View Full Version : Forced Induction
- tranny / clutch is making a whirring noise OMG
- Precision Turbos
- new winter project....400 lb/ft on 93 octane.
- Why do spark plug gaps in FI cars need to be significantly less?
- Bad coil? ignitor?
- what duration/lift should i be looking for in a dual cam ?
- Love/Hate with Crower...
- Hey how mayn PSI are u guys boosting on a stock LS
- what head gasket in this pic?
- Who’s the bitch now mr. clutch
- Best Holset Turbo for B18b1 aiming for 400whp??
- cold startup problems, uberdata, turbo b series
- darton flanged sleeves?
- Uberdata question for supercharged D16Y8
- ITR or LS turbo
- [b]ITR or LS turbo[/b]
- turbo on...wont start....
- 6" intercoolers, look here
- DSM Blue tops???
- blitz ss or greddy type s
- d16z6 greddy turbo kit question
- ignition for nitrous
- ups and downs of kk3?
- The MOST messed up problem?!?!?!
- greddy turbo kit not legal?
- Boost level will not go down? even with MBC?? help Please
- Y7 + 19t
- How much hp without a main girdle?
- Fluidyne or Koyo radiator?
- BLOWN PISTON RING I THINK. NEED HELP!!!! STUCK IN PHILLY!!!
- blown headgasket= blown head.. fixable?
- recommended tuning shop san Diego area
- Neukin or Love fab turbo manifold?
- which turbo to choose for 350-400HP B16A2
- 400hp, great respons what turbo to choose?
- oil in turbo question.
- nx nitrous
- Best Way To Tune OBD2, Keeping The Stock ECU, And Passing Emmisions
- Does anyone know if EVO injectors will work?
- uber help.... quick, before my sh*t blows up
- engine setup Q?
- Zdyne
- Turbo Leaking Oil
- Turbo V6
- Blue smoke at idle - need help!!
- b16 with ctr cams supercharger
- car randomly dies sometimes??
- need more power from my turbo d
- has anyone ever bought one of these kits?? are the any good??
- Misfire at high boost+high RPMs
- Skunk 2 intake PCV elimination question
- Haltech EMS
- Question about RC 370cc injectors
- How much you think a 2" reducer effects spool time?
- i want to turbo my LS its got 135,000 miles
- Anyone use the newer AEM uego widebands? Thoughts?
- How to mesure misalignment of main jurnals ??
- vacuum diagram?
- turbo r
- What turbo for my stock GSR?
- missing link / check valves cause engine to run rich as can be
- 464whp 329 trq on pump gas on DA integra
- Scat Rods Where to buy?
- 1st gen b16 sleeves + boost question
- Crower, Oliver, Pauter, etc rods Personal opinions? Likes dislikes etc.
- Honing Down My Decision, need some INPUT
- eg h22 turbo kit ?
- managing my turbo
- Severe lag. Is this turbo too big or is something else wrong? (GT2854R on DOHC ZC)
- exhaust manifold baking my paint
- Advantage of using RC vs DSM injectors/Wastegate question...
- ITB's on SC?
- Coated my turbo myself, check it out............
- CEL code 7. ive read all posts and none are the same as my problem. please help
- Wastegate - Somone please explain?
- Are my power goals in reaching distance?
- 515whp Uberdata Tuned LS/VTEC
- Datalogging problem?
- Ideas for downpipe heatshield?
- turbo acura production car
- TURBO K20 IN DC2
- gt35r v.s. gt30r
- ****who is running this type of exhaust****
- STR INTAKE MANIFOLD ON TURBO GSR VS OTHER MANIFOLDS
- Best BOV for the buck?
- pistons
- D16Z6 head questions, aftermarket valves w/ OEM springs & retainers?
- Is Fully Synthetic Oils overrated? Your opinions?
- HELP!! w/ greddy boost controller
- gt28r/71 - 48mm trim a/r 0.60
- b18c turbo question
- GT35R oil inlet?
- dyno time...
- What type loctite to use on manifold to turbo studs??
- finally got to the track turbo b16
- D15B7 & 370cc injectors
- 303 whp Dyno - D16Y7 non VTEC
- what manifold is this
- t3/t4 .50/.62 to big for gsr?
- Mase sent me a new timing map for the fall national race this weekend and
- Exhaust Housing
- my d16 engine build post..more updates soon..
- Drag Turbo Kit H22 Accord
- fuel/spark cut after starting on hondata ??
- A .46 .48 turbo on Ls
- Smoke from Engine Bay
- Is there an aftermarket equivalent to a 16g?
- sparkplug advice
- Tial Wastegate and EBC&MBC Question? (searched and FAQed)
- accord fpr same as stock integra ITR fpr?
- H22 turbo smoke and idle problems
- electronic cut out suggestions
- What kinda turbo recommendations for H22 civic?
- What Do You All Think?
- hows this setup sound?
- ls/vtec with vortech sc ??????????
- boost controler
- Turbo fittings
- stock b16 turbo #'s
- JRSC Tuning
- BOV NOT WORKING!!! noob question. HELP. =(
- is it worth it to get the venom IM vs the jg edelbrock?
