View Full Version : Forced Induction
- Mid Build Up Dilema
- nitrous button
- How does this sound...
- Need to vent about stupid people! yes it relates to turbo..
- Best shop in Austin?
- FMAX Group Buy FINAL Notice!!!
- where can i buy some mandrel bend pipes so i can make my own ic piping???
- BEN: clutchnet stage 2?
- Boost !!! How long....
- Turbonectics Deltagate (POS) have the same flange as any TIAL?
- B20 Vs B18< whats the main difference?. . .
- what spark plugs
- A turbo GSR owner needs advice!!!
- got a tial...great but....
- Greddy momentary switch
- please help w/ vacuum line setups
- should I sell my greddy turbo?
- FMU!! Is it really needed???
- garrett homepage
- FMU?
- 3" thermal from GSR on LS..will it work?
- 4th gen turbo lude potential...
- Great Blitz prices for anyone who's interested!
- how/why do our turbo systems make such efficient power?
- Dynoruns w/ EBL v2.0
- Good website for those new to turbocharging...
- Im back and info about the 3" downpipes.
- my first rant......importparts/imoto
- what pistons to get with turbo.
- Should I upgrade my exhaust system?
- Safe Boost
- Are XS engeeneering turbo chargers and intercoolers any good?
- Need some help with my friends gst...
- decided to get a profecB
- Greddy Turbo Timer
- drag III and f-max
- Turbo's Life Expectancy?
- Custom 3" exhaust suggestions? Did search no luck.
- Need help picking from 3 Motors...any info helpful
- The return of jcaudill as HokieITR! :-)
- Turbo Kit waits for install, anything to do while I have it?
- I want a bigger Delta Gate spring! Help me!
- Anyone ever rebuild there turbo themselves?
- How much additional oil for turbo?
- CLUTCH PREFERENCES
- refilling nos
- External inline fuel pumps??
- walboro pump fit this car?
- V-AFC correction amount...
- Gredy Type S blow off valve needed
- My new setup for turbo (think that's what i'm gonna follow)
- Do I really need an LSD right away?
- what motor oil to use for turbo engine?
- do any one make a piggy-back computer that reads boost
- What does the car do when it detonates / pings? How does it react?
- Which clutch to buy?
- peak and hold injectors
- Intake manifold questions
- stock clutch! how long will it last..
- ANOTHER injector question, please help!
- my turbo set up
- which EBC do you recommend.
- What exhuast to get for JRSC????
- Are cam gears important for a turbo LS w/ stock cams?
- New to Honda-Tech
- Finally dynoed my car with greddy kit..
- hello again....tranny swap
- greddy turbo
- JDM B18C oil pump = US B18C1 oil pump?
- How to adjust boost on internal wastegate
- stand alone fuel and ignition management
- Turbo update .. Need Help
- Opinion: Skunk2 Short Shifter/Shifter Bushings
- what cams for high revving turbo b17a motor?
- Hey Arturbo, your downpipe
- Drag gen II sohc transfer to b18c potential probs?
- autometer oil pressure gauge(electric) hookup for the sender
- Drag Turbo Kits?
- ? on intalling a 92-95 SOHC Greddy Turbo kit on a 00 Civic SOHC?
- Shop to build custom turbo in Southern California?
- just alittle more help w/ my 6th gen turbo please
- 5Zigen Exhaust for turbo
- What do you guys think of this DIY Air/Fuel Gauge?
- DRAG GenIII Manifold. What size bolts fit?
- Can someone tell me how to remove the compressor housing?
- OT, but I can't find the answer anywhere else..
- Had my turbo rebuilt, but......
- Recommended break in for turbo.
- The most N2O in a B16A
- oil pan for a 99-00' ex needed
- prelude injectors or GSX injectors for a turbo ex?
- Need a paint scheme for the new car so please everyone help out
- ODB-I v. ODB-II
- Greddy or custom turbo?? Need Help!
- Will a gsr headgasket (b18c) fit an ITR?
- Inline pump
- Digital Gauges
- Custom Kit Price
- Reccomended FMU rate?
- i heard of gst/gsx 450cc injectors will eit in hondas...how does this work?
- Car smoking
- oh... man... 100 octane
- Pretty sure head gasket is blown
- Opinions about the TurboXS type H blow off valve
- o2 bung on down pipe for 2000 and up GSR's
- platinum plugs needed for FI?
- V-AFC uses, got a question.
- Greddy's Blue box
- vigor injectors
- GSR Greddy Turbo Kit?!?!?!?!?!?!
- Anti-Freeze or Water
- HX + Turbo? Anyone even bothered?
- Reliable??????
- removing turbo timer?????
- wastegate confusion
- AIR/FUEL GUAGE
- Anyone have a set of DSM injectors laying around?
- Air/Fuel Mixture Guage
- can boost controllers prevent boost creep?
- trying to install my drag kit and hit some obstacles please help
- took some pics
- please take a look at this spark plug!
- What kinda power at 13psi on a gsr?
