View Full Version : Forced Induction
- is this a zex friendly board?
- wastegate vaccums
- Apexi B series AX kit??
- venom vcn 1000
- What ECU can I use to Boost my Civic
- exhaust leak between the manifold and turbo
- How long do wideband o2 sensors last?
- competition stage 1 Gravity Series 2400 Clutch Kit running 7psi of boost on it
- b16a2 on stock sleevs on high hp project (need advice)
- im installing blow out valve ... need help
- Pretty nice Vid of my Si owning
- Tiny Turbo - Where can I find one of these?
- ANY HELP?
- best turbo for 400 hp d16z6
- 13.8 d15b7
- top air fitting off the tial wastegate
- sti injectors
- Jackson racing supercharger question
- Turbo??
- RX7 Turbo 2, and HF mani
- Custom intake for rev hard kit
- Proof of gains from turbo rebuild (another stock ignition dyno)
- I need to get my car inspected in Queens NY
- broken skunk2 cam
- 700+HP B-Series.....What fuel system?
- What Boost controllers is everyone using? Which is best?
- problems with GT30R and GT2871R
- are the dsm 450's click harder then stock injectors ?
- HOW MUST BOOST BUILT LS???
- Blew my motor, feedback needed! 56k go take a isht
- quEstion about turbonator.com......
- weldon 600-a
- welding a t25 flange onto a t3 downpipe
- Just got My Turbo From PheonixT, and Wastegate,,,Have some?? Pics Included
- Turbo Manifold 94 Accord
- stock GSR throttle body ?
- need local help Tampa bay area, Bradenton...timing issues
- How much boost?
- BOV on FMIC?
- TURBO INTEGRA GSR PICS AND MODS
- turbo kit for 99 lude
- AEM EMS: Cold start problem on new motor - need help!
- biggest shot of nos on 1.6 SOHC
- Need help/advice on buying a turbo kit or putting one together...
- Why do i get a cel with safc and 450's at 10psi?
- .84 ar on a stock h22
- Some piston questions about my new build...
- what spark plugs do you reccomend?
- Golden Ealge Intake Manifold Fittings for an H22
- Radius intercooler piping.......
- Could a brake booster check valve affect a boost gauge????
- HELP!!! APEXI FULL AUTO TURBO TIMER WIRING?!?
- A few turbo install questions.
- smoking after rebuild. B16A. Should I worry??
- I have a b16a2 and want 225-250 Hp and a very reliable car!
- d15a turbo kit
- Worried my Timing is off on Built motor
- map problem???
- Darton or Golden Eagle or AEBS sleeves?
- Would appreciate some advice on the best internal parts to get for next setup...
- b18c1 built for turbo? or b18b1 vtec built for turbo?
- Idle Problem
- Honda-Tech FI Knowledge Base?
- What's the Proper coolant bleeding procedure?
- DEFI Link tachometer wire picture please
- D16a6 jackson racing supercharger on d15b vtec
- hello
- Looking to sell my turbo kit...whats a good price??
- EGT probe at wastegate port?
- fellow h-t'ers i need your help
- ASAP 95 civic- do you need injector clips+resistor box for dsm 390cc injectors?
- turbo
- i found a aem ems for 1000 with the Wideband o2 is that a fair price
- Jackson racing supercharger obd1 b16
- Can I replace my Crower rod bolts with ARP bolts?
- cracked turbine housing -->burn oil?
- how to micropolish a crank ?
- give me some tips
- Max whp from T3/TO4E 57 trim on 9:1 comp. More specs inside.
- h22 vs h23 with h22 head wich to choose
- ARP Headstud install Q (yes... i searched)
- NICE map sensor adapter!
- Just getting into the boost scene. I have a Talon T25 turbo. Q's.
- endyn's existence
- Ek with front mount
- upgrade axles ?
- Turbo Prelude Boost issue???
- Greddy Emanage
- need help whats the difference between a nitrous wet shot and a dry shot?
- 12:1 H22 turbo possible?
- which is better
- all 500+ whp imports.......fuel systems
- Cable trans. Clutch for some power ...
- Resistor box question???
- i need help on something
- swapped d16y8 for d16y7
- oil restrictor
- Tullos Tech electronic boost controller prototypes
- injector wiring harness
- Q regarding rotation of oil drain/oil intake (searched)
- obd0- Gm 3 bar wiring?
- D15 Turbo 1/4 times
- B16 Quaife Tranny or ITR tranny w/ a Qauife ?
- leaf blower + nitrous = pwr
- what shot are you running on your STOCK GSR motor ?
- Skunk2 worked head for boost?
- Injector clip wiring question.
- Opinions on PWR liquid barrel intercooler?
- what power can I get whit this set up ???on D16Z5 doch motor
- is that a wrx/sti/gt bov ?
- limits of stock internal Ls with boost
- Unplugged my ECU, and car still runs?
- 11.5:1 + JRSC w/o standalone... not a good idea? or DO IT DO IT?
- NOS dry shot setup... what else do i need??
- acura 92 all stock
- Turbo problems
- dyno/pics/mod list
- any guesses on what my civic is going to run?
- Silvia T25 turbo too big for my needs?
- tig welded pipes
- Loud Popping when boosting!
- New Times, MId 11's boosted B18b, clamps> ME
- Smoke in Cabin ?
