View Full Version : Forced Induction
- Exhaust Leak from Downpipe Bolt Hole
- ?pipes!
- pics of my progress :)
- Flex downpipe?
- uberdata/datalogging.... HELP!!
- WATER COOLED TURBO
- oil in turbo???
- Car overheats w/ ac on while idling
- Internals to use for Greddy LS-Turbo
- catch can question
- Updated pics of my turbo CRX project...
- wiring plx300 wideband to ecu
- new 2 turbos
- Benefit(s) of a longer dumptube?
- Installing forged rods after motor break-in.......
- Need Help A.S.A.P Problem with LS Turbo Integra!!!!!!!!!!!!!!!
- putting turbo back together problem
- LSD Categorizatoin
- somewhat turbo related (VIDS inside)
- Wiring up boost solenoid to aem need help
- My cooling problem.
- Hondata install writeup
- what do you think of this d16z6 setup?
- Identify this turbo...
- loosing boost
- Oil Leak
- EK with FMIC
- general turbo D16 specs
- Another Turbo Question, but crucial
- Check Valve/Check Engine
- need help tuning
- hard Raditor Hose
- Neptune RTP Board
- Hybred t3 t4
- chip outside of sleeve....should I worry?
- Running Hot/over heating
- turboing my jdm h22a questions
- Boost Controller Question
- Nitrous and boost- how much timing?
- Got street tuned...waiting for dyno tuning. What power increase to expect?
- blowing puffs of smoke when shifting...
- Which wideband is better and why
- Exedy Clutches Question....?
- What type of oil do u use?
- ecu socketing question
- low comp pistons on stock rods
- Long overdue *pics* My b18b turbo install
- jrsc psi?
- jrsc
- turbo sizing
- safc/dsm,255 lph,yay or nay
- Greddy 31V - 24V Intercooler on 96-00 Hatch ?
- LS/VTECH Supercharged
- which oil feed line should i use. thicker one or thinner one????
- first setup?
- Timing - Motor Assmebled. Need To Set Initial Timing, Lost *PIC*
- i know whats head studs and rod bolts but whats MAINSTUDS?
- hello i have a 97 ls integra im thinking about a turbo kit
- question about my new turbo
- who said you cant fit a 3 inch downpipe with stock crossmember 91 integra
- turbo cams???? or oem cams????
- Just an UPDATE on my setup...
- NEW ITR HEAD... valvtrain upgrade?
- Boosted B18B: How much Torque?
- Torque steer question?
- cams,tb,& msd on fi car.....
- Looking for manifold
- Anyone used the David English vaccuum manifold?
- retarding the timing
- opinions: did my wastegate take a crap on me???
- Wastegate gasket question
- -----ok boosted k series head i need some info!------
- This is where your manual boost controller goes correct? ((pic))
- Where to buy turbo parts ?
- Tranny rebuild
- anybody ever boosted a b20?
- where to find chep sleeves
- o2 voltage/testing...quick question....
- 250+whp jrsc
- help with motor
- Headstuds, need a quick answer.
- Turbo eff. and high boost applications
- d16z6 swap worth it?
- 14b turbo how to get low psi from wastegate?
- driving to get it tunned... advice so it doesnt blow!
- new throttle body, pig rich
- Misfiring problem.
- fmu?
- F23 turbo setup, Turbo size?
- AFC pressure sensor setting
- Where to find m10x1.25x30mm bolts for my InlinePro turbo manifold?
- LSVTEC motor, worth throwing in GSR cams?
- FAQ: How to install Hondata S300 on virgin p28
- non intercooled turbo?
- Overheating
- mixed answers....need a little insight
- Drag manifolds
- 1997 Honda Prelude SH Turbo??? Need Help!
- ***H22 TURBO***
- BOV?
- turbo question
- Unable to tighten downpipe bolt, anyone have idea?
- I need a bin/chip - B18C1, Victor X, 1000cc's, GM 3 bar
- keep my boosted y7 or boosted ls
- Anybody know where i can find a turbo xs rfl bov flange?
- turbo crx question
- freshly tuned dohc zc. numbers inside
- What kills stock blocks? Power or Pressure?
- help boost spike
- Hondata L1H1 users
- Anyone use this MAP sensor
- new catch can , have some questions ....
- Jeff Evan ruined my setup!!!
- Another Overheating problem
- hesitation after a long drive
- GT3567R???
- Calling All D16 turbo owners out for video footage!!!!
- B16B Turbo on B16A?
- jrsc rpm
- can't control a/f over 6000 rpm
- horsepower and turbo manifold question
- sleeves, deck guard, or neither?
- How much zex to use on a b16
- what turbo should i get if i have and b18b1 in an eg
- blue top dsm injectors???
- TURBO SET UP Q:
- Power falls off after 7k...please analyze
- mixing cams
- annybody got pics of blox mani with t3to4e?
- fpr needed for 75 shot wet kit?
- te04h flange
- electronically monitor nitrous pressure?
