View Full Version : Forced Induction
- Hello..i'm not iggin U....my IM isn't working...damn DoD networks
- HONDATA
- reading compressor maps...
- can you make 400hp with a s-afc?
- moment of truth...credit card in hand....maxrev or fmax turbokit for 98 lude SH
- 9:5:1 or 10:0 pistons?
- Just a heads up, 3" flex pipes on ebay for $32
- *PICS*, which coolant line do i get coolant for turbo?
- Hondata/wideband
- turbo xs mbc help!!
- gauge readings? EGT, oil pressure.. .
- SARD fuel pressure regulator
- what size piping?
- B18C Turbo Idle problems, any ideas?
- learned a very important lesson about the AFC hack today..
- What size threads for water housing on GT series turbo?
- External WasteGate with Blitz Boost Controller
- Odd "hesitation" problem... Hondata? Fuel pressure???
- Turbosmart Manual Boost Controller Question...
- Hondata + what else?
- went to the dyno tonight....=(
- fuel pump questions
- MaxRev Turbo Kit Fuel Management Help
- greddy kit fit on del sol vtec???
- uberteg chip? fuel....
- big dog turbo guys please help question on garrett gt42r and my set up (long post)
- My car got stolen in PDX
- whp from a greddy 18g kit?
- MAXrev manifolds: flange cutting question..
- IHI RHb5 Turbo inlet/outlet sizes
- What do you guys think of this turbo/manifold/downpipe setup? *junkyard sohc kit*
- hondata and IAC question
- anyone use this wideband??????????? looks nice for $349
- questions about a/f and tuning, bad dyno #'s
- how to release fuel pressure when install injectors
- Experiences with Majestic turbo?
- Can i use a different FPR rather than the AEM on if I have an AEM fuel rail?
- Big Turbo?? Or Engine Management?? HMM
- Can someone answer this question?JDM turbo fans please
- cartech FMU question
- Spark Racing heads?
- B18c in 99 civic
- Sleeves
- Mugen Valve springs under what retainers and what ECU
- When is Ben releasing his book?
- How are crower turbo cams?
- hack vs emanagement?
- pixs of a integra with a civic dx motor and turbo
- building drag car need info help
- 50 trim, .60 A/R, T3/T4 capabilities on a b16?
- Finally got a dyno graph up.
- V-AFC hack problems!!!
- What kind of cams are you running for your turbo setup
- How To Hide Nitrous
- TOda cams on a turbo B16
- turbo worthy motor....
- Drag turbo to manifold bolt size??
- Anyone willing to create me a Hondata Base Map?
- Nitrous Question
- Anyone tried the NOS plate on a GSR
- Where to buy ECU harness plugs?
- Hood for Turbo???
- Down pipe question
- Cheapest place for Stainless Flanges 3bolt, 4 bolt, 2bolt, T3, WG etc?????????????????
- chromoly vs mild steel
- Hondata PALM logger anyone using it???
- tial wastegate spring in deltagate wastegate?
- Crower ECONO billet rods?
- HELP! I think my deltagate leaks vacuum?
- Hondata/ Datalogging Option.
- Who tunes there own car with Hondata?
- ECU / Boost Contollers / confusion.
- Question about clutch chatter
- *Can i Swap 2nd o2 sensor in place of Primary? ASAP *
- Got a Turbo Problem I Need Help With
- Heat Wrap.
- obd2 and afc hack
- HELP! Car backfires then throws CEL/ Stalls and wont start back up. HELP!
- rich vs lean hondata datalogger
- Differences between clockwise and anticlockwise M62
- Who is boosted and running a chipped ECU?
- anyone ever run these intercoolers?
- hks ss not blowing off
- my turbo project- finished
- help on what size injectors
- Is there any way to make the noise of my turbo louder?
- Straight power yo fuel pump?
- precision choice..?
- nitrous b20b
- Is it possible to turbo d15 mini me?
- Civic/GSR JRSC... what other performance parts recommended?
- drag gen III vs. Greddy
- cheapest site for greddy turbo???
- finally done w/ install!!! need tech help
- anyone running the dataq 194?
- Anyone Dyno with missing link
- How long would a stock d16z6 last w/ Greddy turbo kit??(daily drivin)
- final part of turbo install, need help asap
- Can you run a hondata chipped ecu with out the hondata?
- What size IC core are you using?
- I LOVE UPS & FEDEX!!
- JRSC gasket?
- Anyone using Clutchnet's sprung 6 puck.....?
- B16a 2nd gen turbo pistons?
- I screwed the pooch this time
- Had an interesting idea tonight.....what do you think?
- vafc hesitation help
- oil pan gasket replacement
- Long Island Inspection hook-ups...
- 2 Step Colder Sparks For Turbo?
- 90 degree -3 an fitting for feed line?
- Oxidation on my new rods!!!!
- Where on my charge pipe should I install my NX Express Nozzle?
- Need help with Hondata misfire.
- questions about turbo parts
- JRSC coolant line problems
- OT: Garage floor paint/covering?
- 880cc injectors/hondata
- Piece
- Possible turbo/oil feed/return problems
- How do I rotate the tial wastegate so the vac port is in diff spot?
- oil pan compatibility?
- which bov's sound like a greddy type s
- 93 si turbo setup
- How many of you have had turbo's fail due to a poorly designed drain line?
