View Full Version : Forced Induction
- Inspect my Oil Return Line
- 17psi on a vortech vs 20psi on an sc61
- calling all northern turbo'ers!
- problem after nitrous install (VCN-2000)
- crush bent pipes
- GS-R with Tye R cams with a JRSC on it.
- Turbo Setup Problems. HELP!
- What would a nice setup consist of?
- VIC's Car + MASE's Tuning = 540 WHP
- Initial start up probs :(. Crank fluctuation sensor needed?
- Precision gt35E
- fitment of t3/t67(full race turbo) with inline pro manifold on a c1 in a ek?
- possibly looking for a shop who will do a nice turbo setup in PA???
- Pulling base timing.....is there a rule of thumb? how much it too much?
- obd2b ecus si and gsr
- INJECTORS: __ Pintle vs Ball / Disc style injectors ----- Pros / Cons ?
- turbo
- Help me convert to the Darkside
- fmu problems?
- Clutch problems!!!! what to do????
- Questions about greddy sohc kit.....
- Best Cams for B-series Turbo.... 500-600 HP expected..
- How do i kill this gremlin
- LOOK:400+ setups how much timing?
- Detonation with too much fuel?
- HKS Turbo timer hookup?
- I need a T25 Turbo Compressor Map!!!!!
- Someone tune my Hondata..MIA FLA
- boost spiking
- have a chargepipe problem
- What setups are ppl usin on b18a's?
- 300whp EP3
- need pics of sidewider type manifolds
- What BOV has the pissed off squirrel sound to it?
- differences of 60-1 and super 60?
- My turbo R (Pics) 56k go away
- Best place to buy a Garrett Turbo
- Not honda relate, but dope none the less (boost OwnZ), (56k maybe).
- Bending Intercooler piping?! how-to:
- help me with my oil leak please...
- t3 on b18c
- C02 into intercooler ???
- What kind of Gains on Boosted B16 from switching to GSR Cams?
- going to rebuild for reliability daily driven b18c
- Question on Golden Eagle sleeves. Seal on the outside of the sleeve?
- CHECK OUT THIS CAT CONVERTER!!
- Opinions on Skunk2 Turbo cams please
- Endyn rollerwave piston dome volume
- ls turbo in a crx?
- Best Turbo manifold other than Lovefab and Full-Race?
- what is the hole for on my garrett that turbine out part the whole right before the end on side?
- ** Anyone see or use these new tires from kumho Ecsta v710 **?????
- how smooth in neutral does your custom honda turbo rev?
- Which clutch for my set-up?
- What is needed to put in aftermarket rods and pistons?
- greddy 19t kit on D16y7;automatic....will i use Emanage
- internal wastegate question... 5 PSI
- The Dyno Debate
- A couple of EGT questions.
- AN and NPT fittings
- How many LBS?
- Slowly Sliding sidways while acceleration fast?
- Best or good choices for wastegate/bov for 500+ Hp
- stock oil pump ok for high boost?
- Info: Greddy SOHC Turbo kit's performance with 3 Different Exhaust systems. Stock/Open/Full 2-2.25
- 94 turboed hatch pics!
- should i get a breather?
- HKS SSQ owners
- What psi on stock jdm H22
- boost gauge doesnt read till 5k????
- what turbo will suit me best? d16y8 autox, street, drag, daily, 300+whp
- Look, an easily obtained PCB switch for J1 (ECU chipping)
- cometic headgasket
- 592whp on stock port head.
- My turbo stuff
- output o greddy sohc kit???
- Quick question???
- Tubing / Hose for Catch Can / Breather Setup ---- Suggestions
- All charge piping and exhaus piping done and ready for paint.pics inside
- Freeze Plug size to plug stock canister.
- anyone know thermal research's website?
- Any Hondata Tuners in New Mexico or close by???
- how do i tell what size my turbo is?
- Autometer Oil Pressure Gauge Qs
- Nitrous Type-R plots inside
- B20/Turbo, worth it? or build the b18c5?
- 2001 Odyssey 3.5L supercharged ?
- searched (turbo oil temp)
- wtb a fmic for 88-91 crx.
- votech bov sound. anyone have a clip?
- intake mani. question?
- strange problem with rpm...
- Boost on a Eclipse SMIC?
- what should your compression be after a comression test on lowered compression motors?
- Would anybody forsee a problem with....
- Exhaust????
- Hondata S200 + Boost Question
- Your thoughts on Royal Purple
- Quick Injector Question
- 6 gen accord turbo
- How much power do you think my setup will make?
- reuse forged rods/pistons?
- Thoughts on Batronix USB Programmer.
- most powerfull D motor????
- Emmisions and engine management
- First post
- would "porting" the compressor inlet help with power?
- skunk2 intake manifold install on GSR motor...
- Deburring A Block (and the rest of my plans)
- Gathering parts for a LS/VTEC Build, let me know what you think of my set up so far
- civic finally boosted
- Comp CAM 59300 and turbo
- couplers Q's for piping on turbo kit?
- Old Vortech/ B16 swap pics
- One problem after another....
- TECH SCHOOL
- Anyone has a Scan of Autronic SMC wiring diagrams?
- are these intercoolers good ?
- New Turbo GS-R completed -I Feel like an Uncle w/a Newborn nephew
- Where to mount Profec E01?
- More turbo questions.........
- What does it take to beat a 04 viper? or 911T
- Turbor or SC an auto d16z6
- Best ECU to run with Hondata and a 99 Si.
