View Full Version : Forced Induction
- Full-Core Radiator Compatable Turbo?
- whats better for longevity on a turbo car? for an aftermarket or oem oil pump water pump and timing
- bov problem please help
- future plans for my ls
- Looking for a tuner in IL ...
- Does a 60-1 fit a Cast Manifold on a B-Series Motor?
- Are oem crank pulleys solid or are they a "Harmonic damper" ?
- Hondata s300 users, I need help wiring the relay for vtec on non vtec ecu.
- NEED ADVICE!!!
- help me decide on turbo trim.. Accord stock block
- TURBO BOTTOM END BUILD
- smoke out vent on valve cover help
- block guard
- pic request: turbo support bracket (searched)
- Stock fuel pressure regulator and boost
- b16 turbo setup
- Evo 8 turbo on my b18c1
- JRSC..
- Making a 3" Exhaust Quiet? please help.
- Tuning in McKinney, TX
- JW here...
- help
- Dyno Tuned my car last night!! h22 turbo READ
- Car bogs down when given throttle. New build B16 turbo
- So, who's made the most power on Probe pistons??
- dump tube question and a few more
- wideband guages?
- Missing piece
- Low profile exhaust?
- Problem boositng with Spoolin log mani
- NOS Suggestions??
- best plugs to run
- boost problem
- boost problem
- Boosted Y7/Z6 head, What headstuds?
- just installed turbo kit, gotta few problems
- Boosting DA question
- low compression??
- Garrett Turbo or Precision?
- Can anyone identify these injectors?
- D16Y8 M&W Pro 10 HELP!!!!!!!!!
- catch can plasement need help
- Keep blowing out manifold to turbo gasket... WHY?!
- B18c type R turbo question
- how much power can i make with this turbo?
- since he wont listen let honda-tech tell em!
- Noob trying to get turbo Kit. Befor getting a Turbo Kit, What do I need?
- Anyone use a fan on an intercooler?? Would it help in any way?
- pressure to run thread??
- iphone question??
- What would you choose?????
- Need a dyno comparisons
- Edge Brothers, Jacksonville, NC customer reviews
- new software revision coming out soon for the ams-1000
- welding a v-band on a 4 bolt flange turbo
- tial 60mm and s372
- thoughts on using used pistons?
- Factory Stroker Kit??
- Anyone with input on the GT4088 (journal bearing) turbo?
- h22 ported head what do you guys think?
- downpipe
- Post or Block Guard?
- How Much Hp Can The Stock Timing Belt Hold?
- Need help with turbo sizing
- d16z6 turbo
- Oil filter relocation/ Oil feed line question
- sleeved block
- Garrett Turbocharger Speed Sensor ???
- TURBO SETUP??
- Stock Ignition Enough?
- boost?
- oil in oil filter?
- CBR Coil on plug setup... What plugs do I use?!!?!?!?!
- oil feed line question
- Running 3" exhaust under the rear susp.
- My Type R on the Cover of Turbo
- Impressive B series dyno tune
- tuning help....
- help me take my setup to the next step. sohc stock block, 57 trim..
- oe clutch on turbo
- To bore or not to bore... that is the ?
- need aem digital oil pressure gauge wiring diagram
- My car made the Febuary cover of Dsport on sale January 1St!
- what causes bearing failure in a turbo'd engine?
- GREDDY KIT ****
- which radiator for b16 high boost car
- 81mm vs. 81.5mm on a B-series build?
- T4 t0 T3
- 425whp for 4g63??
- almost $6000.... ???
- Boosted>>>>B16a2
- Who can give me the best bottom of the line deal?
- Will a 44mm wastegate be enough?
- ls vtec
- b16a spray questions
- Urgent Advice...regarding piston slap
- help with lsvtec compression
- Garrett T3 t61 on my b18b1
- what size is the oil inlet for the gt35r??
- how much power is this turbo good for??
- boost/ trans opinions needed
- IS THIS GOOD???
- Motor Plate Idea
- Garret tb0356?
- gonna raise boost from 12 up to 15/16psi stock block, is more timing retard required?
- Wiring up a switch for my FAL fan
- Which turbo for 500whp?
- feedback on aebs "patent" bomb proof sleeving
- 1600cc injectors and hondata s200 tuning for e85
- opinions and advice. building b16.
- 1.8L GSR, FR Stg2 Turbo Kit, not seeing the power i want to see....
- ::::::Hidden Turbos Thread::::::::pics and how toos welcome
- Anyone in CT hear of "Mario" -NOT THE DAMN VIDEO GAME
- 400hp Daily Driven DB
- Critique my setup...how much boost can I run before choking?
- Help request on turbo selection from Italy
- LS turbo running but STILLL not driving (vid inside)
- New Turbo - Bent Gasket. ?
- head work really needed?
- Cometic Head Gasket.
- 93 DA ls... 278.6whp @ 12psi BUTTTT....
- what's missing?
- ls turbo clutch...
- am i ok to boost?
- "P" codes needed
- e-85 1600cc injectors, injector driver question
- 30r vs. 35r spool time on K20?
