View Full Version : Forced Induction
- Problem - CEL blinking, car bogging
- I may have quite a bit of an issue...
- Which electronics should I get?
- Think I got into trouble w/this turbo. (vafc, timing, & int. wastgate ?'s)T3 turbo
- 8.5:1 c/r on a b16 too low?
- What hose are you guys using for external wastegate vacuum?
- Ball bearing turbo
- Irratic Idle, cant get rid of it?? HELP
- Integra intercoolers..
- what does it mean when its hard to turn?
- detonation
- Plugging the Wet Bearing
- Bolts for tial - Need help
- Help, with GM 3 bar map sensor
- OBD1 stand alone and semi stand alone
- fmu question??
- Turbo change questions?
- second boost on profec b?
- Can anyone vouch for Arturbo?
- Turbo vs. RSX
- fmax in en EF with B16
- WHITE SMOKE WHILE DRAG RACING....
- Found The Real Reason My Engine Blew! **Warning graphic pics**
- Boost Controller
- Well it was fun while it lasted =(
- AFC Hack and MSD Timing Controls
- 5-bar F.A.S.T. Upgrade Now Available
- Any ideas...
- Where to get bolt for tial in MD?
- clutchmaster satge 3
- motor sputtering when v-tec comes on
- Whcih company made this INtake manifold?
- FI Accords, what spark plug gap are you guys running?
- vafc + pr3 + 440cc injectors ?? tuning it
- B16A JRSC Timing, Detnation, Rich :(
- Turbo GSR is finally up and running! (pics)
- OBX Gauges?
- Turbo Manifold
- Defi vs Greddy (mechanical gauge)
- turbo timer test?
- Full-Race Big T3/Tseries Hybrid turbos
- car hesitating around 1500-2000 rpm
- boost guage?
- WTB: TUrbo kit for 2000 EX
- what is wrong with my h22a1?
- 11.2:1 compression and a supercharger
- How to use a cartech fmu
- oil pressure gauge how do i hook up?
- 310's... need an fmu???
- Well, looks like I may be going vtec now.....shitty story inside.
- best hondata tuner in SLC
- SOHC Turbo, need some help with afc
- ID a turbo for me
- 3" mufflers... best ones?
- Turbo tuners question
- How does this compressor map look?
- Good Hondata Tuner in Sacramento?
- Heading to Drags, got a few questions.
- Oil and Oil vapors coming from v-cover breather, bad fumes in car
- high oil pressure good for turbo?
- What spark plug wires are you running?
- Wierd thing happen to my Greddy type s BOV today...
- If I hit rev-limiter with turbo will it hurt my engine?
- Block Guard or NO Block Guard on B18b
- 2000 civic ex... "Turbo It Or Not?"
- Mechanical vs Electrical Boost Gauge
- Price of a Jackson racing supercharger kit install on a 1994 integra gs-r?
- Can i use radiator hoses as silicone coupling??
- How the #*&@! are you guys getting traction?!
- Thanks for the help. I finally got my fake turbo noise maker installed. Here are the pics!
- Is this cause by the delta wastegate????
- JRSC for 5th Gen lude. Help! I'm new!
- REALLY CHEAP rubber couplings for IC pipes at MENARDS! (same as home depot)
- Intercooler hanging below bumper?
- JRSC Squeels under boost??? HELP
- Greddy Emanage vs. Hondata
- t3/60-1 vs t3/t04e
- How would I know if my walbro 255lph pump is going out?
- Need Help
- jrsc problem with surging motor
- Did a compression and leak test today..
- Can a 38 mm wastegate be used on Drag 3 mani?
- Help with ECU Control
- what head gasket with 84mm bore?
- What the future holds...
- ## afc Hack question ##
- ave a B16 turbo block
- replacing drag manifold....
- good custom downpipe shops in the bay area
- anyone ever heard of a pressure reducer????
- just another Turbo coupe on the streets.....
- Thick Guage Turbo headers
- my homemade intercooler piping>>>
- BLITZ DUAL turbo timer and boost gauge
- What is the largest oval style muffler you can fit on a 99 civic coupe?
- how do i pull the rocker rails from the head?
- What rpm will precision sc61 make full boost?
- Oil splattered out of valve cover filter.
- at last my car is ready
- hesitation problem
- true/ false... tial 35 and 38mm wastegates...
- Sacramento Ca Area peeps with Hondata S200b w/ programmer, I need help?
- Can you fully tune your hondata on the street without a dyno??
- best place to get 3inch to 2.5 reducer??
- nitrous -b18c1...b18c5
- i need help with hondata 2b in my 93 LS turbo hatch
- Math check on a AFC hack
- Stumble after 2 days of boost
- Turbo b16 Ek, If I swap in a b18c1 bottom end what kind of hp+tq gaines ??
- question about nos kit on ls motor?
- my goals
- Suggestion on needing dyno or not on current turbo???
- rev hard = drag 3
- Twin T04S FD3S RX-7
- Is anyone using CPR obd1 --> obd2 injector clips?
- What NOT to do when going FI
- Would this work to pass smog w/ turbo?
- 1,000+hp Twin turbo Buick dyno!
