Oliver rods?
- need some info on sohc vtec boosted.
- Intake temps after turbo and intercooler....what you guys getting?
- Supercharging my Integra!
- Possible to make a oil/water cooled turbo to just an oil cooled?
- how much boost would it take...........
- Just installed turbo with greddy blue box, car died and won't start
- "turbo YZ" ?? Garrett Knockoff... I got scammed..
- just retarded my dizzy with 2 deg (at 14 now) on D16Z6 and ...
- accel dfi wiring diagram?
- looking for used supercharger for sohc d16y8
- Vacuum leak, white smoke, low idle...
- Evaluate this radiator.
- Dyno day with Tony1! Im in the 400hp club!
- eagle rods versus tuner toys rods help needed
- Old DSM turbo identification
- Will It Fit: SOHC VTEC SOLENOID On DOHC MOTOR?
- JRSC alternator stepper pulley issues
- b18c5 b18c1 or b16ek9 type r
- 617 hp 425 tq on stock gsr cams and gears!!!
- turbo spool problem??
- manifold for internally wastegated turbo?
- Synapse Missing Link Installation-B16A
- TPS wiring
- newbie searched !! but not exactly found. turbo on eudm b18c6 type-r integra
- Looking for an electrical oil pressure light with warning
- Adding boost option to hondata s200
- Need help with the S-afc wires.
- Garrett Turbo Identification (56k Make a sandwhich)
- DYNO- motor fine-timing wierd-horsepower not fine
- lower compression/modified ignition maps : Uberdata
- The Build Up (Integra GSR to Integra 600WHP GSR)
- AEM ems and hondata questions
- b16 supercharger help
- *My blown motor*
- accel dfi
- turbo oil feed question / possible problem
- Please dont flame me, (turbo)
- 2004 RSX Type S getting TURBO!!!
- 2004 RSX Type S TURBO!!
- cam in!! ...now should i spray????
- gt3030 or gt30r??
- 87mm CP Pistons
- > Will my turbo eat my filter ? <
- Tranny Rebuild Parts
- Transmission help. Not another gear ratio fight.
- Looking For a map to start off with for crome or uberdata 84mm ls/vtec turbo...... HELP if ya can!
- What coil pack system is this?
- about to drill oil pan please look to see if ok..URGENT
- quick before Home Depot closes - what size fitting for t3/t04e oil inlet?
- what is the most hp with a turboed b16
- Turbo Question ?
- Can anyone verify my numbers....?
- higher PSI = harder to start?
- nitruos question
- Rebuild kit for T3/60-1 turbo
- car wont stay runnin....
- SAFC Tuning Issue
- Pauter Rods Availability
- no spark.. need help !!!
- B16 rods in a B18c, will they work?
- water temps too high??
- Buying a used turbo........
- hondata s100- does is the boost reading accurate vs. electric boost gauge
- the compression results are in.
- turbo squeal??? prolly something easy
- Manifold and downpipe combos
- AEM anti-lag - HELP
- Thinking of doing custom turbo on my ep3
- no boost, wastegate leak?
- h22 map compared to the gsr map (uberdata)
- Stan (Flamenco-T) is the man.....
- info on omnis master cylinder
- angled couplers???
- turbo d15b7/d16y8 mini me @ 12psi
- Anyone ever use Dynotune nitrous stuff
- asked over and over again- DISCUSS traction and driving technique.
- Dumptube question>>>>>>>
- Golden eagle vacuum manifold
- where can i buy just the NOS plate for the gsr... i just need the plate
- Post up your Booster Type-R Setups!
- will a D15 hold up?
- running really hot
- best sleeves?
- 303whp and 260ft/lbs stock block LS
- built SOHC, IS IT OK FOR FI??? SOHC gurus help!
- Two BIG turbines.
- question (not really honda related but turbo related)
- GReddy 15G 5psi on D16Z6 - changing timing on the dizzy Q ?
- FPR spraying fuel! Help.
- Am i forgetting ANYTHING????
- Question about nitrous solenoid
- I just switched to RC injectors 1000cc from Siemens Deka
- Bad Seals?
- Tuning: Vafc1 or 2
- msd inline fuel pump proper installation
- precision sc61
- WTB integra LS 98 supercharger
- buddy club head kit/turbo
- Why do i need a 3 bar map sensor?? And Do i....
- oil pressure
- IC piping question...uh oh
- What BOV shares same flange as a 1g DSM?
- Turbo clocking bolts. What size.
- Place to Buy Oil Catch Can + PVC Breather
- Center cartage section full of white stuff
- boost dilemma
- need uberdata basemap for h22a
- Anybody know a good shop in New England that does braided lines and fittings?
