View Full Version : Forced Induction
- what ignition? turbo gsr ~400whp.. msd or stay stock?
- D-series Turbo manifold........................
- borg warner 6.5 diesel turbo for a b17a
- HOW MUCH NITROUS CAN I RUN
- drag t3/to4E turbo good enough for stock Ls on 11psi
- So i got the SRT dynoed again, With less mods.....
- Water Injection
- do i need oil squiters on a high boost motor??
- SAAB T3 internal wasegate
- need help tuning pfc
- question about full race springs retainers and valves
- 2 steps colder plugs?
- D15B8 mini me boosted
- H22A7 Accord Type R Turbo Conversion Help !!!
- skunk2 ecu and vafc sufficient fuel management?
- FINALLY...started porting my spare head! Take a look...opinions welcomed!
- Anybody have, or know someone with a draw through setup?
- What kinda oil for JRSC?
- Dyno #'s inside
- Victor X throttle body placement?
- Overheating question
- fluctuating boost gauge..
- Fuel is cutting off at 6000 rpms!?!
- difference between B and E trim turbo
- What would a safe redline be for this setup?
- need help with newly boosted eg
- Need help quick - Fuel/Spark issue
- 900cc Venom's HP rating?
- B18C1 how much hp for daily driving....
- trans code help
- partial dyno #'s
- Turbocharge or Supercharge a 2004 honda civic SI
- Finally!!! Install is complete! Im now addicted to boost!
- Help with this tire ongoing project.
- anybody knows how to install a Apexi AVCR old school boost controller??
- A few Questions for ya guys, Thinkin of switching over :)
- Oil coming out from dump tube
- Cooling a GT series turbo
- open vs. closed dumptube
- TURBO GURUS take a look...
- I need A ECU management for my GREDDY KIT!
- Hondata Pocket Programmer2 issues....
- Turbo Manifolds economical price range
- CAR WON'T START AFTER 100 SHOT OF NOS?? HELP ME OUT??
- which kit??
- what car had t3
- what is better ?
- YAY, Another Oil Press thread, what u all pushing in press...
- gsr block
- Roots type, Centrifugal type, and Lysholm Twin-screw type
- T3 turbo on B18A.. Mike K needs help.
- CEL Code 16 (high rpms, in boost)
- Warm Starting With The HACK????
- OBD2 converted to OBD1...Do I still need both O2 sensors?
- what 3 gauges should I get?
- donut gasket for dp to cat connection
- boost experience i've now learned that B18c5=bad for boost
- Blown Oil Seals On Turbo
- INSTALING WASTEGATE
- has anyone ever blew their motor using chrome ( dynotuned also)
- My Allmotor setup with nitrous....
- FI -> NA ...... what do u do with the oilpan ? PLUG ???
- Turbo guys, how big are your exhaust piping and how loud is it?
- Need help choosing a turbo!
- how do peeps get the itr intake manifold 2 fit ls motors?
- Does Intake manifold pressure affect boost?
- Defi Oil Pressure Gauge Question
- what is the dimensions of MAX REV INTERCOOLER
- Demand for Toluene?
- quick is this a good start for my gsr??
- Greddy kit (internal wastegate) + b18c5 = overboost :(
- looking for basic manifold
- hf manfold
- To the long term turbo guys
- RC Injectors install question
- ahhh...good'ol CLEANING DUSTER put to good use
- b16 turbo troubleshooting. Runs dead rich and jerks like crazy. ???
- LS kit on GSR
- Complete n00b question about header flange
- Quick question about boost and rod bearings...
- oil line size?
- went back to turbo
- Spun Big end bearing can you reuse the crank?
- boosted high compression
- Is This Not The Best PCV System??
- Damnit, i keep blowing my turbo seals...Why
- Are ultra-gate wastegate springs compatible with tial?
- steering stops
- LSD help
- Turbo and WG info needed
- 90 deg bend off turbo
- Turbo Mini me blew up....why???
- clocking turbo, i searched
- what a/f guage to use with d16y5?? (relevant to the 5 wire 02 sensors)
- Anyone Know the Trim Sizes of This Turbo??
- GReddy turbo kit installed, gas cuts off at 6k rpm and check engine light comes on...
- Replace oil seals in Mitsu G18 (where, cost?)
- Electromotive Tec3
- Helpp choosing tranny
- Someone needs to stop MASE from destroying his customers cars!
- t3/t4 50 trim
- B18b Guys with real world .48 a/r and .63 a/r housing experiences
- Homemade DYNO!!! Take a look.
- Car is stalling
- Time for an Upgrade - GT30R and tube manifold
- t4/t67 fit on a sfp log?
- boost creep ??
- DYNO - B16A2 w/ GReddy 18G - 9.5psi - Opinions needed
- what do yo guys think??
- guys? whats the max oil pressure for a turbo Bseries. im getting a gauge 0-100 or 0-200?
- Any Full Race ITRs in here?
- Finally... I'm done!!!
- h22 turbo teg *update*
- Need help fast. Idle problem.
- Riken Raptor 205/50/15 325whp?
- Built block, not boosting yet
- Boost stability problem....Please help!!
- boost leak question, this time I cant find it.
- greddy turbo timer problem
- Spark Plug Gapping
- overkill?