- anyone ever shoe horned a JRSC ina CB7?
- DRAG INTERCOOLER
- t25 specs????
- turbo integra gsr's
- Catch can?
- 97 civic, revhard turbokit
- should i use e-manage or vafc2 on my setup? TURB SWAP QUESTION
- oil pouring out of the blow off valve
- Oil leak
- oil grade for the fall/winter
- BLOWN downpipe
- Building engine, want to upgrade the turbo
- how do i install a turbo im clue less on to do it
- HX35
- boost gauge install
- GM 3 bar MAP sensor question.
- What can i do to my JRSC S/C while its off the car?
- D15B POTENTIAL (search isnt working)
- is this a genuine garret?(big pictures)
- how to post pics from my computer?
- Thieves in Florida.. another stolen car
- how do i post pictures?
- Precision SC-32 spool time
- I need a tuner for S200 in Jacksonville florida, Will travel 2-3 hours
- SAFC 'hack' questions.
- Nitrous surging? Why?
- zex street or zex street/strip cams?
- LS Turbo Help!!
- D16 Y8 ... Going Turbo ... Need Some Assistance Please
- Neukin Turbo Manifold vs. Peak Boost Turbo Manifold
- need help with compression ratio
- Tueno spewing oil all over the place.......Help maybe seals or turbo
- Give me your opinions on my current build.... am I missing anything else?
- msd btm and blaster coil
- How much HP?? GSR w/ t3/4
- Pics Of Spoolin Performance AC Compatible Manifold/Downpipe and T3/T4 Turbo
- soon to boost!!!!
- Fuel management ?
- EMERGENCY! Need 2.5" -> 3" resonator with flanges URGENT EMERGENCY HELP
- LS Headwork question
- oil leak?
- JUST WANNA SHARE MY $800 PAINT JOB...
- Boost and wastegate help
- ECU, afc, WbO2
- Im having a problem fitting my fmic
- What Affects Idle Mostly?
- what turbing for the "bernouli effect" hooked up to downpipe???
- FMIC (intercooler) License Plate Bracket....Thought I would share
- Clicking at idle, only when the car is warm.
- Garrett Reliability?
- Idleing and start-up problem
- what size hose for coolant to turbo?
- Opinions on Intercoolers?
- Engine Question Plz LOOK!
- Hondata gasket doesn't match intake ports?
- Turbo CRX still smoking
- just ordered a turbo kit, and I think this turbo is bad..PICS!!!! HELP!!!
- White smoke only at idle... any ideas?
- wich stock DSM parts are upgrades for hondas
- civic si turbo
- turbo seals
- 14b internal wastegate spring
- first rebuild, tips?
- PLZ help
- Skunk2 Pro series IM
- So many opinions, no solid answer - timing retard under boost .. ?!?
- Anyone out there tried to customize whipple SC for integra?
- Boost controller Vs. Wastegate spring...
- small inlet and outlet intercoolers?
- Oil Return and Feed Line Problems
- ** ACTION 2MD Owners ** break in ?????
- Does anybody have pics of an 8inch tall FMIC behind a EG bumper?
- bubbles seeping through my rad cap..
- external wastegate spring ???
- Canton Accusump
- Looking for a pte71 compressor housing w/ ported shroud?
- turbo question
- Turn around time for RLZ?
- I NEED HELP WITH CODE 20 41 AND 43.......2000 TURBOED TYPE R
- Anyone know the size of the exhaust manifold--->head nut?
- peak boost
- turbo on a 01 prelude
- Linear Output on PLX M300????
- wastegate vacuum
- need some pointers for buying a wideband
- Electric boost controller = PID Controller?
- LSD????
- Intercooler Cores
- fs: drag manifold
- 14b turbo with greddy blue box???
- Has anyone here done a full DIY mani, dp, tunning and exhuast?
- Anybody have a PDF of T3 & T4 turbo flanges / Template?
- post your t3t4oe with blox mani on b series pics.
- GSR trannsmission versus Type R tranny?? Which one is better for a BUILT LS VTEC?
- Tuners... maybe you can help me?
- need help on safc tuning for idle
- best spool performance for your b16a
- whats the best sounding magnaflow for my turbo d-series
- torque specs on arp rod bolts???
- What turbo manifold is best for an h22 in a prelude?
- turbo manifold
- GReddy 18G internal wastegate actuator, causing vaccum leak?
- HELP: Hesitation at VTEC transition
- what to expect Clutchmasters fx300?
- Whats a Long Lasting clutch?
- tial 38mm w/g
- how to turbo a honda
- Greddy turbo kit for DC4..
- GT35/40R on 1.6 VTi?
- anotha greddy turbo ?
- Turbo Manifold coating?
- (FI gurus) having problem under load at low RPM/traffic creaping
- Need T3 compressor housing dimensions for .42 a/r and .60 a/r
- cold start issues
- best transmission for power
- Heat protective Hose? Hose is near exhaust housing...
- New Pics Of Our setup this year - -BIG TURBO!
- Block Is Dark/Dirty
- anyone have formulas/excel sheet for turbo size selection?
- boost vs compression question
- Spec request GT42R
- intercooler efficency
- Tuning friend's ls turbo...problems with breaking up in higher rpms
- Downpipe question
- Sleeper Turbo advice
- t3/.67 turbo for a b16a???
