View Full Version : Forced Induction
- anyone have one of these yet??
- t3/60-1 .82 ar or t4-60-1 p trim
- how many lbs. do stock eclipse's run?
- cam gear setting to remove ITR overlap
- Who here uses the boost solenoid for the AEM???
- oil return flange?
- How to install Boost Gauge??
- Greddy blue box wiring
- Thumps/pops at idle
- How to change turbine housing??
- Greddy Profec E-01
- Does anyone have wav files of their exhaust?
- engine life on turbo
- Just turbocharged my friends civic EX, muhahahaha
- Td05-14b fits on Greddy manifold?
- Good basic site for people who are interested in DIY or Homemade/custom turbo kits.
- Getting my greddy kit....i have a few questions
- missing link question
- Please HELP! Need Advice Quick!
- What should i set my timing at to tune S200b?
- throttle bracket for JG manifold(GSR)
- Dual intake for Single turbo (did search)
- Fuel Pump
- (BASIC) Piston end gap question
- ATT: GReddy turbo owners (leaking oil return line!!!)
- Project D-Series Under way..(mad troubles!!)
- New Member....
- What else do I need for 80shot direct port?
- Can someone order me a techedge wb?
- 14b water cooled..what size fitting?
- what plug gap, fuel pressure, and timing to use?
- A/F Gauge reading Probs. can't tune help!
- What do you guys know and think of this wastegate?
- Need pics of DIY turbo piping (b16)
- N2O Peeps!!!!! How much you spryain on what???
- Custom turbo kit
- Blew my injector seals out???
- help me...please
- DSM Injectors and Hondata
- Need some creative help.....
- need help to pass emisions but have a 3" exhaust
- sleeves..would you step deck or O-ring?
- What's Better, A 3 Inch Downpipe or
- your info is wanted
- Turbo kits site??
- After 1.5yrs JRSC'd...heres the dyno finally!
- how to wrap your exhaust ?'s
- will a downpipe clear my a/c? pics
- What do you all think of my junkyard IC pipes? pics
- anyone know an easy way to replace the front main seal?
- are my 450cc dsm injectors sitting right? pic
- what to get next..?
- HELP: Tial wastegate and HKS type r BOV
- What manifold is this?
- Installing Quaife differential
- mixing clutches
- Good thing I didnt go the cheap way!
- Running lean help!!!!!!!!!!!!!
- Please help diagnose problems! *::PICS::*::VID::*
- intercooler piping help
- Building my block
- Looking for Type-R flowbench results
- Boosted Prelude vids, link to prelude forum:
- FS: vafc, 440s, btm, fmu
- 10 MM Female Tee
- need help give me some examples of any turbo manifolds
- Which Color?
- sweet
- dont see this to often
- End tank problem solved, for people who dont have access to welding.
- car not starting, exhaust smells like pure gas
- Vafc Hack in tank or FMU with Inline?
- Blue Box wiring to 00' GSR
- SOHC not getting enough fuel?
- 300 hp street driven sohc
- external wastegate size question
- car running fine but getting the white smoke from breather
- Water cooled junkyard turbo......Hook up water lines?
- Boosted Cali Drivers
- BOV Question
- Kenworth Intercooler.
- JRSC Help!!!!!!
- SOHC Turbo Internals?
- h22 turbo manifold
- Wideband O2. Does it need to wastegate gases?
- Turbp plan from the top
- When installing 3 bar map (already searched, not a wiring question)
- AVC-R Vacuum routing
- Profec B & internal wg users!
- Turbo oil supply/return options?
- Will this turbo fit a LS Teg?
- install on turbo timer
- safe boost on an ls
- ... 3 bar map sensor
- ... downpipe with bung for o2 sensor
- Did i order the wrong fittings for my paxton FPR or what??? this sucks...
- check engine light on-burnt dip stick
- Where to buy steel braided lines.
- First night of tuning and already focked shit up
- Q? Have anyone build a LS/Vtec with JRSC?
- Choosing intercooler size
- best turbo
- best transmission
- H23a Manifolds
- What Horsepower Range Can 550cc Provide?
- AEM EMS, What else do i need???
- Datalogs of cold ass weather...
- Custom Put together kits, Who's got em????
- Please take a look at this
- how many psi is a walbro 255
- any body interested in side exit downpipes?
- turbo xs boost controllers
- Engine trouble, need some help.
- painting the intercooler
- Please Help! Compression #'s
- Will this Magnaflow muffler fit my integra?
- Cylinder to Piston clearance
- turbo wont build boost. HELP!!!!!!
- smc 450s and injector box
- obd0 Vafc Hack
- J&S wiring question
- a little rubber hose for oil return ok?
- Vortech in eg?
- downpipe clearing a/c...
- diy manifold - cut header for flanges
- HELP! A/F not working!
- Blow off valve?
- building a turbo LS, need advice
- AEM adjustable Fpr question
- EGT question...
- Steps to painting intercooler piping?
- greddy tubo install help ****urgent!*****
- forged piston daily drivers--reviews? oil loss, cylinder/ ring wear?