- peakboost hvs vs. edlebrock victor x turbocharger kit
- What's the latest and greatest tuning options for OBD0?
- nitrous Q
- HP limit on eagles*SEARCHED*
- theory on testing boost limit of stock map, will this work?
- need help ls with srp pistons
- bypass valve question
- garret t3 turbo
- Sohc Turbo question need some info.
- Cam for spray
- whats this setup worth?
- New Spa log manifold???
- TIAL 38mm wastegate help
- Most Favored setup?
- Turbo Air Flow Needed
- bypassed iac, upon first start oil press low for about 2 sec, wil this hurt it?
- Enjo motor mount insert replacement?!
- Has anyone tried out the new HKS BOV'S?
- Question: Sleeving tuners. What brand of Sleeve is this?
- Max HP on stock motor mounts
- o2 sensor placement
- gear dependant boost controller?
- Question for DC integra owners about intercooler piping
- question about gear controlled boost.
- DC2 Backdoor and 3" Charge Pipe Routing.... Pics?
- race gas?
- Boosted B-Series Dipstick problems?
- Street Tune needed in Cleveland/Akron Ohio....
- thanks swift racing technologies!!!!
- Exospeed ST2 cams LS-T
- hondata s300 ?
- how much hp did u gain from gsr to itr cams?
- The Turbonator?
- adjusting wastegate pressure
- gasket for JRSC supercharger to intake manifold
- injectors size
- My new build.
- Intercooler question on a dc2...think it will fit?
- New idea for turbo oil feed? Could this work...
- Safe boost?
- B-serie and D-serie rear main seal indentical
- Best break in method for built B16 turbo?
- Got my engine back from the builder, "crank oil seal" wasnt installed?
- Help I need a question answered 57trim or t3 60-1 for 400++whp
- Wastegate sizing questions
- duck call bov
- greddy egt gauge: hooked up right needle doesnt move
- What timing belt for itr water and oil pump
- boosted h22 breaking up isssue, EASY FIX???
- going turbo with bad valve seals?
- which Holset is this??
- Auto-meter wideband....Anyone ever used one?
- throttle BoDy Size !!!!!!!
- Setting up my first turbo build Need help from you guys, thanks
- F20b Turbo?
- Trying to find nitrous gurus??
- i need
- SOHC or DOHC?
- ls/vtec and Turbonetics T3 ok?
- how harmful are boost spikes?
- LS-Vtec Throwing code 6 and 10 upon switch of ECU
- question about intercoolers
- Project 450whp Daily Driver Completed :)
- overboosting bad
- .GT28r
- turbo'd honda quad
- Crower Stage 2 turbo cams over CTR.... 500+whp
- Good Turbo For My Setup??
- v band exhaust?
- gsr missing, after boost?? need help
- street/strip car???????????
- can you but a t3 turbine housing on a t4 t61 turbo?
- differences in ecu's
- Car's chucked oil on first start after rebuild. Is this headgasket fitting correctly?
- Spool time and advice
- DC2, B18C1, Full Race 60-1, What ECU?
- SEARCHED.....and need some opinions.....
- Sleeve engine? if so where in NC?
- How many bends in your B series EG/EK Intercooler Charge Piping?
- dsm turbo parts???
- Question before I throw in some pro1 cams
- LS/VTEC Turbo Build up any suggestions would be good First Turbo build
- Apexi Turbo Timer, Anybody has one?
- E-manage Ultimate vs. K-PRO HELP!!!
- searched: which turbo to go with?
- question about turbo/ i searched
- Garrett 60-1 Turbo question. Spool @ xRPM's?
- CAM timming and OVERLAP....can i tune the overlap of CROWER stg3 cams to ITR overlap....
- BluePrint MFG Sleeves... Anyone used them?
- h22 catch can???
- Rewiring another relay to fuel pump
- Edelbrock turbo kit 98 GSR stock
- Help needed on new turbo for built GSR
- nitrous vs. turbo
- how far from exhaust exit must wideband be? open DP
- tuning with open wastegate
- Broken clutch fork ?????????
- Help installing a NOS kit!!!!!!!!!
- Good turbo for my LS/Vtec
- Neptune RTP vs. Regular Neptune. Really worth the upgrade?
- low oil pressure at 48 degrees...
- h-t lets turbo this n/a guru / h22 - kit or create?
- How much can i boost?
- IHI RHF5 (apexi sohc) turbo - oil restrictor needed?
- Coated honda cranks: GSR, TypeR => "micro polishing"
- cam question
- water spray
- need help on what parts needed
- problem with down pipe please help
- can lc1 wide band be used as a normal 02 for the ecu?
- stock pvc+catch can question
- exhaust flanges for turbo builds
- Issues with losing power @ vtec
- Help I need 9:1 compression!!!
- compressor
- single turbo
- Throttle Body Tech
- what turbo is right for me?
- Emanage Ultimate Pin out for D series
- Cam Measurements (How do i know if it's safe to run a certain cam?)
- Greddy turbo kit On Stock GSR 98
- Tuners - Windows Vista - Hondata, AEM, etc
- Turbo LS
