View Full Version : Forced Induction
- GM 3bar map install...please help...
- My SMOG issue
- would this fuel filter cause me to lean out?
- Turbo installed, everything is done and the one thin that goes wrong isthe only thing I didnt do mys
- Turbo Install Guide
- Where to buy New spring for Tial Wastegate???
- cel code 74...misfire in cyl 4. :(
- JRSC + Nawz Vs. TURBO setup
- custom exhaust vs. thermal turbo
- Boosting R..
- Any difference between Earl's, Russell, Goodridge, or Aeroquip fittings and lines?
- Who here has cracked their cylinder wall?
- Will a T25 bolt up to a Greddy manifold
- Motor Mounts...
- Shaft Play already?
- safc2
- B20a crank in a C5 block?
- Tranny install. Grease the spline inside the clutch disc?
- MSD 6BTM / J&S SafeGuard
- squealing noise during boost?????
- how much for b20 or b18 swap into crx hf, and prepared and ready for turbo?
- Does Jackson Racing make one????
- oil return, silver solder?
- What manifold Would be best for Precision Turbos SC44
- torque plates for machine work?
- TD04L For Sale
- where to buy a turbo manifold?
- Rebuild engine....leave as is....help!
- Pics of my turbo sol in progress
- Please Give Some Suggestions On Possible Turbo's For Integra?????
- Spark Plug question
- bolt size for saab t3,
- Vacum Leak
- AEM Ems help
- DIY AFC boost hack
- Brand New Golden Eagle Parts!! Pictures Inside...
- what ems would be right for me???
- Help me on choosing the right thing to do?????
- MotorMatrix.com Street Car Dyno Video!!!!
- TIAL WG and BOV discussion.
- Drive Shaft Shop axles....
- 3 bar map sensor
- Who is the best tuner for hondata?
- Hondata-- J12 what does it do
- Tial Dumptube Flanges.
- Hondata-- where do these wires go...
- Recomendation requested for The Drop Shop.
- loosing power???
- Threaded IAT sensor compatible with B16A?
- FS: Vortec FMU and Apexi Blow off valve
- maxrev bov install
- hondata related troubles?
- 0.6 bar i will nedd to do any change on ecu ??
- Turbo finally going in
- What should i set my base fuel pressure to? B20 turbo, Zdyne, 350cc injectors
- 85mm HG on 83mm Bore
- How much if any will boring to 81.5 weaken the cyl walls?
- fuel pump
- Exedy Clutch on turbo z6?
- Quick Revhard turbo fitment ?
- Which Turbo For the Integra?>??????
- My Apexi Universal Filter with custom flange :)
- Supercharging the D16Y7
- Garrett T3-60 in a stock LS
- Std Oversize
- Oil on front of block!
- Im getting mixed instructions for the delta wastegate....can someone help me out?
- Resurface B18A/LS Rocker arms?
- Pics of Downpipes? with compressor towards driver side?
- turbo fitting problems in 91 civic dx
- Making a Custon Down Pipe?
- Pics of my standalone, inside factory ECU case
- Do I have to lose the A/C to run Drag intercooler piping?
- gsr bore question?
- WAY WAY off of topic
- Would a 1/2 inch hold in the intake manifold cause all loss of boost?
- 5-bolt ?
- Collector help...
- Best Place to Order Drag Radials ?
- HP estimate
- Detonation sound?
- Turbo Tune....Greensburo NC
- y0...peeps with FI cars....
- Fuel system setup?
- Where does the Nitrous Gauge Go?????
- Tial
- places to get 5 bolt flanges........
- civic ex ls piston swap?
- help me finalize my turbo parts and see if i have everything. PLEASE?
- SMC vs. SMC+
- wastegate ?
- Piping question for turbo.....help
- Took some videos today, short but sweet
- All Show No Go Decided, Where is ZDYNE Group buy
- drag 2C kit or Custom setup for b16a2???
- pics of my clutchnet after 13k mi. Thoughts?
- carthec fmu install + driving without turbo connected
- Let's see you homemade or store bought ....
- Will a P72 ecu run my H23..
- Need advice before I start boostin!!!!
- Still need a boost controller with hondata??
- FMU help
- Pics of my Setup!
- SFC install..
- Defi EGT Guage Sensor Install Location?
- dilemma with 2g dsm intercooler
- How do you guys have your externalwastegate?
- please help fast......... resistor box wiring problem!!
- Anyone interested in a brand new Apexi GT-spec iercooler?
- CTR cams and turbo
- Car Sound Cat Question
- pistons
- Boost control
- monetary dilemna.....which to get first????
- display options for wideband O2 sensor
- oil lines,fittings ect to complete custom set up
- egt same mounting as o2?
- smc+dsm450's wihout turbo users - --- question
- need help bracing a meng tubular manifold
- afc hack question...
- Downshifting when braking
- How To Work Nitrous w/ Out a bottle opener and other ???????'s
- First time to the track boosted...!!!!
- i'm happy...
- Cam identification?
- Hondata question?