- most common fault on honda turbo setups?
- Engine Build-Ups - What Engine Components can be removed?
- b16 with sc 61
- Methods for Tuning with TechEdge 1.0 ... only datalogs the A/F ratio
- how much hp on a stock b16a
- my 1/2 done turbo hf manifold..what yall think (56k wurth the wait ; )
- 3" turbo exhaust help please
- burnout video....my svt lightning
- Anyone else without a dipstick?
- Full-Race t3/60-1 .70/.63 76 Trim turbo ..
- Is the psi on a T25 the same as the psi on a SC61 ?
- any hondata tuners coming too hawaii soon by chance???
- is it worth it?
- Finally got some dyno tunning in, charts inside!
- who wants MASE back up in the north east part of the country?
- Hondata Base map/chip question...
- How do I know if my dsm 450's are bad?
- S2000 turbo manifolds?
- Newbie nitrous questions...
- car boosting, but not showing on gauge
- which bar and plate intercoolers
- T60 - 1 vs. T3T4
- TurboXS RFL BOV Washer Help....
- need some direction in turbo project
- Various Turbo Questions....
- Where do you get your AN fittings?
- Pics of my T78 install not a honda.....
- Custom setup on a 2nd gen integra
- Help me break my motor in ;P
- hondata i/m heatshield gasket install write up :)
- A'PEX Twin Chamber Blow Off sound?
- benson sleeves yo!
- daily driven sohc turbo??
- What is the biggest difference a sleeve with or without a close deck ??? pros and cons
- quick, resleeving h22 tech question
- Motormatix
- Oil Return Line
- b16 turbo problem PLEASE HELP
- my spark plugs after track day...
- THE definitive oil thread....
- TD04 on C1
- Please help me make the proper turbo choice.
- question on wastegate spring
- Tranny pics....opinions...
- HONDATA + CEL = RUNNING LIMP???
- Qs about ARM EMS
- got this today. i know nothing about it HELP
- turbo gurus, identify this garrett turbo for a noob
- green ring inside brake booster vacuum line
- Turbo PROBLEM!!!
- Whats a turbo?
- need help with greddy kit
- what you guys making on your h22's w/ 12 psi?
- check out what im about to get
- Profec B acting up
- how to turbo my new 93 4 door lx......i want it FAST!
- d16 10lbs of boost, recommended fuel setup??
- Whats up with the retarded new search?????
- where to get mandrel bent piping in texas?
- Calling all boosted members with 16" wheels, Need your help on tires.
- Greddy Type S Blow off valve... Sound?
- Does anyone have and SOUND files of what different BOV's sound like??
- 84mm B18c1 with pt67, what flywheel?
- skunk2 stage 1 cams with turbo
- question on turbo apllication
- Quick question about removing a JRSC.........
- help me find this gauge pod pleeeeeeeeeeease
- Whats the best price out there on pre-fab'd IC piping? Who makes it? Where do I get it?
- anyone using motul racing oil on FI applications?
- hey when deciding to put on a turbo, are there any basics I should know
- Greddy 96-00 turbo kit on a 92-95??
- d16 turbo
- DIFFERENCE BETWEEN TURBOS
- REUSE ROD BEARINGS?
- Headgames article in Modified Magazine "February" ..head porting
- Opinions on Lovefab SST and lower IC piping off the turbo
- gasket question???
- T4 SC61 a/r trim help
- location of brake booster? D series honda turbo
- Going from 1.6 SOHC turbo to 1.8 DOHC turbo..
- Integra Turbo Project need inputs
- anyone making 300 or so whp with afc hack?
- reliability of uberdata for daily driving
- haltech
- Are there any sick hondas out there?
- n e pics of your t3/67
- alternatives that are safe for boosting other than Hondata any suggestions??
- what obd1 distributor will fit on gen1 B16a1
- Turbo for beginer.
- Anyone tryed JUN 3 cams in a turbo motor
- My friend owns a smog shop, can I tune on his smog machine?
- turbo LS cams?
- Those running the Sidewinder, any problems?
- CEL P0420 code (67)
- tial WG placement on hf manifold......and egt placement
- OT: aem ems powered S2k
- Need help and pics for mounting a Precision intercooler.
- AEM EMS User's Need Your Help!!!
- turbo JDM ITR head gasket?
- Please help! Oil line issue *pics*
- CAD/ or crossection pic of turbo?
- differences on precision turbine housing
- nitrous
- INJECTORS PROBLEM....???
- lovefab with AC (other than sidewinder)
- jackson racing supercharger making abnormal noises.
- What kit to go with..........
- need help picking exhaust system ASAP and injector info and A/F guage!!
- Fuel management idea for turbocharging an FI motorcycle.
- anyone got there turbocharged car tuned by jeff at IB with hondata...?
- Analog Values from RPM and Map sensor. HW Datalogger completed, now doing software conversions
- is this really the proper break in method?
- f1 4doors?
- vdo guages
- How to identify Type R cams from GSR
- whats the difference between the P74 and the P75 ecus??
- Well...the darkside truly is the money hole...
- 1g DSM bov's
- 450cc DSM Blue top injectors
- What do most of you spend on turbocharging your car?
- Help me with my setup
- Turbo type R ?
- WHER CAN I FIND A USED NITROUS KIT FOR AROUND 200+SHIPPING, AND......?
- extended wheel studs
- Greddy EGT gauge owners.... HELP!!!
