View Full Version : Forced Induction
- 84 trim exhaust on a gs-r
- Aeromotive A1000 fuel pump inline pump wiring electrical search friendly
- Turboing my 99 EM1
- Need help with adj bolt for Greddy Type RS
- is the bov supposed to be open at idle?
- Best Turbo Kit for The Buck.
- Help with turbo selection on a BUILT 2.0L
- finally crossed over to the boost side: parts/ boost/ uego question.
- I have 2 turbos cant decide wich to use for my project!!
- help me build a kit for a gsr
- MPG on a Turbo Stock motor?
- Overloading OEM oil pump?
- cometic head gaskets
- switched to smaller turbo and now have higher boost?
- Current status on the B16T Next Step!
- Question about DSM 450cc Injectors
- E85 LS Turbo
- ball-bearing version of straight t3?
- JRSC
- where can I get a exhaust upgrade for my gt3076R
- tial 38mm wastegate spring color - psi ??
- will any d16 turbo fit.. need help
- otuning question??
- turbo on ebay....
- What's the word on XS Power?
- Need input from boosted h22's downpipe, cat-back size to power ratio
- full-race intake manifold?
- Funciton 7 block girdle
- Turbo Charging 88-91 Prelude
- stock h22a with turbo
- ati or fluidampr
- NEED HELP ASAP!!! Trying to BOOSTTTTT!!!
- PSI???
- D16 Ramhorns?
- turbo d16a8 aka zc
- What does it take to Rev 9500k + ?
- What psi is walboro 255
- Who sells velocity stacks for 3" pipe?
- TE04H
- big big question:is the measured AFR corect if i use dump pipe to the air?
- boost controller
- new to boost, couple quick questions, they arent that stupid :thumbup:
- Emanage help
- Aftermarket main bearings vs. oem fitment?
- New Jersey
- Torquing Head Studs on F20C
- Is the Gt3076R too much for my build??
- anyone use zeitronic wideband w/hondata for tuning??
- Need Tuner in NorCal, any reference?
- thinkin about joinin in on the FI
- plz help what's a good sohc motor 2 turbo on an ef civic
- Wanna Boost my b16 to 300hp or a little more....
- t25 (reversion) need some help
- Zex 55shot dry w boost?
- Oil line?
- Difference between t3/t4e and precision sc61?
- CRANK CASE PRESSURE idea (please check)
- Anybody Dealt with CRPTURBO!!!!!!
- what do you all think??? pros cons
- what is limt of factory headbolts??
- Do integras have exhaust bolts or studs?
- How do I adjust my clutch?
- want to turbo my eg civic - b18c
- hp gain expected on gsr w/ supercharger...?
- -10 AN oil return line, oil pan adapter
- Lets seem some turbo bracing / brace setups!
- will any other headgasket work with GE kit??
- Anyone running Ls/Vtec turbos?
- Tuner In Lincoln Nebraska area
- External Wastegate Dump Tube Muffler
- Could this be possible?
- Ls/Vtec turboed with nitrous?
- Quick ??? SOMEONE HELP???????
- IC piping
- arp head studs for b18c1 what lenght they are?
- 10.5:1+12-13psi = ok on e85?
- SC61 POWER!!!! 424whp on 15psi
- How much do d16z6 rods weigh ?
- Building a Daily 400whp B16?
- Post Your Thunderbird Turbo Setups!
- bottom end build price'n
- New to the FI scene, few questions on future build, looking for 500+
- e-cutout is not fully closed ....
- wd40 ???????
- zex fittings
- who makes the turbo kits with the turbo where the muffler is?
- Full-Race K-Series Stage 1 Kit - 2006 Civic Si?
- Turbo cam question...
- Engine managment, what should I do?
- Building and boosting a b18c1.
- T3/To4E Or GT3076R Peak Boost Kit!
- car wont start in the cold HELP!!!
- boost stopped building
- Anyone else waiting on synapse wg?
- Safest air/fuel ratio
- Motorcycle EMS for turbo/nitrous'd bikes
- ap and im bquestions
- CustomDesignPerformance, anyone used them.
- what is the stock bore of b series fuel rail
- Will my close ratio LSD trans hold up to boost?
- When resurfacing head or block, how much do you tell the machine shop to take off ?
- LS VTEC TURBO BUILD ON EK HATCH
- Losing boost in vtec on dyno.
- What will make the biggest Impact?
- Philly dyno works?? Evans tuning??
- should i drive?
- Need some input on Wiseco pistons and dealers
- best turbo for my setup
- How can i tune w/ nitrous? zex dry
- new product review " TIAL 60MM WG"
- Turbo mufflers
- prostreetonline.com reliability?
- ls/vtec and nitrous??
- What should i get next...
- compresion test 205psi at all 4. B18c 10.6:1 JDM motor, does it sound right??
- Garrett GT3576 .65 A/R picsand results please.
- Built F22b1 SOHC-V: need turbo opinions for 425-475 whp
- H22 Turbo kit Questions???
- Trying to reach 600 whp, having problems with misfires, pics inside
- psi recommendation???
- Proper way to go about using a copper headgasket
- In all honesty, whats possible?
- using ball bearings for ARP head studs
- Ramhorn Turbo Mani, what turbo are you running?