- Hondata--where to get tuned in GA or SC
- ECU questions for Hondata For Non-Vtec
- using hf manifold w/ t28 w/ AC???
- Water Cooled Turbo
- What else besides turbo, mani, and intercooler do I need?
- whats up with all these guys runnin high boost on stock D16Z6??
- NEWBIE question need an answer please!
- VAFC Hack guys... CEL 43 at partial throttle, cruising?
- tech-edge vs fjo wideband units?
- Max EGT in B18c in F.
- Some serious issues with Hondata
- OT: i need to build credit...
- ATTN: Experienced TIG Welders
- Need to buy 3 inch downpipe for a rev hard stage two kit???
- 5 bolt flange on my turbo too small, please look, help
- noob ?'s
- parts to make custom manifolds????
- Detonation at partial throttle on freshly built motor!!
- Diagram Of Turbo Oil Lines
- Anyone Street Tuning IGNITION???
- Compression and Supercharger
- how much does a lightened crank pulley help on a turbo engine?
- set mbc lower than wastegate?
- Hondata question.....
- Stock O2 problems..
- Help To Distinguish Between Head and Cams
- Help With Compression #'s?
- Pics of my Custom Turbo kit... (Not 56k Friendly)
- Everything is hooked up but no boost, any ideas?
- EGT/CE light prob..
- turbo noob help...
- What To Use With ZEX Nitrous Kit?????????
- should i SC my b18b?
- Holy $hit!! has anyone ever used the G-Tech Pro before? Amazing!
- anyone have a bad vx o2 sensor
- saturated or peak and hold RC 370cc's????????
- Doing Hondata IM Gasket install, and it sucks....
- apexi safc 2
- anyone got a pic of a t-60 turbo???
- Which Turbo is better? TDO5-20G or the GT2835r??
- waste controls boost?
- Turbo info?
- Removing/installing vacuum lines from turbo to wastegate...huh
- Internal differences of B-series blocks......
- Intake control solenoid question
- trying to post a pix of my turbo
- Will a gsr greddy oil cooler fit a b18b?
- Which turbo to go with
- 11.05 @ 129mph... 1.l. Suzuki Swift!!!
- Let's see some arming switch pics!
- What causes low EGT's?
- Boost Spike Problem/Very Detailed
- Oil dip stick
- OT: Good Performance Shops In Jacksonville, FL
- What's your CR and how much boost are you running?
- ZC Turbo Update - Pics and Info; Questions too...
- air fuel ratio question
- NOS or JACOBS controller???
- Dry to Wet conversion!?!?
- Turbo?
- Intercooler Piping Diameters
- Auto H22 LSD into 5speed tranny?
- Need help with engine swap/turbo install North NJ will PAY
- Step by step on how to change a Tial WG Spring
- o2 simulator that works with the heater circuitry
- Any Users from "importparts.com''??????Please Read
- who can make custom dps?
- which first? dp or cat back?
- Is my wastegate cracked?
- my boost project
- Will my T25 bolt up to a Greddy manifold
- Worried about brand new turbo/ oil and play questions
- Where do you tap your EGT meter?
- engine pic ready to drop in
- need help with DIY wideband O2 kit
- V-AFC datalogger
- JRSC in EK Civic GSR
- Running waaaay to rich! How can I fix this?
- SportCompactMag....Supercharger
- all those w/maxrev BOV
- Inline Fuel Pump or Intank Fuel pump?
- Where are you mounting your IAT sensor?
- Hello.....
- Controlling revs without an aftermarket ignition....
- Compressor Wheel
- Downpipe material needed?
- compression test
- I've just about had enough....
- are there 3 12v constants in the ignition harness?
- JRSC weight?
- where to get decent headwork?
- Which Nitrous Set Up To Use ZEX or NX?????
- mising link or map sensor bypass valves ??
- sohc turbo question? any dynographs w/ a/f?
- turbo timer and o2/ a/f acting weird!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Break-in period?
- To all the T-shirt winners from the Precision contest ....
- 2000 Civic Si turbo
- Intercooler Install pics of my LS/Vtec Crx (lota pics)
- fuel pump problems?
- Tial 35mm and clearance
- blitz type s boost controller
- Question about 94-95 b18c1 and sandwich adapter
- BOV help
- AFC hack and OBD-2 questions...
- Help me pick a fuel set-up for turbo gsr
- Need FMU if you have greddy blue box....
- ramps....
- Help, Choosing NEW radiator
- any suggestions when installing my oil pan?
- doing turbo install and my boost gauge reads 20psi vaccum at idle...HELP!
- coolant temp sensoror voltage/temp scale?
- D16Z6 block resistance...
- Best way to fix FMIC leak
- Mechanical Or Electronic Gauges??
- 30-35mpg
- T/C my D16Z6 or B20 VTEC ?
- where to get smc
- Pics of Greddy type 31V and 24V IC for 92-95 civic anyone?
- help, Civic b20 w/ Nitrous
- Blitz BOV Can it be converted to a closed loop system, and taping into air filter?
- Where the heck do you find these things????
- Update: Swap day 3, major problem...awesome solution
- Where do you refill nitrous bottles???