- radiators! stock vs. fluidyne
- Strange Problem
- Turbo high compression engine?
- Tech question on turbo R's
- Can someone please verify this.. I want fact. Is white smoke out of exhaust lean or rich. I keep h
- need hondata intake gasket ASAP for ITR
- T3/T04E 50 trim VS 54 Trim
- CEL with test pipe. how to trick the 2nd o2 sensor?
- greddy/rev hard kit questions
- How many of you have blown a motor?
- Haltech or Hondata which one do you guys like better???
- my car makes rattling noises when I drive, sounds like bell
- Why is the TIAL wastegate always what people are upgraded to?
- b18a or b crankshaft...
- WTF? $1300 to install haltech?
- Paging Ben
- Is the Blitz Dual SBC worth it?
- OT: the truth
- NEED oil pan for a sohc civic
- What would happen if the greddy blue box i have failed?
- OT But please help
- Show respect to your country
- Insurance w/ a turboed integra.
- Sites for technical info on turbos...
- Vortech FMU 12:1 - TOO Much fuel?? for Stock Injectors and 5-7psi boost?
- TiAL wastegate, Apex'i AVC-R and Airtex inline pump
- revhard ls 1/4 mile times
- Is turbo lag really THAT bad?
- EF Hatch Catback Question
- Ignition Setup?
- Before and after 1/4mile times after F/I & HP increases
- Hey Viren S, your sellin your car
- i have some stuff that you guys might be interested in...
- looking to maybe join the darkside, but i have a question
- Very much OT: please give blood now.
- Houston meet up..tuning
- All Hondata Users.
- Necessary to do headwork for turbo app?
- hey guys lets take time out to think what happend today
- Turbo Tech?
- F-MAX Group buy ends on Sept 25th!! Speak now or forever hold your peace!
- JRSC Install HELP!
- ACT clutch replacement?
- Tranny Problems
- can u use a super AFC in place of a fmu
- Turbo illegally Kali or others please help me out
- Best Cams to use for Turbo LS
- can u re-sleeve a sleeved motor?
- CAn you hone your cylinder walls with stock bore pistons?
- brass T-fitting
- ARGH - sudden increase in detonation/pinging, help!
- Anyone have pics of Thermal 3 inch exhaust?
- MISSING LINK
- Superchargin H22
- EGT PROBE
- Dustin....do you think you could post those in-car sound clips of you driving?
- Any FI guys with a lightened flywheel?
- what size T- bolt clamps???
- clutch explosion
- how much is the greddy EGT gauge? and where should i mount it
- For all DRAG members.......
- Need help!
- low idle and smoke
- Which codes represent a limp mode?
- superchargers
- which tranny???
- newbie question, but please answer
- HKS headgasket
- best valves for turbo
- anyone try Revolution motorsports stainless steel 2.5 inch exhaust?
- Intake manifold /w turbo?
- what clutch for a turbo honda?
- 18g
- Ideal A/F ratio for FI...
- turbo LS or turbo vtec?
- GReddy Profec B settings
- ProDrive John here...
- I head a poping noise when I drive and change gears..what gives?
- thinking: goin' from all motor to turbo...
- contemplating FI
- Code 43 Fuel System Code?
- Code 1!!!!!!!!!!!!!
- Throwout bearing problem.... question??
- Is a FPR need w/ the extra injector setup (ie: FMAX)?
- Where can I have custom plates made to hold guages in my center consol?
- is it safe to run a 2" exhust with turbo?
- Plug wire question?
- Inline Fuel Pump & FMU Set up
- Ok MF2 question and help
- difference between m/Tand M/H?
- Code 13?? Barometric Bull$hit
- Anyone ever use this Holley FPR?
- Urgent please read!! oil line to turbo????
- Stupid question......
- Code 43 !!!!!!!!!!!!!!!!!!!
- Sandwich style head gasket?
- Misfire codes w/gredddy turbo kit
- could someone please post a pic of the pcv valve on an integra ls?? thanks
- Internals
- Greddy turbo or Drag
- What to do for installation?
- Where to mount 60mm guages?
- If you know anything about engines, take a stab at this one. Update...
- anyone have a daily driven turbo car
- someone buy my turbo kit!
- Which Head Gasket Is The Best?
- Black Smoke???
- anyone got pics of a 94-97 teg w/ spearco/revhard FMIC?
- Full Drag Generation3 Turbo kit for sale...
- traction..
- Platinum Bosch 4?
- ways to decrease spool time... ?
- help with oil return fittings (from ANplumbing.com)
- Compressor Size help
- Best Plugs for Turbo '95 GSR
- building engines for turbo..recommandation?
- haha..i finally solve my turbo problem
- Check valve setup?
- Here is another Vortec Fmu question.....
- What is the optimal distance to place my Blow off valve?
- i got 2K what to do with it.....
- About to be boosting again...
- oil light
- NOS Direct port or Drag 3 kit??
- junkyard turbo's
- What boost level is safe with stock injectors, a upgraded fuel pump and FMU 12:1?
