View Full Version : Forced Induction
- NRG and BDL FPR's
- has anyone boosted a honda civic hatch back
- Nitrours intercooler sprayer
- turbo question
- map sensor and turbo
- Bar & Plate vs Tube fin vs Delta Fin. what works best and why?
- jun cam gears - are they real ?
- need advice on a turbo( 400hp d16 )
- good cam for itr valvetrain??
- spool time on twin scroll bb gt37
- Who has Competive & Affordable Prices on Ramhorn Manifold???
- Blox type b vs GSR cams.....dyno graph inside....
- car sputters when I hit VTEC
- Vtec Studs And Non Vtec Studs???
- Whats the most power on pumpgas 91 right now.....
- sohc build thread :)
- Gauge Repair
- ls oil pan = b20 oil pan?
- Injection
- Turbo civic
- block gridle question help
- built 2.0 gsr need help
- Am i missing anything?
- Turbo gasoline
- sleeving a block?
- $45 Honda/Acura Dyno Day! Sponsored by Phearable.net
- valvetrain
- Cali smog legal boost options for B18C1............
- 440cc precision injectors dont fir d-series?
- skunk2 pro cams + supertech valve springs ???
- WORLD electronics BOOST CONTROLLER video
- question for crome users
- is cruising in boost bad?
- skunk2 pro series stage 1 cams for turbo?
- I should have asked before buying but... is a T3 Super 60 .63 too laggy for a B16A2?
- what kind of power numbers can i expect
- B20 turbo??
- need some advise on my setup
- Turbo piston question: Anyone use probe industries pistons?
- any one know about turbo f23??
- Idle control sensor
- GSR Turbo Setup questions
- eagle crank for 145$ ?
- Turbo Kit non ebay
- We need a tutorial on how to SHIP AND PACKAGE THINGS! 2nd head in a row, damaged.
- Pros And Cons OF DSM 450cc Injectors
- Blox cams vs skunk2 pro cams (for turbo H22)
- How loud are you??
- stock crank vs eagle race crank??
- TUNE
- supercharge gsr
- Identify nos kit please .... help
- Why top mount?
- ok turbo on obd0
- calling all owners of the five blade SPAL fan, how loud is it?
- Help me identify this setup *pics*
- Laminova cores in a intake manifold for a TURBO SETUP
- LAMINOVA CORE question
- tune every psi???
- my turbo build.Advice on piston & rod setup
- Nippon racing vitara vs YCP vitara
- Looking for a special Intercooler...
- Full Race Vertical Flow Intercooler
- Bearing clearance issues please help
- Can someone tell me what the circled part is and where to hook it up for a JRSC sohc THANX!!!
- What head gasket to use?
- Jackson racing FMU
- how much more boost?
- Compression Question
- 550cc injectorys too big for sohc greddy kit
- Turbo Type R
- 2.5" exhaust with forged pistons rods 60 trim turbo. 300+ whp
- drag turbo kit?
- breaking in the motor
- Turbo Kit
- LS intake manifold fine for turbo application?
- Turbo wastegate Actuator adjustable
- Crome Help
- how much power needed to beat a sti?
- jrsc swap to rsx
- greddy vs Edelbrock turbo
- ****Searched**** t3/t67 spool characteristics...
- broken turbo gt35r
- just another slow honda
- Piston Rings?
- Did Innovative Turbo Systems go out of business???
- Can any one tell me about this Turbo?
- Boost control option on JDM ECU
- ecu tuning
- is this a good ebay manifold?
- gsr turbo cometic head gasket
- Littel show from ISRAEL!!!
- will the stock crank hold?
- Go Boost Or Go Home!
- White Smoke
- Turbo manifold design?
- hasitation for a few seconds when crancking a warm engine... crome
- This is a dumb question but, is it possible to drive an incomplete turbo setup?
- advantages/disadvantages on divided/split pulse turbine housing?
- valve adjustment?
- post up pics of you t3/t4 engine bay!
- complete set of turbo for sohc
- which is better hooking the wastegate vac. souce too?
- what head gasket should i use for a d series turbo??
- Will these pistons work for me
- dsm injectors question
- flutter sound from bov or compressor surge? =/
- you think i can close the hood?
- blox intake mani??
- choosing engine mangement!!!!!!
- piston to wall clearance? should i go bigger with 500-600hp.
- turbo info
- greddy sohc turbo kit
- blown headgasket or pistons? PLEASE HELP ASAP!
- mounting slim fan on radiator
- AEM EMS question...
- b16 turbo advice needed. choosing bb charger | compressor maps + cfm ratings????
- **Turbo Choices please help*****
- jackson racing supercharger
- edlebrock intake swap
- Y8 bearings
- WTB: HONEST, reputable, non-idiot shop to finish a project for me, Tri-state NYC area
- T-25 and HF Manifold Question
- i have a 99 honda civic si with a b16a that i plan to turbo and run between 5 to 8 psi
- Do ppl plug off the pcv when boosting?
- d17 injectors?????
- Anyone got a TIAL GT35R exhaust housing .82 in stock?
- what turbo is this?