- Headgasket question :/
- Oil pressure/Oil temp relocated to firewall
- low compression built turbo motor running N/A?
- my PCV idea....evacuation pump.......feedback needed
- white smoke coming from turbo(midsection)...
- tubular manifold on ebay???? good or no?
- blitz dd bov, mine sounds different... why?
- Weird: problems starting car..?
- Storing motor while deployed for 1 year
- Stock ls + 6 psi = What spark plug and gap recommended?
- sputtering problem in turbo gsr
- turbo d16y8 need help with DSM 450s please
- got stock sleeves? high boost? post your setup
- Tial 38mm problem or no?
- Spark plug question
- Turbo Pocketbike
- Who's Been Tuned By Mase?
- which d-series for boost?
- turbo leaking??? any advice
- Polish/Balance Crank....
- 95mm stroke + gt35r turbo question
- i think im getting compressor surge with the hks ssq...
- what do you guys with sweet cars do when its time for balancin/alginment/any shop work?
- DSM Injectors
- BB T3/T4? 1050 too much for you guys?...I know it is for me...
- hondata tuners in NY??
- blowing off in neutral? need a small turbo for it?
- Turbo Hondas - where's the Torque?
- 2 Liter Turbo FLYWHEEL Question ??
- strange vibration while boosting?
- Finally made it to track with my D16 turbo! Timeslip posted.
- who has turbo with a/c and p/s ( what manifold)
- got the ol' bitch tunned... now for the idol... (uberdata)
- MASE TUNED...BAD BAD KNOCKIN!!
- filter on equal length AC manifold possible ???
- after cooler question
- Autometer EGT Probe installation
- Highest reving single cam?
- whats the stock boost for this turbo
- timing for vortech s/c PICTURES INSIDE
- b18b1 turbo
- Hondata s200 datalogging problems!!
- Ls Turbo b16 or gsr Tranny??
- which block
- unplug pcv or remove pcv altogether?
- Post pics of your in line fuel pump
- SSAutochrome's turbos and why they may be better! *LINK*
- Got Built motor started! Runs like ass, -3in hg vac, help asap?
- Winter build, what should I do... suggestions...
- Friends Twin Turbo Camaro dyno video..
- Dejon Tool Boost Controller
- LS-T question... yea I have searched...
- DSS Stage 5 Install Question
- Turbo 2nd gen zc question...
- JRSC reliability on stock engines.
- Anyone ever run at the track with not enough gas in it? Kaboom
- Things to check for....
- SHit.. been running the stock pvc system on boost, what should i change?
- HELP!! w/ boost controller install!
- h22 sounds like a subaru....help.
- what is a safe air fuel for nitrous
- wastegate spring color question......
- which fmic for eg with foglights?
- Eagle Rods ARP Bolts Torque and Angle???
- Who is running turbo without oil catch?
- need help with my setup
- maxs hp with stock b16 turbo
- spiked to 18 psi.................................
- Newbie to Turbo! Searched exhasuted!
- LMA Failure
- Went to the track yesterday
- How does this happen? blown gasket
- how much power can a 14b make on a D16?
- need feedback
- intercooler size help-----searched!!
- Building a Poor Mans R got a few questions
- bolts keep backing out of hot side?!?!
- i need help making base maps!!!
- compression change
- Stumbled across a random turbo from a friend...
- Injector Resistor Wiring Question
- Eagle rod
- missing link?
- high compression boost?
- cometic gasket for turbo...
- Turbo Tips and information
- Times for a turbo'd H22
- jrsc or vortech for an autocross itr?
- The ultimate - what effects EGT temp thread
- rebuilt turbo, quick questions!
- cheapest place to but greddy turbo kits.
- Which manifold for my setup?
- first time at the track
- Ignition Timing: 14* BTDC on a 8.5:! built motor?
- is the evap canister a vacuum source?
- 88mm bore and 87mm head gasket???
- valve check/bypass assembly
- WasteGate Elbow Falling Off Manifold =(
- just got my fast-turbo oil line kit
- greddy turbo timer
- half radiator doesnt fit!
- Venom Intake Manifold vs. All The Rest..........................................
- B16 Turbo CRX TIMES?
- Strange random smoke at idle....need some insight please.
- Prochargers?
- ok i need help with a Garrett TB0356
- t3/t61 vs. SC61...the same thing?
- Aftermarket/high volume d-series oil pumps?
- Garrett T28 vs Garrett GT17
- What's the inlet size of a t3/t04e?
- comparing turbos
- Does this sound legit ..
- Bad Grinding Jingle at 4k RPM's (b16a turbo)
- jrsc stock injectors
- spark plugs problem
- h22 BOGS DOWN IN VTEC
- Quick Help needed about my setup...........
- oil change
- turbo manifold for b-series
- LHT intercooler jacksonracing, who knows where to buy?
- Is it okay to start my car
- gettin tuned
- Tunertoys rods users Unite?
- This has to be a tuning issue!
- carb legality to "second" owner of GReddy turbo??
- TPS on K20 reading off
- Turbo b18b problem
- 3 turbo setup or blown big blocks?