- Has anyone heard of this turbo.
- Engine rebuild parts?
- Rebuilt turbo has problems, axial shaft play, how is this corrected?
- hks evc clicks.
- vacuum please help
- turbo chargin' d16 civic 97'
- is it safe to break in an engine on an old tune?
- a list of possibilities!!!
- quick PLX-m300 wiring/stock 02 question....
- Wanted: Uberdata .bin file for H22a Turbo
- tunertoys injectors with hack?
- where are the honda employees????!!?!?!!
- standalone ecu
- individual throttle bodies AND nitrous
- Car wont start right after new build.. help needed!
- Questions on building a b18a for turbo
- RC 550cc not plugged all the way in (b18c) ???
- h22a Prelude Drag 3 Kit Map Sensor Problems
- car hesitates when giving it throttle
- what the best clutch for a turbo car??
- Best turbo to run on a DD GSR?
- JRSC guys, best SC rebuild place & price.
- turbo on 97 dx
- Look to find out why SFWD/T4 racers don't use single-disc clutches
- tapping/rattling sound coming from tranny?
- Stealth Performance Turbo Manifolds... Any experience???
- Hondata from Jackson Racing
- D series coming soon dyno sheet next week !!!!!!!
- Turbo rebuild question....
- STH Performance-Bad costumer service
- what turbo size you running on you ls?
- AFC
- should i run the fmu? or just wait?
- spark plug gap for ls turbo
- autometer cobalt boost gauge?
- 3 bar map
- how much power will the walbro 255lph hp handle
- peak boost kit wastegate leaking
- waste gate not opening
- synthetic oil in boost applications????
- ???Turbo charged 05 RSX Type S anyone???
- Converting Vaccuum/Catch Can into Stainless/Prolite lines!! (help with sizes)
- Whats a good size turbo for a b18c1?
- hesitation!
- still having toruble with idle!!!
- Not boosting (help)
- turbo thrown off balence what to do?
- TD04 16G Pic Request/Rebuild help plus some other turbo-noob questions.
- need some help guys (idle problem)
- installing/tuning shops
- JDM B16 good for boost
- Brand new Blox FMU for sale!!!!!!!!
- ls pistons in a b18c1 ...
- RC engineering Injectors not fitting B16??????
- Autometer Oil Pressure & Temp gauge
- which oil cooler is everyone using?
- have anyone ever boost on a h23?....
- pic request: downpipes with internal wastegate.
- what is the normal IAT?
- need a good piston & rod combo on stock sleevs B16A2 for 20PSI
- I need to find a shop in AZ
- What does boost feel like???
- changing turbo size, suggestions?
- import power crank pulley good or no good?
- Max safe boost on b20vtec..search kind of....
- THinking about selling home made turbo kit. Opinions?
- search fuction is down, need size of bolts for greddy down pipe to elbow
- h22a turbo......continued
- crx turbo manifold
- Help me Pik a Mani+ Turbo For my build.....dseries(d16y8)
- bov not working
- d16y5 and boost (fuel management)
- t4/t04R vs t4/gt40 vs t4 t04E vs t04S 60-1
- turbo size on h22
- oil feed on turbo
- Best place to find autometer/boost gauges?
- itr retainers/valves/valvesprings and boost?
- Need help socketing obd0 ecu for hondata, walkthrough if any?
- prelude turbo
- how do you bypass the map sensor on turbo ls without a missing link!!! help asap(8/20)
- what is the t3/60-1 turbo equivilant to?
- Q...for the buyers that has order custom pistons from kteller...
- If you do a good tech write-up, I will make it a Sticky
- Can I remove the wastegate??
- which kit for gsr?
- car needs tuning. i know nothing about it.
- 11.5:1 on 100 shot direct port
- GS-R FMAX Turbo question
- mustang dyno???
- t3to4e delsol b16 blox mani what side air intake side?
- question about base timing
- Endyn Breather and Turbo Specs
- BOOST on a GSR
- 95 turbo GSR
- xs turbochargers
- Forged DohcZC
- uberdata 1.66, 1.7 problems...
- does it have to be a vortech blow off valve or will any one work?
- b16 turbo t3 450cc tune of the apex controller can any body give me some tips
- Help me identify the problem (Action 2md)
- The Shodan's Blue Pill & Red Pill
- dyno woes..help
- VORTECH SUPERCHARGER INTEGRA GS
- safe daily psi
- Charge Pipes
- a/f ratio changed dramatically NEED HELP BAD! WHAT COULD CAUSE THIS
- how much psi did you loose after intercooler install?
- stock clutch for ~200whp okie?
- post your t3/t67 set up
- Mysterious coolant
- Can a built D15B2 handle the JR SOHC Supercharger?
- Got my car tuned today DYNO SHEET
- intec racing -vs- carb connection
- LS-Vtec Turbo compression question
- Fluidampr belt size?
- Oil for turbo......ok???
- Intercooler question 56k beware.
- HKS sequental blow off not working
