View Full Version : Forced Induction
- Twin turbo...how does it work?
- Proper break in of new motor
- FS: B&M fuel pressure regulator mounted on stock regulator
- FS: Hondata 3BD with GM 3BAR MAP, p28 ecu, Datalogging software, and data cable *PIC*
- McCleod Race Clutch?
- Mssing link??
- 18G Turbo Owners
- FS: Apexi AVC-R - with box and instruction manuals
- Well I guess i know WHERE my problem is now.....
- Runnng LEAN! :(
- selling my xs engineering intercooler
- Those w/ 12psi or more in a CRX/EF civic, no in-tank pumps for us so...
- Recognizing GM Map Sensor
- Turbo Manifold
- Low Impedence or High Impedence ?
- Help: I need someone to install my DFI in NJ
- head gaskets and copper spray...
- mx6 turbos??
- Just finished my turbo ls powered crx
- Oil return line problem
- Transmission Upgrade?
- wastegates
- EGT ?'s
- WHOA!!!!!!!!! flexible exhaust tubing
- Umm...Gotta little problem here....need help quick! Turbo is dying....
- WOW!!!! Check out my new BOV!!!!!!
- Alright VS Racing...Hondasaver....whos having some good christmas sales?? Need some parts..
- Need some advise....Which T3/60-1 should I run the .63A/R or the .82A/R ?
- Best NY shop for tuning engine?
- Stock injectors
- Dyno Results @ Homemadeturbo.com D16z6/ZC/B16a & LS/VTEC NA
- Biggest street tire size possible?
- whats the most psi you can push safely on a stock b16a2 with a hondata?
- Can someone please post a pic of the APEXi Skyline GTR intercooler on a 94+ teg please
- HKS EVC IV Install (DSM)
- anyone used a centerforce clutch on a turbo setup
- Boost problem
- ClutchNet Stage 1 ? anyone using one? opinions?
- Vacuum line connection questions (pic)
- garrett turbo of a older volvo..?
- cracks in the exhaust manifold
- What's the point of spherical dish pistons for FI?
- ATTENTION Turbo SOHC guys...
- 200 WHP with a turbo D16Z6?
- Apexi Turbo Kit Dyno 's
- Crane Hi-6TR + PS-92 Coil for sale
- Tial 35mm question
- Detonation @ low RPM/Light Throttle.
- turbo seals.?
- Issues with Joe P Manual Boost Controller
- internal wastegate questions..
- Semi Built ls block or Stock 2001 GSR block
- ZDYNE users...spark and fuel maps only to 7400rpm...
- Is this normal for a built motor
- is 990cc injectors to big?
- A temporary cure for bad ring lands or burning oil (blue smoke)!!
- Crower Rods Pre Install Bolt Stretching
- Stuck @ 5 psi
- What dimensions for intercooler on an EG
- Blow by?
- car still stumbling and hesitating, running lean,,,,,,,
- Whatever happened to Tony Fuchs
- JDM B18C swap or Fully built D-series turbo w/ nitrous???????????
- brake pads question
- replace mains without pulling crank?
- Anyone have any problems with Drag cast manifolds?
- Fact or fiction?
- Why would I overheat if my fans are on?
- Which Turbo for a stock b16a?
- Should I get a 12:1 Vortech FMU for my setup?
- sizing question between TiAl 35mm & 40mm same???
- OT: This is what I gave up my turbo integra for....
- HELP! How the hell to get traction,launch?? Can't launch turbo b16 hatch for crap, HELP TIPS..
- B17 with 10.50:1 cr & JRSC question
- fitting on f22b1 block for oil pressure sender???
- Fuel pressure is too high...
- Can a HKS SSQV fit on a greddy charge pipe???
- Gear dependant boost control????
- Water cooling on turbo?
- need a new clutch.
- What octane are you guys running? - high boost only
- Not a honda, but anything with 2 superchargers cant be all bad!!!!
- Injector Clips
- Not a Honda, but anything with 2 superchargers cant be all bad!!!!!
- I NEED to buy your DSM Injectors.
- Pic request: pics of oil feed line routing.
- Difference in dyno numbers.
- F.A.S.T Fuel management
- Inline fuel pump with hondata??
- What settings do I use for 440cc injectors with S-AFC hack???
- denso iridium with ls turbo?
- DIY Junkyard setup complete..Lost about Fuel Management.....
- Protecting A/C Lines
- My dyno results!!
- My thoughts on 300+whp on the street.
- What is needed to replace the Greddy TD04H w/ a 14b?
- Is anyone using the Full-race.com Turbo kit?
- am i running lean?
- first post
- Greddy Blue Box VS Greddy E-Manage
- Injector Cleaning Service is back in Dec.... $25/set.
- LS Drag III hatch
- Anyone have experience with cracked rotor housing on JRSC?
- RUSTY manifold?
- Rev Hard End of Year Sale!
- Pistons melted, are the walls ok?
- Needed: Words of Wisdom
- Block Cleaning Question
- Wastegate question
- Anyone using digital gauges?
- Aeromotive FPR ques
- junkyard turbo set up...Questions...
- Sohc Fuel Upgrades
- Turbo guys....need some words of wisdom!
- Help me to decide which turbo i should get ....
- weird story about fuel pressure...
- motors for turbocharging.. your opinion~
- question about turboing a B18B
- Vortech Supercharger?
