View Full Version : Forced Induction
- What to look for when buying a used JRSC?
- P28 vs P2P (99-00) on VAFC Hack
- Oil Temp Sender... Good Idea or Bad Idea?
- Are they normal flanges?
- no gaskets
- Spark Plug indexing
- AFC hack question
- Pics of my build up...just started AGGIES CAN BOOST TOO!!
- ? about injectors
- Need Help! VTEC BOOST HONDATA related
- Need to retorque headstuds?
- HEEEEEEEEELP!!!!!! Throttle is sticking, what can I do?
- 15g and t25...do they use the same gaskets..
- wiring blue box and afc together?
- overheating troubles on my sohc
- dont know what ecu i have
- how mutch nitrous?
- should i stick with the greddy 18g or go with t3/t4
- How do I reroute coolant lines under the JRSC? leaking coolant...
- what spark plugs to run
- MotorMatrix in SCC Ultimate Street Car Challenge
- A few fuel management questions
- spark plugs?
- how long does it take precision to ship a turbo?
- 2 Questions inside.. piston and rod related.
- Need some info
- damaged injectors?
- Loosing some boost
- Wastegate Question
- another thread re: block guards
- time to cool? searched to no avail
- to the point what do i need?
- Picked up a few psi by changing the Vacuum Source
- Fuel Injector Cleaning
- stupid JRSC garbage...is this belt on the right side?
- any help on blitz turbo timer ?
- looking for zdyne maps
- How can we stop all of these thefts
- ecu harness question.
- Can anyone in So Cal weld my IC pipes for me? nice welds please =)
- compression tester stuck in engine!!
- Really need help with correct turbo sizing!!!
- Need Help with Motec PLM...problems
- GM Map Sensor
- Almost done.....(pics of my car)
- White smoke from exhaust on startup only
- possible problem with head gasket sealing
- Anybody seen this manifold??
- Hondata chips
- oil cooler to turbo question...
- Greddy intercooler : type 31 or type 24 ?
- Water temp gauge probe, where to install?
- Thieves F****in' Thieves PART II
- Hondata s200-b
- Boosting, but not boosting
- aem ems problems
- turbo noob question
- revhard+t3/t4oe+drag downpipe=
- revhard 2c fittings help
- How to run super-ultra / no boost.
- Maxrev Turbo kits, Good or Bad?
- Wiring Greddy Blue Box for ODB1 B18B1
- Supercharging a B16 in an integra or Type-r swap?
- need a manifold made ASAP!! Florida
- turbo outlet size?
- Finally... receive my first couple mods for my Evolution.
- Tial WG bolts striping
- need wire diagram for accel dfi
- Need Help ASAP. I think my car is detonating badly!!
- Knock sensor
- Ah! Turbo is on. HUGE problems!
- What do you guys think of this cutout?
- GhettoDyne vs Hondata vs Uberchip
- turbo newbie question
- Octane for nitrous
- bad gas mileage
- Is the oil kit gonna complete my turbo?
- Question about ecutouts, greddy downpipe and exhaust options
- sfp manifold and 60-1
- Turbine Question. 12 fins vs. 11 or fewer fins??
- How bad is my 450's not squeezing the whole way in
- rc 440's leaking help!!!!
- The Beginnings
- tial wastegate (cnc valve ring) ??
- WHO NEEDS a TUBOBACK EXHAUST?? i made my second one!!!
- Strenghting OEM pistons by variouse methods
- Fixed the gauges!
- Nitrous Oxide Injection - A form of Forced Induction, or not ?
- Gauge pods for 52mm gauges..
- A question for a future project
- Need the directions for Greddy gauges
- i NEED HELP...looking horrible with sputtering
- b series manifold for use with mitsubishi turbo (14b/16g)??
- What else do I need to make a Greddy kit complete?
- LS + .137 long rods... any besides Eagle
- Where to get my tach signal
- 3psi??? mad exhaust leak???
- spark plug evaluation!!
- code 3 b20b turbo with missing like help please
- what are good piston rings for a stock b18c1?
- For those who don't visit GDD. Big Power K-Series N/A!
- O2 and timing questions for greddy turbo
- Head Bolts
- Zip's old 02 sim box????
- Engine Balancing Questions
- car is boosted, but no boost on gauge? help
- Warn me please... JRSC w/ ZEX kit
- Anyone running Ubertegs chip in NOR CAL?
- tuning greddy emanage????
- Hondata IM gasket
- vouch for ladysman
- Eagle Rod new information for the guys that still are skeptical.
- APEXI AVCR - Pressure Sensor
- How much Boost?...
- LS/B20 rod question & other B series Engines
- egt numbers
- vafc settings as far as sensor type is concerned
- wastegate question
- Bar To Psi (boost guage) Search Had No 100% Possitive Answer
- Pics of turbo parts for my turbo kit
- Tuning Cam Gears On Dyno
- recommendations please: for hondata and clutches...
- J & S
- Hmmmmm 60-1 or straight T4
- Which motor should I boost?
- Apexi s-afc tuning capabilities?
- SOHC Turbo>> LS rods & Stock pistons VS B16A rods & toyota pistons
- what do you peeps think???
