View Full Version : Forced Induction
- D16z6 turbo. Good setup? URGENT!
- How do I connect the VTM on the VAFC
- Integra 75 Shot
- Max boost with T28?
- what flywheel? high HP people
- The car runs, BUT NO BOOST! Also the engine wont go past 5K
- Intercooler water sprayers
- Who's running rev hard stage 2 turbo kits???(more)
- Question for ppl that has an Apex intercool
- Did I get the right Chip? 27c256??
- Oil return line?
- what can you use to retard timing for N2O?
- When is a FMIC too big???
- eg turbo
- My first Turbo setup
- EGT temps.......what should they be ?
- Another Wideband 02 Question
- need your guys' help!!!!
- why is my pcv breather smoking??? help asap!!!!!!!!!!!!
- getting cel 3 with missing link but no limp mode??????
- My turbo install: not fun - b16 EF Pics
- WTF IS V/T CONT and V/T unmt??????
- Went from Kit and now doing custom...need a good idea what turbo to start with
- Is a t4 too big for my setup
- HEY IT'S ALIVE! It runs. Ill have pics up in a sec, but it runs good.....
- JRSC & what header?
- does anyone know who makes a nice distributer block off plate?
- Skunk2 chip w/ Turbo~ Injectors size
- Car floods after pumping gas!?
- finally got pics (friends homepage)
- Just bought a Prelude JR SC - Need Advice for fuel & timing controls
- Afc-hack setting using V-afc without vtec
- misfire q's
- Question about JDM LSD's off of ebay
- i think im running lean when i do a cold start
- Would an HF manifold work....???
- t3 compressor efficiency maps......
- need advice, buy a quaife yes or no?
- intercoolers
- Techedge WBO2 Question ...
- missing link question,very dumb question!!
- where can i buy the MICRO 0.020" drill bits for MBC
- Guess what full race sent me!!!
- Cheapest place to buy SOHC Greedy turbo kit?
- Engine noice possible piston slap *VIDEO INSIDE*
- GReddy turbo kits? Yes or No?
- what does GReddy blue box do?
- Quick yes/no question...
- Which exhaust is best for my TURBO LS? Best and cheapest?
- ECU Chipping 1K Ohm Resistor: 1/2watt or 1/4 watt? Does it matter?
- Best inexpensive turbo kit for d15b
- Boost Questions 94 LS turbo...Fuel pump, lbs of boost?? opinions/advice
- How should I run Nitrous in addition to my turbo?
- PLEASE READ!!! just got my hondata and now tony1 is leaving
- how much power do honda's make with trubos chargers nos
- who will build me a bottom end and what kind of pricing am I looking at???
- Problems connecting hondata and FJO to use auto tune
- PLEASE!! can someone explain this to me...
- Using Dual Wastegates???
- School me, im ready for boost
- boost on long trips
- GREDDY KIT and D16 -- What are you making?? need to compare my HX to other d16
- Wastegate size ?
- losing boost??
- Gator Racing Axles has arrived
- Opinions, buy some internals for boost? Or buy a bike?
- S2000, 16.5 psi of BOOOOOOOOOOOOOST
- water injection
- Why am I Detonating at 9 psi with VAFC hack and MSD BTM with 440cc
- won't build boost in lower gears....help!
- Random Flashing CEL at idle = ??
- ving to California and I was wondering what California TURBO?
- tuning for 2 different boost settings with a SAFC
- B20 Turbo Dyno
- what will happen if i run out of nitrous while im spraying???
- Tune and Dyno, a Day with Torin
- GSR turbo dyno results..
- can i loose hp??
- >>>LASKEY RACING WEBSITE DEBUT!<<<
- Turbo STOPED Spining
- tach skipping
- What was everybodys first reaction when they boosted a honda?
- Do I need the zif socket with this burner?
- NEW turbo question
- Explain Hondat boost cut/limiter
- dont buy greddy turbo kit from b18toslowtogo@yahoo.com
- Help with VAFC!
- ddoes this board recommend golden eagle???
- Hastings and Topline?
- tps help
- help with greddy turbo
- Is the 5 gen VX O2 sensor the ONLY Wideband sensor option?
- HKS 2001+ Civic (D17) turbo manifolds are available!!!
- **** search items deleted.... old tread about hondata not working with DSM injectors?
- quick question about deltagate wastegate
- Want to run 1 bar of boost using hack on built engine.
- integra intercooler question
- Can someone ID this intercooler
- OBDII Dyno-Scan Tool
- Some dumb questions
- oil sandwich blocks...1/8 npt
- Where you mount an EGT Probe on a drag manifold?
- HELP with greddy turbo kit
- cloud of smoke behind me when i accelerate what could it be?
- think this fmic will still function well?
- Engine noise with forged pistons??? do you all hear this noise after a rebuild
- Low boost B16 exhaust size....
- *Any Shops In Orlando/Custom Exhausts
- running charge pipes (need to cut fender well)
- a REAL blow off valve question
- gsr turbo vacuum problems... help!!!
- Wideband HELP.
- 2.0 Bottlefed DC2 dyno results
- Hi Flow Cat and Power Loss.
- The darkside rocks!
- s-afc and injectors?
- Help and suggestions please. Hondata/JRSC
- Timing belt not lining up after install? Please Help???
- precision vs garrett
- Need a Dyno in New England
- B18B Sleeved block with 84mm or 86 mm pistons - Can I just do 550cc and Hondata?
- ok 48hrs later...I have the head pulled...need some expert advice...(pics)
- Quick Question About The Sc61 (ArtTurbo or MotorMatrix)
- MY spark plugs and some other problems...
