View Full Version : Forced Induction
- reading cam settings
- need help boosting
- Anybody makes something to interlock bolts that hold turbo to manifold?
- Who makes the largest throttle bodies?
- Evo 3 GT Turbo. Need adapter plate info.
- t3 turbo
- turbo timer question!!!
- GT3076R with .48 AR on exhaust housing
- gt28rs problem
- ran into a problem fitting turbo.....
- reasonable boost limits for built H22 on pump/E85
- Fuel/Engine managment for beginner?
- car's blow off valve sounds different all of a sudden
- Injector Type for D16Y8
- Fuel delivery problem
- my manifold is cracking
- 300+hp with a 15g?
- Air/Fuel Problem at Idle
- GT30R on low compression built b16 spool times and whp numbers with it
- My Turbo Checklist..let me know if im missing anything
- 11.5:1 comp dart sleaved...good to boost?
- Sleeves...
- DSM 1g turbo to a b18b?
- Questions about Hondata S300
- exedy w/ act clutch disk??
- need help with boosted ls!!!
- compression
- b20
- why here replace's turbine wheels
- No compression after turbo
- Of EGT questions and such
- Springs and retainers....
- 75 Shot?
- what does a blown spark plug sound/feel/look like?
- gauge pods that stick to the windshield...
- does a y7 oil pan fit on a y8block..?
- Help with quiet Exhaust.
- So I have to ask...has anyone fit a GT42 into the CRX/EF chassis?...
- Trying to tune past 15 psi but backfires, hesitates
- Pics of your Profec Black Box mounting please.
- which valvesprings/retainers are best?
- EBAY FMIC kits?
- Wich T3/T04 to choose for my goals on a B16
- back from the dyno, car is not making power HELP !!
- super charger for a d16a6
- Turbo Manifolds
- Going turbo while saving A/C and P/S: FMIC vs. SMIC
- Which Bottom End in Turbo Dart B18 2.0L ?!
- LS turbo and A/C
- \\** POST UP THOSE FORCED INDUCTION EK'S **//
- B18A1 in a 92 cx hatch along with the turbo.
- Fuel Pump
- First time going turbo
- Anybody got pics of 18g setups running an external wastegate?
- Official Greddy Kit Numbers reference. Post up greddy kit numbers all engines.
- Turbo Kit Install, now I've got smoke
- turbo piping?
- ///////////F20b block w/ H22a head? Will this work, or be usefull in turbo set-up?\\\\\\\\\\\\
- anyone turbo use a scoop or vent in hood?
- Which will spool faster?
- High Tech Turbo
- GT3582R / GT3567R / T67R with T4 Divided Turbine Housing & Divided Turbo Manifold
- got tuned yesterday...
- .... Home made Heat Shield ..... good? ..ok? or Toss it?
- AVC-R related, the search isn't working right
- Engine Block Paint. Does it work?
- Mandrel bent vs bent downpipes
- Dyno'd my car, slightly disappointed.
- pr3 vs pr4 vs p72 rods? what ones are the strongest?
- are valves and springs the same in a d16y7 and d16z6?
- going to turbo my b16 during winter. need some help.
- new car!
- boost gauge.. what does the negative numbesr below 0 psi mean? whats safe to cruise?
- manifold suggestions
- questions about turbo's.
- Is it possible to replace the comp wheel of a gt35r? I tried searching
- ONE bad cylinder???
- WHATS THE BIGGEST SIZE INTERCOOLER THAT WILL FIT BEHIND A EK BUMPER
- Trying to pick the right turbine... Need help making sure math is right.
- resistor box wiring
- fully built motor, making weird sounds--or is it?
- Dizzy coil keeps frying
- Building a turbo
- Advantages of FI????
- Hondata S300 vs. Neptune RTP
- Need Help Selecting Intercooler piping sections for Kit
- MBC Vacuum Hose Length?
- turbo bolts
- two questions
- Vacuum Lines for wastegate, mbc, and turbo - HELP!
- wideband sensor location
- ? for FMU users
- What intercooler is this?
- Do any of you drive without factory O2 sensor??
- are AN wrenches really needed for AN fittings?
- ****Turbo question****
- Neptune Users Check In !
- First time on nitrous, fried the crap outta my plugs. Help me!
- Need expert to hook up or explain hondata and plx hook up~!
- Q??? Which Moderator Administrator do I Contact For Scams???
- 100 shot on A beam rods? Yes? No?
- How can I turn down the boost on a internal wastegate? (DSM T25)
- dumptube
- AFR's are lean during idle and light throttle Why?
- where do i get this gasket?
- just ordered a gt4294
- Tool list for motor build ? What brands
- t3/t4 on a b16 autocross
- Greddy VS Apexi Boost Controller
- how much $ to weld a stainless steal bov flange on a pipe??
- 600whp questions... need some opinions
- GT3076R what manifold will work with AC and PS?
- Valve floating ? How can it be diescribed and explained?
- Oil and water temperature
- Check out my boosted set up... Progress pics from 2 weeks, teal hatch
- h22 turbo choice
- spark plug gap 55 shot nitrous
- Stock clips on rc injecters
- So i figured out the f****** oil leak problem
- Air / Fuel after throttle lift - Is this normal >> ?
- Help! Is this a real Blitz BOV or some knockoffs? WTF man
- Fuel pressure/idle problem....
- where and how much did you guys get your roll cages for?
- anyone with experience with putting a DBB CHRA into a t3t4?