- gas/exhaust smell when AC is on:help:
- My venture into the Nissan world, week 1
- Basic Hondata questions
- intercooler install problem
- AEM standalone fuel management help out please.......................
- boost controller is not controlling boost need help asap dyno tune tomorrow morning
- which of these catch can setup is BETTER?
- throwing 7 different codes (need help)
- Super vs Turbo
- Size of wastegate bolt?
- Anyone know any companies that sell 3" downpipes for T3/T4
- Updated pics of the project.
- Another Honda Lost to F%$#&*g Theives!!!!
- where can i get a braided stainless fuel line?
- Well, 2 moths of 10.6 comp and 6.5lbs, my motor is still healthy.
- what size wastegate is this ?
- Is a t25 oil exit flange the same as a t3?
- Boosting Integra Tomorrow! Just need some quick answers.
- Did compression test today
- Dyno Tuning in Phoenix. Searched already
- Does anybody here sell Drag 3 kits? Or any other good kits.
- wich motor for turbo????
- GT3040 Update pics + Downpipe 80% installed
- hondata and ? option
- greddy boost gauge install help
- Hondata bin file
- LS block aquired- time to build
- stay t3/t4e and boost 20-25 psi or go sc61?
- Sup guys? Im new here ..heres my question/problem
- Oil weights and viscosity?
- What size KN filter?
- is 550cc rc saturated injectors good for boosting at 6-10 psi??
- How'd you wire your SPAL fan that came with your C&R Radiator?
- if u just build ur motor would u ?
- Any FI tuners in NOR CAL?? Works with s-afc and/ or hondata????
- Out with N/A, in with FI
- anyone running the Max rev kit on si?
- Some pics...im bored
- built b16a turbo 12.6@109
- Looking for Single Fogger NX Express system
- Hesitation/Bogging
- Engine dies.....very intermitent; could it be MSD?
- did a seach. Valve springs, when to upgrade?
- Running Hondata for the first time, having problems...
- Boosted y8 Please Help
- still white comming from exghaust side of my turbo.....
- Hondata tuning help please (jrsc hype r)
- Can out of round cylinders be fixed?
- What turbo and what motor should I get?
- where to put the o2sensor for a wideBand
- Building a motor what to do to it??
- what about zdyne??
- Can't raise boost!
- Projeck "Spooled" update
- can we use this stuff instead resleeving?! HARDBLOK?!
- upgrading the intercooler
- why not all GT turbos on Garrett homepage?
- BOOST Guage and BOV Help needed
- Car Stolen, Wrecked, and now I quit
- Anyone ever hear of the Flexlite fuel cooler that Summit sales?
- This is what MaxRev's Blow Off Valve sounds like..
- I need help on turbos
- Threw a rod
- Anyone ever do buisness with Too_Smooth
- revhard 2c intercooler question
- hey how much boost is the greddy kit good for a gsr?
- VAFC HACK with 310cc
- Check this out! (somewhat OT)
- PRO and CONS of FMIC and L/AIC
- Any experience with Leitner&Bush T-Top sleeves?
- blow off valve
- turbo kit recomendations
- will greddy piping for a 00' si fit on a 00' ex?
- Cams for B20B VTEC (Normally Aspirated)
- map sensor and AEM EMS
- what to do with the b16
- New Custom 3" Exhaust Installed!
- Another Zdyne question
- nos + b16
- can this manifold be fixed???
- Great night at track, smoked every import, ran a new best
- Possible exhaust problem? 2.5" dp to 3" cat
- Supercharged B18c1 + CRV crankpully question
- Is a gurdle necessary?
- i just want a simple awnsers to my d15 turbo questions
- Is this turbo any good?
- Where to buy GM 3bar map sensor??
- guessing when it comes to tuning.
- Strange Wobble Under Acceleration...
- BTM frustrations
- Help: DSM injector -> manifold Install.
- What exhaust are you guys runing wiht??
- Greddy oil cooler for SR20DET fit integra?
- Probs. w/ Greddy Turbo Timer
- Hondata Tuning in Nor. CA
- Making a downpipe, have a few questions.
- Difference in Greddy turbo kit for 95 Civic and 96+ Civic
- greddy intercooler on LS
- Just did Leakdown, Compression Test, and Checked Spark Plugs....
- how much detonation can a built take?
- attn WRX owners: Hks downpipe good?
- skunk2 manifold is NOT dsm injector friendly
- Future Setup
- which manufacturers make the "thick" boobst headgaskets?
- HOw high is too high to rev stock b18b on boost???
- Apex-i vafc
- I finally got my dyno pic and my maps...can someone please host?
- Am I detonating or what???
- maintaining a SC
- upgrading the greddy kit
- Use smaller brakes for more acceleratiion?
- Max Daily driven boost?
- Whos running AFC hack at 10psi or more? Your experiences..
- What AN line fitting matches up with 1/8NPT?
- Turbo Honda CRX HF
- Roll Cages, what are people using/liking?
- HKS EVC IV or GReddy Profec B spec II
- Nitrous Brands
- Which is louder? A bosch BOV or a 1G dsm BOV?
- SC61 AR question
- bov and pop off valve?
- Factory turbos
