View Full Version : Forced Induction
- ebay scammer, WHY CAN'T I FIND A TURBO
- B&M FPR any good?
- New Possible D.D.? Semi-OT!
- Need turbo manifold built - Toronto Area.
- who actually OWNS and USES an E-CUTOUT? Post up if you do :)
- CRvtec throttle cable question
- Copper Spray on Cometic Gaskets?
- eagle rods w/ arp bolts?
- Sizing the piping diameter ??? ....
- longevity of turbo'd gsr???
- VAFC 2 Question??
- cometic hg ?
- Pinging On Top End Under Boost
- who has made their own downpipe?.......questions inside
- Another Flamenco-t is the BESTEST thread
- Boost Creep,.... Solutions! Post experiences HERE!
- Is Intercooler too big for Application
- engine code(running too lean in bamk one) with afc????
- Question with the AEM EMS
- where to get custom intake mani in nj area?
- B20 pistons on a B16?
- need help with cooling troubles...
- My map sensor is throwing a code, I am going to boost , maybe not so bad???? plz help
- anyone interested in a wideband tech edge FULL set up?
- N/A To JRSC
- Lets see your nitrous set-ups!!
- Anyone use this regulator?
- pic of my intercooled JRSC ( not LHT )
- I need ebryone's help on gsr turbo swap!!!
- Is This a Good Idea???
- intake manifoilds for STAGGED injection?
- some pix of the ricer
- avcr or greddy profec B?
- v-afc hack 440cc injectors help
- blue box...using 310cc saturated or peak and hold?
- Any Opinions on VOrtec 12:1 FMU on a JRSC
- guessing q-mile time....
- direct port NOS
- Walbro High Flow 255 lph fuel pump Q's
- 11psi jrsc?2k si
- drag gen1 kit on d16, what should I do to my engine?
- Building head and was wondering if Ferrea is a good brand?
- Greddy Turbo Gaskets
- just got the engine done
- ProfecB spec 2 questions.
- FS
- s100 or s200
- please help me decide on my setup, need reliability/power, kinda long
- making my turbo kit
- oil feed line
- Need Help. I have a sleeved b18c1 that needs to be cleaned??????
- sound with vortech bov!!!
- Does anyones intercooler hang below bumper?
- B&M Fuel Pressure Regulator, walbro 255lph, aeromotive fpr
- need help pls
- Happy Thanksgiving Everyone!!!
- What does the knock sensor look like, in this picture.
- What's The FULL Parts List for custom Kit?!?!
- Question on Intercoolers, Air to Air or Air to Liquid
- how do you feel about the skunk2 turbo cams?
- afc hack with jrsc
- MSD 2-step installation
- JRSC 12 psi intercooled, want 15 psi intercooled !!
- Help me Choose the right Sc61
- how do you guys pull your motors????
- water injection?
- Does anyone make a -10AN to 3/8 NPT 45 degree adapter??
- T fitting back of block for oil return line..
- d-series greddy turbo kit for $1500, but i have a gsr
- What do yo think about the flow of DRAG manifold for D16 ....
- where to get Rebuild kit for t3/t4?
- Final Drives. Whats best?
- Bov Question
- Greddy Profec B...
- SOHC y8 block on z6 head?
- question about 3" exhaust
- Pistons melting.....
- Fuel pressure too high to crank good???
- turbo da integra stolen in las vagas...
- Intercooled JRSCed b18c and high compression???
- turbo is leaking from the exhaust side!!! any advice would be appreciated..
- Timing belt / head issues...
- Is running too cool a bad thing ?
- Turbo nipple to vacuum source?
- Just got it started ... is it ok to....
- IGNITION RETARD QUESTION
- summitracing partnumber for MSD injector clips ? anyone know it>?
- 3Map sensor work with stock ecu and no Hondata
- Block Options: D16z6 or D16y7
- What should I expect to pay for endtanks on an IC core?
- ECU tuners
- DART block vendors??? Anyone that sells honda dart blocks on H-T?
- Can I assemble the bottom end my self or do I have to take it to a machine shop?
- arp head studs???/
- gsr cams in b16
- Skunk2 stuff - quick questions?
- Quick question
- People who aligned bored their blocks and have whp....
- Removal of internal wastegate
- Gear Sets
- Ordering a car sound cat, 1 or 2 o2 bungs?
- why locked?
- good tig welding sites?
- TURBO FOR LS MOTORS
- 1 goal down.....2 to go...
- Pics of my New GE block from Bodykits NW
- In search of the world's fastest B16 turbo street car !
- Weird idle issues going on, need suggestions
- can i weld these pipes with a mig welder
- Anyone measure a set of stock bore wiseco pistons?
- In search of world's fastest street B16 turbo civic ?
- Rate this Turbo Kit...
- pistons and ringlands
- s afc parts???
- Turbo xs type-s?
- Greddy 15g to bseries
- losing oil
- Precision intercooler question...
- Compression Ratio?
- rotating turbo housing and oil lines
- CheapTurbos new Turbo!!!!! "The Blowzilla"
- need help removing stock coil and adding msd coil
- jrsc 12psi on stock internals in 2k si ?
