View Full Version : Forced Induction
- help installing turbo timer?
- Need quick help... How much???
- Wheel size determination: this helps
- Hondata 3b or s200 w/boost and features
- Greddy install
- Spent all day digging out car for buildup...
- What size downpipe do you t3/60-1 owners use?
- Having problems sourcing parts :(
- Turbo help!!
- Boost Controllers and Turbo Timers
- nice racing seats for "big" people
- spool up time on a t3/o4e 57 trim .48 ar stge 3 wheel
- fine tuning with fieldS
- Is a B18C motot w/ a B16 intake manifold and ITR Cams good for turbo?
- reasonable final hp numbers
- Set up tuning day and i have some questions about power and limitations.
- VAFC Hack settings for a b16 with dsm 450's????
- Supercharger Essentials
- OT: Might be getting a turbo II rx7...
- Where to get MaxRev manifold?
- new turbo install, I'm throwing cel code 1....then code 74. :(
- Full race manifold installed *pics inside*
- Nitrous gone bad
- anybody have jsrc installed 2+ years?
- Do you guys recommend studs+nuts over bolts for turbo manifolds and stock manifolds?
- $2000 budget, what parts to get?
- MAP-ECU piggy back
- Custom rods.........
- bastard oil leak!!
- T25 compressor maps... anyone have one???
- Not your average flywheel question.
- Which Turbo/Mani For a B18B Integra??????
- Forced Induction + 130,000 miles= What????
- Dyno in Two Weeks, whp estimation ?
- DSM 450cc injectors
- 2nd Gen Eclipse turbo in a 6th Gen Accord?
- K-smotorsports
- oil on outside edge of compressor wheel?
- B16A Head/GSR Block- Good for Turbo?
- Turbo installed but surging and waste gate is open at idle??
- Sleeve Question for turbo guys
- just got a turbo timer and dont know how to hook it up
- H-haters what do you guys think?
- Lets end the Gearing debate with this final post. . . . .Viren, Tony . . all the fast guys more thna
- Check engine when spraying?
- How Much Horsepower Can I Expect???
- question???
- when is an upgraded fuel rail required?
- I'm I missing fittings?
- Dimensions for the DRAG intercooler?
- Where to go for S-AFC tuning on a Dyno in the NOVA region?
- Fitting size for venom fuel rail/
- wil the greddy 15g turbo fit the 18g manifold?
- Best reliable Ignition Control Module to buy?
- sc61 question plz help me chose the good one
- Turbo Cams - R these any good
- 202WHP from a 1.5L turbo
- damn EMS!!!
- 350-400whp for a 2.4l
- New goal!!
- which tranny for turbo h22?
- Best spark plugs for nitrous
- Looking for a certain oil line fitting (turbo oil feed)
- New Hks Evc Boost Controller
- Supercharge? or Turbo?
- Using dipstick tube for turbo drain?
- Gear selection thoughts....HF final drive in a ZC tranny....
- Jet Hot Coating on Rear Turbo Housing???
- Turboing a b18c1, a couple questions
- dsm injector question
- RevHard tubular turbo manifold ?'s CRX fitment?
- 1/4 estimation?? b18b turbo
- oil return line? size?
- breather filters effect on pcv system (info)
- Custom Manifold Interest?
- Crazy question...will my motor spool this?
- apexi n1 with turbo
- Need battery relocation ideas and pics
- 1/4 for 89 hf with zc turbo
- D series turbo mani
- would this turbo be too big for a B18A ?
- went to dyno today WTF!!!
- greddy sohc?
- header fittings
- Strange Sound, Help PLZ! (Video Inide)
- just like to say one thing... F*CK IMPORTBUILDERS
- hondata s200 problems(help)
- Question for Gredy torbo owners...
- Your opinion and experiences with Air/Fuel Ration meters.....
- how will this cam work with boost?
- Jacob's MasterMind Install???
- For those with OBDII to OBDI conversions
- Which to use for Hondata? P72 J or P28 for 95 GSR
- Greddy 3 row too big?
- wastegate question
- Just compression tested my jdm b18c, i think my numbers are high.
- CAMS FOR TURBOS???????????
- ... OT : shops in the pensacola area...
- ... acl bearings... who has installed?
- Misfire codes 72, 73, 74 after AEM FPR install
- Not Honda but Supercharger question
- Turbo Kit Install? HELP!
- some pics of my Boosted Si
- trading a complete turbo kit for b-series !!!
- OT...how do you change your title?
- Forged Pistons, Rods, etc.
- Do Fidanza flywheels have a timing mark??? (i need to know asap)
- Downpipe bolt...why does it look like this?
- What do i still need for my custom turbo kit... plus a bit of help:)
- Best universal muffler for turbo appl.
- garett t28 and greddy D16 manifold bolt up ok?
- What size trim and wheel specs for T4 60-1 ????????????
- Golden eagle sleeve pictures...
- sohc greddy turbo on y7....
- Will a DRAG III manifold for a Integra fit a B16?