- 12:1 with 18psi
- compressor outlet flange?? where do i get it???????
- the GS-R is gone
- A few Hondata tuning questions...
- WTF kind of manifold is this?
- anyone using the Spark racing manifold?
- Brass on Oil Pan?
- Here are the pics of my problems with the manifold....
- honda tuned... installed 3" dp now it studders at full boost (2psi more)
- Supercharged or Turbocharged TL-S members checkin..... questions
- Last MIN. Manifold
- MAX REV DP
- Venom intake?
- Gain pounds by moving wastegate line
- need help runing vacum tube into cabin on 95 grs.....
- oil pressure sensor removal ?
- Turbo Oil Pan Questions
- RPS Header
- Intrest in UP-Dog?
- bad synchros
- using hondata tuned for supercharger on turbo setup?
- OT: 11 months into project. Help keep me motivated.
- 4.5 liter twin turbo beast...
- ITBs interest?
- exhaust quesiton
- COOLANT PROB: overflowing resivoir and starved radiator
- how about this this frankenstein job?
- h22A injectors work?
- secret services in tampa
- blitz powerID & sbcID
- Stupid question about pipping.
- Greddy Type S has 2 nipples
- coolant bypass ?? Did search
- JRSC: Are these rotors ok?
- Oil feed line -4 or -6 anyone???? I have looked and can not find anything.
- str intake manifold gains
- Where to buy a new thermometer for my whacked out EGT gauge (Defi)
- Oil pan :mad:
- Here is my list of upcomming upgrades
- 92-93 LS Cable Tranny Guys with 300-400 WHP
- i dont know what to do next!
- Difference between LS pistons and GSR pistons besides compression??
- turbo talk
- SOHC setup
- JUST GOT BACK FROM THE TRACK! 13.9
- Changing turbine a/r
- good clutch to go with nitrous setup?
- internal to external
- how much will I gain with new cams
- Fuel Pressure ?
- donwpipe?
- where to get vacuum TEE's?
- Hondata Timing Maps...How do they look for a D16? For All You Hondata Tuning Pros
- Some headgasket questions..
- Propane injection
- Stroke.. worth it..with BIG BOOST?
- Just when you thought nothing esle could POSSIBLY go wrong..
- Stock 99 B16 turbo ?
- hondat s200b prob. help!!!!!!!
- low compression high boost or high compression low boost
- Supercharger gas mileage?
- Alright what the hell... Skunk2 is getting a horrible call tomorrow from myself.....
- Info on SC50 (pte site down)
- hks ssq
- JRSC type R at 9psi....= 13.703@108.56 on winter tires!
- Cheesefrog is the man. CIVIC vs. SUPRA *vids* are back!
- What kind of teflon paste do i use on oil fittings? permatex brand ok?
- Timing is off , help !!!!
- which o2 to get? obd0-obd1
- His and Hers
- Spearco Boost Gauge
- anyone have a write up on installing a sump on a factory fuel tank?? and a parts list??
- about to hit 11's... rollbar ?'s
- OK i thought i think about some crazy stuff LOOK
- Big Problems w/Turbo B20!!!!
- Blow off sound with automatics???
- what kind of numbers should i expect for a built b16
- Prelude Turbo installation HELP!!!
- how much to rebuild a t/3
- Blow Off Valve Sound
- greddy intercooler kit
- Walbro Fuel Pump
- Effects of LS head with GSR block???
- Which Radiator to use for Backdoor Intercooler?
- The Hack Causing High Fuel Pressure?
- Can a car run with no throttle body?
- diesel turbos vs petrol turbos
- how much more fuel... vafc hack question
- Exedy clutch for turbo?
- Some autox pics from last sunday.
- Oil return question, *pic inside*
- breaking in a new engine - can i just take out the wastegate spring to run no boost?
- 500whp civic, 650whp supra, *VIDEOS*, Tony1, HondaHvn, SC61.... come inside!
- Fedex To Australia large 850 or 920cc injectors....ASAP who can help.
- Intercooler advice
- what charge pipe do I need for GSR w/ Skunk2 manifold?
- Turbonetics Elect Boost controllers?
- Weird Greddy Warning EGT activity
- raced my buddies camaro z28... got questions.
- REDWIDOW_93_4dr_civic
- The best price on pistons.
- Intgera Forced Induction
- help!!!!!!! getting a few check engine lights!!!
- Civic Turbo Question.... I need help!
- does ACT clutches have a website?
- ZC DOHC motor with boost?
- Vtec
- installing fuel mods before turbo?
- Is there something wrong with my greddy manifold?
- Best price/performance compromise for a clutch
- JB Weld? ? ?
- 10:1 compression vs. 9:1 compression basemap fuel
- Minimum fuel pressure
- What compression to use for Stage 1 JRSC
- Need quick answer about greddy please help!
- hks turbo timer type-1
- Should i get this car
- Injector Wiring already searched
- Tranny question
- i just have one thing to say.
- Extrude Hone on High Boost Appl.
- Problems with Swift-Performance! Buyer Beware.
- are the VAFC hack settings particular to the engine type?
- Need your Help, Compression test down 15psi, will excess crankcase pressure kill my turbo?
- SOHC VTEC HEAD???? PLEASE HELP
