View Full Version : Forced Induction
- which diamater exhaust for this setup?
- Making my own 3 in Downpipe and full exhuast, What bend do i need??
- missing link screws
- ugh, hot weather owns me
- 440's or 550's?
- injectors
- heat, heat, heat.
- which fuel system works best with turbo?????
- idle problem
- what could I use to retard timing only when nitrous sprays? msd unit?
- Intercooler fitment on Accord
- Greddy E-manage
- Q's on LS Rods
- sohc turbo guys need your help, I'm building my block!!
- Found another good book about turbos..
- ANYONE know... 86mm BORE pistons for B Motor ????????
- Exospeed Sleeves.... anyone using them? Any regrets?
- Benefits of street tunning?
- turbo timer not keeping the radiator fan on...
- ENDYN Stepper Pulley: Another Problem
- Forum for turbo D-Series?
- good place to buy a turbo kit
- problem with friends turbo,,,???
- Gsr Block
- Just got my car done after 9 months. Then it happens.
- How much HP with FMU
- Power FC Boost control kit
- Hondata s200
- Greddy oil filter block adapter.
- HONDATA PPL, will this set up work for me??
- Just about ready to put turbo on, what takes the longest to install?
- what is an e-cut out
- max recomended boost on a t25 simi built zc
- Dump Tube Piping
- Vouch for TOO_SMOOTH
- Looking for a very small oil cooler (about 5"x6.5")
- best incoooler from...
- Which oil drain plug do I get from Greddy???
- What pistion rod setup?
- cel code 1 and srs light
- ANyone know if Honda injectors will fit Nissans?
- looking for a good n20 installer. nj. two questions regarding nitrous on two different cars.
- video of sohc turbo cars
- What do you guys think of Cosmo Racing?
- Where to find serious technical theory on turbochargers.
- just a quick run-down of my near future setup...(no turbo advice needed plz)
- Need help finding a the phone number for a carbon fiber hood company.please help
- New exhaust review and question
- most credible nitrous manu. claims...
- going to the dyno thursday...what questions do i need to ask or what instructions should i give???
- Done with install...now I just need a good dyno....where???? So. Cal.
- Calibrating Techedge with Hondata......A/F's are off between Display and Hondata...Help!!
- Official Injector Resistor Box Install......56k, Buy Broadband.
- Tial Wastegate question Regarding Electronic Boost Controller Hookup (AVCR)
- Where to get Rod bearings
- PROfec A or Turbo XS MBC? did i get robbed? help!
- Best Bov and Wastegate to use..
- Wastegate changed...!!
- Best Check Valves??
- similar to hitting a rev limiter...
- Rev hard official website
- CAI to charge pipe?
- Is there anything special about the different sides of a 35mm flange?
- Turbo SOHC life.
- SMC ecu?
- afc and 450's install car wont start
- Chipping p28 for hondata.....
- Anyone boosting 10-11 psi on a LS motor???
- cylinder flooding with gas
- Cracked sleeves and driving
- My new Resevoir!
- head gasket
- STock SLeeve dependability
- A few thoughts...
- Boost and headgaskets
- gsr shortblock and boost??
- Fast and Furious NX Nitrous Kit at Kragen???
- Lower compression for this boost?
- what is a nutec turbo?
- What's the deal? (bogging/stalling)
- Help with Fuel Management
- Hondata VS Z-Dyne
- Errr..... help me out guys.....
- More GT28 questions...?
- High Compression...Lower Boost OR Low Compression.... Higher Boost?? The Real one This time!!
- DOHC ZC Turbo Charging Question...
- Last dyno chart of Apex D series kit on LS... it's topped out
- turbine applied
- DRAG turbo kit or Rev hard?
- Sohc turbo.....what exhaust are you using??
- highflow cat conv for my turbo
- filter opinions please
- Home Made Catchcan
- downpipe question
- whats everyone paying for juice/ per lb. in your area?
- What do you think of this turbo setup for my integra ls?
- rubber vacuum hose for boost controller/gauge..where to get 'em?
- Question about my turbo's filter
- What I did to prevent car theft... (my repost from the EG forum)
- Horrible Shop Experience..Motorsports Performance Frederick MD.
- How hot does your car get?
- trans gear ratios
- EEs help....traction control idea.
- Too old to turbo?
- JG/edelbrock intake fit question.
- What could Cause this? Pictures Inside... Sorry 56k
- Does anyone offer any aftermarket/stronger rotor?
- cam timing
- Getting closer
- HKS SSBOV and Greddy weld on flange?
- Setting up a T25 on an Integra LS - How much should it cost to install?
- Td04-13H sohc set up
- Wanted: Uberteg software
- turbo manifold
- installing, have a cpl ?'s
- t25 turbo on a b16?
- whats the deal with the trim sizes ....
- Lovefab powered SOHC!
- Hondata maps, what do the fuel numbers mean?
- need honest help
- SMIC -> FMIC - worth the upgrade?
- Possilbe to mount bottle style nitrous pressure gauge up front?