- Dumptube question- can u make one for me?
- Greddy Turbo Install Instructions
- ACT...Which clutch for my setup
- Problem with SMC and MAP sensor
- Have about $500 bux to start a custom turbo project, whats a good inexpensive manifold?
- Blitz dual turbo timer install --- you know it's a wiring question !!
- sleeving
- For all w/ lots of HP/Tq, what LDS do you use?
- need help: all drag car, plug ALL coolant lines!? working on it today..
- Any suggestions before I tear down the engine! :trying to find problem:
- not for a honda but does anyone know a place that sells used turbos for a good price
- Who has put aftermarket Motor mounts in their car?
- Pauter rods........
- Need help finding off shelf piston...
- check out the new turbo manifold i am making at work
- ZC TURBO PROJECT DONE! (99%)...Lots of pics - need HELP and criticism! (LONG)
- Just got the March 2003 Turbo Magazine.....
- 60-1/T3 Boosted B16A at the track...
- What computer for a turbo'd ZC
- Question for 400+ whp honda owners
- SRP or Wisco Pistons??????
- blow off problem
- my car will never be done :(
- my messed up air fuel gauge
- how do i get the bolt out from my exhaust housing???
- D16y7 worth turboing?
- Turbo Timer and Electronic Turbo Boost Controller
- n eTwin Scroll
- Has anyone ever messed with the new DFI Gen 7??
- prices on overboring
- Questions
- Overheating after turbo back on- Conclusions
- When sleeving to 84mm should i bother with matching the chambers?
- WTB: turbo
- How can i Up the HP instead of adding more boost?
- GReddy Turbo Timer Help
- Law of unintended consequences...
- Cam Gear design. Won't slip.
- what do 99-00 civic si's run with jrsc at stock boost?
- Resleeving.
- Which intercooler? Help!
- Homemade Turbo for DOHC ZC
- TB ...whats to big?
- Cheaper wideband o2 sensors
- Thoughts On My Engine Set Up For Summertime
- Turbo question....can't find a search on particular subject!!!!
- bottom end for crx
- Groupbuyers of Maxrev kit on Check in here!!!!
- Ls head set up
- wtf is up with my clutch ?!..
- t4 turbo
- Another Precision Turbo Beauty!! GT 61 w/ pics!!!
- An in-progress pic of my exhaust manifold...
- does anyone have a d series head flange?
- sensors on greddy kit
- 450ccs, vafc, b16, and NO turbo yet. Can i run it??
- turbo-performance manifolds, anygood?????(pics)
- The best springs and retainers for a turbo B16A
- toda cam gears and boost?
- JRSC GSR running Lean someone help
- JE 9:1 pistons + compression?
- where to get 4" mandrel bent piping
- which exhaust to get?
- OK big timming issue...4 use with s200b
- Nitrous on stock ls
- OBDI / OBDII clips
- Good intercooler to use with Greddy 18g?
- Cold spark plugs question
- Nitrous in H22
- Some ?'s about SOHC turbos??
- turbonetics manifold
- hondata tuning near pittsburgh
- I just have to share some of my new goodies....
- TURBO LS what size exhaust and what brand
- i almost blew up.
- possible to mig weld stainless steel?
- B18C1 turbo and strengthening
- Adjustable Cam gear on a boosted SOHC??
- silicone gasket sealant
- i've search but need a specific answer... 97integ ls
- where to buy wideband o2 sensor
- DSM Injectors/Resistor box
- question about what comprssion pistons to get?
- , maxrev turbo kit install questions
- best supercharger cam profile
- ... will i be able to spool a t3/60-1 with this setup?
- DRAG Gen III Turbo Pics
- Do I need injector clips???
- Standard A/R on max rev turbo kit??
- Anyone here have a JDM ITR Header and a JRSC?
- wrist pin lock question
- Need Help..Rev Hard Stage 2 Installation! Contains Lots of Pictures!
- DRAG Gen III Turbo Kit Install Pics
- Uh oh, injector problem
- Electronic Assisting with Turbo spool
- Turbo question for 96 civic EX
- o-ring reciever groove in the head???? help
- where can i get oil feed/return kit?
- B20/VTEC vacuum lines question...
- lengthen actuator arm to lower boost
- same old question.... Crank underdrive pulley with turbo, someone explain why i can be bad
- T3/60-1 turbo specs for 450 whp?
- is a catch can needed? why not just a breather filter?
- GS-R is going into boost this weekend, take out the ctr intake cam?
- Help me identify this manifold (pics)
- maybe you FI guys can help out with this?
- Good place to buy aluminum piping?
- Turbo cams, who has them and what results did you see?
- Attn Tuners; The Difficulty Tuning Ball-Bearing T
- CEL 13 barometric pressure
- a little help....
- b18 to b20 compatbility questions, please hlp
- Picture request
- LS motor with SI tranny.
- Balance and Blueprint
- ThePartsBin and O2 for the techedge kit
- What HP with stock fuel lines?