- how long of flex pipe--- searched
- bov
- please give me a picture if you own a gsr with JRSC set up.....
- Charge pipes?
- attaching blower to jr mani, did you use silicone?
- Uberdata on 98 EX (built motor)
- problem with the fuel regulator....help
- anyone here know of JDM2 in fresno?
- oil in my ic piping, wtf is goin on?
- B18b1 turbo owners... What's your fuel management. Need advice.
- proper vacume diagram for turbo setup..
- what filter for full-race kit stage 2?
- supercharging a gsr(have searched tons already)
- quick question on cooling a turbo motor
- help with some turbo stuff
- Aem 5 bar map DOA Please Help
- precision sc34 vs. garrett gt28r?
- JRSC prices
- A/F ratio during idle
- Ross pistons
- HELP!!!1 Integra isn't boosting!!!!
- Determining Injector Size?
- Is your Turbo made in China?
- Flywheel questions... And I want answers from people who really have LFW setups.
- Problems with Greddy profec b (Original)
- questions when street tuning with a wideband
- arias pistons part number check B series 8015 HP ??
- which ngk plug to use on my d16y8
- B20/Vtec/Turbo....LACK of OIL??????
- t3 on greddy mani
- turbo guru's question that I don't think anyone has tried what do you think
- what tranny should i use on my turbo setup
- b16 turbo tuned at 15psi with stock map sensor and missing link
- hondata install????
- help!!what turbo size recommended
- keep gsr IM or go blox/sk2?
- Strange valvecover problem with friend's car
- Boosted d16z6 guys, how high are you reving stock valvetrain?
- SX fuel pump install questions?
- Fab-Works new CNC bent IC Piping
- d16z6 t3/t04e help
- Is this intercooler bad????
- H22 A/C Compatible Turbo Manifold, Downpipe, & Intercooler Piping for 90-93 Accord
- how big should the holding tank be for my air----->water IC
- upgrading hot side A/R question?
- aheap catch can..will this work?
- block guard install
- Help Analyze Muckman's Smushed Spark Plug
- My new turbo from Speed trap!
- 10psi on 310cc injectors
- JSRC w/ skunk2 mani. possible?
- apexi turbo timer instal
- LS Turbo problems
- Turbo Experts. What turbo is this. You got an idea? Some help please.
- which turbo cam for my z6 head?
- Where to buy a 3" flexpipe?
- No room for ac fan...
- Stock LS valvetrain: how high is too high?
- kteller downpipe
- AEM EMS ?
- mini me and jackson racing??
- Jdogg Tuning in the NE July 25-30th
- Where to get TIG Welding done on Valvecover in Orlando, Florida area?
- can i use two wastegates to avoid boost creep
- Any places in MD to fabricate a dumptube? or to buy one online?
- HUGE Problems!!!
- plz post pics of ur huge ic on ur eg . with the bumper cutted
- replace all 5 motor mount inserts? es + prothane?
- Confused, can this be done?
- question about HKS blow off valve inserts
- plx wideband questioin....
- Turbo oil supply..?
- Boosted GSR with T3 .48/.42 at 7-9 psi, need to upgrade catback?
- I need advice on putting ic on a hb
- Which tuning do you use?
- Anyone running without a motor mount???
- do t3/t4 turbos come internally gated?
- Head works
- my fan isnt spinning
- how to custom build a turbo kit!?
- Garrett compressor fitting
- Trouble shotting needed for an LSD installation..
- my little brother turbo kit. (nissan)
- Can I change my T3 exhaust housing to a T4 on my SC61???
- K20 eg swap with JRSC....Same modification as the Hasport CRX??
- 609whp...619whp....401whp...ALL TUNED BY MASE
- weird problems started today, whats causing them?
- n00b fuel management question
- Turbo setup?
- boosting a b16b questions?
- sve 3bar map sensor
- 60/40 ok?
- T25 flange help
- making your own boost and oil pressure gauge????
- t3 42/48 or 48/60 for my d
- boosting a b16
- best turbo manifold for a.c
- generally speaking.......prices on turbo parts?
- b18b turbo hit the dyno tonight
- precision sc61 on a stock b16?
- Post your post-turbo gas milage results
- turbo question HELP!!!!
- How should I run my IC piping? (56k warning)
- cant fell the 55 shot???
- Will a wideband still read effectively if you are running a open dump
- How to pass emissions on a catless turbo honda
- good clutch for B16 turbo
- Wastegate HELP
- oil line Q's?
- Need to know....HELP
- compression ratio and boost
- Is turbocalculator.com a reputable website? if not then who?