- Accord turbocharged
- quick qustion.. please help.. wastegate
- using apexi kit from d on b series motor
- At what temperature does your radiator fan turn on and off?
- Who know dastek unichip ?
- Does anyone see anything wrong
- Affordable Axles....anyone interested ?
- Got my oil changed and put the others to shame! (funny story)
- ECU throwing misfiring codes
- turbo question
- turbo air filter question
- Advice on building block
- PASSING INSPECTION: Things you do to your turbo'd cars to pass...
- Im feeling left out... Here are some pics of IC piping...
- ZDyne users: copying the 3D graph table...
- Any one running a 7.5 aluminum flywheel with there turbo?
- How to make a charge pipe for my integra w/ BOV flange?
- Stupid question on boost gauge
- Intercooler piping? who sells it?
- Just got back from Dyno...
- Dropped the exhaust and now hardly any boost...help
- Help car hesitating
- 96lb or somewhere closer to 70lb injectors
- RC Injector Help....My OBD1 Clips Won't Work!!!
- Help me with a turbo swap!
- How much boost are you SOHC guys running on your blue box (Greddy kit)?
- crx revhard question
- gsr greddy kit fitting>?
- Greddy or Drag 3?
- need secondary on 15 pounds?
- Thinking of Stage1 MS Action clutch... vs MD Stage 1 Action clutch
- Stock Cat+Boost?
- Wanting to Run in the 12's, what would you do? Please share your ideas.
- Wanting some BOOST ideas.....Need some questions answered......
- Can i see your slim fan installs?
- K20A3 Turbo manifold where can i get one.
- how you dyno without damaging motor...
- my mechanic is SC all the way...
- dissapointed!
- Looking for pics of installed nitrous systems
- Can you upgrade a Greddy/mitsu turbo?
- My car run really rich...why ?
- bad turbo????????? PLEASE HELP!!!!!!!
- b20 turbo-what turbo to purchase?
- question for the turboed ludes
- Fuel Pressure Regulator - 255 pump
- Cylinder Misfires....
- whats the best trans for a turbo setup
- What T3 turbo fitd good in my 94 Integra????
- cam gear play?
- got a t25.. help me plan the next couple of weeks
- revhard stg3
- tranny for turbo
- AEM EMS + rc 440's
- inline pro manifold + tial 35mm wastegate
- sohc turbo....tranny problems?
- downpipe materials
- Tuning a V-AFC without dyno
- How much CFM?
- drivable? with no piping?
- Weather and A/F?
- Head gasket question?
- Head rebuild need help with a quick question please read...
- Help me decide which intercooler
- First start of the year = no start, resistor box maybe?
- aftermarket rocker arms
- HELP!!!! problesm with map sensor i think
- Anyone running a PWR radiator
- Flex pipe on downpipe? Yay or Nay?
- am i hurting my turbo w/ my exhaust setup?
- Turbo Size for itr?
- ignition/cam timing
- 8-12 Psi in stock b18a, is .8 degrees retard per psi too conservative?
- 450's/resistor Ques. going back to stock, quick question
- oil leak?????????????????why??????
- Compression ratio for supercharged B16
- How do u guys widen ur plugs?
- JRSC kits come in different size?
- ihi has a b sries turbo kit??
- i know this has been asked before... (b20-T)
- need input on manifold design/demand...
- Drag 3 Manifold and Turbo (? gasket?)
- arp headstuds.....lube?
- Oil return
- SAFC II Wires???
- Changing Drive Axles?
- newb BOV question
- A little ole turbo setup i slapped together...
- Warner ISHI IHI Turbo
- Puttin on new distributor, how can i get timing exactly back to where it was before?
- 70mm throttle body too big ?
- anyone have pictures of maxrev bseries in a crx?
- GM 3bar Map sensor problems
- open loop help
- rc injector question
- putting my kit together... need some advice
- Is there anyway of Changing your vtec crossover on Hondata S200....
- Data Logging EGTs with Greddy Warning EGT Gauge
- GReddy gauges and AFC mounted.....
- itr intake camshaft and gsr exaust camshaft question
- My turbo GSR is running way too rich...help
- wastgate install question
- calling all hondata peeps... just got running.. having problems.
- How exactly does a t3 turbo work w/ internal wastegate???
- Lowest fuel pressure with large injectors??
- all motor or turbo
- Newb here
- my new 1/4 mile times
- Flywheels and Boost?
- Turbo decision...need advice
- BBK 255lph fuel pump
- Prelude Revhard kit?
- Pics of my new FMIC!
- Now Boosted. Feels great! Few worries though.
- FI Radiator Q
- Turbo Coatings
- could someone help me out downpipe fitment problems Do
- ... fan configuration... before vs after radiator... push vs pull... recommendations?
- Three weeks of boosting, and my car is funged. Someone please help.
- Is your turbo car your daily driver?
- Couple Questions For All You Turbo Experts?????
- IC piping tool?
- NOS Relay, is it neccessary..
- compression ratio on d15B
- boost on d15b
- WTB or where to buy a obd 1 intake air temp sensor for jrsc and hondata.
- How many of you are running nitrous with your turbo setup?
