View Full Version : Forced Induction
- Acura/Honda B16/B18/H22/VTEC Valve Spring Compressor
- Garrett GT oil feed restrictor
- alternator belt issues do to turbo?
- HELP Clocking a Turbo
- built ls vtec Q's 56k no no
- turbo exhaust question??
- JRSC
- Build it your self or have a shop do it.
- Garrett GT3271 Turbo B16A2 too big?
- anybody want to trady my gt 3076r tial stainless housing for your gt3076r t3 housing
- Detonation, headgasket, or both?
- white smoke after warm up
- Melted piston...again
- HKS boost controller question
- HELP: Torque spec for band on 19t turbo??
- 1993 civic hatch Type R turbo
- How much boost? Greddy 18g, stock GSR motor
- High comp turbo
- crane coil PS91. whats so good about it?
- best turbo set up
- compression test results look inside
- garrett turbo t3t4 57 trim question.
- Waste Gate Dump tube atmospheric exit location. Where is optimal?
- T4/T3..not T3/T4
- Sleeve thickness?
- Fuel Pump Question
- Performance Parts for my b16
- Turbo Bolts
- Help on my ECU please?!
- RC 550's in a D16Z6 intake manny?
- what rods i need?
- Crower non-turbo cams? Who has ran them?
- Map Sensor Problems
- need advice on cams
- fully built civic turbo over heating
- Best source for replacement Tial wastegate hardware?
- gt2871r on b16.
- 44mm wastegate vband size
- Rough idle/low oil pressure on cold starts
- lsi or vtec turbo
- Will 6psi WG Spring open without reference line?
- 6265
- Reversed superchargers: I just proved it can be done.
- recirculating your dump tube
- 7 lb. wastegate spring.... 15+ lbs. of boost?!?! wtf>?!
- adding a inline 044
- Causes of boost leak???
- Limp mode!?
- stock + inline 255
- FML 200whp on turbo b16?!
- new to FI, any ideas
- Pistol Pete's H22 Turbo Hatch
- oil pump!
- clutch life....
- ls/vtec turbo HELP!!!
- cooling issues?
- precision turbo 67mm power ??
- Why use online pro head gasket
- Honeing block. help
- advise on supercharger cam selection
- Top mount + Power steering??
- Finally...
- tial 50mm bov surge
- turbo or oil restrictor??
- quick question! plz help!
- Boosted b16a2 headgasket question
- Ignition breaking up under higher boost
- garrett t3/t04e flange help oil return
- DSeries Manifold?
- B16 Turbo head leaking oil badly
- 4" stainless bends
- Is there such thing as too small of an exhaust housing?
- Eagle LS rods/vitara pistons?
- Whats the Max Power on a Garrett 57 Trim?
- smoking lsv help!!!!
- stock fuel pump
- 2 step (launch control) settings
- Smokey Turbo again....
- JRSC on my B16a2 or not?
- is this oil return too high?
- I need someone to fabricate a custom downpipe and exhaust
- VHT header paint
- VHT hearder paint
- ATTN: The Shodan!
- 800+ whp. dyno inside. vids soon.
- Edelbrock Victor X ... Which TB and Size are you using
- 2 ?'s.. problem with AEM wideband, RC fuel pressure?
- vacumm leak iacv help!
- E85 ? and need help
- Over Heating Problem
- LSvtec ARP head stud torque spec
- B16a2 Turbo build
- Greddy 18G....*sigh*...a little help please.
- NEED HELP !!!!!!!!!!!!
- is this worth following
- VITARA BUILD what not to do (won't work for 1.5 engines)
- 1 to 1 fuel pressure regulator
- what turbo for my build?
- 440hp, sheared/broken studs?
- S366 drain line pics?
- Daily Race Car?
- 100k on a turbo, is it worn out?
- think 300whp is obtainable?
- I'm poor, homeless, unemployed and have a turbo Civic.
- Lsvtec burning white smoke
- Needing parts to finish my my turbo set-up...
- Find me some more power
- Fuel Cell/Pump Question
- best OEM cams combo for JRSC?
- What plugs ? ?
- MSd on forced induction
- Did adding a turbo impact the coldness of your air conditioner?
- JRSC not making boost
- aeromotive external fpr ?'s
- tial diaphragm came unseated
- help identifying turbo (have p/n and s/n)
- Replacing turbo and tranny B16-T
- HKS GT2540?
- Turbonetics Waste gate fakes?
- what fuel system is this ?? (pics)
- Hondata s300 and omnipower 3 bar map
- What turbo size for 350whp B16 spool <4000
- zeitronix wideband install
- H22 turbo issue..
- Can I still have an a/c if I boost a GSR?