- Garage SEll TUrbo Stuff.
- Reading spark plugs
- need help in shocks...
- Could I use a Civc EM/EK radiator on my 1.8L?
- High compression turbo motor?
- Alright Check this out....Thoughts?
- Were to get an oilfeed/return line kit??
- i need to get a delta gate spring
- info on what i need to change in my b16a for a turbo.
- Can anyone help with this T3/t4?
- Need help!!! Leaning out. Fuel pump??
- Drag Generation 3 & Hybrid Turbo Kits
- turbo and nitros d16z6?
- turbo integra's?
- T3/T4 How much Hp ???
- what turbo?? any info?? will it work for my plans?
- Valvetrain work....
- ware to buy a dyno???
- Oil coming out BOV????
- Spoon Sports 4.7 FD tranny
- can a 92-95 type 24 greddy intercooler fit a 99 civic????
- The Junkyard project is finally done! (pics)
- hey need help
- JR FMU questions
- turbo HF is it worth it.
- turbos anyone?
- ATTN: To all the FIF's (forced induction frequents)
- greddy turbo kit injectors
- I'm having trouble putting my fuel pump back in
- Would you conver to ODBI?
- what size intercooler piping should i run
- can i use the autometer steel braided line as an oil feed line
- how much boost on a stock B16?
- Good place to purchase top fuel turbo cams?
- crx downpipe
- homadeturbo.com peeps
- A few nitrous wiring questions...Nitrous gods help please!
- Reliable Turbo Teg
- Which Supercharger?
- flow bench/chart of Cartech cats? graph?
- Oil in intake inlet of turbo. My turbo seals screwed?
- Rockets WTF cams..!!! Special
- Snapped the metal fuel line.. what now?
- Hondata problem
- Anyone seen this before? Air/Fuel ratio monitor...o2 sensor...
- Car is hessitating...Why?
- question for you guys
- Wanted,,,,, Jackson manifold......
- Turbo Manifold ????
- Pic of Junkyard kits
- Vortech FMU idea...would it work?
- post pics of your direct port nitrous install.
- Turbo kits
- help !! hesitation/jerking @ 4000 RPM, D16Z6 in 89 hatch DIY turbo
- noob nitrous q?
- What size of turbo to get
- Inside pix of the PWR water to air
- What are full-sweep gauges?
- inlinepro T3 turbo manifold....
- vortech hybrid?
- Bench Racing @ it's finest. What will it take to hit 11' s on Drag Radials?
- boost controller up or down?
- Biggest turbo for a daily driver?
- Please look at this piston for me and tell me if it is ok
- wow!!! I just joined the darkside...and so happy!!!
- thinking of going Turbo ?
- best standalone for the $ ?
- what hondata should i get?
- pictures of my project..
- New motor is in.....finally!!!!
- Wide band 02 Honda Civic HX?
- I need one SRP piston and a set of rings/ HELP
- How much would Just Greddy Blue Box and 310 Injectors be worth?
- Best type/place/price for hose clamps?
- Drag III LS, having startup problems.
- Need Help...Honda Lovers
- Anyone paint exhaust mani, or turbo housing? post pics
- good street turbo for b16a?
- OT: Which Color Should I coat my Piping ?
- turbo setup for b16a 1st gen
- Okay to remove fuel pump?
- *groupbuy* CHEAPTURBO.com T3 2.5" stainless vband discharge adapters
- Thanks for all your negative input...
- Bosch blow off valve??
- AEM rail or stock?
- crankshaft pulley to boost jrsc
- 01' GSR and Drag III kit, install???
- How good is this intercooler?
- air/water ic setup
- FS: LS/VTEC Turbo Parts
- old greddy sohc kit... blue round thing???
- Hondata EEPROM Switch
- Turbo setup.
- exaust diameter for turbo?
- new turbo stuff for sell
- APEX-i Turbo Timer
- Has anyone tried SMC map sensor controller
- What kind of gas mileage do u get in ur turbo'd car??
- Boost gauge question
- What would cause this...
- New 2003 NHRA Class Rule Book Available For Download
- High-compression & Boost
- Stock fuel rail: Can it accommodate 550cc injectors + stock FPR?
- HKS turbo timer on 5th gen Lude
- All Greddy stuff tommorow one day only is 30% off
- Service Check Connectoron a 95 Prelude... where?
- It Never ends...
- TIAL WG flanges..
- Victor X IM is in...idle problems
- Does this sound strange?
- Turbo mounting questions?
- black box on old school greddy kit?
- Where to find obd-2 to obd-1 harness?
- who here likes CLutchnet or not
- How much boost?
- which injectors on H22 ???
- What turbo are u using on your B18C1??
- Need 2000-2001 Integra ECM wiring diagram, please help
- Which pump should I get for my greddy kit????
- Tial Wastegate, and Drag Intercooler Questions.
- K26 K24?
- blue box can i install?
- Best place to buy TIAL wastegate???
- Re-dyno tune if replacing headgasket?
- Ugh NOBODY wants to weld up entanks for my FMIC
- Oil Pan compatibility issue b16/b18b
- ... sleeved street car...
- anyone offer 3 inch downpipe that keeps AC for the prelude with rev hard mani?
- WTB: Drag or Revhard Mani
- Torco Race Fuel???
- I Total cost of turbo? estimates?