- Safe Boost on a D16Z6
- What is an affordable radiator for a turbo 6g Civic??
- Zdyne vs. Hondata
- what more i need??? to boost 7psi street 10psi track??
- i have a pretty stupid question but i have to know...
- Car just died...
- Turbo Manifold Temperature
- Backfire and Cel?
- bottom end noise SOHC... can i ?
- Greddy Profec B Spec II Help
- what do you guys predict?
- turboing a d16z6 ?'s
- FMIC...does it matter which way?
- water to air intercooler....
- How much horsepower will a jackson racing supercharger add to a 1994 integra gs-r?
- Turbo Oil Flange
- NEED HELP -- any shops in Bay Area that carry Earl's fittings?
- pics or dimensions of greddy intercoolers?
- autometer boost gauge
- Benson Sleeved Blocks..How they are made and why they are the best
- cometic head gasket question..
- :: dual core del sol radiator for turbo gsr civic :: anyone running this setup? ::
- someone help have jdm itr ecu what em do i use
- Best oil for a freshly rebuilt turbo'd engine!!!!!
- something with fuel?
- Downpipe Question 2.5" or 3"
- just bought some Accel injectors out of a buddy's eclipse and..............
- how sturdy is the d16?
- Any advantage?
- anyone ever paint your block ?
- Question on Magnaflow Mufflers
- Driveability with Emanage
- differences b/w vafc and boost gauge
- itr lsd...how much boost?
- which b-series transmission is best for boost????
- fuel management questions for boosting d16y8....
- LS crank pulley = B16 crank pulley?
- do i need an o2 sensor wit the aem ems
- 3 BAR Map Sensor & piggy, Missing Link, Tanabe G Medallion
- Blue Box and 310cc injectors potential?
- Wastegate elbow
- Map sensor Code 3, I have a fields controller
- To All With Hybrid Hondas
- Which DFW shop to go to for turbo work? VSV or Jotech
- Rebuilding b18c1?
- tial wastegate question??
- 300whp in a B18C1
- Just did a Compression Test.=(
- how many lbs of tq for screw clamps?
- Blow off valve
- Rev Hard or Drag kit for LS?
- Is my hondata broken
- anyone with an older blitz bov
- JRSC Melts IAT Sensor
- 84mm on a RS machine Sleeve?
- will d16z6 JRSC fit onto d16y7???
- spiral max turbo air twister
- Does compressor and turbine side have to be on certain side?
- 8 injectors w/ 2 fuel rails
- TIPS On Keeping Engine Bay Temperatures Low
- ok daily driver turbo setup....
- :: radiator options for eg :: 3/4 length :: not full-length integra ::
- Which Pump to buy?
- Welp...my Apexi filter is about 1/2" too long...Small K/N or HKS foam?...=(
- plug gap causes problems?
- Revhard manifold help!
- Greddy turbo kit on a GSR....Power?'s
- Critique setup please
- Can some one explain why my engine is still in one piece?
- B&M New Volt (keyword add: newvolt 20v 20volt ignition)
- need help with choosing a bigger turbo
- Max HP and Boost from 450DSM's
- safe to take guages apart??
- Are all 02 Sensors the same?? I really need help!
- Whats a decent turbo for a stock b20?
- PWR Radiator
- HELP!! 50 or 57 trim
- Turbo LS Spool
- Teaser pics
- JunkYard Turbo kit for JDM H22A Civic.
- :: looking for free mods to improve turbo spool up to full boost ::
- HELP >> Need a good zdyne gold B20 base tune ....
- Vortechcharger ???
- how much psi can this setu take?
- :: t3/60-1 users ::
- front mount intercooler
- need opinions about fuel management for sohc(d16z6) greddy kits
- Your thoughs on aluminum valvespring retainers......
- Black anodized intercooler
- Tial wastegate with revhard manifold?
- where to buy waste gate springs
- Power output guesstimates
- boost bogging?!!?!?
- Delare Slim fan question
- my check engine keeps blinking..
- How Good is this turbo
- Update: New Dyno #'s of b16a2 (12psi)
- stock clutch
- pusher fans
- GReddy turbo kit fit 96-00 Civic LX?
- which turbo spec!?
- Help me decide
- quiet a turbo?
- anyone using exedy racing clutch on boosted cars?
- How much boost???d16z6
- turbo 92 teg
- Radiator
- AEM EMS or Hondata?
- any other cooling i can do..
- Deltagate w/ Greddy Profec B problem...
- cant make up my mind (help)
- injector help PLEASE
- Greddy blue box work with any ecu?
- My head bolts were hand tight, WTF!
- Benson Offset Bore LS Block
- What is the best to use?
- how much hp will i make
- Need help deciding on an intercooler.
- How is the new version of AEM?
- what engine managment to use
- Can I add NOS to my slow ass DX?
- whats needed with a vafc?
- Vouch for Turbopanda
- Yet another a/f and boost gauge question...
- Why is my car running so lean all of a sudden!??!
- Map CEL after UNinstalling turbo
- Help me out. I screwed up bad. I was going to the duno today..
- Turbo Manifold?
- Rev Hard Summer Sale
- Oil Weight
- greddy 60mm gauges
- Cams for a Non-Vtec Turbo setup?
