View Full Version : Forced Induction
- Help working in car right now! Kinked Oil return?!
- HYTECH k20a kit
- mod my head or do ls/vtec...more to the situation...
- larger valves?
- Who passes emissions? (when they want to)
- garrett t3 turbo
- built block do i block off oil squirters? and spun bearing Q
- Wheel & Turbo size question???
- ITR Muffler/Exhaust W/Boost
- having problems with uberdata
- happy birthday to tinker219 Mr. Loverfabber
- Winter Essentials for your Car !
- hooking up both wastegate ports using a boost controller?
- build your own turbo manifold???
- Whats the Difference between Hondata s200 w/boost and Hondata stage 2 w/boost ????
- What do i need for a turbo set up?
- Hondata Needs to go 5BAR
- RC550's work with the Vafc hack?
- using stock FI "seals" on RC?
- LS-Vtec Questions!
- autometer boost gauge
- Info for b20 turbo, turbo experts pleez help!!!!!!!!!
- Boosted 2 liter gsr + 3" exhaust = quiet?
- Uberdata HELP - Installed Wideband, runnin rich!
- boost?
- E-Cutout and turbo life
- bkr vs. zfr
- Vortech Supercharger
- Anyone ever heard of or ordered from "ONEFAB"?
- Who uses a non-fart can muffler?
- ic endtanks and the advantages?
- d series pre boost timing
- GT-P trim
- $70,000 Turbo Integra?
- Wideband - HELP FAST PLZ!
- Strange noise comeing from engine bay
- dynojet wideband commander???
- an-r header wanted and advice..
- Exhaust systems on a turbo DC2???
- First time boosting a DC2.....what should I do?
- battery light comes on at 6000 rpm. WHY???
- machine shops in s. wisconsin
- Thoughts, advice and opinions on this setup?
- H22 manifold
- turbols finally dyno'd!!!
- Similar manifolds as Greddy B series
- overkill?
- throttle body options, ~400whp JG Edel IM
- Need 3" exhaust for my turbo
- Mod your diff to lsd
- greddy e manage help installing
- Dont you love competition?
- whos got a turbo car with no catch can?
- Please help DIY intercooler piping on integra
- Diy catch can.
- Turbo Question
- uberdata tutorial?
- Need some answers on custom turbo kit
- Wideband / narrowband simulation
- Stenciling Brand on FMIC ?
- Compressor surge
- Pardon my bandwagon smashing - Profec B's
- can i use stock civic injectors on a turbo step up?
- how do you actually make my civic boost
- SRT-4 Intercooler. What Are They Rated To? Anyone Have Pics?
- tranny question
- Del Sol center vent gauge install
- Quick Spooling, High HP Turbo???
- b16 with gt30r turbo
- Backdoor intercooler: IC piping question
- LS PR4 rod interchangeablility???
- gt35e .63......want to know more.
- vtec vs. non vtec
- Axles - Which are the real deal drag racing makes?
- No Hondata on Auto Tranny! Any other Options?
- Emanage Problems
- Built D16z6..GT28RS VS. Precision Sc-60 DYNO Inside
- Max Boost on a 2000 SI Stock Internals
- How do my h22 sleeves look?
- Yep I Turbocharged An AUTOMATIC Integra LS!
- Calling all with GSR heads (JDM or USDM)
- about intake in JRSC
- Help diagnose a strange idle *vid included*
- precision injectors? What do I need to mod to use them?
- nitrous....stainless steel valve?
- SAFC Question with boost
- feedback on the T3/T4R "big kahuna"
- Question for JDM ECU people
- 38 mm flange same as 40 mm? Wastegate question.
- Pic Request: Din Bezel for 3 gauges to replace radio in EG
- what kind of HP are we looking at?
- QUESTION: how much boost can i run on a gsr b18c block with a blockguard?
- b16 with pistons and rods. how much hp? non sleeved block.
- Moates Ostrich Realtime Emulator
- t15 on a 1.4L engine
- Garrett "blowzilla" t3/t04e?
- t3to4R boost levels on pump gas?
- t25 on b18a1
- BlueBox .Vs. FMU
- Take a Look at my surge tank design (pro's & Cons?)
- If you had sleeving job, can you get it re-sleeved?
- What size downpipe do I need? LS CRX with t3/t04e turbo
- Which turbo? (2nd Gen Teg LS - B18A)
- N20 spray and pray!
- Who wants to make me a downpipe?
- Sigh my car is filling up with smoke after turbo install
- Fuel Problem with turbo
- Ebay turbo kits haha?
- uberdata tuner in socal
- Going Turbo...
- need some help...can I do this??
- Walbro 255
- ss ac mani worth $100 new?
- cel 16 with blue box and 310's on obd1 car anyone know how to fix this?
- Anyone have pix of Darton Open Deck Sleeves?
- TURBOEDIT?????
- What kind of Turbo Manifold is this???
- Fmax for a 00 Si
- Turbo bracket mount...please help
- oil spraying out during 18+ psi boost
- Nitrous Cams?
- Help with Turbo Kit B16
- So I go a shop today...
- revhard BOV
- JG weld on fitting???
- ls Turbo and lsd who what how fast?
- K-series owners (or anyone else that may know). Problem with motech 3 bar map sensor install
- Full-race turbo manifold best bang for the buck?