- about to boost my b18.....need some advice
- BLOX CAMS ARE THEY THE MONST UNDERRATED CAM ON THE MARKET
- Blown Headgasket on Poormans Type R Turbo
- Help! Smoke!
- JRSC Question?
- overheating issues?! turbo/ac
- Gsr block with b16b head (turbo)
- picking a engine to boost
- PreLoading Tial38mm WG Springs?!?
- 14b turbo outlet flange?
- going turbo..auto tranny hold up?
- still lean after walbro fuel pump! help!!
- external wastegate exhaust housing?
- What's the best turbo setup for a GSR?
- What do you guys think of these injectors?
- Oil in Intake manifold, near BOV
- PTE 6062 journal vs. PTE 6265 DCBB
- 97 integra turbo ?
- what kinda turbo manifold ,and turbo to go with
- Post Turbo Integra A/C setup Pics-Help Me!
- EM1 turbo desicion..
- Has anyone ever done this?
- rebuilt motor, put turbo on after or while breaking in?
- Turbo installed, smoking question
- nos kit
- 3" turbo exhaust ?
- Nitrous Spark Plug Tuning Tips
- Stock rod strength?
- Need some help on B16 swap/wireing info
- Running Wired After head swap (Boosted D16)
- RC PB8X-1000 Injectors?????
- boosted mini me
- oil pressure issues
- hey post up your t1 catch cans
- Just another 400hp single cam, need some help
- flex section
- tire options and diamond racing wheels..
- stock fuel pump hp limit? 92 integra
- New Ls/Vtec overheating, HELP!
- excessive blowby, cracked ringland?... Looking for some advice/options on what to do
- big problems did wire tuck cant go pass4000 rpm under boost
- half sized radiator question
- having a few thoughts on my turbo
- Built D16 turbo size ?
- Question to all you turbo experts come in read and reply
- 2000 DC2 OBD2B: Greddy turbo kit compatibility?
- Turbo SOHC
- quick question on exhaust system
- 1 shortblock question?
- perfect air-fuel ratio???
- IHI RX8 CART/IRL turbo information
- B18C5 Turbo Build, what would you do?
- B16 build 500-600 goal need advice
- Need more fule
- What engine oils are people preferring in their turbo engines? 2010-present
- My build
- obd1 conversion help, no spark
- turbo build...what kind of valves??
- ls vtec turbo problems... help needed
- Boosted OEM P30, Max ign adv. ?'s
- Turbo Oil Return..How would you fix this? Pics Inside
- precision turbo dimensions?
- Share your Fuel system setup.
- stock fuel pump = lean????
- EBC solenoids...whats the difference?
- problems with pcv
- Going for turbo ITR...
- vtec wont cross over any reason why
- Trouble starting Ignition? fuel?
- What turbo should i choose?
- 81.5mm headgaskets?...
- oil feed/return length and size?
- wich rods would you go with?? please help
- my turbo setup...inputs please
- Will this manifold fit?
- h22a Vectorx manafold
- Coil dwell time, spark strength vs timing
- ? on holset turbos.
- A/C Compatable Turbo Setup
- driving untuned turbo
- LATEST TURBO WORK
- *noob* intercooler/bov fitment
- Need Some Assistance Identifying My Garrett Turbo
- 91% duty cycle with 750's?!?
- resistor box
- b20vtec, what kind of turbo?!
- sounds like turbo blown?
- KingMotorsports Built K20 with Kraftwerks C38-61
- car smokes on deacceleration..need help...
- turbo ls help!
- Most Hp or stock tranny and axles
- Borg warner turbo id
- breaking up in boost-PLEASE HELP
- turbo housing?
- 510 injectors max psi?
- Question about spool on T3/T4 57 trim
- TURBO REBUILD COST
- Buddy Club Spec 3 cams for boost
- Biting the bullet, new turbo advice
- wastegate question
- Fuel rail issues.
- universal/knock-off greddy type s bov diaphragm question.
- Wtf is the problem? no one knows and its getting really annoying
- peakboost has anyone contacted them lately?
- Switching from MSD to OEM
- tial q vs 50mm
- Looking for a post - K20 GT28
- I may need to replace my wastegate...or so I thought!!
- Tial MVS Fakes on eBay
- turbo b18b help
- another coolant line question
- Removing oil drain line
- Where to get IC piping for EG Hatch?
- T3 6262-SP .63 vs .82 housing.. Dyno Comparison
- Kpro Installed Yet @ idle AFR goes off the wideband./lean why?
- D series breather setup?
- Intercooler Effectiveness?
- EVO MR turbo for LS help
- master power 60 trim vs. garrett
- Turbo Setup Question B18c1
- Garrett T3/t4 vs Precision SC 44 ~450WHP~
- sohc vitara ?
- Bolisbuilt 600+whp S2000 Street Beast
- Need Help