- FS: Drag Gen 3 intercooler...supported 400HP
- Peakboost Kit
- post your turbo set up
- BOV that Blow off when you are idling
- fuel line/hose with banjo bolt question...
- t3/t4 q??
- Might be selling the teg...need a beater that can be a fun project.
- Who needs a computer?
- turbo kit finally in but radiator fitment probs
- People From Georgia Listen please
- What is the best TURBO set up for a ITR
- Ordering pistons some help would be nice!!!!
- Turbo spiking?
- Will a Tail 38mm support a Sc61??
- Turbo running without piping/ or downpipe. SAFE?
- Nitrous Push button setup or MSD window switch
- Opinions: JRSC + 2000 DX
- V-AFC HACK
- sleeves!
- valve seat in 35mm tial
- ATI Damper... Is it really necessary for over 700whp??
- Action 2ks vs Act xt/ss Need some input.
- Which IM: JG, Skunk2, AEBS????
- Dumb timing question
- Finally got an intercooler one..
- injector 0-rings...
- ford turbo crew cab... video
- D15B2 "DX" head vs D16A6 head under boost ??
- OK...what do i need?
- motor back from engine builder! pictures!
- What size injectors?
- LS+b16tranny+turbo= good or bad??????
- Edelbrock turbo kit problems, need advice
- Updated pics: fixed the return line
- GSR, CTR, or ITR cams better for turbo?
- simple question
- Fuel Flow required for 12 lbs boost
- Turbo Questions
- tial bov videos
- [SEARCHED] Will a 97+ Oil Pan (h22a4) fit a JDM h22?
- My "EF-1" cams have stock markings...WTF?
- Boost activated/deactivated switch?
- Which size injector would be best
- AFC Hack mess
- ***HELP! Greddy Profec b
- F40 dyno vid
- 15+ psi on the hack!!!!! Look here...
- ebay mani. anyone ever used one?
- darton sleeves?
- Question about geoff's intercooler
- f/s: greddy turbo kit w/ type 31 intercooler complete less then 2000 miles
- Turbo Related Questions and a Poll.
- car running, but bad idle and loud rattling
- AEM tru power pullies
- Welding a turbo flange on a Manifold
- Best pistons for LS turbo
- Quick question about turbo talk?
- Turbo Fuel system.. what do i need?
- Is LS/Vtec worth it? Questions about LS turbo
- Downpipe Question...
- Intercooler (water) sprayer Kits?
- looked at compressor maps-------------------------some clarification needed about specs
- little help
- muffler shop downpipe
- Vortech Owners!
- Ceramic coating the inside of the turbine housing.
- DSM 450cc injectors 1G = saturated 2G = peak and hold?
- Taking a welding class, which one do the welding pros recommend I start with.
- PLX Devices wideband? ANybody using this...
- A few teasers of what's to come...
- Best place to put AVCR in Si???
- turbo exhaust question
- Anybody using the PLX device wideband??
- ATTN- Socaol Tuning Sessions!!!
- help me with my setup...please
- overheating??
- b20vtec, ef hatch just installed turbo won't start help help help help
- anybody use a mitsu starion turbo?
- Lower temp thermostats... yay or nay?
- Question on this SC63
- medical grade nitrous??????
- Where to buy stuff in Japan?
- Anyone know of a place in the bay area that...
- Tial/Deltagate Gasket
- Debate: Compression ratio Vs. Boost/Psi levels
- 96-00 Greddy 19T kit = 300-310whp Greddy SOHC turbo?
- ** WHP Honda's *** Where do you stand
- Bullet Proof H22 bottom end...
- Y8 turbo kit on a Y7
- What clutch/flywheel to get for a B18C
- Which is a better Turbo Kit
- "JRSC" Rotors vs. "Mercedes" Rotors
- NGK Plugs - search no help.
- Junk Yard Turbo Time!!!
- Who makes 5 bolt t3/t04e flange?
- What cars came stock with an adjustable blowoff/bypass valve?
- Intank and Inline pump, too rich?
- Looking to get a turbo kit. What brand
- Can I run all motor on a turbo hondata base map safely temporarily?
- Turbonetics NewGen Wastegate Pics!!!
- Intercooler with Supercharger?
- proper walbro 255 intank pump installation?
- garrett tubo q??
- gsr cams vs. skunk2
- 15g vs t3 .48/.42
- JRSC intercooler
- BOV
- Let's see what the "GodFather of Boost" is up to... (56K DIE!!)
- Drag3 Turbo & JRSC dyno comparison (So no more turbo vs SC posts!)
- Hmm what is this O rubber ring?
- My first turbo kit, opinions/advice? Power estimates? 1/4 estimates?
- turbo<?>supercharger
- Optimum A/F ratio.
- Hi Low throttle safc setting. What exactly do they mean?
- turbo install question
- turbo B16A in a 88-91 CRX
- New dartin Sleeves who has them and what they think of them???
- ANYONE running a straight T4 Turbo???
- manifold project
- What Do You Think About My Setup!!
- Anyone tuning with LM-1 wideband O2 and Hondata
- Sleeve question?
- dsm 450cc injectors!
- Just to confirm.....
- Help a long time member of HT
- well what are the H22 turbo guys runnin? thinking about swithing from NA
- precision turbo blades