- ls bored to 84mm
- Tranny For Boost????
- OBX Top mount manifold??
- Turbo Surge
- gsr Block/Ls Crank/B16 Head
- does anybody heat wrap the intercooler piping?
- b16/gt2871r t3/t4 .48a/r question
- turbo question
- HOW TO INSTALL AN FITTINGS!!!!
- B16B TURBO TUNED AND DYNOED
- LOVE FAB MINI ME EQ B16/gt2871r build: oil return line question
- aem ems users chime in, car not starting once it gets hot.
- Replacement(upgraded) turbo manifold for greddy turbo kit with TDO5 18G
- H23vtec vs. H22
- dsm blue top vs black top?
- ** Twisted Ramhorn Users leave feed back****Another Chinese manifold thread
- Does this T3 look legit (Garrett)?
- Posted Your Boosted K-series!!!
- Small turbo
- Cutting edge Turbo setup!!!! -- Possible repost
- Need help building z6 head for boost
- chipped turbo fins...how bad is the damage?
- Let me hear your advicessss.... :)
- Post your Full Race Kit shots!
- Any ideas on how this couldve happened?
- ***What H series super charger set up are you running?***
- For you HIGH elavation people
- thinkin about running spray....
- oil lines and coolant??
- somthings really bothering me about this PSI thing..
- My Car is Featured in Dsport this month!
- Purchasing a used DRAG gen 3 kit
- cant get the air out of my coolant system...
- will my clutch be able to handle?
- blow off valve
- NEED HELP WITH TURBO FLANGE!!!!!
- deltagate?
- >Is This Detonation?? PICS!!
- My Turbo Setup - 14b, 11psi, on stock rebuilt f22
- Greddy type c waste ate or a tial wastegate whats better!!!
- Anyone used the Skunk2 Pro 2 or Pro 3 cams on turbo set-up?
- Post your Injectors/Duty cycle/Fuel pump specs
- What car for a 2jz?
- 99 accord converted to obd1- do i run 2 O2 sensors or just 1????....help please
- stupid question
- Power Capability of this turbo..
- Manifold question / Boost Creep etc...
- Turbo Info
- Rebuild my Turbo D!@ beware of my useless car knowledge!
- Identify this Turbo
- Is it possible to have an Internal WG that is compatible with A/C on a B16A2 EK?
- turbo noob need simple answers
- Turbo manifold
- can i turbo this motor
- Anyone have a similar set-up? Have some questions.
- Help!!!!! BDL throttle body problem need some help
- Integra type R 420whp
- intercooler pipe question
- Am after a nice manifold for T3/T4
- look at this kit
- s200 and crome
- can i run e85 stock gsr turbo???
- car dies when coming to a stop
- My 300+hp goal.
- oil past seals
- Pistons and Rods Low numbers!!!
- *****SUPERCHARGER HELP*****
- JRSC Engine Build Help/Advice needed
- Looking For New England Tuner
- Hondata s300 installed in obd2 ecu? Is this possible.
- How can i HOOK-UP better????
- B16 Turbo @ 8.7psi (0.6bar) Dyno Cams Test - S2S2 no IC x B16 no IC x B16 with IC
- which one better for turbo
- Thinking about a rebuild - Comments? Recommendations?
- Hondata injectors cutting out??
- boost on GE sleeved LS
- Getting basemap to work? (crome)
- Fuel management
- Compression Test Results, What could it Be? 2000 Prelude
- JRSC setup
- A/C compatible equal length: the best bang for the buck?
- Is it really that hard to install a turbo?
- just bought a turbo coupe...oxygen sensor question
- VAFC HELP (BOOST)
- turbo/muffer?
- first time boosting, need help
- NEED SOME STUFF FOR MY D16 VTEC TURBO
- SPA Topmount Cast Turbo Manifold. Let me know your experience please
- my ek build.. t4/t67 benson sleeved gsr
- Anyone know what rims these are???
- Question about boost and volume?
- boosting more
- dyno'd the car couple weeks ago
- overheating caused by detonation? or headlift?
- oil restrictor? where are you getting yours?
- H22 shifter box Plate and some pics of the car h22T
- just started my motor do i need a street tune or no
- projekt camo sol...lsv turbo shooting for 600
- If you bought a turbo and it looked like this????
- Boost loss what should i look for...
- IHI RHB5 on a B18A?? (Yes i search foo's)
- never thought it would happen!!!!
- question!!! greddy 18G
- Hit the 1/8 for the first time. Need advise!
- K20A2 / DC5 ECU
- How high do you boost with meth injection
- issues with boosted B18c1
- Electric Gremlins?
- GT2871R dyno sheets
- need help on finding 84mm turbo pistons
- Hawaii SFWD dyno
- what do i need for a d15 build
- Turbo Kit?
- weird turbo sound
- dynod my car, just sharing the numbers.
- best e cutout?
- tiny pin hole in oil pan
- did a search... still confused, pcv setup for boost???
- !!!post up turbo single slams with a/c!!!!
- need the flash and burn install instustions again
- ***HELP*** JACKSON RACING SUPER CHARGER ANSWERS NEEDED***
