View Full Version : Forced Induction
- gt30r / gt35r stock b18c's reliabilty ?
- want to turbo my d16z6 ef hatch
- How to build a Jackson Racing supercharged integra and not get ripped off.
- Turbo cams
- ethanol and e85 same thing
- 64mm throttle body
- Bad miss after freeway trip, fouled plugs, remove #2 wire don't make diff.
- about bearing clearances
- DA integra oil return anyone used 45 degree bulkhead?
- go-autoworks vs synapse/rc autoworks ramhorn
- b16 clutch recomandations 250-300whp.
- Info on turbo size
- OEM Hard Fuel line on my EK
- Mbc help need diagram or explanation
- oil cooler with 99SI slim radiator ok for turbo?
- AC friendly manifold options
- oversized valves?
- Turbos, hmm ?? which one
- 100 psi seat pressure valve springs wear.
- how can i get louder turbo sound
- STOCK RAIL RC750CC'S ???
- cracked my sleeves on my lsv turbo
- Should i keep my PRECISION SC44 60 TRIM?? ANSWER MY POLL, YES OR NO!!!!!NEED OPINIONS
- hard start after a timing belt adjustment
- after market throttle body
- problem on old full-race.com car that has never happened before HELP
- Am I Gonna Run Into Trouble With These Used ID1000s
- Oil cooler location?
- short gear or long gear for boots?
- Crower stage 2 (63402a-2) and boost
- looking for a small 4" inlet filter
- High RPM boost??
- Boost by gear set ups?
- watercooled MVS
- Planning on going turbo
- what should i expect from the turbo kit...
- choices for 3" mufflers for turbo pictures
- drag gen 3 intercooler.
- Question for the turbo guru's
- stock bumper mesh blocking intercooler good or bad
- what to do with a 99 hx
- help!!best turbo for my setup??
- E85 GSR TURBO Stock Block Can hold??
- Drag radial/street tire?
- Full length radiator
- greddy 18G output??
- 3" V-Band my ass... not happy!!!
- B16A2 Rebuild for 300whp
- Breather tank....is it a must?
- input on my 550whp lsvtec
- turbo in ls eg questions need info/help
- Ordering pistons for a boosted ls/vtec setup. Which part number?
- Art of piecing a turbo kit...need advise
- open dump waste gate
- Thinking of buying a used sc kit for my b16; Thoughts and questions
- what spark plugs to use??
- Jacksonracing supercharger grinding noise!!
- Seafoam + wastegate question
- Manley pistons ??
- Top end HELP d16z6
- flexpipe??
- Any one running the speed factory cast top mount?????
- bone stock turbo gsr, on 9lbs going to 14lbs, what will go first?
- b16 jrsc setup!
- Where to get eclipse turbo?
- boost internals???
- Anyone with the Inline Pro SS T3/T4 manifold?
- turbo troubles
- Tuning and exhaust
- nippon high CR and headgasket and boost question
- Peak and hold injectors?
- turbo question
- building gsr
- OBD TURBOING HELP PLZ!!!
- Where can i find instructions to install a turbo on my Honda CRX?
- Need your help guys D16Z6 New Turbo Build Precision 6756SP Or 6262SP?????
- d16z6 turbo wastegate spring?
- h22 greddy turbo kit.????
- my eg h22 turbo project
- is my 60mm exhaust too restrictive if i have open waste gates?
- What dictates whether you need an oil restrictor for your turbo?
- B18 GSR intake manifold restriction??
- compression testin
- Best 1993 Honda Civic DX Coup Engine/Turbo Combo
- d16z6 boosted catch can hook up
- boosted stock b18b1
- What is a 50 trim .48 exhaust housing turbo capable of?
- PTE BB 6262 or 6265?
- garret T3/T04E 50 trim .48 exhaust
- Boosted B20VTEC in 90 CRX SI
- My new EM1 build, shooting for 500+ whp
- Exhaust Reversion, velocity, pressure Qs
- Thanks "The Shodan"
- DSM or EVO 4-8 Turbo Manifolds for B-Series/D-Series
- Heavy Oil consumption when riding out rpm
- ls turbo or ls/vtec turbo
- Quick spool and turbo questions (Stock b18c1)
- Turbo D16A6 CRX, Raised boost and now got problems, Need Diagnosed.
- BEST turbo under $700 for a stock LS motor street/strip build?
- IS THIS A REAL GARRETT? HELP LIKE NOW
- Jsrc Gsr Build Help
- HELP ID my T3 Please!
- B18c or f23/h22?
- b16 84mm what turbo for my?
- Methonal vs. E85
- da9 lsvtec
- b17 turbo?
- bov vacuum line help...
- How serious is it to upgrade valve spring retainers?
- JRSC on a B16 that is in DC2
- getting rdy to turbo, what do i need? help..
- Methanol M85 vs Ethanol E85
- Cut out problem
- Twin Turbo K20 video, whats the point?
- Coating AND wrapping?
- B16 Stock Sleeves 93oct and 500+ WHP ?