- GReddy turbo Kit CARB legal...OBD2B??? IS it possible? This info has me thinking..
- your opinions on ls set up
- mercedes bov?
- Transmission Techs
- SOHC custom set up.... ur thoughts?
- Issues with Greddy kit on GSR. Anyone in NOVA willing to help?
- stock Y8 with mitsu turbo....
- Where do you guys mount your ecu?
- Better cooling equipment and winter!
- civic si project pics!
- which way is better for the feed line?
- ZC turbo dyno slighly lean... this is why FMUs don't cut it!!
- LS trans for trade
- Built D16 Dyno
- vacum lines??
- help me clean up my mapsensor, missing link, and fpr setup. pix's!!
- air leak in intake manifold? clogged fuel filter?
- to build...or not to build...my D
- Master Power TO4E with 0.48 exhaust
- what charge
- UBERDATA QUESTION
- Building a h22 bottom end
- how to pull wires from plugs and reinstall....
- Stock LS turbo what kind of power can a 16g turbo create
- What Injectors for 500hp
- Getting GSR turbo kit to fit on EK chasis
- td05 that came off a starion? specs?
- boost problems- car starts, no boost
- VAFC Settings for B16 turbo with 310cc....
- Evo8 injectors.... questions
- Turkey Call BOV
- my Turbo Teg at the Track in Brno, Czech Republik
- Turbo Exhaust system?
- Questions: I'm considering a supercharger
- i blew my tranny last night :(
- H22 turbo tunning experts needed Please help!!!!!
- This is a bit off topic guys but maybe you could help me out ... (240sx Related)
- OBDII engine with an OBDI ECU (P06)
- this motor better blow - part 4
- Which Turbo injectors do i need?
- My setup
- Autometer Air/Fuel gauge?
- Will an Eclipse DSM exhaust manifold fit on an LS head?
- Does my Wastegate Valve look normal???
- Innovate LM1 - It doesnt have narrowband output?
- Tuners in New England
- any proven power from hondata Intake manifold gaskets or fake ones
- Is it normal for....
- VR4 fuel pump? Long Shot!
- Safe boost on a b18c1 ? ? ?
- condering TURBO as another alternative..
- anybody making over 350hp with ngk spark plug wires?
- pics of finished product
- how to get more boost out of my jsrc
- whats a good temp for EGT probe to read at idle and wot?
- need help car wont start
- drag turbo size spec t3/t4e
- Fuel Pump
- egt on greddy manifold
- Oil Pan Return Fitting
- BOOSTING 7lbs NEED ADVISE PLEASE
- what should i use to clean up intercooler and piping?
- O/T what fittings for water temp gauge
- really important ????????????????
- EGT gauge sensor mount?
- Thanking sponsors...
- what is the best RPM to use NOS at?
- Which injector is best?
- WTF- Garett makes different size 5-bolt T3 exhaust housings????
- GSR turbo setup on b16a?????????
- turbo si high idle. searched
- DAMMIT!! need a turbo for my baby...
- JRSC install problems
- Excessive Blow-by - Built 83mm block
- needing help t3/t04e trim
- Question about SSAutoChrome
- Oil Catch can question
- Place to buy wastegate actuator for a rhb5
- STSTURBO.COM
- Full-Race Tubo engine setup
- Golden Eagle Vacuum Manifold install???
- LS vs GSR spool time (same turbo, manifold, downpipe, exhaust ect)
- turbo check list
- turbo b16a valve lash
- alaniz or port flow.
- owrt it to switch to ITR tranny (from GSR?)
- what next on b18t
- 84mm Darton Sleeved b16.....Almost there....pics inside....
- Got a decently built LS-Vtec turbo setup, which Spec SC61...
- IM runnin too much PSI, why??
- Supercharger Problem need help.... FAST
- Has anyone ever done LSVTEC w/TD05H-18G Greddy kit?
- T70 too big for h22a Accord
- Porting a Greddy Turbo exhaust Housing (wastegate)
- Vince/Golden Eagle... D-Series Headgasket Question
- Piston skirt to cylinder wall clearance
- stupid question...
- Wastegate Options
- Tune effected by new intercooler?
- JRSC LIQUID COOLER! PLZ HELP
- how well does a T3 super 60 work?
- Any info on homemade BOVs?
- ongoing boosting problem!! need help
- Double stacking head gaskets
- Coolant Temp under Boost...
- Will I have to grind my block?
- Civic ECU Wiring Diagram
- need help with turbo sizeing and trim sizeing
- I dont know where to put this but.. why is my cursor a MOO smiley face
- ls/vtec turbo ?
- rtv silicone gaskets
- turbo exaust outlet
- o2 sensors
- MSD Ignition.....what is it all about?????
- BmC RACING B Series AC Log Manifold *Pics Inside*
- missing link noise?
- car is slow to start
- Tial Wastegate......help
- What happened to the Lisa post??????
- d16z6 turbo question. FI NEWBIE
- what makes equal length manifolds make soo much HP
- where to fill my bottle with c02 in cali oc.?
- B16a Turbo, starts but stumbles and doesnt idle
- Precision 1000cc injectors and idle?
- Cam gears for turbo?
- Help me decide on a welder (between two)
- Turbo Manifold Spacer???
- what kind of performance would I get outta b16 stock boosted 7lbs
- str products