- HEY! FOR THOSE BOOSTED. Do i need to hook up this line off the top of the valve cover?
- bogging in boost?
- Max boost with 9:1 comp?
- Blue Box Help TURBO HELP!
- Edelbrock Turbo Kit - turning boost up
- How plugs should look when FI.
- Is anybody using this turbo kit ?????
- Got the Project Car running. Thanks Steve "SGT Racing", and C-Speedracing.
- High miles engine + Turbo
- PCV VALVE AND CATCH CAN FOR TURBO SETUP
- Prelude JRSC question
- I need help picking a TURBO for my b16a
- Greddy E-Manage
- does sohc greddy mani fit 2g dsm t25?
- SoCal: Church Automotive Tuning a hondata?
- Difference between Greddy Type 24 & Type 31 Intercoolers
- When did you realize you were hooked on boost?
- Wideband O2 question, tuning with uberdata most likely
- vortech fmu install on prelude
- hondatat problems!!!
- anyone ever heard of doing this to help seat rings???
- Uberdata and Chrome Fuel MGMT programs HELP!! U have one?
- OBDII injectors????
- msd start retard and zex
- Good for boost?
- densos and n20
- 12:1 fmu vs dsm injectors and aem fpr
- Complete conversion of obd2-obd1
- Dseries TECII with T3/T4
- FI Newbie: Tried searching, buuuttt...
- Installing Spearco FMIC today... will I notice a difference?
- turbo or no turbo guys
- CEL: 13
- Greddy Blue box with 440's??
- Are blitz intercoolers good?
- In tank Fuel Pump Choices HELP!!!!!!!!
- Downpipe bolts -- Why are they becoming loose!?!?
- WTF: Ks-Motorsports???
- Can the aem ems idle 1600cc injectors?
- Welders! I need some advice
- Please look at this it's halarious!
- aluminum mounting tabs
- Dyno"d the D16Y8 at 10psi today in the acura 1.6EL
- JE Piston ring end gap?
- Are you dynoing on a Dynojet or a Mustang Dyno?
- Wrong GM 3Bar?
- How do you install a MBC on a greddy turbo?
- F22 boost
- What are some of the notorious issues with the Deltagate?
- Has anyone tried a 46 trim T04E with .63 or .48 A/R turbine?
- Hondata Limitations? Whos doing what with it and what s maxxing it out ?
- Engine Management
- Head studs...ARP's Vs Stock
- just got my civic done
- 3" exhaust.. whos running what, and is there a new one out??
- I need help with a problem please read! thank you
- BKR6E???
- Uberdata for b16?
- revhard h22 kit which size turbo ????
- Seimen Deka Q's
- 91 CRX Si with d16 motor/ is turbo possible??
- SMC+ 450cc code 45
- b16Forged Rods, Pistions, Block Guard, Head studs and a headgasket,Tunning PSI?
- Please advice on this issue
- how much horepower can a STOCK LS (b18B) engine handle?
- noOb turbo Q's...just a few!
- what material to use to make a 3" downpipe?
- who makes good rocker arms???
- i have money to spend what to buy turbo hatch, s13, gt4
- civic SI what set should i do
- High compression engine + turbo = bad?
- Emissions trouble ???
- are these any good for turbo hondas -- ngk zfr7f-11
- Uberdata in the NJ/NY/PA Area
- DRAG 3 TURBO KIT instructions
- Can anyone tell me about this BOV?
- post ur turbo horror stories
- Anyone recommend a good quality oil relocation kit?
- how can you tell if you have a blown head gasket???
- Does anyone know what comes with the Greddy 60mm universal intercooler pipe kit?
- Shipping a block: INFAMOUS STYLE!!!
- tell me what this is good for on pump gas.
- joe p mbc looks crude as hell
- boost spike driving me nutz
- What's with all this Greddy SoHC maniforl fitting on B series Motors?
- flow charts for sc61 vs. t3 60-1
- These with built block - How are you piston rings holding up?
- what do u guys think of this turbo? t66 BB
- WTF!! Driving today and boost cut at 10psi!! what happened? Hondata?
- n20 on an a6???
- how do you guys keep your wheels from spinning >>
- Want to purchase 1st welder...suggestions?
- ngk plug problem!!!@!!!
- my friend wants to buy this intercooler. Need advice
- Zex jet chart?
- What manifold to get for Garrett T25 turbo?
- Where to buy Endtanks?
- Another question on O2 sensors... can i driect wire to the ecu pins??
- h22a turbo integra fuel????
- Greddy down pipe question...
- Went Turbo and now getting a CEL, I have the answer to, but will this work?
- HX/VX ecu uses with wideband O sensor correct? more inside?
- Trim = [(exducer^2)/major^2]*100 --> A/R = ???????
- What comes with....
- What size turbo???
- tuners in Fairfield, Ca area........
- OBD0 + 450CC DSM???
- quaife problem?
- Wideband
- HELP, i need a 450cc Hondata map by tonight
- Turbo LS Integra....opinions/thoughts.
- WHP? Whos put down the most on a stock motor with HONDATA?
- Does the TIAL 38mm fit on a 35mm flange??
- Engine making ticking noises????
- What is rpm rev limit on a JDM P30?
- Crome
- Only have $1000 to build motor with, what's best for boost?
- Autometer A/F Gauge >>> Wideband convertor???
- tial bov ?
- B-Series Drag III Kit plus extra's
- battle of the catbacks: greddy evo 70mm (2.75in) vs. thermal 3in
- is the zex purge kit worth the $$$?
- question with exhaust moisture
- help buying a turbo
- Can I drill & tap my oilpan?