- TUNING in southern CT
- show me ur big FMIC in ur ek plz .show pics
- gt28r "disco potato" good up to?
- injectors
- Where to buy rods, bearings, wrist pins, rings and gaskets? (one place)
- Valve seals or turbo seals?? help!
- synchronic piston/pull-type BOV
- arp hardware???
- What trim and size t3/t3 would be sufficient for h22?
- What size and brand injectors should I use for turbo h22?
- *Nitrous* Anyone Willing to Help me on My Set up Step by Step
- Dented FMIC - Should I be worried?
- oil cooler possibility
- Stock oil pump, oil cooler lines and a turbo
- Which pistons for ls/vtec turbo?
- Gear based timing retard VS multi-stage boost controller?
- headgasket thickness question
- BEST turbo piping for stock GSR
- Emissions?
- is anyone elses zex59300 cam loud as hell???
- Stock F22B2 Turbo?
- switching to race gas at track. will 110 leaded hurt ??
- Where can i get vitara C clips, And What kind of rings to run>?
- integra intercooler specs
- Please Help! Turbo Problems...
- LONG distance driving with 500+whp non-vtec
- flow rates for precision sc34
- Which GT30r turbo makes the most power?
- precision injector clips???
- WTF is a dose pipe?????????????
- Difference in engagement between XTR6 vs. XXR6.............
- Spitting and Sputtering on Boosted Integra
- in need of an oil return line!
- What kind of oil to use with boost?
- FMU or Apex SAFC?
- best way to get at stubborn bolts under my b16 in. manifold????
- wiseco 9.1:1 questions on ls/vtec
- ITR valve train vs aftermarket?
- Best turbo manifold for h22 that is AC compatible?
- everyone with turbo zc. what spark plugs?
- Help determining compression ratio
- Is there a company that makes a non-cross drilled crank for the B16a?
- CCA inercooler??
- -3an oil feed with restrictor
- Difference between turbos
- b16a1
- high egt. didnt change anything on car
- High EGT's + no tune overheating car?
- Vac Lines - HELP!
- just dyno'd my bone stock Integra..baseline before turbo....how much after????
- why do injectors "tap"
- pump gas
- efficient turbo for 700hp
- Lakewood Traction bar on a turbo integra?
- Any Suggestions on which sensors to buy?
- Y7's oil pressure
- How to hook-up my boost cont. when my WG has 2 fittings??
- Boosted EFs, what FMIC fits behind stock bumper?
- Moates Wideband O2
- Calling all or former D15B2 drivers
- Tired of searching. Please help me pick out a turbo. ls/vtec setup
- Electric Supercharger's
- pistons for high hp motor
- car smoking need help
- TURBO SIZE ON GSR
- Intercooler piping from streamlinemotoring
- Will stock injectors work??
- NEED TO KNOW IF MY B18C1 BLOCK CAN BE SLEEVED
- GSR or LS crank for turbo
- Tranny: LS with 3 & 4 from GSR or B16???
- Help Help!!! Jackson Racing Supercharger
- Tuning with PeakBoost Turbo kit.
- Built B16A, ITR oil pump, CONSTANT 60+ psi of pressure. Turbo inlet pressure?
- High Horsepower H-series thread
- Semi DONE!!!!! SOHC turbo ninja dyno inside
- ls crank vs gsr crank??
- I have a MILLION questions.......
- fuel injector plugs?
- anyone using xtr clutch for boost
- Wheel Spin OR Clutch Slip - What Is My Car Doing?
- Searched, but not found. Arias piston question
- need somone to make me a nice crome basemap for me to start with? D14 engine
- i need help with tuning my car with the hack and engine question
- damaged, but how much?
- i need help with the tuning on my car..
- BOV help. stipped screw
- clutchmaster alluminium flywheel
- ebay sandwich adapter for oil feed.
- Info and pics on side exit wastegate dump
- 3.5" Cold Side Charge Piping to large for 700whp?
- Full Synthetic Oil Will it yeild blue smoke when burned in engine?
- Does anyone rebuild 16G (Evo) turbos?
- external watsegate on STD manifold?!
- ITR Hatch Build
- Did anyone use the extended tip turbo on a b series?
- HOW MUCH HP AND PSI CAN I USE SAVELY
- legality of my turbo set-up?
- Finished my setup, Sorta :p
- any 1 got a ls trany
- T3/T67 with a InlinePRO Manifold?
- SC61 H22a's
- can't decide on my next mod....need some advice.....
- gsr setup good?
- missing link
- y8 turbo and keep a/c???
- D-series turbo to B-series engine
- which t28!?!?
- Horsepower Dynamic's 800hp Supra Videos?
- How to install a turbo kit on a gsr
- what injectors to get?
- Post up your pics of fuel pump mount shots....
- **SMOKE OUT OF DIP STICK 00 SI TURBO***
- ebay turbo's any good or just wak?
- thicker head gasket for my b20 turbo setup?
- can my stock b16 in. manifold be ported to match my 70mm throttle body????
- I feel like such a Douche but can someone explain to me what Bore and Hone is ?
- HKS FROM EBAY?
- High Idle and boost creep from 7k-9k
- is d16a1 saturated or peak and hold...
- MSD 2step & Timing Retard
- D15 turbo questions?
- Diffrence between gt4088 or gt4067 and pt71with .81 ar what would you recomend
- the ring 'gasket' when bolting on an external wastegate
- head gasket???
- Anyone else have this problem with their BBK TB?
- cheapest place to buy a wideband sensor for my lm1 ?