- 1/4 Mile estimation for D16 coupe with 9psi???
- where to get those little check valves???
- what is z10 website url?
- turbo rebuild
- Turbo Intsall $$$$$ ??????
- max-rev vs. inline pro.
- 432 awhp. Some encouragement for AEM users
- anyone have pics of how they ran piping on a non-intercooled b16(or similar) setup?
- turbo math
- Anyone ever have a bad idle with a Flakey ICM?
- Break-in with untuned EMS, or stock ECU?
- open wastegate?
- Turbo Idea
- It's decided, I'm doing my own turbo install. THINGS I should know before I start?
- Tech. advise please, problem under boost
- ... jackson racing btc... anyone ever use with a turbo (for the vafc hack)???
- Vortech FMU ratio?
- What A/R is this?
- blitz dual sbc spec r
- crv pulley on jrsc
- Oil feed line....
- injectors to horsepower / what injectors are good to what hp
- Handling messed up after swap w/turbo.
- EVO VIII Intercooler Water Sprayer?
- DSM injectors + seals
- 450cc dsm injector question - caps
- How much HP/TQ has been made with DRAG turbo kit???(Please post Dyno sheets)
- What Turbo manifold applications are you looking for?
- Problems w/ my maxrev manifold
- irratic idle and engine check light??
- Newbie question about sleeves.
- Fuel return line size?
- turbo and smog in CA
- wastegate acutator with two nipples
- KNock sensor question
- most ghetto junkyard turbo finished one advise
- Speedpro base maps...
- Lambda Link a/f guage
- turbo gsr civic pulls vr6 turbo
- JRSC DC2, 10lb/hondata Question
- Pullies for SC
- What setup is better for turbo?
- Wideband O2's in Ion and K Series?
- Stand Alone Fuel Management System
- Manual Boost Controller
- I need help picking the appropriate turbo...
- JRSC belt/alternator problem
- 550 injectors or larger???????
- does anyone have a list of the spring rate colors for tial 40mm wg?
- anyone live in cali, san diego in particular
- Turbo Manifold Warp (how much is too much)
- Turbo Braniacs help me out!!
- Paging Sonny! D series building
- need smog hook up (so cali)
- Nitrous cooling effect...
- valve clearance adjustment in cold weather -- ok?
- Secondary Fuel Rail Question
- turbo kit for 00 itr? does hks make one.........
- how much power with this setup??
- What pulley kit is better aem or unorthodox racing
- down time sucks!
- wastegate open?
- Hondata for 95 GSR motor - secondary runner ?
- help hooking up vafc
- vacuum related question...sorta
- Some Q's about turbos
- Will the hf oil pan fit on the zc
- plug wires...
- stock cam + boost
- Autotuning question
- SC 61
- which supercharger for a 03 s2000?
- b16b W/Greddy Kit
- A bit OT: Did a FMIC on a Jetta 1.8T
- Tuning devices.
- Revhard turbo peeps . . .
- Golden Eagle Cam Seals
- 220 WHP Jrsc?
- ... acl bearings and thrust washers... part numbers...
- Building a turbo kit - check list
- most miles on a boosted engine?
- knife edged crank
- What flange to use with 1G DSM bov?
- Fuel delivery question on a built turbo'd ZC
- GSR trbo vs ITR motor in my newly acquired hatchy? :-)
- Question about sleeving
- *Pics* of DRAG Setup
- oil supply at turbo ???
- Anybody have an SR20DET in a CRX or Civic?
- What are your thoughts on this?
- afc hack-----greddy blue box
- What hondata? Which to get?
- Quick Question
- vac. routing for deltagate
- Garrett GT30 Downpipe Size??
- C&R or PWR
- Lsd...how much did it actually help u...
- what to do about high milage transmission?
- b20 turbo vs. LS Turbo...which one?
- Anyone played with Ford injectors???
- Cleaning turbo...
- deltagate mark II wastegate
- Hondata Question
- superturbo charged?!?!
- welding hks bov?
- question about costom turbo kit
- Accel DFI vs. Hondata 4b
- turbo ls i need help no boost
- Engine builders...what's the usual amount to hone out cylinders to straighten it out?
- turbo accord finished
- what kind of HP?
- 4g63 dsm into a 98 integra?
- is this a fair price for a block and crank?
- Does anyone have pictures of the oil line tee attached to the blocK????
- motor came in today!!! hope to boost it soon! 56k beware!!
- RevHard 2 or 2c on stock b16 internals?
- What should I do?....sell civic single core and buy a double?
- FMU Question
- how hot do turbo manifolds get?
- removing the oil squirters
- greddy turbo kit on d16z6
- can you weld drag III manifolds?
- V-AFC Hackers.....
- someone help me
- drag 3 next week?? need advice
- I'll be missing you..
- Finished tearing down my tranny...
- Question about AEM fuel rail for b16a1
- nOOb greddy SOHC question...
- Opinions on This setup...
- brake line/nitrous line...?
- MP Racing Manifold???
- vortech superchargers
- quick question about rc injectors...