- thread pitch on AFI t3 manifold
- LS "Low" Build
- higher compression wit tdo5h safe??
- Build motor first or buy turbo kit first?
- ?"s on my h23a1 engine build
- Greddy 15G Down-Pipe - 2" only?!
- I Need Some Help
- boosting stock ls
- how big of a turbo should i get? zc crx.
- Nitrous Rings????
- turbo help need info for relible setup's
- What BOV Is My Intercooler Piping Flanged For?? *PICS*
- Thinking of Boosting my 98 ITR
- Condition Of My Engine?? (oil in catchcan)
- will a garret 4 bolt housing fit on a sc61 5 bolt turbo ?
- Which of these two intercooler for 380-400whp?
- Exhaust "pancake" pipe
- Has anyone made over 400whp with a johnnyracecar intercooler?
- Sleeve Tolerance
- Inspecting / Rebuilding a Tial Wastegate. How To Tell If My Unit Is Broken?
- GT35R T4 is the shit
- where to tap for oil (goin d16 turbo)
- Weird stuff... on my Benson Sleeves.
- timing in part throttle vacuum
- Need help Siemens Deka fuel injectors..
- B16 head with Crower STG 2 turbo camshaft & OEM ehxaust camshaft?
- chiping question
- f22 t borg warner gm-8
- how to measure a wasgate
- Mini-Me turbo
- What grade inserts?
- Finally My turbo b16 DA9......!!!
- dynoed the Y8 yesterday
- drag kit
- CAROLINA PPL! CP Race (CPR) in Charlotte??
- can i re-use my turbo kit
- quaife lsd
- Rebuilding a Blow Off Valve???
- Best way to flush out White Lithium Assembly Lube out of your engine??
- B16A2 Head assembly...??
- Questions to ask when buying a built motor?
- where to buy 1/8 NPT Tee fitting
- Newbie needs assistane: What are these three sensors/relays on top of my JRSC manifold
- 3" Thermal R&D GSR Sedan exhaust
- Where can you buy BUILT motors?
- Tube & Fin Construction or Bar & Plate
- Help suggestion a turbo set up...
- ls/vtec turbo ?
- What kind of turbo Honda guy are you?
- S100b or S200b, i want one, tuner wants the other one.
- Sleeves rusting, what should I do?
- T3/T4 or GT 3076
- What kind of signal is a tach signal?
- Autometer Wideband
- Need help, B18b and C boost questions- melted pistons
- need second opinion
- How do you make a murge collector?
- turboing auto
- Anybody have a VES for sale ( ATP Turbo V.E.S.)
- electric/manual Cut Out With Y Pipe
- Similar setup
- D series Greddy Turbo manifold question
- turbo builds (w/c shop)
- ***HELP*** why am i still getting boost creep?
- Oil Sandwich plate for a DOHC ZC?
- new engine: when to switch to full synthetic oil?
- Max dynamic compression question
- Dart block help please....
- Fuel Line
- How noisy is your sleeved H22 with forged pistons at cold start.
- Need Help installing Defi BF Control Unit II
- Anyone else in California running into detonation issues with new fuel?
- how is this set up, just pick it up (gsr turbocharged)
- need title of the song in this video
- Safe Boost
- difference in PR vitaras and OEM ones
- Sohc turbo problem
- E-Cutout's in winter time
- RC720 injectors with fmu & Vafc for H22 at low boost.
- A/C compatable manifold
- turbo b18
- CC-Fab ramhorn manifolds
- a far fetched question
- An off the wall idea...
- turbo'd b16
- using a 1g eclipse turbo on an h22.....stupid too small?
- b20a5
- T25 homemade setup car is breaking up
- aeromotive eliminator pump leaking??? any suggestions???
- dsm bov's
- My boosted ls/vtec valve destruction, tell me what you think, pics inside.
- *If you have or have had a VORTECH supercharger - please post here! Class action lawsuit anyone?
- Bearings, Bearings, Bearings....
- HELP NEED TO KNOW????
- full race stage 3 kit...
- Post your supercharged setups
- dp to exhaust
- 00' sir killing to much gas
- When is race gas needed?
- 2 step or 3 step??
- Question
- turbo stock GSR?
- **Need help if you have a blitz turbo timer please look inside
- what hp i can get from my list?
- Resistor Box install in '99 Civic EX
- DP flange leaking..how to seal it??
- DRAG III Turbo kit FORSALE
- Which intercooler/piping setup will be more efficient?
- Intercooler Question
- Clutchmaster or Competiton clutch RSX twindisc??
- H22A Turbo Crx...think there is enough room in this bay :)
- sorry to ask...manifold question
- Turbo LS Dyno numbers - What to expect?
- radiator fan problem
- valve cover vent/fittings
- i tihnk the seals are going bad
- Turbo 96 LS
- Want to daily run 6psi. What is needed?
- CRAZY AS HELL........car started with 1000cc and 3 bar map?????
- Can I use uberdata with my JDM P13
- Wastegate help....*pics*
- Tuning Question
- 1993 Del Sol Si build thread...quickie build for spring underway..LS/vtec, custom turbo setup, etc.
- Is anyone using an Apexi ws exhaust on their turbo set up?
- B16 or H22,Opinions Needed on the situation!
- engine build from hell