- 750cc injectors w/ uberdata?
- 300 whp on DSM 450s???
- scottish b16a owner after low pressure turbo kit anyone import and not charge the earth???
- BFG street rubber
- head work
- tried boosting more now more problems...
- Any interest in a Central FL Dyno Day?
- Woohoo! Just got my block back!
- b16a1 Turbo - need so help with project...
- NA to Boost, Dyno numbers on 7psi
- Greddy turbo boost question??
- Could this be a solution for traction problems in big HP cars?
- Oil Pressure sender location and Low Oil Pressure?
- Traction control for ecu
- custom turbo kit downpipe
- which FPR to get? want to ditch my B&M...
- iHi RHB5 turbocharger into 91 Accord F22???
- 2nd Gen Teg Turbo Project has officially begun!
- OIL FEED which is better? Sandwich/ Oil Send Unit
- fun times..
- Full-Race vs. Log Manifold SR20DET Test!
- COMPRESSION
- what temperature ...
- any new developments in e-cutouts?
- turboedit help...
- Tuning question for all you High HP B18C fellas...
- IC on NSX ???? where does it go
- NEED HELP....
- how do you know if you have a head lifting problem?
- cyl wall scratches - read old- this is diff.
- inline pro and tial: dumptube issue? integra DC2
- Are Crower Stg 2 turbo cams worth it for a D16Z6?
- ctr s2s1 cams with nitrous
- T3/To4e spool time
- error code 45 after installing turbo
- Drag manifold.... Tial or internal wastegate?
- Does a big turbo make more hp than a small turbo on the same engine at the same psi?
- HONDATA EXPERTS NEED!*
- ** Does Hondata make my MSD 6 BTM useless??**
- LS TRANNY?
- D16Z6-T video
- 393 whp H22 turbo dyno plot & vid
- uberdata tuners around DFW or texas?
- Need some help to piece together a turbo kit for a h22 .. Please
- AVC-R BOOST CONTROLLER HELP PLEASE!!!!
- how does turbine size effect compressor efficiency???
- piston rings?
- gt30r or gt35r for k20a2?
- Turbo smoke, please help d16y8
- Stock sleeves on Honda motors
- Questions on Turbo Setups
- newb type question Bst = how much psi.
- who makes X beam rods?
- i gave up boost but now i'm back...
- b20vtec turbo... no vtec?
- pics of your lovefab mini-me?
- downpipe question
- Highest comp ratio with nitrous
- Wastegate springs ??
- sraying fuel injector cleaner into throttle....
- Bigger Exhaust cause boost creep!???
- 00' civic si B16a2 fuel pressure??
- IS head work necessary for a heavy turbo app?
- 2.5" or 3" exhuast?
- good head gasket for super charger
- vortech supercharger..
- Over heating on boost....
- who has the best price for f.a.s.t. / speed pro ems
- Precision sc51 ?
- turbo guys I need an ooinion...
- A shop to machine ls rods for sohc y7 and provide bearings ?
- iacv 3 wire to 2 wire?
- FINALLY DYNO 92 civic d16z6 with spray
- EE Major's, I NEED U .. Boost Controller w/ LED's
- controlling the boost
- My turbo tranny setup, good choice?
- Do any sponsors do injector cleaning? Any recommendations?
- T3/T4 turbo and I need to clean and test it for high boost. Any tips on doin this????
- wiring for turbo timer and alarm
- Backdoor intercooler fitment
- Precision Turbos?
- Installing Jackson Racing Supercharger on High Mileage Auto, suggestions for longevity
- way to find compression ratio?
- h22 turbo oil feed line
- compression test results question
- Yeah... So I just definatley blew up the z6. Taking guesses on what let go!
- Dyno SC61 b16
- Need Help with Hondata question......
- Anyone using oil restricters on your turbos
- Car just died on the street
- Greddy Turbo timer problem..
- PWR Half-Size Radiator w/ ONE Slim line fan on a DC2...will A/C work?
- Whats That Supercharge your car for 70 Bucks.
- Do turbos basically sit in the same spot?
- some new pics with a Q.
- noob VAFC help!
- majestic turbo ripped me off 600 and wont fix my turbo under warranty
- So close yet so far!! Huge Thumbs up to Tony1!
- ..Headgasket most likely?
- What size core for EK?
- New headgasket required? Which 1?
- 95 Integra LS ECU - uberdata?
- keep it stock or aftermarket(head gasket)
- O2 Sensor on 96-00 Civic Wiring Harness HELP!!!
- OBX I/C
- AEBS sleeve work
- will 2.2l probe turbo or 626 turbo injectors work with turbo d? (yes i searched)
- Members running 26"slicks
- JG edelbrock intake with aem fuel rail and fpr
- question on sc63 vs my t3/t4oe 60 trim stg 5
- End is way off w/ cp !!!!!!! (middle ring)
- Wastegate Problems
- turbo pressure in civic
- turbo?
- B16a2, 550's and fuelpump
- Crx Downpipe!!!
- Uberdata . . . Can't Get Car Started!
- B16a2 turbo setup
- JDM front and what is a good size intercooler. (Integra)
- will T3 fit on hf mani ?
- Differences in Turbo manifolds