- need help buildin
- D16 On boost+ water meth
- Fuel Injection flow patterns, boost, no boost etc.
- E85 vs Premium For boost
- E85+Turbo Mpg's
- b20b turbo build
- Best setup for slightlymod'd GSR?
- Borg Warner EFR turbos
- GodSpeed manifolds???
- go autoworks (feed back needed)
- Victor x on a vortech blown bseries: yay or nay?
- Any dyno numbers on the pte 6768 non bb turbo on a b series?
- Internal vs External Wastegate
- Breaking up at full boost
- XS Power turbo kits?
- B18C Recommended Timing retard question
- Ls/Vtec sandwich plate and turbo feed line
- hondata 4bar map sensor???
- Ring question
- what yall think about a stock gsr witrh a 75 shot
- oil leak...return line the problem?
- Will a t4 open housing turbo perform good on a t4 divided manifold?
- About pauter rods - edm?
- Darton Dry Sleeves
- Intank fuel pumps
- need help:turbo h22
- interesting thread on porting.
- Damaged flexpipe causing major boost lag?
- thoughts on evo 8 or evo 9 turbos?
- Eg hatch Bone Stock B18 turbo tips
- Crankcase evacuation issue...
- wastegate problem on b18
- Upgrade mounts or poly inserts?
- t3 t67ho?
- 250+ whp how do i do it?
- what tranny should i put on my b20?
- Stock LS + Holset turbo build... manifold??? Which would be the best?
- flywheels bolts
- Turbo GSR
- Shops that turbo cars in socal?
- HEADGASKET!!!
- turbo, blown seals?
- Forged piston shopping..
- b18c1 600hp or bust lol
- garrett and ebay parts compatibility.
- 518whp oem internally b16 finally broke.......
- Boost gauges?
- B20B JRSC Re-Build (long)
- removing wrist pin ?
- gt3076 with .82 what boost can it handle? max boost?
- Anyone know details on PWR intercoolers?
- suggestion on wut B block to use for turbo build
- An option for turbo water lines
- reuse oem bearings with rebuild?
- P8R head... What pistons??
- Has anyone used this turbine housing? Special Turbine Housing T25-EWG-44
- pipe size on top mount
- b16a b18cr... I have both need advice
- Who's running a precision 6768 on a beries??
- b16 lsd trans or put an lsd in my ls trans?
- aftermarket rods
- Smoking Issues..... Catch Can Needed???
- 6262sp ramhorn dc2 AC/PS??
- Rod Bearing Failure> clearance #(numbers)
- Nippon turbo pistons?
- First Turbo Build W/ Pics Insight/Advice Welcome
- What oil to use for turbo app?
- What size turbo for my newly built GSR MOTOR.
- Ebay Intercoolers??
- 20psi with 7:1 compression Question
- boosting my b18c1... need some advice
- Greddy Timer SHUTS OFF AND TURNS BACK ON when turning..
- has anyone ever heard of spa turbos??
- runs terrible only on 5 psi
- spark plugs burnt out, now metallic noise?
- no boost. help!!!
- Boosting b16....
- Problem with my map sensor on my JRSC
- Honda Element Turbos
- Who's running a single scroll topmount with pte6768?
- flat faced valves VS.FI
- SIZE MATTERS!
- turbo with nos????
- retainers: aftermarket suggestions
- 2 maps on E85
- Forged Performance Manifold?
- new to turbo
- turbo
- Gapless top rings?
- need help getting oem head gasket
- FI newbie questions
- flat faced valves exhaust only??
- E85 35R Stroker build
- Panda 2.0 w/ video
- family race car revisited. My 1990 Accord photo essay
- 96 hx single cam v turbo :]
- whats the best injectors to use when boosting d16y8
- DFR's EK hatch build thread.
- Garrett Airesearch Turbonetics size comparison
- Turbo suggestions
- Lateral gas ported pistons?
- identify turbo?
- want some info
- Heavy Duty... Exhaust Manifold Studs?
- Will a t3/t67 fit a spoolin performance log mani with ac?
- NO BOOST CUTTING OUT AT 5K RPM PLEASE HELP
- precision Hp series turbos
- d16y8 turbo
- me and my bros turbo da integra build for under $1200
- f22b1 turbo ring gap??????
- GT3076R and Precision 5557B
- D16 Turbo Feedback!!
- Catch can/sensor question with pic
- injectors
- inline fuel pump or dual walbros?
- EJ2 coupe intercooler!
- Garrett GTX Turbo Tech Explained
- What size waste gate for my application?
- Intercooler Alternatives
- about my JDM ZC Turbo
- turbo leaks oil
- French seeks turbo kit
- fuel pressure regulator vac for bov???
- Godspeed turbo kit?!
- turbo header 3 to 4
- Killed a 30r ..Why ?
- Oil restrictor ? with smoking on idle
- turbo question...
- d16 build for boost
- Looking for a decent t25 flanged D16 turbo manifold that retains a/c and p/s
- Turbo Gsr 526hp on pump gas
- can anyone tell me the vitara 75.5 npr piston ring part number?
- New to Boosting
